[ 0.000000] Linux version 5.2.0-licheepi-nano+ (root@ll-virtual-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #8 Thu Jul 2 11:43:51 CST 2020
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=tty0 console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[ 0.000000] Memory: 23756K/32768K available (5120K kernel code, 208K rwdata, 1284K rodata, 1024K init, 218K bss, 9012K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] random: get_random_bytes called from start_kernel+0x254/0x42c with crng_init=0
[ 0.000045] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000109] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000590] Console: colour dummy device 80x30
[ 0.000949] printk: console [tty0] enabled
[ 0.001032] Calibrating delay loop... 358.80 BogoMIPS (lpj=1794048)
[ 0.050246] pid_max: default: 32768 minimum: 301
[ 0.050591] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.050643] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.052018] CPU: Testing write buffer coherency: ok
[ 0.053973] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.055883] devtmpfs: initialized
[ 0.060848] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.060984] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.061300] pinctrl core: initialized pinctrl subsystem
[ 0.063783] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.065465] cpuidle: using governor menu
[ 0.112206] SCSI subsystem initialized
[ 0.112635] usbcore: registered new interface driver usbfs
[ 0.112849] usbcore: registered new interface driver hub
[ 0.113050] usbcore: registered new device driver usb
[ 0.113501] pps_core: LinuxPPS API ver. 1 registered
[ 0.113568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.114068] Advanced Linux Sound Architecture Driver Initialized.
[ 0.114402] clocksource: Switched to clocksource timer
[ 0.140612] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.142412] Initialise system trusted keyrings
[ 0.143024] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.160394] Key type asymmetric registered
[ 0.160493] Asymmetric key parser 'x509' registered
[ 0.160703] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.160771] io scheduler mq-deadline registered
[ 0.160803] io scheduler kyber registered
[ 0.170063] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.330561] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.335590] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.337161] printk: console [ttyS0] disabled
[ 0.357484] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 26, base_baud = 6250000) is a 16550A
[ 0.683182] printk: console [ttyS0] enabled
[ 0.709828] 1c25800.serial: ttyS1 at MMIO 0x1c25800 (irq = 27, base_baud = 6250000) is a 16550A
[ 0.721809] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.739092] SCSI Media Changer driver v0.25
[ 0.744707] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.757999] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[ 0.771120] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.777840] ehci-platform: EHCI generic platform driver
[ 0.783376] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.789731] ohci-platform: OHCI generic platform driver
[ 0.795497] usbcore: registered new interface driver usb-storage
[ 0.802132] udc-core: couldn't find an available UDC - added [zero] to list of pending drivers
[ 0.812013] input: 1c23400.lradc as /devices/platform/soc/1c23400.lradc/input/input0
[ 0.820767] i2c /dev entries driver
[ 0.827773] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.865845] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 0.874972] usbcore: registered new interface driver usbhid
[ 0.880603] usbhid: USB HID core driver
[ 0.899222] Loading compiled-in X.509 certificates
[ 0.912042] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.923415] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[ 0.934216] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc06374b4)
[ 0.943202] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc063610c)
[ 0.951051] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.957740] [drm] No driver support for vblank timestamp query.
[ 0.964954] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.111159] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.111518] mmc0: new SD card at address cffc
[ 1.116819] mmcblk0: mmc0:cffc SU512 484 MiB
[ 1.133846] Console: switching to colour frame buffer device 100x30
[ 1.168720] mmcblk0: p1 p2
[ 1.227867] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 1.245515] vcc3v0: disabling
[ 1.258227] vcc5v0: disabling
[ 1.270401] ALSA device list:
[ 1.282474] #0: Loopback 1
[ 1.309175] random: fast init done
[ 1.392239] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.409673] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.430905] devtmpfs: mounted
[ 1.449141] Freeing unused kernel memory: 1024K
[ 1.462800] Run /sbin/init as init process
[ 1.507532] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.524115] CPU: 0 PID: 1 Comm: init Not tainted 5.2.0-licheepi-nano+ #8
[ 1.539435] Hardware name: Allwinner suniv Family
[ 1.552620] [<c010e3f8>] (unwind_backtrace) from [<c010b9dc>] (show_stack+0x10/0x14)
[ 1.569095] [<c010b9dc>] (show_stack) from [<c0116db4>] (panic+0xe8/0x2e4)
[ 1.584758] [<c0116db4>] (panic) from [<c01185e8>] (do_exit+0x9dc/0xa18)
[ 1.600117] [<c01185e8>] (do_exit) from [<c0119184>] (do_group_exit+0x3c/0xb4)
[ 1.615993] [<c0119184>] (do_group_exit) from [<c0122d3c>] (get_signal+0x10c/0x7bc)
[ 1.632223] [<c0122d3c>] (get_signal) from [<c010af4c>] (do_work_pending+0x1a8/0x558)
[ 1.648678] [<c010af4c>] (do_work_pending) from [<c0101068>] (slow_work_pending+0xc/0x20)
[ 1.665503] Exception stack(0xc1831fb0 to 0xc1831ff8)
[ 1.679064] 1fa0: be841f10 00000000 00000000 00000000
[ 1.695964] 1fc0: 00000940 00000000 00000000 00000000 00000000 00000000 000275e4 00000000
[ 1.712794] 1fe0: 00000000 be841f10 b6f90b53 b6f91000 00000030 ffffffff
[ 1.727783] Rebooting in 5 seconds..
[ 7.719715] Reboot failed -- System halted这个是我的buildroot 的.config 文件
这个问题前面回答过你了:
用 arm-2014.05-29 这个工具链编译根文件系统(kernel和zImage不用管),药到病除: https://whycan.cn/t_2847.html#p23264
是的, http://nano.lichee.pro/build_sys/rootfs.html 这个看云里也是使用的是这个工具链,也许是uboot-2018 对gcc 版本要求高6.0以上才使用的这个7.2的编译器,哎,先不管了,明天应这个工具链试一下。。
