移植用老版本littlevGL,移植成功后显示汉子成功;通过在线取模(https://littlevgl.com/ttf-font-to-c-array-old)。之前版本字体样式
lv_font_t chinese1_m1_font =
.unicode_first = 19968, /*First Unicode letter in this font*/
.unicode_last = 40959, /*Last Unicode letter in this font*/
.h_px = 25, /*Font height in pixels*/
.glyph_bitmap = chinese1_m1_font_glyph_bitmap, /*Bitmap of glyphs*/
.glyph_dsc = chinese1_m1_font_glyph_dsc, /*Description of glyphs*/
//.glyph_cnt = 18, /*Number of glyphs in the font*/
.unicode_list = chinese1_m1_font_unicode_list, /*List of unicode characters*/
.get_bitmap = lv_font_get_bitmap_sparse, /*Function pointer to get glyph's bitmap*/
.get_width = lv_font_get_width_sparse, /*Function pointer to get glyph's width*/
#if USE_CHINESE1_M1_FONT == 1
.bpp = 1, /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 2
.bpp = 2, /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 4
.bpp = 4, /*Bit per pixel*/
#elif USE_CHINESE1_M1_FONT == 8
.bpp = 8, /*Bit per pixel*/
//.monospace = 0, /*Fix width (0: if not used)*/
.next_page = NULL, /*Pointer to a font extension*/
移植最先版本littlevGL 6.0.0后,发现字体结构改变了,请教需要怎么修改?
typedef struct _lv_font_struct
/** Get a glyph's descriptor from a font*/
bool (*get_glyph_dsc)(const struct _lv_font_struct *, lv_font_glyph_dsc_t *, uint32_t letter, uint32_t letter_next);
/** Get a glyph's bitmap from a font*/
const uint8_t * (*get_glyph_bitmap)(const struct _lv_font_struct *, uint32_t);
/*Pointer to the font in a font pack (must have the same line height)*/
uint8_t line_height; /**< The real line height where any text fits*/
uint8_t base_line; /**< Base line measured from the top of the line_height*/
void * dsc; /**< Store implementation specific data here*/
#if LV_USE_USER_DATA
lv_font_user_data_t user_data; /**< Custom user data for font. */
} lv_font_t;
在 https://littlevgl.com/ttf-font-to-c-array 上想生成字体移植失败。
@cdft 这个问题后来解决了吗?
@hengyongchao 没有解决
重新去光网生成字体即可使用
重新去光网生成字体即可使用
请问是哪个地址呢
zwmasdf 说:重新去光网生成字体即可使用
请问是哪个地址呢
就是2楼的地址
超级萌新 说:zwmasdf 说:重新去光网生成字体即可使用
请问是哪个地址呢
就是2楼的地址
可以么?
分享一个好用的 littlevgl 字体生成工具. https://whycan.cn/t_1350.html
学习下。。。
