启动logo:
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 346
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 69150
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x2000
GPT part: 1, name: trust, start:0x4000, size:0x2000
GPT part: 2, name: misc, start:0x6000, size:0x2000
GPT part: 3, name: dtbo, start:0xc000, size:0x2000
GPT part: 4, name: vbmeta, start:0xe000, size:0x800
GPT part: 5, name: resource, start:0x8000, size:0x8000
GPT part: 6, name: kernel, start:0x10000, size:0xc000
GPT part: 7, name: boot, start:0xe800, size:0x10000
GPT part: 8, name: recovery, start:0x1e800, size:0x30000
GPT part: 9, name: backup, start:0x4e800, size:0x38000
GPT part: 10, name: security, start:0x86800, size:0x2000
GPT part: 11, name: cache, start:0x88800, size:0xc0000
GPT part: 12, name: metadata, start:0x148800, size:0x8000
GPT part: 13, name: frp, start:0x150800, size:0x400
GPT part: 14, name: super, start:0x150c00, size:0x714000
GPT part: 15, name: oem, start:0x864c00, size:0x100000
GPT part: 16, name: userdata, start:0x964c00, size:0x52b3df
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x4000.
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xfb1c8
RunBL31 0x40000 @ 116000 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-266-gee81607c #1 Mon Aug 17 09:23:30 UTC 2020 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Aug 31 2021 - 17:48:37 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 7dbc8000, fdt: 7bdbc358
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
Android 10.0, Build 2020.11
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1000000 uV
Model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
no recovery key node
Rockchip UBOOT DRM driver version: v1.0.1
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
ANDROID: reboot reason: "recovery"
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:757: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition...
Could not find "system" partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000...
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 ...
Kernel load addr 0x00280000 size 19241 KiB
RAM disk load addr 0x0a200000 size 7949 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image from 0x00280000 to 0x00280000 ... OK
'reserved-memory' ramoops@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831dd60
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0x80000000 (size: 0x75e00000)
Total: 588.660 ms
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.111 (le@le-desktop) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #3 SMP PREEMPT Wed Sep 8 15:24:24 CST 2021
[ 0.000000] Machine model: ROC-RK3399-PC-PLUS HDMI+DP(Android)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 23 pages/cpu s57304 r8192 d28712 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 507912
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.slot_suffix= androidboot.serialno=PEC0V81TLG console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.wificountrycode=US androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 firmware_class.path=/vendor/etc/firmware init=/init root=PARTUUID=af01642c-9b84-11e8-9b2a-234eb5e198a0 earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m androidboot.boot_devices=fe330000.sdhci,fe320000.dwmmc
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1979292K/2064384K available (11006K kernel code, 1256K rwdata, 3932K rodata, 3008K init, 2175K bss, 68708K reserved, 16384K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @7b880000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x000000007b820000
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000007b830000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x4ec with crng_init=0
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.002095] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003084] pid_max: default: 32768 minimum: 301
[ 0.003646] Security Framework initialized
[ 0.004042] SELinux: Initializing.
[ 0.004504] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005148] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.007415] ASID allocator initialised with 32768 entries
[ 0.008041] rcu: Hierarchical SRCU implementation.
[ 0.008918] Platform MSI: interrupt-controller@fee20000 domain created
[ 0.010072] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.011721] smp: Bringing up secondary CPUs ...
[ 0.012793] Detected VIPT I-cache on CPU1
[ 0.012830] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.012869] CPU1: using LPI pending table @0x000000007ba10000
[ 0.012913] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.013807] Detected VIPT I-cache on CPU2
[ 0.013842] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.013880] CPU2: using LPI pending table @0x000000007ba60000
[ 0.013923] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.014758] Detected VIPT I-cache on CPU3
[ 0.014791] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.014830] CPU3: using LPI pending table @0x000000007ba80000
[ 0.014873] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.015742] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.015748] CPU features: enabling workaround for EL2 vector hardening
[ 0.015757] Detected PIPT I-cache on CPU4
[ 0.015781] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.015833] CPU4: using LPI pending table @0x000000007bad0000
[ 0.015862] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[ 0.016584] Detected PIPT I-cache on CPU5
[ 0.016612] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.016664] CPU5: using LPI pending table @0x000000007bae0000
[ 0.016694] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[ 0.016803] smp: Brought up 1 node, 6 CPUs
[ 0.029427] SMP: Total of 6 processors activated.
[ 0.029877] CPU features: detected: GIC system register CPU interface
[ 0.030501] CPU features: detected: 32-bit EL0 Support
[ 0.035368] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.036186] CPU: All CPU(s) started at EL2
[ 0.036612] alternatives: patching kernel code
[ 0.038458] devtmpfs: initialized
[ 0.052771] Trying to unpack rootfs image as initramfs...
[ 0.053304] Registered cp15_barrier emulation handler
[ 0.053321] Registered setend emulation handler
[ 0.054616] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.055566] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.056611] pinctrl core: initialized pinctrl subsystem
[ 0.057724] NET: Registered protocol family 16
[ 0.058746] schedtune: configured to support 6 boost groups
[ 0.059500] audit: initializing netlink subsys (disabled)
[ 0.061145] audit: type=2000 audit(0.053:1): state=initialized audit_enabled=0 res=1
[ 0.061925] cpuidle: using governor menu
[ 0.062681] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.071189] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.073677] console [pstore-1] enabled
[ 0.074224] pstore: Registered ramoops as persistent store backend
[ 0.074817] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.089668] rockchip-pinctrl pinctrl: wrong pins number or pins and configs should be by 4
[ 0.090471] rockchip-pinctrl pinctrl: failed to parse function
[ 0.091903] rockchip-pinctrl: probe of pinctrl failed with error -22
[ 0.100853] cryptd: max_cpu_qlen set to 1000
[ 0.102766] vcc_sys: supplied by dc_12v
[ 0.104099] rk_iommu ff650800.iommu: version = 1
[ 0.104921] rk_iommu ff660480.iommu: version = 1
[ 0.105603] rk_iommu ff670800.iommu: version = 1
[ 0.106323] rk_iommu ff8f3f00.iommu: version = 1
[ 0.106957] rk_iommu ff903f00.iommu: version = 1
[ 0.107597] rk_iommu ff914000.iommu: version = 1
[ 0.108270] rk_iommu ff924000.iommu: version = 1
[ 0.109231] SCSI subsystem initialized
[ 0.109899] usbcore: registered new interface driver usbfs
[ 0.110449] usbcore: registered new interface driver hub
[ 0.111039] usbcore: registered new device driver usb
[ 0.111788] pps_core: LinuxPPS API ver. 1 registered
[ 0.112276] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.113155] PTP clock support registered
[ 0.116012] rockchip-cpuinfo cpuinfo: SoC : 0
[ 0.116447] rockchip-cpuinfo cpuinfo: Serial : 7d9418e5de243167
[ 0.117459] clocksource: Switched to clocksource arch_sys_counter
[ 0.160794] VFS: Disk quotas dquot_6.6.0
[ 0.161221] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.163056] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.164053] NET: Registered protocol family 2
[ 0.164890] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[ 0.165690] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.166519] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.167392] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.168147] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.168787] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.169573] NET: Registered protocol family 1
[ 0.171602] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.172684] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.174866] Initialise system trusted keyrings
[ 0.175439] workingset: timestamp_bits=45 max_order=19 bucket_order=0
[ 0.179796] Registering sdcardfs 0.1
[ 0.181033] fuse init (API version 7.27)
[ 0.182480]
[ 0.182480] TEE Core Framework initialization (ver 1:0.1)
[ 0.183165] TEE armv7 Driver initialization
[ 0.183905] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[ 0.184553] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[ 0.185281] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=63)
[ 0.187051] Key type asymmetric registered
[ 0.187457] Asymmetric key parser 'x509' registered
[ 0.187948] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.188663] io scheduler noop registered
[ 0.189135] io scheduler cfq registered (default)
[ 0.189600] io scheduler mq-deadline registered
[ 0.190034] io scheduler kyber registered
[ 0.190500] io scheduler bfq registered
[ 0.192423] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.195296] iommu: Adding device ff670000.iep to group 2
[ 0.195837] iep ff670000.iep: Linked as a consumer to ff670800.iommu
[ 0.196606] iep: failed to find iep power down clock source.
[ 0.199668] iep: IEP Power ON
[ 0.199983] iep: IEP Power OFF
[ 0.200335] iep: IEP Driver loaded succesfully
[ 0.200924] iep: Module initialized.
[ 0.201397] mpp_service mpp-srv: probe start
[ 0.202170] iommu: Adding device ff660000.rkvdec to group 1
[ 0.202734] mpp_rkvdec ff660000.rkvdec: Linked as a consumer to ff660480.iommu
[ 0.203599] mpp_rkvdec ff660000.rkvdec: probing start
[ 0.207712] rkvdec_init:1178: failed on clk_get clk_hevc_cabac
[ 0.208314] mpp_rkvdec ff660000.rkvdec: shared_video_hevc_cabac is not found!
[ 0.209009] rkvdec_init:1206: No hevc cabac reset resource define
[ 0.209845] mpp_rkvdec ff660000.rkvdec: probing finish
[ 0.211147] iommu: Adding device ff650400.vdpu to group 0
[ 0.211692] mpp_vdpu2 ff650400.vdpu: Linked as a consumer to ff650800.iommu
[ 0.212534] mpp_vdpu2 ff650400.vdpu: probe device
[ 0.213349] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 0.213926] mpp_vdpu2 ff650400.vdpu: reset_group->rw_sem_on=0
[ 0.214684] mpp_vdpu2 ff650400.vdpu: probing finish
[ 0.215537] iommu: Adding device ff650000.vepu to group 0
[ 0.216067] mpp_vepu2 ff650000.vepu: Linked as a consumer to ff650800.iommu
[ 0.216770] mpp_vepu2 ff650000.vepu: probe device
[ 0.217561] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 0.218116] mpp_vepu2 ff650000.vepu: reset_group->rw_sem_on=0
[ 0.218883] mpp_vepu2 ff650000.vepu: probing finish
[ 0.219558] mpp_service mpp-srv: probe success
[ 0.222293] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.223035] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.224991] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.225734] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.227642] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.228637] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.229466] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.233075] iommu: Adding device ff8f0000.vop to group 3
[ 0.233620] rockchip-vop ff8f0000.vop: Linked as a consumer to ff8f3f00.iommu
[ 0.234668] iommu: Adding device ff900000.vop to group 4
[ 0.235191] rockchip-vop ff900000.vop: Linked as a consumer to ff903f00.iommu
[ 0.237492] random: fast init done
[ 0.238109] random: crng init done
[ 0.238436] rockchip-drm display-subsystem: Linked as a consumer to ff8f0000.vop
[ 0.238468] rockchip-drm display-subsystem: Linked as a consumer to ff900000.vop
[ 0.240690] rockchip-drm display-subsystem: Linked as a consumer to ff940000.hdmi
[ 0.245354] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.251671] brd: module loaded
[ 0.264643] loop: module loaded
[ 0.265263] zram: Added device: zram0
[ 0.265866] SCSI Media Changer driver v0.25
[ 0.268604] register firefly_spi_init spi return v = :0
[ 0.269857] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.271210] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.273076] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.273716] ehci-pci: EHCI PCI platform driver
[ 0.274183] ehci-platform: EHCI generic platform driver
[ 0.275136] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.275754] ohci-platform: OHCI generic platform driver
[ 0.277038] usbcore: registered new interface driver cdc_acm
[ 0.277593] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.278393] usbcore: registered new interface driver usblp
[ 0.278953] usbcore: registered new interface driver cdc_wdm
[ 0.279534] usbcore: registered new interface driver uas
[ 0.280066] usbcore: registered new interface driver usb-storage
[ 0.280669] usbcore: registered new interface driver ums-alauda
[ 0.281252] usbcore: registered new interface driver ums-cypress
[ 0.281860] usbcore: registered new interface driver ums-datafab
[ 0.282461] usbcore: registered new interface driver ums_eneub6250
[ 0.283071] usbcore: registered new interface driver ums-freecom
[ 0.283674] usbcore: registered new interface driver ums-isd200
[ 0.284257] usbcore: registered new interface driver ums-jumpshot
[ 0.284870] usbcore: registered new interface driver ums-karma
[ 0.285456] usbcore: registered new interface driver ums-onetouch
[ 0.286059] usbcore: registered new interface driver ums-sddr09
[ 0.286653] usbcore: registered new interface driver ums-sddr55
[ 0.287233] usbcore: registered new interface driver ums-usbat
[ 0.287852] usbcore: registered new interface driver usbserial_generic
[ 0.288499] usbserial: USB Serial support registered for generic
[ 0.289089] usbcore: registered new interface driver option
[ 0.289642] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.290328] usbcore: registered new interface driver trancevibrator
[ 0.290978] sensor_register_slave:kxtj9,id=11
[ 0.291398] sensor_register_slave:mma8452,id=17
[ 0.291842] sensor_register_slave:lis3dh,id=7
[ 0.292261] sensor_register_slave:mma7660,id=18
[ 0.292703] sensor_register_slave:gs_mxc6655xa,id=24
[ 0.293178] sensor_register_slave:lsm303d,id=26
[ 0.293620] sensor_register_slave:gs_mc3230,id=27
[ 0.294069] [Gsensor] gsensor_init
[ 0.294412] sensor_register_slave:mpu6880_acc,id=28
[ 0.294886] sensor_register_slave:mpu6500_acc,id=29
[ 0.295355] sensor_register_slave:lsm330_acc,id=30
[ 0.295821] sensor_register_slave:bma2xx_acc,id=31
[ 0.296279] sensor_register_slave:akm8975,id=35
[ 0.296720] sensor_register_slave:akm8963,id=36
[ 0.297153] sensor_register_slave:l3g4200d,id=50
[ 0.297603] sensor_register_slave:l3g20d,id=51
[ 0.298028] sensor_register_slave:ewtsa,id=52
[ 0.298454] sensor_register_slave:lsm330_gyro,id=56
[ 0.298921] sensor_register_slave:cm3217,id=58
[ 0.299347] sensor_register_slave:cm3218,id=59
[ 0.299780] sensor_register_slave:ls_stk3410,id=67
[ 0.300239] sensor_register_slave:ps_stk3410,id=72
[ 0.301349] i2c /dev entries driver
[ 0.303086] __power_supply_register: Expected proper parent device for 'test_ac'
[ 0.303929] __power_supply_register: Expected proper parent device for 'test_battery'
[ 0.304874] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.305661] __power_supply_register: Expected proper parent device for 'test_usb'
[ 0.307158] device-mapper: uevent: version 1.0.3
[ 0.307857] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 0.308839] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 0.309833] cpu cpu0: bin=1
[ 0.310124] cpu cpu0: leakage=28
[ 0.310465] cpu cpu0: Failed to get reg
[ 0.310842] cpu cpu0: bin-scale=34
[ 0.311205] cpu cpu4: bin=1
[ 0.311503] cpu cpu4: leakage=50
[ 0.311827] cpu cpu4: Failed to get reg
[ 0.312202] cpu cpu4: bin-scale=17
[ 0.313603] sdhci: Secure Digital Host Controller Interface driver
[ 0.314193] sdhci: Copyright(c) Pierre Ossman
[ 0.314677] Synopsys Designware Multimedia Card Interface Driver
[ 0.315642] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.342905] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.344405] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.347495] usbcore: registered new interface driver usbhid
[ 0.348079] usbhid: USB HID core driver
[ 0.348959] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.351704] rockchip-saradc ff100000.saradc: Linked as a consumer to regulator.6
[ 0.353510] optee: probing for conduit method from DT.
[ 0.354020] optee: revision 1.1
[ 0.354515] optee: initialized driver
[ 0.355169] rknandbase v1.2 2018-05-08
[ 0.355850] netem: version 1.3
[ 0.356148] u32 classifier
[ 0.356410] Actions configured
[ 0.357390] xt_time: kernel timezone is -0000
[ 0.357927] gre: GRE over IPv4 demultiplexor driver
[ 0.358394] IPv4 over IPsec tunneling driver
[ 0.359483] Initializing XFRM netlink socket
[ 0.359913] IPsec XFRM device driver
[ 0.360585] NET: Registered protocol family 10
[ 0.361848] Segment Routing with IPv6
[ 0.362274] mip6: Mobile IPv6
[ 0.363201] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 0.364444] NET: Registered protocol family 17
[ 0.364904] NET: Registered protocol family 15
[ 0.365371] Bridge firewalling registered
[ 0.365853] l2tp_core: L2TP core driver, V2.0
[ 0.366601] sensor_register_slave:mpu6500_gyro,id=54
[ 0.367079] sensor_register_slave:mpu6880_gyro,id=55
[ 0.369085] registered taskstats version 1
[ 0.369495] Loading compiled-in X.509 certificates
[ 0.370346] Key type ._fscrypt registered
[ 0.370779] Key type .fscrypt registered
[ 0.371158] Key type fscrypt-provisioning registered
[ 0.371892] pstore: Using compression: deflate
[ 0.372703] rga2: Module initialized.
[ 0.381812] mmc0: new HS400 MMC card at address 0001
[ 0.383537] mmcblk0: mmc0:0001 MMC8GB 7.28 GiB
[ 0.384669] mmcblk0boot0: mmc0:0001 MMC8GB partition 1 4.00 MiB
[ 0.385934] mmcblk0boot1: mmc0:0001 MMC8GB partition 2 4.00 MiB
[ 0.386825] mmcblk0rpmb: mmc0:0001 MMC8GB partition 3 4.00 MiB, chardev (241:0)
[ 0.392897] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 0.401970] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.403651] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.404961] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.406663] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.410234] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.411115] reg-fixed-voltage vdd3v3-pcie-regulator: ignoring dependency for device, assuming no driver
[ 0.412194] reg-fixed-voltage vcc-sd: ignoring dependency for device, assuming no driver
[ 0.413139] reg-fixed-voltage vcc-wifi-regulator: ignoring dependency for device, assuming no driver
[ 0.414185] reg-fixed-voltage fan-ctl-regulator: ignoring dependency for device, assuming no driver
[ 0.415694] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.416750] rockchip-pwm ff420000.pwm: ignoring dependency for device, assuming no driver
[ 0.417786] rockchip-pwm ff420020.pwm: ignoring dependency for device, assuming no driver
[ 0.418929] pwm-regulator vdd-log: Failed to get PWM: -517
[ 0.419666] dw-apb-uart ff180000.serial: ignoring dependency for device, assuming no driver
[ 0.420698] dwhdmi-rockchip ff940000.hdmi: ignoring dependency for device, assuming no driver
[ 0.421890] dwc3 fe800000.dwc3: Failed to get clk 'ref': -2
[ 0.422947] dwc3 fe900000.dwc3: Failed to get clk 'ref': -2
[ 0.424883] rk3x-i2c ff3c0000.i2c: ignoring dependency for device, assuming no driver
[ 0.426300] rockchip-thermal ff260000.tsadc: ignoring dependency for device, assuming no driver
[ 0.427501] pwrseq_simple sdio-pwrseq: ignoring dependency for device, assuming no driver
[ 0.428624] dwmmc_rockchip fe320000.dwmmc: ignoring dependency for device, assuming no driver
[ 0.430049] rockchip-dmc dmc: Cannot get the regulator "center"
[ 0.430716] reg-fixed-voltage vcc5v0-host-regulator: ignoring dependency for device, assuming no driver
[ 0.432353] Freeing initrd memory: 7948K
[ 0.432976] hctosys: unable to open rtc device (rtc0)
麻烦各位大佬指点一下,看看问题出在哪里????非常感谢!!!
找个正常机器的日志对比一下。
我的也最近在调android11 也是有些莫名其妙内核跑飞了 其中有些是电源控制的gpio没改对。
你有碰的哪些问题 后来跑通了吗
好像rk芯片的启动好复杂的样子,不是安卓的缘故把。
某鱼两百来块 买了个拆机板(感觉不是很划算,前面这个板子他卖150,后面加到200,咱也没讲价,电源适配也没有),感觉rk没有v3s这些这么简单啊。。。
