直接上代码:
/* @file adxl357.c */
/* @version V1.00 */
/* $author: yuanxihua@21cn.com */
/* $Date: 2022/01/13 02:54 $ */
/* @brief SWM181CBT6 Series ADXL357 Driver Sample Code */
/* @note */
/* Copyright (C) 2010-2022 PM9GZY Technology Corp. All rights reserved. */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "adxl537.h"
________________________________________________
| SWM181CBT6 ADXL357 |
| PA12 NSS0 ----> CS/SCL |
| PA13 MISO0 <---- MISO |
| PA14 MOSI0 ----> MOSI |
| PA15 SCLK0 ----> SCLK |
|_______________________________________________|
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ADXL357_CS_L() GPIO_ClrBit(GPIOA, PIN12)
#define ADXL357_CS_H() GPIO_SetBit(GPIOA, PIN12)
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void ADXL357_Initial(void);
void ADXL357_Reset(void);
/* Private functions ---------------------------------------------------------*/
void SPI0Init(void)
SPI_InitStructure SPI_initStruct;
GPIO_Init(GPIOA, PIN12, 1, 0, 0, 0);ADXL357_CS_H(); //GPIOC.4 -> IOSPI.SSEL
// PORT_Init(PORTA, PIN12, PORTA_PIN12_SPI0_SSEL, 0);
PORT_Init(PORTA, PIN13, PORTA_PIN13_SPI0_MISO, 1);
PORT_Init(PORTA, PIN14, PORTA_PIN14_SPI0_MOSI, 0);
PORT_Init(PORTA, PIN15, PORTA_PIN15_SPI0_SCLK, 0);
SPI_initStruct.clkDiv = SPI_CLKDIV_4; //80NS , 12500KHZ
SPI_initStruct.FrameFormat = SPI_FORMAT_SPI;
SPI_initStruct.SampleEdge = SPI_SECOND_EDGE;
SPI_initStruct.IdleLevel = SPI_HIGH_LEVEL;
SPI_initStruct.WordSize = 8;
SPI_initStruct.Master = 1;
SPI_initStruct.RXHFullIEn = 0;
SPI_initStruct.TXEmptyIEn = 0;
SPI_initStruct.TXCompleteIEn = 0;
SPI_Init(SPI0, &SPI_initStruct);
SPI_Open(SPI0);
ADXL357_Reset();
ADXL357_Initial();
uint8_t ADXL357_Read(uint8_t addr,uint8_t *data,uint32_t len)
uint8_t cmd=(addr<<1)|0x01; // D0=R/W=1,读取模式
ADXL357_CS_L();
SPI_ReadWrite(SPI0,cmd);while(len--){*data++ =SPI_ReadWrite(SPI0,0x55)&0xff;}
ADXL357_CS_H();
uint8_t ADXL357_Write(uint8_t addr,uint8_t *data,uint32_t len)
uint8_t cmd=(addr<<1)&0xFE; // D0=R/W=0,写入模式
ADXL357_CS_L();
SPI_ReadWrite(SPI0,cmd);while(len--){SPI_ReadWrite(SPI0,*data++);}
ADXL357_CS_H();
uint8_t ADXL357_Read_Register(uint8_t addr){uint8_t val;ADXL357_Read(addr,&val,1);return val;}
void ADXL357_Write_Register(uint8_t addr,uint8_t data){ADXL357_Write(addr,&data,1);}
void ADXL357_Reset(void){ADXL357_Write_Register(ADXL357_Reset_REG,0x52);delay_ms(10);}
void ADXL357_Initial(void){}
float ADXL357_Read_TemperatureRead(void)
uint8_t tmp[2];ADXL357_Read(ADXL357_TEMP2,tmp,2);uint16_t tempH=tmp[0]&0x0F,tempL=tmp[1];
float Temperature = ((float)(tempH<<8)) + ((float)tempL);
return (25-((Temperature-1885)/9.05));
void ADXL357_Test(void)
uint8_t data[47];ADXL357_Read(ADXL357_DEVID_AD,data,sizeof(data));printf("\n\r");for(uint8_t i=0;i<sizeof(data);i++){printf("0x%02x ",data[i]);}printf("\n\r");
printf("ADXL357_DEVID_AD = 0x%02x \n\r",ADXL357_Read_Register(ADXL357_DEVID_AD));
printf("ADXL357_DEVID_MST = 0x%02x \n\r",ADXL357_Read_Register(ADXL357_DEVID_MST));
printf("ADXL357_PARTID = 0x%02x \n\r",ADXL357_Read_Register(ADXL357_PARTID));
printf("ADXL357_REVID = 0x%02x \n\r",ADXL357_Read_Register(ADXL357_REVID));
printf("ADXL357_Temperature = %f \n\r",ADXL357_Read_TemperatureRead());
//代码完毕
