楼主 #1 2021-03-09 11:47:28
xiaohua4758
f1c200(板子widora tiny200-r3)的lvgl7.11.0移植例程(屏是800x480的电容屏)
上传到这里做个笔记^^
重新编辑原因:原来的LVGL刷屏速度太慢了,下午调试发现把lv_tick_inc(5)新开一线程更新,速度上来了,重新上传修改后的代码
源码是:lvgl7110_f1c_demo.7z,自己下载解压
  1. 改lvgl及makefile
    (1)lvgl
    东西都是现成了,下了当前最新的lvgl 7.11.0版本,
    主要改了lv_conf.h,lv_drv_conf.h,lv_ex_conf.h三个配置文件,以及main函数修改了一下。
    具体忘记改哪些了,都是make的时候,哪里报错就改哪里的,直接看我的例程源文件
(2)
参考网上把makefile文件改了一下,主要是把交叉编译链的目录改成自己的目录就可以了,比如我的是
CC = /home/myway/f1c200/buildroot-tiny200/output/host/bin/arm-buildroot-linux-gnueabi-gcc-8.4.0
然后就可以make 生成执行文件 lvgl_7110_demo
  1. 运行
    将编译出来的lvgl_7110_demo放在tiny200-r3的文件系统,比如我的放在root文件夹下,运行如下
    # pwd
    /root
    # ls
    lvgl_7110_demo
    # chmod 777 lvgl_7110_demo
    # ./lvgl_7110_demo 3
    lvgl version:7.11.0
    demo num:3
    The framebuffer device was opened successfully.
    800x480, 32bpp
    The framebuffer device was mapped to memory successfully.
总共51个demo,运行第几个demo就加相应的数字,如运行第3个就是
./lvgl_7110_demo 3
demo数字对应的数字如下,参考main函数:
	switch(demo_num)
		case 0:
		case 1: lv_demo_widgets(); break;
		case 2: lv_demo_music(); break;
		case 3: lv_demo_printer(); break;
		case 4: lv_demo_keypad_encoder(); break;
		case 5: lv_demo_benchmark(); break;
		case 6: lv_ex_get_started_1(); break;
		case 7: lv_ex_get_started_2(); break;
		case 8: lv_ex_get_started_3(); break;
		case 9: lv_ex_style_1(); break;
		case 10:  lv_ex_style_2(); break;
		case 11:  lv_ex_style_3(); break;
		case 12:  lv_ex_style_4(); break;
		case 13:  lv_ex_style_5(); break;
		case 14:  lv_ex_style_6(); break;
		case 15:  lv_ex_style_7(); break;
		case 16:  lv_ex_style_8(); break;
		case 17:  lv_ex_style_10(); break;
		case 18:  lv_ex_style_11(); break;
		case 19:  lv_ex_arc_1(); break;
		case 20:  lv_ex_tileview_1(); break;
		case 21:  lv_ex_spinner_1(); break;
		case 22:  lv_ex_spinbox_1(); break;
		case 23:  lv_ex_slider_1(); break;
		case 24:  lv_ex_roller_1(); break;
		case 25:  lv_ex_page_1(); break;
		case 26:  lv_ex_objmask_1(); break;
		case 27:  lv_ex_objmask_2(); break;
		case 28:  lv_ex_msgbox_2(); break;
		case 29:  lv_ex_list_1(); break;
		case 30:  lv_ex_linemeter_1(); break;
		case 31:  lv_ex_line_1(); break;
		case 32:  lv_ex_imgbtn_1(); break;
		case 33:  lv_ex_img_1(); break;
		case 34:  lv_ex_gauge_1(); break;
		case 35:  lv_ex_gauge_2(); break;
		case 36:  lv_ex_dropdown_1(); break;
		case 37:  lv_ex_dropdown_2(); break;
		case 38:  lv_ex_cpicker_1(); break;
		case 39:  lv_ex_cpicker_2(); break;
		case 40:  lv_ex_cont_1(); break;
		case 41:  lv_ex_checkbox_1(); break;
		case 42:  lv_ex_chart_1(); break;
		case 43:  lv_ex_chart_2(); break;
		case 44:  lv_ex_canvas_1(); break;
		case 45:  lv_ex_canvas_2(); break;
		case 46:  lv_ex_calendar_1(); break;
		case 47:  lv_ex_btnmatrix_1(); break;
		case 48:  lv_ex_btn_1(); break;
		case 49:  lv_ex_btn_2(); break;
		case 50:  lv_ex_bar_1(); break;
		case 51:  lv_ex_arc_1(); break;
		case 52:  lv_ex_arc_2(); break;[video]/files/members/6042/printf1.mp4[/video]
		default:
源码:lvgl7110_f1c_demo_v1.0.7z
最近编辑记录 xiaohua4758 (2021-03-09 16:48:27)
#2 2021-03-09 14:54:47
xrff_z
已发帖子: 26
Re: f1c200(板子widora tiny200-r3)的lvgl7.11.0移植例程(屏是800x480的电容屏)
谢谢分享。
#3 2021-04-02 17:05:16
buliaoqq
已发帖子: 20
用楼主的demo不知道为什么触屏不能用,用ts_test已经能正常测试触屏了。
#4 2021-04-25 22:41:06
WangLY_Snot
已发帖子: 19
that is ok..
#5 2021-09-17 17:35:08
HongSang
+1......触摸只有一小块能用
#6 2021-09-23 16:57:15
lg676041036
已发帖子: 39
HongSang wrote:
+1......触摸只有一小块能用
是不是GT911触屏重新配置了数据,不同厂家的的屏配置数据不一样,尽量不要动配置,动之前先备份。
#7 2021-11-02 14:14:06
HongSang
@lg676041036
这么一说 厂家提供了一组gt911的初始化数组 应该是这样原因
#9 2022-04-07 09:18:40
三哥
有没有整个含板子驱动的代码?
#11 2023-09-27 18:00:51
chen849928055
lv_conf.h
lv_drv_conf.h
lv_ex_conf.h
需要修改的这三个文件还有main.c,放在什么目录下,单独创建个文件夹吗?和之前的lvgl,lv_drivers,examples目录同级的吗
#12 2023-10-08 11:02:41
colt
tina是哪个系统内核
#15 2024-11-25 20:13:15
KingDong
你好,我自己做的板子 也是Tina系统,编译出了出来的LVGL 运行不起来,提示我
root@TinaLinux:~# ls
demo
root@TinaLinux:~# ./demo 1
-/bin/sh: ./demo: not found
#16 2024-11-25 20:45:44
demo
编译命令行加静态链接参数, -static
