基于STL的内存池类 和 测试程序 在linux下已做过稳定性测试
一共三个文件:
MemPool.h
#ifndef MEMPOOL.H
#define MEMPOOL.H
#include <pthread.h>
#include <stdio.h>
#include <list>
#include <iostream>
using namespace std;
// when you have used the mem, call InsertFreeItem
#define DEFAULT_MEM_COUNT 32
template <class TYPE>
class CMemPool
public:
CMemPool(void);
~CMemPool(void);
int Init(int memCount=DEFAULT_MEM_COUNT);
void Fini();
int GetFreeMemCount(){return m_nFreeMemItemCount;};
TYPE* GetFreeMem();
void InsertFreeMem(TYPE* pItem);
int GetUseMemCount(){return m_nUseMemItemCount;};
TYPE* GetUsedMem();
void InsertUsedMem(TYPE* pItem);
private:
int m_bInit;
int m_nMemSize;
int m_nMemItemCount;
int m_nFreeMemItemCount;
int m_nUseMemItemCount;
pthread_mutex_t m_freeListCs;
list<TYPE*> m_freeMemList;
pthread_mutex_t m_useListCs;
list<TYPE*> m_useMemList;
// implention
CMemPool<TYPE>::CMemPool(void)
m_bInit=0;
m_nMemItemCount=DEFAULT_MEM_COUNT;
m_nFreeMemItemCount=m_nMemItemCount;
m_nUseMemItemCount=0;
pthread_mutex_init(&m_freeListCs,0);
pthread_mutex_init(&m_useListCs,0);
CMemPool<TYPE>::~CMemPool(void)
pthread_mutex_destroy(&m_freeListCs);
pthread_mutex_destroy(&m_useListCs);
int CMemPool<TYPE>::Init(int memCount)
if (m_bInit)
if (memCount<=0)
return -1;
for (int i = 0; i<memCount; i++)
TYPE* pMemItem=new TYPE;
if (0!=pMemItem)
pthread_mutex_lock(&m_freeListCs);
m_freeMemList.push_back(pMemItem);
pthread_mutex_unlock(&m_freeListCs);
return -1;
m_nMemItemCount=memCount;
m_nFreeMemItemCount=memCount;
m_bInit=1;
void CMemPool<TYPE>::Fini()
if (!m_bInit)
return;
for (class list<TYPE *>::iterator itor = m_freeMemList.begin(); itor!=m_freeMemList.end(); itor++)
TYPE* pItem=*itor;
delete pItem;
itor = m_freeMemList.erase(itor);
pthread_mutex_lock(&m_useListCs);
for (typename list<TYPE*>::iterator itor = m_useMemList.begin(); itor!=m_useMemList.end(); itor++)
TYPE* pItem=*itor;
delete pItem;
itor = m_useMemList.erase(itor);
pthread_mutex_unlock(&m_useListCs);
m_bInit=0;
TYPE* CMemPool<TYPE>::GetFreeMem()
int nListSize=m_freeMemList.size();
if (nListSize>0)
TYPE* pItem=m_freeMemList.front();
m_freeMemList.pop_front();
m_nFreeMemItemCount--;
return pItem;
return NULL;
void CMemPool<TYPE>::InsertFreeMem(TYPE* pItem)
if (NULL==pItem)
return;
m_freeMemList.push_back(pItem);
m_nFreeMemItemCount++;
TYPE* CMemPool<TYPE>::GetUsedMem()
int nListSize=m_useMemList.size();
if (nListSize>0)
TYPE* pItem=m_useMemList.front();
m_useMemList.pop_front();
m_nUseMemItemCount--;
return pItem;
return NULL;
void CMemPool<TYPE>::InsertUsedMem(TYPE* pItem)
if (NULL==pItem)
return;
m_useMemList.push_back(pItem);
m_nUseMemItemCount++;
#endif /* MEMPOOL.H */MemPoolTest.cpp
#include "MemPool.h"
typedef struct FRAME_ITEM
int nBufLen;
char* pBuf;
FRAME_ITEM()
pBuf=new char[32*1024];
nBufLen=32*1024;
~FRAME_ITEM()
if (0!=pBuf)
delete pBuf;
}FRAME_ITEM;
int main()
CMemPool<FRAME_ITEM> pool;
int nRet=pool.Init();
if (nRet!=0)
printf("init failed \n");
int n=100;
while (n)
FRAME_ITEM* pItem=pool.GetFreeMem();
printf("free item num %d \n",pool.GetFreeMemCount());
pool.InsertUsedMem(pItem);
printf("used item num %d \n",pool.GetUseMemCount());
pItem=pool.GetUsedMem();
pool.InsertFreeMem(pItem);
usleep(10*1000);
n--;
pool.Fini();
getchar();
}Makefile
#INCLUDE := ./*.h
CFLAGS =
SRC = *.cpp
LIB = -lpthread
BIN = test
all:
g++ -o ${BIN} ${CFLAGS} ${SRC} ${LIB} -g
clean:
rm ${BIN}
install:
cp ${BIN} /bin/
uninstall:
rm -rf /bin/${BIN}
.PHONY:
all clean install uninstall离线
