楼主 # 2022-04-21 14:52:52
哔哔肆
Tiny200 Uboot下载后有问题现在有什么排查方法么
U-Boot 2018.01 (Apr 20 2022 - 18:19:45 -0700) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SPI-NAND: GD5F1GQ5UEYIG is found.
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
SPI-NAND: 1310720 bytes @ 0x0 Updated: OK
SPI-NAND: 2490368 bytes @ 0x80000 Read: OK
Unknown command 'sf' - try 'help'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
=> reset
resetting ...
U-Boot SPL 2018.01 (Apr 20 2022 - 18:14:04)
DRAM: 64 MiB
Trying to boot from sunxi SPI
#1 2022-04-21 15:06:59
baidxi
Re: Tiny200 Uboot下载后有问题现在有什么排查方法么
@哔哔肆
没有编译spi flash相关的命令进去。找不到sf命令
楼主 #2 2022-04-21 17:09:07
哔哔肆
baidxi wrote:
@哔哔肆
没有找到什么办法编译进去:(
