有大佬A64上用过LVDS屏吗
当前内核版本 4.19.67
内核和设备树要做怎样的配置呢?
目前现象一直是红绿蓝颜色轮换,(一直处在上电检测状态?)
还望有经验的大佬支支招 拜托了!
你的设备树和驱动是怎么配置的?
具体怎么配我还有点不清楚
这是从全志生成的dtb 反编译成dts里导出来的节点信息
我目前按这个来的
lcd0@01c0c000 {
compatible = "allwinner,sunxi-lcd0";
pinctrl-names = "active", "sleep";
device_type = "lcd0";
lcd_used = <0x1>;
lcd_driver_name = "default_lcd";
lcd_backlight = <0x32>;
lcd_if = <0x3>;
lcd_x = <0x500>;
lcd_y = <0x320>;
lcd_width = <0x96>;
lcd_height = <0x5e>;
lcd_dclk_freq = <0x46>;
lcd_pwm_used = <0x1>;
lcd_pwm_ch = <0x0>;
lcd_pwm_freq = <0xc350>;
lcd_pwm_pol = <0x1>;
lcd_pwm_max_limit = <0xff>;
lcd_hbp = <0x14>;
lcd_ht = <0x58a>;
lcd_hspw = <0xa>;
lcd_vbp = <0xa>;
lcd_vt = <0x32e>;
lcd_vspw = <0x5>;
lcd_lvds_if = <0x0>;
lcd_lvds_colordepth = <0x1>;
lcd_lvds_mode = <0x0>;
lcd_frm = <0x1>;
lcd_hv_clk_phase = <0x0>;
lcd_hv_sync_polarity = <0x0>;
lcd_gamma_en = <0x0>;
lcd_bright_curve_en = <0x0>;
lcd_cmap_en = <0x0>;
lcd_bl_en = <0x31 0x3 0x17 0x1 0x0 0xffffffff 0x1>;
lcd_bl_en_power = "none";
lcd_power = "vcc-lcd-0";
lcd_fix_power = "vcc-dsi-33";
pinctrl-0 = <0xbe>;
lcd_pin_power = "vcc-pd";
pinctrl-1 = <0xbf>;
驱动 我只看到内核里 有个Generic LVDS panel driver
还有哪些是相关的?
4.19 是主线 Linux 吧, 不是全志官方的 bsp ?
对的
移植的主线的
示波器量一下lvds口,不过也没什么用,你都不知道lvds外设时钟有没有开启。
你好,我看内核驱动有panel_lvds ,和panle_simple 加载这个再配好dts就可以吗
还有人吗T.T 我想用lvds的屏 我用内核4.19.67自带的panel-lvds 驱动 加上如下dts 可行吗 这种思路是对的吗?
&tcon0{
compatible ="panel-lvds"; // 使用4.x内核的simple panel框架
power-supply = <®_dc1sw>;
//power-supply = <&vcc_lcd>; // 因为屏幕不使用gpio供电,所以注释掉
//backlight = <&backlight>; // 因为屏幕不使用背光调节,所以注释掉
//bus-format = <MEDIA_BUS_FMT_RBG888_1X24>; // RGB888
enable-delay-ms = <10>;
allwinner,data-mapping = "vesa-24"; // lvds数据格式
allwinner,data-width = <24>; // 24位
allwinner,output = "lvds"; // lvds接口输出
allwinner,width-mm=<110>;
allwinner,height-mm=<56>;
pinctrl-names = "default";
pinctrl-0 = <&lvds_pins>;
panel-timing {
clock-frequency = <70000000>; // 参考第1点
width-mm=<110>;
height-mm=<56>;
hactive = <1280>; // 这里填分辨率即可
vactive = <800>;
hback-porch = <10>; // 参考第1点
hfront-porch = <8>; // 参考第1点
vback-porch = <3>; // 参考第1点
vfront-porch = <3>; // 参考第1点
hsync-len = <32>; // 参考第1点
vsync-len = <6>; // 参考第1点
hsync-active = <0>; // 参考第2点
vsync-active = <0>; // 参考第2点
de-active = <1>; // 参考第2点
pixelclk-active = <0>; // 参考第2点
