楼主 # 2022-03-17 16:40:27
chenzhongjie
荔枝派zero v3s GPIO sysfs interface问题
板子使用lichee zero v3s
内核使用zero-4.13.y
使用root用户登录
当我使用导出gpio 6 时,无问题
echo 6 > /sys/class/gpio/export
ls /sys/class/gpio/
export gpio6 gpiochip0 unexport
当我使用导出gpio 193 时,提示busy(193为PG2,是LED灯)
echo 193 > /sys/class/gpio/export
sh: write error: Device or resource busy
求助~~
#1 2022-03-17 17:10:16
dtsayhi
已发帖子: 27
Re: 荔枝派zero v3s GPIO sysfs interface问题
GPIOIO被占用了 检查设备树
楼主 #2 2022-03-17 17:26:39
chenzhongjie
dtsayhi wrote:
GPIOIO被占用了 检查设备树
好的 该引脚是配置给了LED 开始不知道两个不能同时使用, 感谢
	leds {
		compatible = "gpio-leds";
		blue_led {
			label = "licheepi:blue:usr";
			gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
			default-state = "on";
		green_led {
			label = "licheepi:green:usr";
			gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
			//default-state = "on";
		red_led {
			label = "licheepi:red:usr";
			gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
