小弟我司想把官方的AP6210换成ESP8089,而原来用的又是Linux + QT的模式,所以小弟我根据A33的官方资料,把sysconfig.fex中的配置根据esp8089修改了,但是烧成固件后却不起作用,出现过2个错误:
1.
[ 343.623704] Unable to handle kernel paging request at virtual address 5c8219cc
[ 343.630819] pgd = c0004000
[ 343.630819] [5c8219cc] *pgd=00000000
[ 343.630819] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 343.630819] Modules linked in: esp8089(+) rtl8152 vfe_v4l2 ov5640 vfe_subdev vfe_os cci actuator videobuf_dma_contig videobuf_core sw_device lcd disp
[ 343.630819] CPU: 2 Not tainted (3.4.39 #148)
[ 343.630819] PC is at kmem_cache_alloc +0x40/0x168
[ 343.630819] LR is at kmem_cache_alloc+0x3c/0x1682.第二个因为当时没有截取linux报错信息,仅仅记得启动wifi后,驱动加载走的是bcmdhd的流程,报错是:bcmdhd_wifi_init: sdio_register_driver timeout or error ,但是我用的是esp8089.。。
请问论坛的各位大佬对这些错误有思路吗?怎么解决?
或者告诉我怎么使用这个驱动?给我点思路?
可以,因为我只改变了wifi部分的sys_config.fex,就先把这部分贴出来:
;wifi configuration
;wifi_sdc_id: 0- SDC0, 1- SDC1, 2- SDC2, 3- SDC3
;wifi_usbc_id: 0- USB0, 1- USB1, 2- USB2
;wifi_usbc_type: 1- EHCI(speed 2.0), 2- OHCI(speed 1.0)
;wifi_mod_sel: 0- none, 1- ap6181, 2- ap6210(wifi+bt),
; 3 - rtl8188eu, 4- rtl8723au(wifi+bt),
; 5 - rtl8723bs, 6- esp8089
[wifi_para]
wifi_used = 1
wifi_sdc_id = 1
wifi_usbc_id = 1
wifi_usbc_type = 1
//6210
;wifi_mod_sel = 2
;wifi_power = ""
;wifi_power_ext1 = ""
;wifi_power_ext2 = ""
//8089
wifi_mod_sel = 6
wifi_power = "axp22_dldo1"
wifi_power_switch =
; 1 - ap6181 sdio wifi gpio config
;ap6xxx_wl_regon = port:PL06<1><default><default><0>
;ap6xxx_wl_host_wake = port:PL07<4><default><default><0>
;ap6xxx_lpo_use_apclk = 1
; 2 - ap6210 sdio wifi gpio config
;ap6xxx_bt_regon = port:PL08<1><default><default><0>
;ap6xxx_bt_wake = port:PL10<1><default><default><0>
;ap6xxx_bt_host_wake = port:PL09<4><default><default><0>
; 3 - rtl8188eu usb wifi gpio conifg
; 4 - rtl8723au usb wifi + bt
; 5 - rtl8723bs sdio wifi + bt
;rtl8723bs_chip_en = port:PL11<1><default><default><0>
;rtl8723bs_wl_regon = port:PL06<1><default><default><0>
;rtl8723bs_wl_host_wake = port:PL07<4><default><default><0>
;rtl8723bs_bt_regon = port:PL08<1><default><default><0>
;rtl8723bs_bt_wake = port:PL10<1><default><default><0>
;rtl8723bs_bt_host_wake = port:PL09<4><default><default><0>
;rtl8723bs_lpo_use_apclk = 0
; 6 - eagle sdio wifi
;esp_wl_chip_en = port:PL03<1><default><default><0>
;esp_wl_rst = port:PL02<1><default><default><0>
//sinlinx A33 8089
esp_wl_chip_en = port:PL07<1><default><default><1>
esp_wl_rst = port:PL06<1><default><default><1>
; 7 - ap6476 sdio wifi gpio config
; 8 - rtl8189es sdio wifi gpio conifg
;rtl8189es_shdn = port:PL06<1><default><default><0>
;rtl8189es_host_wake = port:PL07<4><default><default><0>
usb_vbus_power_ctrl = port:PL11<1><default><default><1>
usb_eth_power_ctrl = port:PL04<1><default><default><1>标注6210是之前的,标注8089的是之后的,谢谢晕哥关注问题!!!敬候佳音!!
经过昨晚和今天早上查资料,我知道V3S的camdroid是可以在sunxi linux3.4的情况下使用esp8089的,那按道理,A33的应该也可以才对,但是A33下不知道怎么修改内核和BSP。。。。。同时发现camdroid里面sysconfig.fex没有8089的相关配置,直接用的6210去适配。。。。。这点很不解。。。请教各位大佬,求解惑啊!!!!!
我请教一下,A33上的esp8089驱动能直接用吗?不能的话,@晕哥,你这个彩虹派的驱动,我应该怎么移植?我对比之后看了一下,这个驱动确实跟A33的不一样
按照经销商的说法,原厂已经没有FAE了,都是交由方案商去弄。。。但是方案商收费挺贵。。。。。看来只能自己搞了。自己搞的话,晕哥能给我点意见或者思路吗?谢谢晕哥!!!!
我把彩虹派的驱动直接复制到A33上编译,编译成功了,但是板子启动log有问题,而且esp8089也启动失败,晕哥能看看这是什么问题吗?
U-Boot 2011.09-rc1-00004-ga1ab41d (Jul 28 2014 - 16:21:09) Allwinner Technology
[ 0.359]version: 1.1.0
[ 0.440]pmbus: ready
[ 0.443]PMU: AXP221
[ 0.445]PMU: AXP22x found
[ 0.448]PMU: dcdc3 1200
[ 0.451]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
set power on vol to default
dcdc1_vol = 3000
dcdc2_vol = 1100
dcdc3_vol = 1200
dcdc4_vol = 0
dcdc5_vol = 1500
aldo2_vol = 2500
aldo3_vol = 3000
find power_sply to end
no battery, limit to dc
fel key new mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[ 0.500]DRAM: 512 MiB
relocation Offset is: 15b11000
smcl's set manager is NULL
<axp22, dldo1>
workmode = 0
MMC: 2
[ 0.703][mmc]: mmc driver ver 2014-07-15 17:16:00
[ 0.708][mmc]: get sdc_2xmode ok, val = 1
[ 0.712][mmc]: get sdc_f_max fail,use default sdc_f_max 50000000
[ 0.718][mmc]: get card_line ok, card_line = 4
[ 0.723][mmc]: get sdc_ex_dly_used fail,use default dly
[ 0.728][mmc]: SUNXI SD/MMC: 2
[ 0.733][mmc]: mmc 2 2xmode config clk
[ 0.743][mmc]: ************Try SD card 2************
[ 0.748][mmc]: mmc 2 cmd 8 timeout, err 100
[ 0.753][mmc]: smc 2 err, cmd 8, RTO
[ 0.758][mmc]: mmc 2 mmc cmd 8 err 0x00000100
[ 0.762][mmc]: mmc send if cond failed
[ 0.766][mmc]: mmc 2 cmd 55 timeout, err 100
[ 0.770][mmc]: smc 2 err, cmd 55, RTO
[ 0.776][mmc]: mmc 2 mmc cmd 55 err 0x00000100
[ 0.780][mmc]: send app cmd failed
[ 0.783][mmc]: ************Try MMC card 2************
[ 0.824][mmc]: mmc 2 2xmode config clk
[ 0.834][mmc]: mmc 2 2xmode config clk
[ 0.844][mmc]: mmc 2 2xmode config clk
[ 0.853][mmc]: MID 000011 PSN d82fa5a0
[ 0.856][mmc]: PNM 004GA0 -- 0x30-30-34-47-41-30
[ 0.861][mmc]: PRV 0.2
[ 0.864][mmc]: MDT m-11 y-2018
[ 0.867][mmc]: MMC ver 5.0
[ 0.870][mmc]: ---------------mmc->clock 50000000-----------
[ 0.875][mmc]: ---------------mmc->bus_width 4--------------
[ 0.881][mmc]: SD/MMC Card: 4bit, capacity: 3776MB
[ 0.886][mmc]: boot0 capacity: 2000KB,boot1 capacity: 2000KB
[ 0.892][mmc]: ************SD/MMC 2 init OK!!!************
[ 0.898]sunxi flash init ok
In: serial
Out: serial
Err: serial
-total partitions:5-
-name- -start- -size-
boot-res : 1000000 1000000
env : 2000000 1000000
boot : 3000000 1000000
rootfs : 4000000 20000000
UDISK : 24000000 0
base bootcmd=run setargs_nand boot_normal
bootcmd set setargs_mmc
key 0
recovery key high 5, low 3
cant find fstbt value
no misc partition is found
misc_message->command = 0
to be run cmd=run setargs_mmc boot_normal
mount part name boot-res
cant open script.bin, maybe it is not exist
WORK_MODE_BOOT
board_status_probe
[ 0.977]pre sys mode
sunxi_bmp_logo_display
[ 1.259][mmc]: blkcnt should not be 0
screen_id =0, screen_width =800, screen_height =480
[ 1.311]Hit any key to stop autoboot: 0
read boot or recovery all
[ 1.903]sunxi flash read :offset 3000000, 14177888 bytes OK
no signature
[ 1.915]ready to boot
para err in disp_ioctl, cmd = 0xa,screen id = 1
[ 1.921][mmc]: mmc exit start
[ 1.926][mmc]: mmc 2 2xmode config clk
[ 1.935][mmc]: mmc 2 2xmode config clk
[ 1.947][mmc]: mmc 2 cmd 8 timeout, err 100
[ 1.952][mmc]: smc 2 err, cmd 8, RTO
[ 1.957][mmc]: mmc 2 mmc cmd 8 err 0x00000100
[ 1.961][mmc]: mmc send if cond failed
[ 1.965][mmc]: mmc 2 cmd 55 timeout, err 100
[ 1.969][mmc]: smc 2 err, cmd 55, RTO
[ 1.975][mmc]: mmc 2 mmc cmd 55 err 0x00000100
[ 1.979][mmc]: send app cmd failed
[ 2.006][mmc]: mmc 2 exit ok
[ 2.008]
[ 0.736737] aw_pm_init: not support super standby.
[ 0.909825] Bluetooth: get rtl8723bs rtl8723bs_bt_host_wake gpio failed
[ 0.909832]
[ 0.961885] otg_wakelock_init: No USB transceiver found
[ 0.967796] ths_fetch_sysconfig_para: type err device_used = 1.
[ 0.975533] fetch C0_LV_count from sysconfig failed
[ 1.012250] ------------[ cut here ]------------
[ 1.017374] kernel BUG at drivers/mmc/core/core.c:228!
[ 1.022183] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
[ 1.022183] Modules linked in:
[ 1.022183] CPU: 2 Not tainted (3.4.39 #152)
[ 1.022183] PC is at __mmc_start_req+0x228/0x2cc
[ 1.022183] LR is at __mmc_start_req+0x3c/0x2cc
[ 1.022183] pc : [<c0410558>] lr : [<c041036c>] psr: 20000013
[ 1.022183] sp : df8a5d48 ip : 00000080 fp : df8a5d74
[ 1.022183] r10: defad000 r9 : defb5c00 r8 : 00000000
[ 1.022183] r7 : df8a5dc8 r6 : df8a5dc8 r5 : dedc0c00 r4 : df8a5df8
[ 1.022183] r3 : df8a5dc8 r2 : 00000000 r1 : 00000200 r0 : 00000200
[ 1.022183] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 1.022183] Control: 10c5387d Table: 4000406a DAC: 00000015
[ 1.022183]
[ 1.022183] PC: 0xc04104d8:
[ 1.022183] 04d8 e5933000 ebfa2786 e5d531dc e2033002 e6ef3073 e3530000 1a000002 e59f00fc
[ 1.022183] 04f8 e3a010dc ebf09556 e5943004 e3a02000 e5832020 e5943004 e583402c e5943008
[ 1.022183] 0518 e1530002 0a00001d e5930008 e59511b4 e1500001 9a000000 e7f001f2 e593100c
[ 1.022183] 0538 e595c1b8 e151000c 9a000000 e7f001f2 e0010190 e595c1b0 e151000c 9a000000
[ 1.022183] 0558 e7f001f2 e5941004 e5813028 e5943008 e5832010 e5943008 e5834020 e594300c
[ 1.022183] 0578 e3530000 0a000005 e5941008 e581301c e594300c e5832020 e594300c e583402c
[ 1.022183] 0598 e59502a4 e3a010ff eb0053d0 e595316c e1a00005 e1a01004 e5933010 e12fff33
[ 1.022183] 05b8 e3a00000 e24bd01c e89da8f0 c0a604e1 c07b2799 c040fa98 c09f8e00 c09f8ea8
[ 1.022183]
[ 1.022183] LR: 0xc04102ec:
[ 1.022183] 02ec e58d3000 e3a02020 e1a03001 eb001669 e2505000 0a000006 e5943000 e1a02005
[ 1.022183] 030c e59f0018 e5931034 e3510000 05931010 eb08b970 e1a00005 e24bd014 e89da830
[ 1.022183] 032c c081a0f1 e1a0c00d e92dd8f0 e24cb004 e24dd010 e92d4000 e8bd4000 e3a03000
[ 1.022183] 034c e1a06001 e1a05000 e1a04001 e5a63010 e2810014 e59f225c e59f125c ebf111dc
[ 1.022183] 036c e59f3258 e5843024 e59531e4 e3530000 0a000009 e5933170 e3130080 0a000006
[ 1.022183] 038c e5943004 e3e0407a e1a00006 e5834020 ebf13888 e1a00004 ea000084 e5943000
[ 1.022183] 03ac e3530000 0a00000e e59f2214 e1d22bba e3120004 0a00000a e5931004 e5952034
[ 1.022183] 03cc e59f0200 e58d1000 e5931018 e3520000 05952010 e58d1004 e59f11ec e5933000
[ 1.022183]
[ 1.022183] SP: 0xdf8a5cc8:
[ 1.022183] 5cc8 00000001 df8a4000 df8a5cf4 df8a5ce0 c0062e68 c0062d80 c041055c 20000013
[ 1.022183] 5ce8 c0010694 00000000 df8a5d74 df8a5d00 c00103ec c000a00c 00000200 00000200
[ 1.022183] 5d08 00000000 df8a5dc8 df8a5df8 dedc0c00 df8a5dc8 df8a5dc8 00000000 defb5c00
[ 1.022183] 5d28 defad000 df8a5d74 00000080 df8a5d48 c041036c c0410558 20000013 ffffffff
[ 1.022183] 5d48 c00f8ddc c028d860 df8a5da4 c028b864 df8a5df8 dedc0c00 defb6e00 df8a5dc8
[ 1.022183] 5d68 df8a5d8c df8a5d78 c041061c c041033c ffffffff 00000200 df8a5e5c df8a5d90
[ 1.022183] 5d88 c0415364 c0410608 c04123f8 dedc0c00 00000008 00000000 00000000 00000000
[ 1.022183] 5da8 00000000 00000000 000000b5 00000000 00000000 00000000 00000000 df8a5df8
[ 1.022183]
[ 1.022183] FP: 0xdf8a5cf4:
[ 1.022183] 5cf4 df8a5d00 c00103ec c000a00c 00000200 00000200 00000000 df8a5dc8 df8a5df8
[ 1.022183] 5d14 dedc0c00 df8a5dc8 df8a5dc8 00000000 defb5c00 defad000 df8a5d74 00000080
[ 1.022183] 5d34 df8a5d48 c041036c c0410558 20000013 ffffffff c00f8ddc c028d860 df8a5da4
[ 1.022183] 5d54 c028b864 df8a5df8 dedc0c00 defb6e00 df8a5dc8 df8a5d8c df8a5d78 c041061c
[ 1.022183] 5d74 c041033c ffffffff 00000200 df8a5e5c df8a5d90 c0415364 c0410608 c04123f8
[ 1.022183] 5d94 dedc0c00 00000008 00000000 00000000 00000000 00000000 00000000 000000b5
[ 1.022183] 5db4 00000000 00000000 00000000 00000000 df8a5df8 02faf080 00000000 00000200
[ 1.022183] 5dd4 00000001 00000000 00000200 00000000 00000000 00000000 00000001 df8a5e20
[ 1.022183]
[ 1.022183] R3: 0xdf8a5d48:
[ 1.022183] 5dc8 02faf080 00000000 00000200 00000001 00000000 00000200 00000000 00000000
[ 1.022183] 5de8 00000000 00000001 df8a5e20 00000000 00000000 df8a5d98 df8a5dc8 00000000
[ 1.022183] 5e08 00000000 00000000 00000000 df8a5e14 df8a5e14 c040fa98 c1763472 00000e00
[ 1.022183] 5e28 00000200 00000000 c00f8f18 defb5c00 df8a5ecc 00000000 00000004 defad000
[ 1.022183]
[ 1.022183] R4: 0xdf8a5d78:
[ 1.022183] 5d78 ffffffff 00000200 df8a5e5c df8a5d90 c0415364 c0410608 c04123f8 dedc0c00
[ 1.022183] 5d98 00000008 00000000 00000000 00000000 00000000 00000000 000000b5 00000000
[ 1.022183] 5db8 00000000 00000000 00000000 df8a5df8 02faf080 00000000 00000200 00000001
[ 1.022183] 5dd8 00000000 00000200 00000000 00000000 00000000 00000001 df8a5e20 00000000
[ 1.022183] 5df8 00000000 df8a5d98 df8a5dc8 00000000 00000000 00000000 00000000 df8a5e14
[ 1.022183] 5e18 df8a5e14 c040fa98 c1763472 00000e00 00000200 00000000 c00f8f18 defb5c00
[ 1.022183] 5e38 df8a5ecc 00000000 00000004 defad000 c04123f8 00000000 df8a5e74 df8a5e60
[ 1.022183] 5e58 c0415b24 c041527c 00000200 00000000 df8a5e9c df8a5e78 c0413a70 c0415b00
[ 1.022183]
[ 1.022183] R5: 0xdedc0b80:
[ 1.022183] 0b80 00000004 00000002 00000000 00000000 00000000 00000000 dedc4f40 dedc4ec0
[ 1.022183] 0ba0 dedc4e40 dedc4d40 dedc4dc0 dedc4c40 dedc4cc0 dedc4bc0 00000000 00000000
[ 1.022183] 0bc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.022183] 0be0 00000000 00000000 00000000 00000000 00000000 00000000====codec_init_events===
[ 1.022183] 00000000 00000000
[ 1.022183] 0c00 c09d8f00 00000000 c09d8f00 dedb70c0 df8f4380 dedc0814 c09d8d94 dedb4380
[ 1.022183] 0c20 df8c7d40 c09984e8 dedbf648 00000003 00000007 00000000 00000000 00000001
[ 1.022183] 0c40 00000000 00000000 dedc0c48 dedc0c48 00000000 00000000 00000000 00000000
[ 1.022183] 0c60 00000000 00000000 00000000 00000000 dedc0870 c09d8df0 7fffffff 00000000
[ 1.022183]
[ 1.022183] R6: 0xdf8a5d48:
[ 1.022183]
[ 1.022183] R7: 0xdf8a5d48:
[ 1.022183]
[ 1.022183] R9: 0xdefb5b80:
[ 1.022183] 5b80 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] 5ba0 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] 5bc0 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] 5be0 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] 5c00 dedc0c00 00000000 dedc0c08 00000000 00000000 defb5c14 defb5c14 00000000
[ 1.022183] 5c20 df8c7d40 c09984e8 00000000 00000001 00000001 00000000 c09d828c 00000001
[ 1.022183] 5c40 00000000 00000000 defb5c48 defb5c48 00000000 c09d81ec 00000000 00000000
[ 1.022183] 5c60 ffffffff 00000000 00000000 00000000 defb5c70 defb5c70 7fffffff 00000000
[ 1.022183]
[ 1.022183] R10: 0xdefacf80:
[ 1.022183] cf80 def936f0 c09e3500 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.022183] cfa0 00000000 00000000 00000000 defa5680 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] cfc0 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] cfe0 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] d000 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] d020 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] d040 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] d060 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 1.022183] Process kworker/u:0 (pid: 5, stack limit = 0xdf8a42f8)
[ 1.022183] Stack: (0xdf8a5d48 to 0xdf8a6000)
[ 1.022183] 5d40: c00f8ddc c028d860 df8a5da4 c028b864 df8a5df8 dedc0c00
[ 1.022183] 5d60: defb6e00 df8a5dc8 df8a5d8c df8a5d78 c041061c c041033c ffffffff 00000200
[ 1.022183] 5d80: df8a5e5c df8a5d90 c0415364 c0410608 c04123f8 dedc0c00 00000008 00000000
[ 1.022183] 5da0: 00000000 00000000 00000000 00000000 000000b5 00000000 00000000 00000000
[ 1.022183] 5dc0: 00000000 df8a5df8 02faf080 00000000 00000200 00000001 00000000 00000200
[ 1.022183] 5de0: 00000000 00000000 00000000 00000001 df8a5e20 00000000 00000000 df8a5d98
[ 1.022183] 5e00: df8a5dc8 00000000 00000000 00000000 00000000 df8a5e14 df8a5e14 c040fa98
[ 1.022183] 5e20: c1763472 00000e00 00000200 00000000 c00f8f18 defb5c00 df8a5ecc 00000000
[ 1.022183] 5e40: 00000004 defad000 c04123f8 00000000 df8a5e74 df8a5e60 c0415b24 c041527c
[ 1.022183] 5e60: 00000200 00000000 df8a5e9c df8a5e78 c0413a70 c0415b00 00000000 defb5c00
[ 1.022183] 5e80: dedc0c00 00000000 00000004 c06c5098 df8a5efc df8a5ea0 c041409c c04139ec
[ 1.022183] 5ea0: 00000080 dedc0dc8 00000000 c06c4f5c 00000000 c0a15080 11010030 30344741
[ 1.022183] 5ec0: 3002d82f a5a0b519 c0ff8080 00000000 df8a5efc dedc0c00 00000000 c06c4f4c
[ 1.022183] 5ee0: 00000000 c06c4f5c c04123f8 c0a15080 df8a5f1c df8a5f00 c0415124 c0413c7c
[ 1.022183] 5f00: df8a5f44 00ff8080 dedc0e00 dedc0c00 df8a5f44 df8a5f20 c041266c c0415004
[ 1.022183] 5f20: 00000000 df82ad00 c0a15080 df9dd800 dedc0e00 00000000 df8a5f84 df8a5f48
[ 1.022183] 5f40: c004f344 c0412404 c0649a1c c0062e90 df9dd805 00000000 df8a5f74 df82ad00
[ 1.022183] 5f60: c0a15080 c09efc88 df8a4000 df82ad10 00000089 c0a15080 df8a5fb4 df8a5f88
[ 1.022183] 5f80: c004f8b0 c004f0bc 00000000 df899ec0 df82ad00 c004f708 00000013 00000000
[ 1.022183] 5fa0: 00000000 00000000 df8a5ff4 df8a5fb8 c0054630 c004f714 00000000 00000000
[ 1.022183] 5fc0: df82ad00 00000000 00000000 00000000 df8a5fd0 df8a5fd0 00000000 df899ec0
[ 1.022183] 5fe0: c0054594 c0011a04 00000000 df8a5ff8 c0011a04 c00545a0 aaaaaaaa aaaaaaaa
[ 1.022183] [<c0410558>] (__mmc_start_req+0x228/0x2cc) from [<c041061c>] (mmc_wait_for_req+0x20/0x30)
[ 1.022183] [<c041061c>] (mmc_wait_for_req+0x20/0x30) from [<c0415364>] (mmc_send_cxd_data+0xf4/0x120)
[ 1.022183] [<c0415364>] (mmc_send_cxd_data+0xf4/0x120) from [<c0415b24>] (mmc_send_ext_csd+0x30/0x38)
[ 1.022183] [<c0415b24>] (mmc_send_ext_csd+0x30/0x38) from [<c0413a70>] (mmc_get_ext_csd+0x90/0x110)
[ 1.022183] [<c0413a70>] (mmc_get_ext_csd+0x90/0x110) from [<c041409c>] (mmc_init_card+0x42c/0x12c8)
[ 1.022183] [<c041409c>] (mmc_init_card+0x42c/0x12c8) from [<c0415124>] (mmc_attach_mmc+0x12c/0x1c8)
[ 1.022183] [<c0415124>] (mmc_attach_mmc+0x12c/0x1c8) from [<c041266c>] (mmc_rescan+0x274/0x31c)
[ 1.022183] [<c041266c>] (mmc_rescan+0x274/0x31c) from [<c004f344>] (process_one_work+0x294/0x48c)
[ 1.022183] [<c004f344>] (process_one_work+0x294/0x48c) from [<c004f8b0>] (worker_thread+0x1a8/0x2a4)
[ 1.022183] [<c004f8b0>] (worker_thread+0x1a8/0x2a4) from [<c0054630>] (kthread+0x9c/0xa8)
[ 1.022183] [<c0054630>] (kthread+0x9c/0xa8) from [<c0011a04>] (kernel_thread_exit+0x0/0x8)
[ 1.022183] Code: e0010190 e595c1b0 e151000c 9a000000 (e7f001f2)
[ 2.281067] ---[ end trace e3e3a3fe01437fbe ]---
[ 2.286270] Unable to handle kernel paging request at virtual address fffffffc
[ 2.291003] pgd = c0004000
[ 2.291003] [fffffffc] *pgd=5fffe821, *pte=00000000, *ppte=00000000
[ 2.291003] Internal error: Oops: 17 [#2] PREEMPT SMP ARM
[ 2.291003] Modules linked in:
[ 2.291003] CPU: 2 Tainted: G D (3.4.39 #152)
[ 2.291003] PC is at kthread_data+0x18/0x20
[ 2.291003] LR is at wq_worker_sleeping+0x1c/0xc4
[ 2.291003] pc : [<c0054968>] lr : [<c00503a4>] psr: 20000093
[ 2.291003] sp : df8a5b58 ip : df8a5b68 fp : df8a5b64
[ 2.291003] r10: 00000002 r9 : df83faf8 r8 : df838ac0
[ 2.291003] r7 : df83fce4 r6 : df8a4000 r5 : 00000002 r4 : c17b2280
[ 2.291003] r3 : 00000000 r2 : c09f01a8 r1 : 00000002 r0 : df83fb00
[ 2.291003] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 2.291003] Control: 10c5387d Table: 4000406a DAC: 00000015
[ 2.291003]
[ 2.291003] PC: 0xc00548e8:
[ 2.291003] 48e8 e8bd4000 e1a05001 e3a01002 e1a04000 eb003aef e3500000 1a000003 e59f003c
[ 2.291003] 4908 e3a010e2 ebff8452 e89da830 e59f3030 e205101f e1a052a5 e2811001 e1a00004
[ 2.291003] 4928 e1a05105 e0831101 e0651001 eb00407f e594300c e3833301 e584300c e89da830
[ 2.291003] 4948 c07b4138 c064c098 e1a0c00d e92dd800 e24cb004 e92d4000 e8bd4000 e59031b8
[ 2.291003] 4968 e5130004 e89da800 e1a0c00d e92dd800 e24cb004 e92d4000 e8bd4000 e3a00000
[ 2.291003] 4988 e89da800 e1a0c00d e92dd8f0 e24cb004 e92d4000 e8bd4000 e1a0300d e3c36d7f
[ 2.291003] 49a8 e59f1118 e3c6603f e596400c e1a00004 eb02bd50 e1a00004 ebffc3f8 e59f1100
[ 2.291003] 49c8 e1a00004 eb0041a7 e596000c e59f30f4 e2800d0b e593400c eb17d3fb e596300c
[ 2.291003]
[ 2.291003] LR: 0xc0050324:
[ 2.291003] 0324 e1a03000 e59f100c e5910000 e1a01003 ebffffe4 e89da800 c097425c e1a0c00d
[ 2.291003] 0344 e92dd818 e24cb004 e92d4000 e8bd4000 e1a04001 eb00117c e5903024 e31300f8
[ 2.291003] 0364 189da818 e1a00004 ebfff139 e1903f9f e2833001 e1802f93 e3320000 1afffffa
[ 2.291003] 0384 e89da818 e1a0c00d e92dd878 e24cb004 e92d4000 e8bd4000 e1a05001 eb00116a
[ 2.291003] 03a4 e1a06000 e1a00005 ebfff118 e1a04000 e1a00005 ebfff126 e5963024 e21310f8
[ 2.291003] 03c4 13a00000 189da878 e1a0200d e3c23d7f e3c3303f e5933014 e1550003 0a000000
[ 2.291003] 03e4 e7f001f2 f57ff05f e1902f9f e2422001 e1803f92 e3330000 1afffffa f57ff05f
[ 2.291003] 0404 e3520000 11a00001 189da878 e5941008 e2843008 e1510003 0a000006 e5b43020
[ 2.291003]
[ 2.291003] SP: 0xdf8a5ad8:
[ 2.291003] 5ad8 c0974c10 df83fce4 df838ac0 c17b27c0 df8a5b2c df8a5af8 c0054968 20000093
[ 2.291003] 5af8 ffffffff df8a5b44 df8a5b64 df8a5b10 c00102d8 c000a1b4 df83fb00 00000002
[ 2.291003] 5b18 c09f01a8 00000000 c17b2280 00000002 df8a4000 df83fce4 df838ac0 df83faf8
[ 2.291003] 5b38 00000002 df8a5b64 df8a5b68 df8a5b58 c00503a4 c0054968 20000093 ffffffff
[ 2.291003] 5b58 df8a5b84 df8a5b68 c00503a4 c005495c 0420806c c17b2280 df83fb00 df8a4000
[ 2.291003] 5b78 df8a5bbc df8a5b88 c0648398 c0050394 c0957280 c0957280 df8a5bb4 df83fb00
[ 2.291003] 5b98 00000001 df8a5bdc df83fc68 df838ac0 df83faf8 df83fc68 df8a5bcc df8a5bc0
[ 2.291003] 5bb8 c06488f8 c06482a4 df8a5c14 df8a5bd0 c003a018 c0648878 df8a5c04 00000001
[ 2.291003]
[ 2.291003] IP: 0xdf8a5ae8:
[ 2.291003] 5ae8 df8a5b2c df8a5af8 c0054968 20000093 ffffffff df8a5b44 df8a5b64 df8a5b10
[ 2.291003] 5b08 c00102d8 c000a1b4 df83fb00 00000002 c09f01a8 00000000 c17b2280 00000002
[ 2.291003] 5b28 df8a4000 df83fce4 df838ac0 df83faf8 00000002 df8a5b64 df8a5b68 df8a5b58
[ 2.291003] 5b48 c00503a4 c0054968 20000093 ffffffff df8a5b84 df8a5b68 c00503a4 c005495c
[ 2.291003] 5b68 0420806c c17b2280 df83fb00 df8a4000 df8a5bbc df8a5b88 c0648398 c0050394
[ 2.291003] 5b88 c0957280 c0957280 df8a5bb4 df83fb00 00000001 df8a5bdc df83fc68 df838ac0
[ 2.291003] 5ba8 df83faf8 df83fc68 df8a5bcc df8a5bc0 c06488f8 c06482a4 df8a5c14 df8a5bd0
[ 2.291003] 5bc8 c003a018 c0648878 df8a5c04 00000001 c00359d8 df8a5bdc df8a5bdc df83fcb0
[ 2.291003]
[ 2.291003] FP: 0xdf8a5ae4:
[ 2.291003] 5ae4 c17b27c0 df8a5b2c df8a5af8 c0054968 20000093 ffffffff df8a5b44 df8a5b64
[ 2.291003] 5b04 df8a5b10 c00102d8 c000a1b4 df83fb00 00000002 c09f01a8 00000000 c17b2280
[ 2.291003] 5b24 00000002 df8a4000 df83fce4 df838ac0 df83faf8 00000002 df8a5b64 df8a5b68
[ 2.291003] 5b44 df8a5b58 c00503a4 c0054968 20000093 ffffffff df8a5b84 df8a5b68 c00503a4
[ 2.291003] 5b64 c005495c 0420806c c17b2280 df83fb00 df8a4000 df8a5bbc df8a5b88 c0648398
[ 2.291003] 5b84 c0050394 c0957280 c0957280 df8a5bb4 df83fb00 00000001 df8a5bdc df83fc68
[ 2.291003] 5ba4 df838ac0 df83faf8 df83fc68 df8a5bcc df8a5bc0 c06488f8 c06482a4 df8a5c14
[ 2.291003] 5bc4 df8a5bd0 c003a018 c0648878 df8a5c04 00000001 c00359d8 df8a5bdc df8a5bdc
[ 2.291003]
[ 2.291003] R0: 0xdf83fa80:
[ 2.291003] fa80 00000000 ffffffff ffffffff c0a183f4 df83fa90 df83fa90 00000000 df83fa9c
[ 2.291003] faa0 df83fa9c 00000000 00000000 00000000 00000000 00000000 00000020 00000000
[ 2.291003] fac0 0000c350 0000c350 00000000 ffffffff 00000000 00000000 00000000 00000000
[ 2.291003] fae0 00000000 00000000 00000000 00000000 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 2.291003] fb00 00000040 df8a4000 00000002 0420806c 00000000 00000000 00000001 00000000
[ 2.291003] fb20 00000078 00000078 00000078 00000000 c064d5e4 00000000 00000400 00400000
[ 2.291003] fb40 00000001 00000000 00000000 df83fb4c df83fb4c 00000000 884575c0 00000000
[ 2.291003] fb60 4c7c17be 00000000 6353a033 00000000 4c7b696d 00000000 00000005 00000000
[ 2.291003]
[ 2.291003] R2: 0xc09f0128:
[ 2.291003] 0128 00000000 00000000 c0842922 00000000 00000000 00000000 00000000 c084293c
[ 2.291003] 0148 00000000 00000000 00000000 00000000 c0842954 00000000 00000000 00000000
[ 2.291003] 0168 00000000 c0842966 00000000 00000000 00000000 00000000 c0842985 00000000
[ 2.291003] 0188 00000000 00000000 00000000 c08429a5 00000000 00000000 00000000 00000000
[ 2.291003] 01a8 c08429bc 00000000 00000000 00000000 00000000 c08429d0 00000000 00000000
[ 2.291003] 01c8 00000000 00000000 c08429e7 00000000 00000000 00000000 00000000 c08429ff
[ 2.291003] 01e8 00000000 00000000 00000000 00000000 c0842a19 00000000 00000000 00000000
[ 2.291003] 0208 00000000 c0842a42 00000000 00000000 00000000 00000000 c0842a55 00000000
[ 2.291003]
[ 2.291003] R4: 0xc17b2200:
[ 2.291003] 2200 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 2220 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 2240 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 2260 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 2280 00000001 00000000 00000000 00000400 00000200 00000100 00000080 00000040
[ 2.291003] 22a0 ffff8bb4 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 22c0 0000003c 00000000 000001f8 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 22e0 00000000 00000000 6353a033 00000000 6353a033 00000000 00000000 00000000
[ 2.291003]
[ 2.291003] R6: 0xdf8a3f80:
[ 2.291003] 3f80 c004f9a0 c0648878 00000000 df899ec0 df82ad40 c004f708 00000013 00000000
[ 2.291003] 3fa0 00000000 00000000 df8a3ff4 df8a3fb8 c0054630 c004f714 00000000 00000000
[ 2.291003] 3fc0 df82ad40 00000000 00000000 00000000 df8a3fd0 df8a3fd0 00000000 df899ec0
[ 2.291003] 3fe0 c0054594 c0011a04 00000000 df8a3ff8 c0011a04 c00545a0 aaaaaaaa aaaaaaaa
[ 2.291003] 4000 00000000 00000005 00000000 df83fb00 c097dc68 00000002 00000015 c17b2280
[ 2.291003] 4020 df83fb00 df8a4000 00000000 dee0ab80 c00103ec c0986430 df8a5bec df8a5bb8
[ 2.291003] 4040 c0648740 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003] 4060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003]
[ 2.291003] R7: 0xdf83fc64:
[ 2.291003] fc64 df838740 df83fc68 df83fc68 df83fc70 df83fc70 df83fb00 df83fc7c df83fc7c
[ 2.291003] fc84 df83fc84 df83fc84 00000000 00200200 00000000 df8381d8 00200200 00000000
[ 2.291003] fca4 df8381e4 00200200 00000000 df83fcb0 00200200 00000000 00000000 00000000
[ 2.291003] fcc4 00000000 00000002 00000000 00000002 00000000 00000000 00000000 0000001d
[ 2.291003] fce4 00000003 00000000 042c1d82 00000000 042c1d82 00000000 00000000 00000000
[ 2.291003] fd04 00000000 00000000 00000000 df83fd10 df83fd10 df83fd18 df83fd18 df83fd20
[ 2.291003] fd24 df83fd20 df839640 df839640 00000000 726f776b 2f72656b 00303a75 00000000
[ 2.291003] fd44 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.291003]
[ 2.291003] R8: 0xdf838a40:
[ 2.291003] 8a40 00000002 ffffffff ffffffff c0a183f4 df838a50 df838a50 00000000 df838a5c
[ 2.291003] 8a60 df838a5c 00000000 00000000 00000000 00000000 00000000 00000020 00000000
[ 2.291003] 8a80 0000c350 0000c350 00000000 ffffffff 00000000 00000000 00000000 00000000
[ 2.291003] 8aa0 00000000 00000000 00000000 00000000 aaaaaaaa aaaaaaaa aaaaaaaa aaaaaaaa
[ 2.291003] 8ac0 00000002 df898000 00000002 00200140 00000000 00000000 00000000 00000000
[ 2.291003] 8ae0 00000078 00000078 00000078 00000000 c064d5e4 00000000 00000400 00400000
[ 2.291003] 8b00 00000001 00000000 00000000 df838b0c df838b0c 00000000 4155d265 00000000
[ 2.291003] 8b20 2e6a4655 00000000 30e11ed3 00000000 2cdbce5a 00000000 00000006 00000000
[ 2.291003]
[ 2.291003] R9: 0xdf83fa78:
[ 2.291003] fa78 00000000 00000001 00000000 ffffffff ffffffff c0a183f4 df83fa90 df83fa90
[ 2.291003] fa98 00000000 df83fa9c df83fa9c 00000000 00000000 00000000 00000000 00000000
[ 2.291003] fab8 00000020 00000000 0000c350 0000c350 00000000 ffffffff 00000000 00000000
[ 2.291003] fad8 00000000 00000000 00000000 00000000 00000000 00000000 aaaaaaaa aaaaaaaa
[ 2.291003] faf8 aaaaaaaa aaaaaaaa 00000040 df8a4000 00000002 0420806c 00000000 00000000
[ 2.291003] fb18 00000001 00000000 00000078 00000078 00000078 00000000 c064d5e4 00000000
[ 2.291003] fb38 00000400 00400000 00000001 00000000 00000000 df83fb4c df83fb4c 00000000
[ 2.291003] fb58 884575c0 00000000 4c7c17be 00000000 6353a033 00000000 4c7b696d 00000000
[ 2.291003] Process kworker/u:0 (pid: 5, stack limit = 0xdf8a42f8)
[ 2.291003] Stack: (0xdf8a5b58 to 0xdf8a6000)
[ 2.291003] 5b40: df8a5b84 df8a5b68
[ 2.291003] 5b60: c00503a4 c005495c 0420806c c17b2280 df83fb00 df8a4000 df8a5bbc df8a5b88
[ 2.291003] 5b80: c0648398 c0050394 c0957280 c0957280 df8a5bb4 df83fb00 00000001 df8a5bdc
[ 2.291003] 5ba0: df83fc68 df838ac0 df83faf8 df83fc68 df8a5bcc df8a5bc0 c06488f8 c06482a4
[ 2.291003] 5bc0: df8a5c14 df8a5bd0 c003a018 c0648878 df8a5c04 00000001 c00359d8 df8a5bdc
[ 2.291003] 5be0: df8a5bdc df83fcb0 df8a42f8 df8a5d00 df83fb00 00000001 df8a42f8 00000000
[ 2.291003] 5c00: c00103ec defad000 df8a5c44 df8a5c18 c0014c48 c0039890 df8a42f8 0000000b
[ 2.291003] 5c20: df8a5c44 df8a5d00 c0410558 e7f001f2 00000000 e7100000 df8a5c54 df8a5c48
[ 2.291003] 5c40: c0014cd8 c0014a90 df8a5cfc df8a5c58 c000a184 c0014c88 00000006 c00cece4
[ 2.291003] 5c60: 00000004 00000000 00030001 c0410558 ffffffff c064954c df8b7800 c0986430
[ 2.291003] 5c80: df8a5c9c 00000010 00000000 00000000 c0062d88 00000050 00000001 df8a4000
[ 2.291003] 5ca0: df8a5cc4 df8a5cb0 c0062d88 c00855d8 00000001 00000001 df8a5cdc df8a5cc8
[ 2.291003] 5cc0: c0062d88 c00855d8 00000001 df8a4000 df8a5cf4 df8a5ce0 c0062e68 c0062d80
[ 2.291003] 5ce0: c041055c 20000013 c0010694 00000000 df8a5d74 df8a5d00 c00103ec c000a00c
[ 2.291003] 5d00: 00000200 00000200 00000000 df8a5dc8 df8a5df8 dedc0c00 df8a5dc8 df8a5dc8
[ 2.291003] 5d20: 00000000 defb5c00 defad000 df8a5d74 00000080 df8a5d48 c041036c c0410558
[ 2.291003] 5d40: 20000013 ffffffff c00f8ddc c028d860 df8a5da4 c028b864 df8a5df8 dedc0c00
[ 2.291003] 5d60: defb6e00 df8a5dc8 df8a5d8c df8a5d78 c041061c c041033c ffffffff 00000200
[ 2.291003] 5d80: df8a5e5c df8a5d90 c0415364 c0410608 c04123f8 dedc0c00 00000008 00000000
[ 2.291003] 5da0: 00000000 00000000 00000000 00000000 000000b5 00000000 00000000 00000000
[ 2.291003] 5dc0: 00000000 df8a5df8 02faf080 00000000 00000200 00000001 00000000 00000200
[ 2.291003] 5de0: 00000000 00000000 00000000 00000001 df8a5e20 00000000 00000000 df8a5d98
[ 2.291003] 5e00: df8a5dc8 00000000 00000000 00000000 00000000 df8a5e14 df8a5e14 c040fa98
[ 2.291003] 5e20: c1763472 00000e00 00000200 00000000 c00f8f18 defb5c00 df8a5ecc 00000000
[ 2.291003] 5e40: 00000004 defad000 c04123f8 00000000 df8a5e74 df8a5e60 c0415b24 c041527c
[ 2.291003] 5e60: 00000200 00000000 df8a5e9c df8a5e78 c0413a70 c0415b00 00000000 defb5c00
[ 2.291003] 5e80: dedc0c00 00000000 00000004 c06c5098 df8a5efc df8a5ea0 c041409c c04139ec
[ 2.291003] 5ea0: 00000080 dedc0dc8 00000000 c06c4f5c 00000000 c0a15080 11010030 30344741
[ 2.291003] 5ec0: 3002d82f a5a0b519 c0ff8080 00000000 df8a5efc dedc0c00 00000000 c06c4f4c
[ 2.291003] 5ee0: 00000000 c06c4f5c c04123f8 c0a15080 df8a5f1c df8a5f00 c0415124 c0413c7c
[ 2.291003] 5f00: df8a5f44 00ff8080 dedc0e00 dedc0c00 df8a5f44 df8a5f20 c041266c c0415004
[ 2.291003] 5f20: 00000000 df82ad00 c0a15080 df9dd800 dedc0e00 00000000 df8a5f84 df8a5f48
[ 2.291003] 5f40: c004f344 c0412404 c0649a1c c0062e90 df9dd805 00000000 df8a5f74 df82ad00
[ 2.291003] 5f60: c0a15080 c09efc88 df8a4000 df82ad10 00000089 c0a15080 df8a5fb4 df8a5f88
[ 2.291003] 5f80: c004f8b0 c004f0bc 00000000 df899ec0 df82ad00 c004f708 00000013 00000000
[ 2.291003] 5fa0: 00000000 00000000 df8a5ff4 df8a5fb8 c0054630 c004f714 00000000 00000000
[ 2.291003] 5fc0: df82ad00 00000001 00000000 00000000 df8a5fd0 df8a5fd0 00000000 df899ec0
[ 2.291003] 5fe0: c0054594 c0011a04 00000000 df8a5ff8 c0011a04 c00545a0 aaaaaaaa aaaaaaaa
[ 2.291003] [<c0054968>] (kthread_data+0x18/0x20) from [<c00503a4>] (wq_worker_sleeping+0x1c/0xc4)
[ 2.291003] [<c00503a4>] (wq_worker_sleeping+0x1c/0xc4) from [<c0648398>] (__schedule+0x100/0x578)
[ 2.291003] [<c0648398>] (__schedule+0x100/0x578) from [<c06488f8>] (schedule+0x8c/0x90)
[ 2.291003] [<c06488f8>] (schedule+0x8c/0x90) from [<c003a018>] (do_exit+0x794/0x7d0)
[ 2.291003] [<c003a018>] (do_exit+0x794/0x7d0) from [<c0014c48>] (die+0x1c4/0x1f8)
[ 2.291003] [<c0014c48>] (die+0x1c4/0x1f8) from [<c0014cd8>] (arm_notify_die+0x5c/0x60)
[ 2.291003] [<c0014cd8>] (arm_notify_die+0x5c/0x60) from [<c000a184>] (do_undefinstr+0x184/0x1a8)
[ 2.291003] [<c000a184>] (do_undefinstr+0x184/0x1a8) from [<c00103ec>] (__und_svc_finish+0x0/0x14)
[ 2.291003] Exception stack(0xdf8a5d00 to 0xdf8a5d48)
[ 2.291003] [<c00103ec>] (__und_svc_finish+0x0/0x14) from [<c0410558>] (__mmc_start_req+0x228/0x2cc)
[ 2.291003] [<c0410558>] (__mmc_start_req+0x228/0x2cc) from [<c041061c>] (mmc_wait_for_req+0x20/0x30)
[ 2.291003] [<c041061c>] (mmc_wait_for_req+0x20/0x30) from [<c0415364>] (mmc_send_cxd_data+0xf4/0x120)
[ 2.291003] [<c0415364>] (mmc_send_cxd_data+0xf4/0x120) from [<c0415b24>] (mmc_send_ext_csd+0x30/0x38)
[ 2.291003] [<c0415b24>] (mmc_send_ext_csd+0x30/0x38) from [<c0413a70>] (mmc_get_ext_csd+0x90/0x110)
[ 2.291003] [<c0413a70>] (mmc_get_ext_csd+0x90/0x110) from [<c041409c>] (mmc_init_card+0x42c/0x12c8)
[ 2.291003] [<c041409c>] (mmc_init_card+0x42c/0x12c8) from [<c0415124>] (mmc_attach_mmc+0x12c/0x1c8)
[ 2.291003] [<c0415124>] (mmc_attach_mmc+0x12c/0x1c8) from [<c041266c>] (mmc_rescan+0x274/0x31c)
[ 2.291003] [<c041266c>] (mmc_rescan+0x274/0x31c) from [<c004f344>] (process_one_work+0x294/0x48c)
[ 2.291003] [<c004f344>] (process_one_work+0x294/0x48c) from [<c004f8b0>] (worker_thread+0x1a8/0x2a4)
[ 2.291003] [<c004f8b0>] (worker_thread+0x1a8/0x2a4) from [<c0054630>] (kthread+0x9c/0xa8)
[ 2.291003] [<c0054630>] (kthread+0x9c/0xa8) from [<c0011a04>] (kernel_thread_exit+0x0/0x8)
[ 2.291003] Code: e24cb004 e92d4000 e8bd4000 e59031b8 (e5130004)
[ 12.090039] esp_sdio_init ------ RETRY ------
[ 12.095054] =======================================================
[ 12.102024] ==== Dislaunching Wi-Fi driver! (Powered by Rockchip) ====
[ 12.109261] =======================================================
[ 12.116220] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(01/22/2016),Drv: 2.26) exit.
[ 12.126850] gpio esp_wl_chip_en set val 0, act val 0
[ 12.142364] [esp8089]: sdio wifi power state: off
[ 12.247582] =======================================================
[ 12.254540] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 12.261497] =======================================================
[ 12.268445] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[ 12.279094] gpio esp_wl_chip_en set val 1, act val 1
[ 12.294608] [esp8089]: sdio wifi power state: on
[ 23.390033] esp_sdio_init ------ RETRY ------
[ 23.395007] =======================================================
[ 23.401974] ==== Dislaunching Wi-Fi driver! (Powered by Rockchip) ====
[ 23.409211] =======================================================
[ 23.416169] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(01/22/2016),Drv: 2.26) exit.
[ 23.426795] gpio esp_wl_chip_en set val 0, act val 0
[ 23.442308] [esp8089]: sdio wifi power state: off
[ 23.547526] =======================================================
[ 23.554484] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 23.561441] =======================================================
[ 23.568389] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[ 23.579035] gpio esp_wl_chip_en set val 1, act val 1
[ 23.594549] [esp8089]: sdio wifi power state: on
[ 34.690033] esp_sdio_init ------ RETRY ------
[ 34.695003] =======================================================
[ 34.701967] ==== Dislaunching Wi-Fi driver! (Powered by Rockchip) ====
[ 34.709203] =======================================================
[ 34.716162] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(01/22/2016),Drv: 2.26) exit.
[ 34.726787] gpio esp_wl_chip_en set val 0, act val 0
[ 34.742300] [esp8089]: sdio wifi power state: off
[ 34.847517] =======================================================
[ 34.854476] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 34.861433] =======================================================
[ 34.868381] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[ 34.879026] gpio esp_wl_chip_en set val 1, act val 1
[ 34.894540] [esp8089]: sdio wifi power state: on
[ 45.990033] esp_sdio_init ------ RETRY ------
[ 45.995001] =======================================================
[ 46.001965] ==== Dislaunching Wi-Fi driver! (Powered by Rockchip) ====
[ 46.009202] =======================================================
[ 46.016160] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(01/22/2016),Drv: 2.26) exit.
[ 46.026785] gpio esp_wl_chip_en set val 0, act val 0
[ 46.042298] [esp8089]: sdio wifi power state: off
[ 46.147517] eagle sdio can not power up!
[ 46.151882] ALSA device list:
[ 46.155168] #0: audiocodec
[ 46.159046] Freeing init memory: 328K
[ 61.060016] INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 0, t=6002 jiffies)
[ 61.069887] INFO: Stall ended before state dump start
[ 241.110008] INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 0, t=24007 jiffies)
[ 241.119967] INFO: Stall ended before state dump start
[ 421.160008] INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 0, t=42012 jiffies)
[ 421.169965] INFO: Stall ended before state dump start
[ 601.210008] INFO: rcu_preempt detected stalls on CPUs/tasks: { 2} (detected by 0, t=60017 jiffies)
[ 601.219965] INFO: Stall ended before state dump start离线
该问题搞定没有啊,分享下?我也遇类似问题了
板子是樱桃派的,报错:
esp8089 linux3.4
看代码流程已经进入初始化esp_sdio_init了,驱动也挂上去了,就是等超时了
8089是挂在mmc1上的,不知道下面配置是否有问题
[wifi_para]
wifi_used = 1
wifi_sdc_id = 1
wifi_usbc_id =
wifi_usbc_type =
wifi_mod_sel = 6
wifi_power = ""
; xxd
lpo_use_apclk = 200
;dpi
;wl_reg_on = port:PB05<1><default><default><0>
;yj
wl_reg_on = port:PE24<1><default><default><0>
;wifi_power = "axp22_dldo1"
wifi_power_switch =
esp_wl_chip_en = port:PL07<1><default><default><0>
esp_wl_rst = port:PL06<1><default><default><0>
[mmc1_para]
sdc_used = 1
sdc_detmode = 4
sdc_buswidth = 4
sdc_clk = port:PG00<2><1><1><default>
sdc_cmd = port:PG01<2><1><1><default>
sdc_d0 = port:PG02<2><1><1><default>
sdc_d1 = port:PG03<2><1><1><default>
sdc_d2 = port:PG04<2><1><1><default>
sdc_d3 = port:PG05<2><1><1><default>
;xxd
sdc_det =
sdc_use_wp = 0
sdc_wp =
sdc_isio = 1
sdc_regulator = "none"
