楼主 #1 2020-06-10 22:22:41
everlink
已发帖子: 93
{水} 整好板子又整了两天固件,发一个 H3 KERNEL 5.7 (BIN)
https://whycan.cn/files/members/3162/h3-spiflash8m_bin.gz
[    0.141840][    T1] NET: Registered protocol family 2
[    0.143509][    T1] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.143613][    T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.143703][    T1] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.143791][    T1] TCP: Hash tables configured (established 1024 bind 1024)
[    0.144102][    T1] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.144207][    T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.144733][    T1] NET: Registered protocol family 1
[    0.149020][    T1] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.167464][    T1] jffs2: version 2.2. (NAND)  2001-2006 Red Hat, Inc.
[    0.168943][    T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.168985][    T1] io scheduler mq-deadline registered
[    0.169012][    T1] io scheduler kyber registered
[    0.186821][    T1] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.192118][    T1] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    0.376655][    T1] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.382524][    T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[    0.384937][    T1] printk: console [ttyS0] disabled
[    0.385147][    T1] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 35, base_baud = 1500000) is a 16550A
[    1.028890][    T1] printk: console [ttyS0] enabled
[    1.043667][    T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
[    1.056040][    T1] spi-nor spi0.0: w25q128 (16384 Kbytes)
[    1.061663][    T1] 4 fixed-partitions partitions found on MTD device spi0.0
[    1.068807][    T1] Creating 4 MTD partitions on "spi0.0":
[    1.074325][    T1] 0x000000000000-0x000000100000 : "u-boot"
[    1.084379][    T1] ftl_cs: FTL header not found.
[    1.092428][    T1] 0x000000100000-0x000000110000 : "dtb"
[    1.099595][    T1] ftl_cs: FTL header not found.
[    1.107455][    T1] 0x000000110000-0x000000510000 : "kernel"
[    1.117461][    T1] ftl_cs: FTL header not found.
[    1.125361][    T1] 0x000000510000-0x000001000000 : "rootfs"
[    1.133174][    C0] random: fast init done
[    1.139675][    T1] ftl_cs: FTL header not found.
[    1.150193][    T1] libphy: Fixed MDIO Bus: probed
[    1.155142][    T1] CAN device driver interface
[    1.161282][    T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.168595][    T1] ehci-platform: EHCI generic platform driver
[    1.175205][    T1] ehci-platform 1c1b000.usb: EHCI Host Controller
[    1.181576][    T1] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 1
[    1.190511][    T1] ehci-platform 1c1b000.usb: irq 24, io mem 0x01c1b000
[    1.224993][    T1] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    1.234215][    T1] hub 1-0:1.0: USB hub found
[    1.238880][    T1] hub 1-0:1.0: 1 port detected
[    1.245390][    T1] ehci-platform 1c1c000.usb: EHCI Host Controller
[    1.251745][    T1] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[    1.260595][    T1] ehci-platform 1c1c000.usb: irq 26, io mem 0x01c1c000
[    1.294976][    T1] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    1.303980][    T1] hub 2-0:1.0: USB hub found
[    1.308631][    T1] hub 2-0:1.0: 1 port detected
[    1.314993][    T1] ehci-platform 1c1d000.usb: EHCI Host Controller
[    1.321351][    T1] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 3
[    1.330186][    T1] ehci-platform 1c1d000.usb: irq 28, io mem 0x01c1d000
[    1.364975][    T1] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    1.373924][    T1] hub 3-0:1.0: USB hub found
[    1.378575][    T1] hub 3-0:1.0: 1 port detected
[    1.384675][    T1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.391667][    T1] ohci-platform: OHCI generic platform driver
[    1.398158][    T1] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    1.405603][    T1] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
[    1.414368][    T1] ohci-platform 1c1b400.usb: irq 25, io mem 0x01c1b400
[    1.492179][    T1] hub 4-0:1.0: USB hub found
[    1.496833][    T1] hub 4-0:1.0: 1 port detected
[    1.503134][    T1] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    1.510588][    T1] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 5
[    1.519404][    T1] ohci-platform 1c1c400.usb: irq 27, io mem 0x01c1c400
[    1.601075][    T1] hub 5-0:1.0: USB hub found
[    1.606004][    T1] hub 5-0:1.0: 1 port detected
[    1.612289][    T1] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    1.619763][    T1] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 6
[    1.628576][    T1] ohci-platform 1c1d400.usb: irq 29, io mem 0x01c1d400
[    1.711068][    T1] hub 6-0:1.0: USB hub found
[    1.715978][    T1] hub 6-0:1.0: 1 port detected
[    1.725875][    T1] sun6i-rtc 1f00000.rtc: registered as rtc0
[    1.731750][    T1] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T02:06:21 UTC (7581)
[    1.740710][    T1] sun6i-rtc 1f00000.rtc: RTC enabled
[    1.746227][    T1] i2c /dev entries driver
[    1.751075][    T1] IR NEC protocol handler initialized
[    1.756387][    T1] IR RC5(x/sz) protocol handler initialized
[    1.762150][    T1] IR RC6 protocol handler initialized
[    1.767427][    T1] IR JVC protocol handler initialized
[    1.772667][    T1] IR Sony protocol handler initialized
[    1.778038][    T1] IR SANYO protocol handler initialized
[    1.783454][    T1] IR Sharp protocol handler initialized
[    1.788902][    T1] IR MCE Keyboard/mouse protocol handler initialized
[    1.795487][    T1] IR XMP protocol handler initialized
[    1.802879][    T1] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.811893][    T1] cpu cpu0: failed to get clock: -2
[    1.817072][    T1] cpufreq-dt: probe of cpufreq-dt failed with error -2
[    1.825434][    T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[    1.836520][    T1] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    1.867612][    T1] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.876396][    T1] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[    1.889069][    T1] usbcore: registered new interface driver usbhid
[    1.895444][    T1] usbhid: USB HID core driver
[    1.903590][    T1] NET: Registered protocol family 17
[    1.908916][    T1] can: controller area network core (rev 20170425 abi 9)
[    1.916116][    T1] NET: Registered protocol family 29
[    1.921286][    T1] can: raw protocol (rev 20170425)
[    1.926353][    T1] can: broadcast manager protocol (rev 20170425 t)
[    1.932748][    T1] can: netlink gateway (rev 20190810) max_hops=1
[    1.939532][    T1] Key type dns_resolver registered
[    1.944914][    T1] Registering SWP/SWPB emulation handler
[    1.980428][    T1] ALSA device list:
[    1.984154][    T1]   No soundcards found.
[    2.180169][    C0] random: crng init done
[    2.894074][    T1] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    2.902980][    T1] devtmpfs: mounted
[    2.911206][    T1] Freeing unused kernel memory: 1024K
[    2.917124][    T1] Run /sbin/init as init process
Starting logging: OK
Starting network: OK
Welcome to Buildroot
buildroot login: root
# uname -a
Linux buildroot 5.7.0-g8dcbf7e #2 SMP Wed Jun 10 21:19:56 CST 2020 armv7l GNU/Linux
#2 2020-06-10 22:27:35
黄粱梦
已发帖子: 45
Re: {水} 整好板子又整了两天固件,发一个 H3 KERNEL 5.7 (BIN)
果然水, 坐等教程吧
#3 2020-06-10 23:07:05
checkout
已发帖子: 173
最近也在用H3,你自己画的板子?
楼主 #4 2020-06-10 23:08:06
everlink
已发帖子: 93
checkout 说:
最近也在用H3,你自己画的板子?
en, 是的
#5 2020-06-10 23:43:24
checkout
已发帖子: 173
板子裸照发出来大家看看:)
everlink 说:
en, 是的
最近编辑记录 checkout (2020-06-10 23:44:00)
楼主 #6 2020-06-10 23:50:22
everlink
已发帖子: 93
checkout 说:
板子裸照发出来大家看看:)
之前有在一位大神的贴子跟帖发过,大概长这样
#7 2020-06-13 00:04:42
yangshuwei
已发帖子: 138
围观,板子很漂亮
六层的吗?复位那块咋飞线了
最近编辑记录 yangshuwei (2020-06-13 00:06:42)
#8 2020-06-13 00:09:38
yangshuwei
已发帖子: 138
大佬,我的那个emmc好了,已经可以正常启动了。
楼主 #9 2020-06-13 10:25:54
everlink
已发帖子: 93
yangshuwei 说:
大神你好,我的板子预留了emmc,但是没有焊.理由
1,感觉用不上这么大的空间
2,emmc贵,大神你比较有钱
3,TF 卡也挺好
#10 2020-06-17 11:23:04
yangshuwei
已发帖子: 138
everlink 说:
1,感觉用不上这么大的空间
2,emmc贵,大神你比较有钱
3,TF 卡也挺好
哈哈 还好啦8G的好像36一片
楼主 #11 2020-06-17 12:35:22
everlink
已发帖子: 93
yangshuwei 说:
哈哈 还好啦8G的好像36一片
有钱yin
事实上,如果要做产品,真的没有必要背个8G。我发的BIN是8M。易谦多背
#12 2020-08-17 23:00:11
haregun
everlink 说:
https://whycan.cn/files/members/3162/h3+f1c100s.png
请问两边板子用的PMIC是一样的吗,什么型号的呀?
