楼主 #1 2020-06-03 15:16:51
QbasicJacky
反汇编 u-boot 的elf 文件 ,怎么才能 跟源码对应上,没有混排方式 @晕哥 大大
通过 arm-linux-gnueabihf-objdump -D u-boot > u-boot.dis
但是 生成的 代码 是纯汇编,两者没有混排起来,不知道 那些虹 被执行了
有没有 生成 混排起来的 反汇编, 应该是 gcc 优化掉了 它对应的调试消息 怎么改
例如:函数 s_init对应的 C 代码是
void s_init(void)
  • Undocumented magic taken from boot0, without this DRAM
  • access gets messed up (seems cache related).
  • The boot0 sources describe this as: "config ema for cache sram"
    #if defined CONFIG_MACH_SUN6I
    setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0x1800);
    #elif defined CONFIG_MACH_SUN8I
    __maybe_unused uint version;
/ Unlock sram version info reg, read it, relock /
setbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15));
version = readl(SUNXI_SRAMC_BASE + 0x24) >> 16;
clrbits_le32(SUNXI_SRAMC_BASE + 0x24, (1 << 15));
  • Ideally this would be a switch case, but we do not know exactly
  • which versions there are and which version needs which settings,
  • so reproduce the per SoC code from the BSP.
    #if defined CONFIG_MACH_SUN8I_A23
    if (version == 0x1650)
    else / 0x1661 ? /
    setbits_le32(SUNXI_SRAMC_BASE + 0x44, 0xc0);
    #elif defined CONFIG_MACH_SUN8I_A33
    if (version != 0x1667)
    / A83T BSP never modifies SUNXI_SRAMC_BASE + 0x44 /
    / No H3 BSP, boot0 seems to not modify SUNXI_SRAMC_BASE + 0x44 /
#if defined CONFIG_MACH_SUN6I || \
defined CONFIG_MACH_SUN7I || \
defined CONFIG_MACH_SUN8I || \
defined CONFIG_MACH_SUN9I
/ Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg /
asm volatile(
"mrc p15, 0, r0, c1, c0, 1\n"
"orr r0, r0, #1 << 6\n"
"mcr p15, 0, r0, c1, c0, 1\n");
#if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I_H3
/ Enable non-secure access to some peripherals /
tzpc_init();
clock_init();
timer_init();
gpio_init();
i2c_init_board();
eth_init_board();
对应的 汇编是:
42e01140 <s_init>:
42e01140: e3a03507 mov r3, #29360128 ; 0x1c00000
42e01144: e92d4010 push {r4, lr}
42e01148: e5932024 ldr r2, [r3, #36] ; 0x24
42e0114c: e3822902 orr r2, r2, #32768 ; 0x8000
42e01150: e5832024 str r2, [r3, #36] ; 0x24
42e01154: e5932024 ldr r2, [r3, #36] ; 0x24
42e01158: f57ff05f dmb sy
42e0115c: e5932024 ldr r2, [r3, #36] ; 0x24
42e01160: e3c22902 bic r2, r2, #32768 ; 0x8000
42e01164: e5832024 str r2, [r3, #36] ; 0x24
42e01168: ee110f30 mrc 15, 0, r0, cr1, cr0, {1}
42e0116c: e3800040 orr r0, r0, #64 ; 0x40
42e01170: ee010f30 mcr 15, 0, r0, cr1, cr0, {1}
42e01174: eb000023 bl 42e01208 <clock_init>
42e01178: ebfffd29 bl 42e00624 <timer_init>
42e0117c: e3a01003 mov r1, #3
42e01180: e3a00028 mov r0, #40 ; 0x28
42e01184: eb00004e bl 42e012c4 <sunxi_gpio_set_cfgpin>
42e01188: e3a01003 mov r1, #3
42e0118c: e3a00029 mov r0, #41 ; 0x29
42e01190: eb00004b bl 42e012c4 <sunxi_gpio_set_cfgpin>
42e01194: e3a01001 mov r1, #1
42e01198: e3a00029 mov r0, #41 ; 0x29
42e0119c: eb000074 bl 42e01374 <sunxi_gpio_set_pull>
42e011a0: e8bd4010 pop {r4, lr}
42e011a4: ea000190 b 42e017ec <i2c_init_board>
楼主 #2 2020-06-04 10:02:09
QbasicJacky
Re: 反汇编 u-boot 的elf 文件 ,怎么才能 跟源码对应上,没有混排方式 @晕哥 大大
输入 命令
arm-linux-gnueabihf-objdump -S u-boot>u-boot.dis
就能得到 混编 的 uboot 反汇编文件
42e01140 <s_init>:
asm volatile(
tzpc_init();
最近编辑记录 QbasicJacky (2020-06-04 10:03:14)
