楼主 #1 2019-12-11 04:45:08
Iron
已发帖子: 65
lichee-pi zero v3s 安装 alpine linux 运行日志
U-Boot SPL 2019.10-ge71ae959-dirty (Dec 10 2019 - 19:15:16 +0000)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2019.10-ge71ae959-dirty (Dec 10 2019 - 19:15:16 +0000) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   mmc@01c0f000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No working controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
207 bytes read in 3 ms (67.4 KiB/s)
1:	Linux vanilla
Retrieving file: /boot/initramfs-vanilla
6588262 bytes read in 300 ms (20.9 MiB/s)
Retrieving file: /boot/zImage
3608368 bytes read in 177 ms (19.4 MiB/s)
append: modules=loop,squashfs,sd-mod,usb-storage quiet
Retrieving file: /boot/dtbs/sun8i-v3s-licheepi-zero.dtb
8455 bytes read in 16 ms (515.6 KiB/s)
   Loading Ramdisk to 427b7000, end 42dff766 ... OK
   Loading Device Tree to 427b1000, end 427b6106 ... OK
[    0.001675] /cpus/cpu@0 missing clock-frequency property
   OpenRC 0.41.2.6fc2696f3e is starting up Linux 4.10.0-rc1-gdd75eb5de (armv7l)
 * /proc is already mounted
 * Mounting /run ... * /run/openrc: creating directory
 * /run/lock: creating directory
 * /run/lock: correcting owner
 * Caching service dependencies ... [ ok ]
 * Clock skew detected with `(null)'
 * Adjusting mtime of `/run/openrc/deptree' to Mon Jun 10 08:36:51 2019
 * WARNING: clock skew detected!
 * Remounting devtmpfs on /dev ... [ ok ]
 * Mounting modloop  ... * Verifying modloop
mount: can't setup loop device: No such device or address
 * ERROR: modloop failed to start
 * Mounting debug filesystem ... [ ok ]
 * Starting busybox mdev ... [ ok ]
 * Loading hardware drivers ... [ ok ]
 * Loading modules ...modprobe: can't change directory to '/lib/modules': No such file or directory
 [ ok ]
 * Setting system clock using the hardware clock [UTC] ... [ ok ]
 * Checking local filesystems  ... [ ok ]
 * Remounting filesystems ... [ ok ]
 * Mounting local filesystems ... [ ok ]
 * Configuring kernel parameters ...sysctl: error: 'net.ipv4.tcp_syncookies' is an unknown key
sysctl: error: 'net.ipv6.conf.all.accept_redirects' is an unknown key
sysctl: error: 'net.ipv6.conf.all.accept_source_route' is an unknown key
sysctl: error: 'net.ipv6.conf.default.use_tempaddr' is an unknown key
sysctl: error: 'net.ipv6.conf.all.use_tempaddr' is an unknown key
 [ ok ]
 * Migrating /var/lock to /run/lock ... [ ok ]
 * Creating user login records ... [ ok ]
 * Wiping /tmp directory ... [ ok ]
 * Setting hostname ... [ ok ]
 * Starting busybox syslog ... [ ok ]
Welcome to Alpine Linux 3.10
Kernel 4.10.0-rc1-gdd75eb5de on an armv7l (/dev/ttyS0)
alpine login:
楼主 #2 2019-12-11 04:51:25
Iron
已发帖子: 65
Re: lichee-pi zero v3s 安装 alpine linux 运行日志
lol 终于跑起来,主要问题更新 sd 卡 u-boot-sunxi-with-spl.bin 和 zimage
  • sudo dd if=<board>/u-boot-sunxi-with-spl.bin of=/dev/<sdX> bs=1024 seek=8
  • zimage 开启 initramfs 支持,并修改 size 为 32768,数量为 1
  • /extlinux/extlinux.conf
  • KERNEL /boot/vmlinuz-vanilla
    >> KERNEL /boot/zimage
  • /boot/grub/grub.cfg
  • linux /boot/vmlinuz-vanilla modules=loop,squashfs,sd-mod,usb-storage quiet
    >> linux /boot/zimage modules=loop,squashfs,sd-mod,usb-storage quiet
login: root
setup-alpine 执行 Alpine linux 安装
TODO...
最近编辑记录 Iron (2019-12-11 04:54:07)
#3 2019-12-11 07:19:23
alpine linux 怎么玩的,有没有教程?
楼主 #4 2019-12-19 17:13:08
Iron
已发帖子: 65
https://wiki.alpinelinux.org/wiki/Main_Page
只能看官方文档咯0..0,我也不熟,学习摸索中。
#5 2024-10-19 16:29:23
蜗牛奋斗666
楼主方便沟通一下吗? 关于alpine linux。
