void Enable_WDT_Reset_Config(void)
set_IAPEN; // Enable IAP function
IAPAL = 0x04;
IAPAH = 0x00;
IAPFD = 0x0F;
IAPCN = BYTE_PROGRAM_CF;
set_CFUEN; // Enable CONFIG writer bit
set_IAPGO; //trigger IAP
while((CHPCON&SET_BIT6)==SET_BIT6); //check IAPFF (CHPCON.6)
clr_CFUEN;
clr_IAPEN;
CONFIG.4 熔丝位设置成 0x0F 倒是没什么问题
但是我设置成 0xFF, 就不行了。
发现无论 CONFIG.4 是 0xXF 什么, 都可以编程为 0x0F
如果原来是 0x0F, 就不能编程为 0xFF
看来有可能是需要先擦除, 才能写。
//擦除 CONFIG0/1/2/4
void Erase_All_Config(void)
set_IAPEN;// Enable IAP function
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
IAPCN = ERASE_ALL_CF;
clr_CFUEN;
clr_IAPEN;
}//编程 CONFIG4
IAPAL = 0x04;
IAPAH = 0x00;
IAPFD = 0x5F;
clr_CFUEN;
clr_IAPEN;
main 函数调用:
void main (void)
Erase_All_Config();
Enable_WDT_Reset_Config();
while(1);
这样先擦除, 再编程, 就OK, 想写多少就写多少, 编程前, 先把这四个熔丝位保存起来, 擦除后写回去。
UINT8 Read_Config(UINT8 cfg)
UINT8 value = 0;
IAPAL = cfg;
IAPAH = 0x00;
IAPCN = BYTE_READ_CF;
value = IAPFD;
clr_CFUEN;
clr_IAPEN;
return value;
void main (void)
UINT8 cfg0, cfg1, cfg2, cfg4;
cfg0 = Read_Config(0);
cfg1 = Read_Config(1);
cfg2 = Read_Config(2);
cfg4 = Read_Config(4);
这样可以把各熔丝位读出来了。
全部代码:
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */
// Nuvoton Technoledge Corp.
// Website: http://www.nuvoton.com
// E-Mail : MicroC-8bit@nuvoton.com
// Date : Apr/21/2017
// File Function: N76E003 CONFIG program demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
Since the DATAFLASH is in the APROM. Program command is same as program APROM
#define PAGE_ERASE_CF 0xE2
#define BYTE_READ_CF 0xC0
#define BYTE_PROGRAM_CF 0xE1
#define ERASE_ALL_CF 0xE2
#define ERASE_FAIL 0x70
#define PROGRAM_FAIL 0x71
#define IAPFF_FAIL 0x72
#define IAP_PASS 0x00
Following IAP command register is also define in SFR_Macro.h
#define set_IAPEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON |= SET_BIT0 ;EA=BIT_TMP
#define clr_IAPEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;CHPCON &= ~SET_BIT0;EA=BIT_TMP
#define set_CFUEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN|=SET_BIT2;EA=BIT_TMP
#define clr_CFUEN BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;IAPUEN&=~SET_BIT2;EA=BIT_TMP
void IAP_ERROR_LED(void)
while (1)
clr_P03;
Timer0_Delay1ms(100);
set_P03;
void Trigger_IAP(void)
if((CHPCON&SET_BIT6)==SET_BIT6) // if fail flag is set, toggle error LED and IAP stop
clr_IAPFF;
IAP_ERROR_LED();
WARNING:
No matter read or writer, when IAPFF is set 1,
this step process is fail. DATA should be ignore.
Write CONFIG subroutine:
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
clr_CFUEN;
clr_IAPEN;
UINT8 value = 0;
IAPAL = cfg;
IAPAH = 0x00;
value = IAPFD;
clr_CFUEN;
clr_IAPEN;
return value;
IAPAL = 0x04;
IAPAH = 0x00;
IAPFD = 0x5F;
clr_CFUEN;
clr_IAPEN;
void main (void)
Set_All_GPIO_Quasi_Mode;
//---------toggle GPIO1---------
clr_GPIO1;
set_GPIO1;
clr_GPIO1;
set_GPIO1;
//---------end toggle GPIO1---------
Erase_All_Config();
while(1);
#include "Common.h"
#include "Delay.h"
while (1)
clr_P03;
set_P03;
clr_IAPFF;
IAP_ERROR_LED();
WARNING:
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
clr_CFUEN;
clr_IAPEN;
UINT8 value = 0;
IAPAL = cfg;
IAPAH = 0x00;
value = IAPFD;
clr_CFUEN;
clr_IAPEN;
return value;
void Write_Config(UINT8 cfg, UINT8 value)
IAPAL = cfg;
IAPAH = 0x00;
IAPFD = value;
clr_CFUEN;
clr_IAPEN;
void main (void)
//读熔丝位
//擦除熔丝位
Erase_All_Config();
//编程熔丝位
Write_Config(0, cfg0);
Write_Config(1, cfg1);
Write_Config(2, cfg2);
Write_Config(4, 0x0F);
while(1);
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
clr_CFUEN;
clr_IAPEN;
}UINT8 Read_Config(UINT8 cfg)
UINT8 value = 0;
IAPAL = cfg;
IAPAH = 0x00;
value = IAPFD;
clr_CFUEN;
clr_IAPEN;
return value;
}void Write_Config(UINT8 cfg, UINT8 value)
IAPAL = cfg;
IAPAH = 0x00;
IAPFD = value;
clr_CFUEN;
clr_IAPEN;
}void main (void)
//读熔丝位
//擦除熔丝位
Erase_All_Config();
//编程熔丝位
while(1);
终于把狗屎一样的 SDK 改好看一点了
