淘宝售价10元左右,性价比逆天了啊,有没有大佬感兴趣的?
这个芯片不仅内置256MDDR2,还内置了512Mflash,
用来跑linux+QT妥妥的。跑安卓也问题不大了
香橙派2G就是用的这个芯片,
功能如下,该有的基本都有了,
1.1 PLATFORM FEATURES
+ AP MCU subsystem
- ARM Cortex-A5 32-bit RISC processor, with FPU and SIMD NEON engine, up to 1G Hz
- 32kB L1 I-cache and 32kB L1 D-cache- 256kB unified L2 cache
- In-house VOC DSP for voice and image process
- 64-bit AXI fabric, up to 400MHz
- 64kB on-chip ROM for system boot
- 64kB on-chip SRAM for internal use
+ memory interface
- Integrated 2Gb LPDDR2 SDRAM //256M LPDDR2 SDRAM
- Integrated 4Gb 8Bit 2.8V 4K SLC Nand Flash //512M nand flash,做产品成本可以压到极至了
- Two SDIO interfaces, for TF cards and WIFI
- support 4.4.1 EMMC interface
- support SPI-NAND and SPI-NOR
+ Connectivity
- Support 3 SIM cards and both 1.8V and 3.0V device
- USB2.0 high-speed OTG
- 3 UARTs for GPS, BT, FM, and debugging interfaces
- 3 SPI for peripheral devices
- 3 I2C for peripheral devices
- 1 I2S for peripheral devices
- 4 10-bit GPADC for sampling peripheral signals
- 64 GPIOs, includes 16 interruptable GPIOs
- Pulse Width Modulation (PWM) 1 PWL, 1 PWT and 1 LPG
- 2 memory card controller
- 8x8 Keypad scanner with multiple key detection, support ADC serial interface Keypad
1.2 MODEM FEATURES
+ System CPU(XCUP)
- RDA RISC Core 32x32 bits
- 16/32 bit instruction set
- 4KB I-cache and 4KB D-cache
+ Base Band CPU (BCPU)
- RDA RISC Core32x32 bits
- 1KB I-cache and 1KB D-cache
- GSM/GPRS Dedicated accelerators
- RF Interface (RF IF)
- DigRF interface for communication with the integrated transceiver
- EGPRS class 12
+ RF Transceiver
- Quad bands integrated transceiver
- Integrated RF transceiver, Saw-Less, only needs external PA.
- Digital low-IF receiver
- Direct modulation transmitter
- Frequency synthesizer
- Integrated VCO, loop filters, etc.
- Digital AFC
- DigRF interface between digital baseband and transceiver
- RF FEM control
+ Voice and Modem codec
- Supports HR, FR, EFR, AMR voice codec
- Integrated microphone bias
- DTMF and Comfort Tone generator
- 4 samples In and Out Fifos
- I2S / DAI Interface
- Serial Input / Output at 8/16 ks/s
- Can be used for test purpose in DAI mode
- Audio Interface To ABB
- 13 bit RX Data from audio ADC
- 16 bit TX Data to stereo DAC
1.3 MULTI-MEDIA FEATURES
+ LCD display
- Support LCD module interface with 8/16/24 bit parallel interface or SPI series interface
- Support RGB565/666/888 interface
- Typical image sizes: QCIF, QVGA, WQVGA, CIF,VGA,WVGA,FWVGA
- Support DSI interface, up to 1GHz
- Support image size up to qHD
- 4-layers blending graphical engine capable of resizing and YUV2RGB conversion
- Support 2chip select
+ Image signal processor
- Support 8-bit parallel or 1/2/4-bit series interface
- Support CSI-2 interface, up to 1GHz
- Support up to 5Mpix sensor
+ Vide
- Separate video processor
- Decodes up to 1080p 30fps
- Encodes up to 1080p 30fps for H.264 format
+ Graphics
- Separate graphic processor, Vivante’s GC860
- support OpenGLES1.1/2.0
- support OpenVG1.4
- support DirectFB
- support GDI/DirecShow
- 30Triangle/s, 250Pixel/s
+ Audio
- 2 channels voice ADC, 8kHz, 13 bits/sample for headset and on-board microphone
- Voice DAC, 8kHz, 13 bits/sample for receiver
- High fidelity Stereo DAC, up to 48kHz, 16 bits per sample
- Stereo Audio speaker driver
- 1.5W differential output stereo amplifier for loudspeaker, Class K
- Stereo analog audio line input
1.4 POWER MANAGEMENT FEATURES
+ Power Management
- Power On reset control
- Internal 32K OSC for standby/ shutoff/ sleep state
- Integrated Li-ion battery charger (from USB or AC charger)
- Integrated all internal voltages from VBAT
- Provide all LDOs for external components
- Integrated 4 DC-DC, 1 BOOST
- Integrated LCD backlight controller
- Integrated Touch screen controller
- Integrated RGB, keypad backlight controller最近编辑记录 saub (2021-04-07 00:10:54)
这芯片停产了 尾货 没资料 没支持 才这么便宜
哦?,原来如此,那香橙派2G是哪里来的芯片呢?
以前的手机芯片
用香橙派开发板把项目开发到一半,同事说可能停产了,到处打听确实停产了,都停产了,推广个锤子啊
ᥬ?᭄我也是无意看到这个芯片,没了解清楚,见谅哈!
但为什么香橙派还在卖这款呢?香橙派OrangePi 2G-IOT电脑开发板WIFI+蓝牙2G模块RDA芯片,他们哪里来的芯片?难道都是用的二手拆机芯片?那也太不负责任了吧
最近编辑记录 saub (2021-04-07 09:52:36)
兄台我不是说你,是说那个卖开发板的。
这种芯片就和单片机一样了,都集成了
这太方便了,现在还有没有这样的SoC可用了?
早就停产了,而且A5 性能太差。
为啥都不多搞一些这么好的芯片。
