重启有时不能正确获取IP
[ 2.952472] systemd[1]: Expecting device dev-ttyS0.device...
[ 3.237578] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.719839] systemd-udevd[96]: starting version 215
[ 4.879314] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.325725] systemd-journald[83]: Received request to flush runtime journal from PID 1
[ 7.654572] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=-1)
[ 7.673036] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 7.684349] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
有时候启动 没有下面的内容
[ 22.248938] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
拔插网线之后是不是就可以了?
好像也不行 分配不了IP地址
好像是没有拿到mac地址
有的时候行 有的时候不行 显示dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx就可以了
设了静态IP地址 ping不通网络
