楼主 #1 2019-09-05 17:46:35
无情一刀
已发帖子: 723
IO口作为按键中断写入了字符设备 Open的时候出现IO口申请错误
这个代码是通过晕哥那个中断驱动的帖子该了
#include <linux/major.h>
#include <linux/slab.h>
#include <asm/fb.h>
#include <linux/uaccess.h>
#define DEVICE "myKey"
#define PB3_GPIO 35 //PB3 35=32*1+3
#define GPIO_INT_NAME  "PB3_int"
#define GPIO_HIGH gpio_get_value(PB3_GPIO)
#define GPIO_LOW (gpio_get_value(PB3_GPIO) == 0)
short int irq_any_gpio    = 0;
int count =0;
struct class *key_dev_class = NULL;
struct class_device *key_dev_class_dev = NULL;
enum { falling, rising } type;
static irqreturn_t r_irq_handler(int irq, void *dev_id)
    count++;
    printk(KERN_DEBUG "interrupt received (irq: %d)\n", irq);
	if (irq == gpio_to_irq(PB3_GPIO))
        type = GPIO_LOW ? falling : rising;
        if(type == falling)
            printk("gpio pin is low\n");
            printk("gpio pin is high\n");
    return IRQ_HANDLED;
int led_open(struct inode *inode, struct file *filp)
   int ret;
	int err;
   if (gpio_request(PB3_GPIO, GPIO_INT_NAME ))
      printk("PB3_GPIO request failure: %s\n", GPIO_INT_NAME );
      return -1;
   if ( (irq_any_gpio = gpio_to_irq(PB3_GPIO)) < 0 ) {
      printk("PB3_GPIO to IRQ mapping failure %s\n",GPIO_INT_NAME );
      return -1;
   printk(KERN_NOTICE "Mapped int %d\n", irq_any_gpio);
   if (request_irq(irq_any_gpio,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , GPIO_INT_NAME, NULL))
      printk("Irq Request failure\n");
      return -1;
	printk("led_open == ok\n");
static int key_dev_read(struct file *filp, char __user *buff, size_t count, loff_t *offp)
	unsigned long err ;
	printk("Enter key_dev_read == %d\n",type);
	buff[0] = type;
	//err = copy_to_user(buff,&type,1,1);
	printk("copy_to_user == %d\n",buff[0]);
	//return err ? -EFAULT : 0;
int r_int_release(struct inode *inode, struct
 free_irq(gpio_to_irq(PB3_GPIO), NULL);
   gpio_free(PB3_GPIO);
struct file_operations led_fops ={
		.owner		= THIS_MODULE,
		.open		= led_open,
		.release	= r_int_release,
		.read		= key_dev_read
struct miscdevice led_dev ={
		.minor		= MISC_DYNAMIC_MINOR,//minor是这个混杂设备的次设备号,由系统自动配置,
		.name		= DEVICE,			//.name 设备名
		.fops		= &led_fops
void r_int_config(void)
   int ret;
   ret = misc_register(&led_dev);//注册驱动程序时采用misc_register函数注册,此函数中会自动创建设备节点,即设备文件
   if(ret)
			printk("error: cannot register misc.\n");
			return ret;
static void __exit Key_exit(void)
		misc_deregister(&led_dev);//杂项设备的注销过程,其实就是注册过程的逆向过程
		printk("mise-deregister %s\n", DEVICE);
int init_module(void)
        printk("<1>Hello World\n");
    r_int_config();
module_init(init_module);    // Do some better naming
module_exit(Key_exit);
MODULE_AUTHOR("ysc201995");             	// 驱动程序的作者
MODULE_DESCRIPTION("Key")
楼主 #2 2019-09-05 17:47:53
无情一刀
已发帖子: 723
Re: IO口作为按键中断写入了字符设备 Open的时候出现IO口申请错误
主要是在
   int ret;
    int err;
      return -1;
      return -1;
      return -1;
我在Qt上面去Open设备的时候一到这里就就就进去了  if (gpio_request(PB3_GPIO, GPIO_INT_NAME ))   就返回负一了
#3 2019-09-05 17:58:26
已发帖子: 9,389
和这个对比测试一下: https://whycan.cn/t_1261.html
楼主 #4 2019-09-05 18:17:14
无情一刀
已发帖子: 723
就是按着你那个去写的 只是加了一个字符设备 通过读取字符设备获取状态
#5 2019-09-05 18:25:47
已发帖子: 9,389
PB3 有没有被其他功能占用?
楼主 #6 2019-09-06 17:02:59
无情一刀
已发帖子: 723
PB3 有没有被其他功能占用?
没有被其他的占用  但是我按下去的时候有进到中断里面 ,就是在QT层去读取的时候有错误
[  224.167890] Mapped int 44
[  224.170614] genirq: Flags mismatch irq 44. 00000002 (PB3_int) vs. 00000002 (PB3_int)
[  224.178386] Irq Request failure
open event0 error
[  226.711062] interrupt received (irq: 44)
[  226.715010] gpio pin is low
[  227.053878] interrupt received (irq: 44)
[  227.057826] gpio pin is low
楼主 #7 2019-09-06 17:41:20
无情一刀
已发帖子: 723
#8 2019-09-06 18:12:15
已发帖子: 9,389
你这是一个 GPIO 的 按键驱动?
楼主 #9 2019-09-06 18:16:48
无情一刀
已发帖子: 723
你这是一个 GPIO 的 按键驱动?
是的 就是GPIO按键驱动  然后我在QT层去读取字符 可以获取到按键是按下还是弹起  现在在/dev下面有一个字符设备 了
#10 2019-09-06 18:23:35
已发帖子: 9,389
GPIO KEY 按键驱动(轮询): https://whycan.cn/t_2393.html#p18258
GPIO KEY 按键驱动(中断): https://whycan.cn/t_2393.html#p18270
根本不需要自己动手, Linux自带光环
楼主 #11 2019-09-06 18:29:23
无情一刀
已发帖子: 723
是啊  就想把这个按键驱动通过代码形式,可以运行起来,晕哥你能帮我看看那个代码吗
