ubuntu oops既然是直接死机,syslog的信息全他妈的0000000000000?嵌入式linux死机串口还有oops出来!好家伙!
Raw data transmitter (c) 2015 befinitiv GPL2
device wlan0 entered promiscuous mode
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c1c40000
[00000000] *pgd=81c8a831, *pte=00000000, *ppte=00000000
Internal error: Oops: 80000005 [#1] ARM
Modules linked in: rtl8188eusHI3518(O) cfg80211 rfkill hi_mipi(O) hi3518e_adec()
CPU: 0 PID: 169 Comm: tx Tainted: P O 4.9.37 #11
Hardware name: Hisilicon Hi3518EV20X (Flattened Device Tree)
task: c1ca43a0 task.stack: c27f0000
PC is at 0x0
LR is at rtw_monitor_xmit_entry+0x148/0x204 [rtl8188eusHI3518]
pc : [<00000000>] lr : [<bf3ad278>] psr: 60000013
sp : c27f1d38 ip : c298f060 fp : 00000000
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : 00008180 r6 : 80809b6e r5 : 0114a89d r4 : 1f004267
r3 : c1c0d900 r2 : 000011c7 r1 : c29d91a0 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005317f Table: 81c40000 DAC: 00000055
Process tx (pid: 169, stack limit = 0xc27f0190)
Stack: (0xc27f1d38 to 0xc27f2000)
1d20: 00000000 00000000
1d40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1d60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1d80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1da0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1dc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1de0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1f40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1f60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1f80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fe0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[<bf3ad278>] (rtw_monitor_xmit_entry [rtl8188eusHI3518]) from [<00000000>] ( ()
Code: bad PC value
---[ end trace 9956beced7b189f8 ]---
Kernel panic - not syncing: Fatal exception in interrupt
---[ end Kernel panic - not syncing: Fatal exception in interrupt其实也看不出啥出来,只能确定堆栈的地址指向 rtw_monitor_xmit_entry,这个函数的问题?哪一行呢?
