楼主 # 昨天 15:57:32
jxcxb
Luban-Lite,完整copy别人的整个sdk过来,为什么在我的电脑上编译不了,me菜单中的设置也保存不上去
$ m
scons: Reading SConscript files ...
Load config from target\configs\d12x_TaiLin_baremetal_bootloader_defconfig
Loaded configuration 'E:\luban-lite\target\configs\d12x_TaiLin_baremetal_bootloader_defconfig'
Configuration saved to '.config'
scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly
File "E:\luban-lite\SConstruct", line 20, in <module>
cc1.exe: warning: is shorter than expected
TypeError: int() can't convert non-string with explicit base:
File "E:\luban-lite\SConstruct", line 146:
fsinstall)
File "E:\luban-lite\tools/scripts/aic_build.py", line 1943:
prj_app, prj_defconfig, fsinstall)
File "E:\luban-lite\tools/scripts/aic_build.py", line 1545:
'.config', aic_pack_dir + '.image_cfg.json.tmp')
File "E:\luban-lite\tools/scripts/calc_linked_addr.py", line 24:
load_base = hex(int(text_base, 16) - 0x100)
Load config from target\configs\d12x_TaiLin_rt-thread_4.3_defconfig
Loaded configuration 'E:\luban-lite\target\configs\d12x_TaiLin_rt-thread_4.3_defconfig'
