Makefile :
# Top makefile
CROSS ?= riscv64-unknown-elf-
# System environment variable.
HOSTOS := windows
# Load default variables.
ASFLAGS := -g -ggdb -Wall -O3
CFLAGS := -g -ggdb -Wall -O3
CXXFLAGS := -g -ggdb -Wall -O3
LDFLAGS := -T 03_MCU/Linker_file/link.ld -nostdlib
ARFLAGS := -rcs
OCFLAGS := -v -O binary
ODFLAGS :=
MCFLAGS := -march=rv64gcvxthead -mabi=lp64d -mcmodel=medlow -fno-stack-protector
LIBDIRS :=
LIBS :=
INCDIRS :=
SRCDIRS :=
ifeq ($(strip $(HOSTOS)), linux)
MKSUNXI := 00_boot0/tools/linux/mksunxi
endif
ifeq ($(strip $(HOSTOS)), windows)
MKSUNXI := 00_boot0/tools/windows/mksunxi
endif
# Add external library
INCDIRS += 00_boot0/include \
00_boot0 \
02_CPU \
03_MCU \
03_MCU/MCU_drivers \
03_MCU/startup \
04_GEC \
05_UserBoard \
06_SoftComponent \
07_APPprg
SRCDIRS += 00_boot0 \
02_CPU \
03_MCU/startup \
04_GEC \
05_UserBoard \
06_SoftComponent \
07_APPprg
# You shouldn't need to change anything below this point.
AS := $(CROSS)gcc -x assembler-with-cpp
CC := $(CROSS)gcc
CXX := $(CROSS)g++
LD := $(CROSS)ld
AR := $(CROSS)ar
OC := $(CROSS)objcopy
OD := $(CROSS)objdump
MKDIR := mkdir
CP := cp -af
RM := rm -fr
CD := cd
FIND := find
# X variables
X_ASFLAGS := $(MCFLAGS) $(ASFLAGS)
X_CFLAGS := $(MCFLAGS) $(CFLAGS)
X_CXXFLAGS := $(MCFLAGS) $(CXXFLAGS)
X_LDFLAGS := $(LDFLAGS)
X_OCFLAGS := $(OCFLAGS)
X_LIBDIRS := $(LIBDIRS)
X_LIBS := $(LIBS) -lgcc
X_OUT := Debug
X_OBJ := obj
X_NAME := $(patsubst %, $(X_OUT)/%, $(NAME))
X_INCDIRS := $(patsubst %, -I %, $(INCDIRS))
X_SRCDIRS := $(patsubst %, %, $(SRCDIRS))
X_OBJDIRS := $(patsubst %, obj/%, $(X_SRCDIRS))
X_SFILES := $(foreach dir, $(X_SRCDIRS), $(wildcard $(dir)/*.S))
X_CFILES := $(foreach dir, $(X_SRCDIRS), $(wildcard $(dir)/*.c))
X_CPPFILES := $(foreach dir, $(X_SRCDIRS), $(wildcard $(dir)/*.cpp))
SFILENDIR := $(notdir $(X_SFILES))
CFILENDIR := $(notdir $(X_CFILES))
CPPFILENDIR := $(notdir $(X_CPPFILES))
X_SDEPS := $(patsubst %, obj/%, $(SFILENDIR:.S=.o.d))
X_CDEPS := $(patsubst %, obj/%, $(CFILENDIR:.c=.o.d))
X_CPPDEPS := $(patsubst %, obj/%, $(CPPFILENDIR:.cpp=.o.d))
X_DEPS := $(X_SDEPS) $(X_CDEPS) $(X_CPPDEPS)
X_SOBJS := $(patsubst %, obj/%, $(SFILENDIR:.S=.o))
X_COBJS := $(patsubst %, obj/%, $(CFILENDIR:.c=.o))
X_CPPOBJS := $(patsubst %, obj/%, $(CPPFILENDIR:.cpp=.o))
X_OBJS := $(X_SOBJS) $(X_COBJS) $(X_CPPOBJS)
VPATH := $(SRCDIRS)
.PHONY: all clean
all : $(X_NAME)
$(X_NAME) : $(X_OBJS)
@echo [LD] Linking $@.elf
@$(CC) $(X_LDFLAGS) $(X_LIBDIRS) -Wl,--cref,-Map=$@.map $^ -o $@.elf $(X_LIBS)
@echo [OC] Objcopying $@.bin
@$(OC) $(X_OCFLAGS) $@.elf $@.bin
@$(OC) $@.elf -O ihex $@.hex
@$(OD) -D $@.elf > $@.lst
@echo Make header information for brom booting
@$(MKSUNXI) $@.bin
$(X_SOBJS) : obj/%.o : %.S
@echo [AS] $<
@$(AS) $(X_ASFLAGS) -MD -MP -MF $@.d $(X_INCDIRS) -c -O0 $< -o $@
$(X_COBJS) : obj/%.o : %.c
@echo [CC] $<
@$(CC) $(X_CFLAGS) -MD -MP -MF $@.d $(X_INCDIRS) -c -O0 $< -o $@
$(X_CPPOBJS) : obj/%.o : %.cpp
@echo [CXX] $<
@$(CXX) $(X_CXXFLAGS) -MD -MP -MF $@.d $(X_INCDIRS) -c -O0 $< -o $@
clean:
@$(RM) obj $(X_OUT)
# Include the dependency files, should be place the last of makefile
sinclude $(shell $(MKDIR) $(X_OBJ) $(X_OUT)) $(X_DEPS)
安装平头哥官网提供的riscv64 windows版的交叉编译工具链,通过cmd make命令编译工程,出现如下错误:
Makeflie如下:
Makefile.rar
求大佬解答
