非常奇怪的现象
T113-S3 SDC0 接EMMC
SDC2 接 XR829
在board.dts中一旦使能 (okay)SDC2,内核就无法启动了,disabled可以正常启动
启动的时候SDIO CLK引脚会有一个短暂的时钟信号,CMD引脚也有短暂的时钟信号,然后内核就挂了
M/TC: OP-TEE version: 53fe17e2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3
-2016.05)) #6 Fri Feb 18 08:54:51 UTC 2022 arm
** 60 printk messages dropped **
[ 0.006685] 001: devtmpfs: initialized
** 2 printk messages dropped **
[ 0.025421] 000: futex hash table entries: 512 (order: 3, 32768 bytes, linear
[ 0.026213] 000: pinctrl core: initialized pinctrl subsystem
[ 0.028186] 000: NET: Registered protocol family 16
[ 0.032121] 000: DMA: preallocated 256 KiB pool for atomic coherent allocatio
ns
** 9 printk messages dropped **
[ 0.142015] 000: videodev: Linux video capture interface: v2.00
** 16 printk messages dropped **
[ 0.188719] 000: sunxi_spi_resource_get()2177 - [spi1] SPI MASTER MODE
[ 0.243086] 000: [DISP]disp_module_init finish
** 1 printk message dropped **
[ 0.245782] 000: sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dum
my regulator
[ 0.246181] 000: uart uart1: get regulator failed
[ 0.246202] 000: uart uart1: uart1 supply uart not found, using dummy regulat
or
[ 0.246742] 000: uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 150000
0) is a SUNXI
[ 0.252255] 000: uart uart5: get regulator failed
[ 0.252837] 000: uart5: ttyS5 at MMIO 0x2501400 (irq = 38, base_baud = 150000
0) is a SUNXI
[ 0.252865] 000: sw_console_setup()1808 - console setup baud 115200 parity n
bits 8, flow n
[ 0.252931] 000: printk: console [ttyS5] enabled
[ 0.254287] 000: misc dump reg init
[ 0.258222] 001: libphy: Fixed MDIO Bus: probed
** 5 printk messages dropped **
[ 0.259262] 001: usbcore: registered new interface driver cdc_ncm
[ 0我觉得是DTS文件有关SDC2的部分配置有问题,但是找不出问题在哪里
* Allwinner Technology CO., Ltd.
/dts-v1/;
/* optee used 7MB: SHM 2M: OS: 1M: TA:4M*/
/memreserve/ 0x41900000 0x00100000;
/* DSP used 1MB */
/* /memreserve/ 0x42000000 0x00100000; */
#include "sun8iw20p1.dtsi"
model = "sun8iw20";
compatible = "allwinner,r528", "arm,sun8iw20p1";
reg_vdd_cpu: vdd-cpu {
compatible = "pwm-regulator";
pwms = <&pwm 3 5000 0>;
regulator-name = "vdd_cpu";
regulator-min-microvolt = <810000>;
regulator-max-microvolt = <1160000>;
regulator-settling-time-us = <4000>;
regulator-always-on;
regulator-boot-on;
reg_usb1_vbus: usb1-vbus {
regulator-name = "usb1-vbus";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-enable-ramp-delay = <1000>;
gpio = <&pio PD 19 GPIO_ACTIVE_HIGH>;
enable-active-high;
can0: can@0x0 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "allwinner,sun8i-can";
pinctrl-0 = <&can0_pins_a>;
pinctrl-1 = <&can0_pins_b>;
device_type = "can0";
id = <0>;
can1: can@0x1 {
#size-cells = <0>;
pinctrl-0 = <&can1_pins_a>;
pinctrl-1 = <&can1_pins_b>;
device_type = "can1";
id = <1>;
&cpu0 {
cpu-supply = <®_vdd_cpu>;
&pio {
sdc0_pins_a: sdc0@0 {
allwinner,pins = "PF0", "PF1", "PF2",
"PF3", "PF4", "PF5";
allwinner,function = "sdc0";
allwinner,muxsel = <2>;
allwinner,drive = <3>;
allwinner,pull = <1>;
function = "sdc0";
drive-strength = <30>;
bias-pull-up;
power-source = <3300>;
sdc0_pins_b: sdc0@1 {
function = "sdc0";
bias-pull-up;
power-source = <1800>;
sdc0_pins_c: sdc0@2 {
function = "gpio_in";
/* TODO: add jtag pin */
sdc0_pins_d: sdc0@3 {
pins = "PF2", "PF4";
function = "uart0";
drive-strength = <10>;
bias-pull-up;
sdc0_pins_e: sdc0@4 {
pins = "PF0", "PF1", "PF3",
"PF5";
function = "jtag";
bias-pull-up;
sdc1_pins_a: sdc1@0 {
pins = "PG0", "PG1", "PG2",
"PG3", "PG4", "PG5";
function = "sdc1";
bias-pull-up;
sdc1_pins_b: sdc1@1 {
function = "sdc1";
sdc2_pins_a: sdc2@0 {
allwinner,pins = "PC2", "PC3", "PC4",
"PC5", "PC6", "PC7";
allwinner,function = "sdc2";
allwinner,muxsel = <3>;
function = "sdc2";
bias-pull-up;
sdc2_pins_b: sdc2@1 {
wlan_pins_a:wlan@0 {
pins = "PG11";
function = "clk_fanout1";
lvds0_pins_a: lvds0@0 {
allwinner,pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
allwinner,pname = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
allwinner,function = "lvds0";
allwinner,pull = <0>;
lvds0_pins_b: lvds0@1 {
allwinner,function = "io_disabled";
allwinner,muxsel = <7>;
uart0_pins_a: uart0_pins@0 { /* For EVB1 board */
function = "uart0";
bias-pull-up;
uart0_pins_b: uart0_pins@1 { /* For EVB1 board */
uart1_pins_a: uart1_pins@0 { /* For EVB1 board */
pins = "PG6", "PG7", "PG8", "PG9";
function = "uart1";
bias-pull-up;
uart1_pins_b: uart1_pins { /* For EVB1 board */
uart2_pins_a: uart2_pins@0 { /* For EVB1 board */
pins = "PD1", "PD2", "PD3", "PD4";
function = "uart2";
bias-pull-up;
uart2_pins_b: uart2_pins@1 { /* For EVB1 board */
uart3_pins_a: uart3_pins@0 { /* For t113_evb */
pins = "PG0", "PG1", "PG2", "PG3";
function = "uart3";
bias-pull-up;
uart3_pins_b: uart3_pins@1 { /* For t113_evb */
uart4_pins_a: uart4_pins@0 { /* For t113_evb */
pins = "PD7", "PD8";
function = "uart4";
bias-pull-up;
uart4_pins_b: uart4_pins@1 { /* For t113_evb */
uart5_pins_a: uart5_pins@0 { /* For t113_evb */
pins = "PD5", "PD6";
function = "uart5";
bias-pull-up;
uart5_pins_b: uart5_pins@1 { /* For t113_evb */
twi0_pins_a: twi0@0 {
pins = "PB2", "PB3";
function = "twi0";
twi0_pins_b: twi0@1 {
twi1_pins_a: twi1@0 {
pins = "PE14", "PE15";
function = "twi1";
twi1_pins_b: twi1@1 {
twi2_pins_a: twi2@0 {
pins = "PG14", "PG15";
function = "twi2";
twi2_pins_b: twi2@1 {
twi3_pins_a: twi3@0 {
/* pins = "PE16", "PE17"; */
/* pins = "PG10", "PG11"; */
pins = "PB6", "PB7";
function = "twi3";
twi3_pins_b: twi3@1 {
s_cir0_pins_a: s_cir0@0 {
pins = "PB1";
function = "ir";
bias-pull-up;
s_cir0_pins_b: s_cir0@1 {
pins = "PB1";
ir1_pins_a: ir1@0 {
pins = "PB0";
function = "ir";
bias-pull-up;
ir1_pins_b: ir1@1 {
pins = "PB0";
dmic_pins_a: dmic@0 {
/* DMIC_PIN: CLK, DATA0, DATA1, DATA2, DATA3*/
pins = "PB12", "PB11", "PB10", "PE14", "PB8";
function = "dmic";
drive-strength = <20>;
bias-disable;
dmic_pins_b: dmic@1 {
bias-disable;
daudio0_pins_a: daudio0@0 {
pins = "PB29", "PB23", "PB24",
"PB25", "PB26", "PB27", "PB28",
"PB22";
function = "i2s0";
bias-disable;
daudio0_pins_b: daudio0_sleep@0 {
"PB22";
bias-disable;
daudio1_pins_a: daudio1@0 {
/* MCLK, LRCK, BCLK */
pins = "PG12", "PG13";
function = "i2s1";
bias-disable;
daudio1_pins_b: daudio1@1 {
/* DIN0 */
pins = "PG14";
function = "i2s1_din";
bias-disable;
daudio1_pins_c: daudio1@2 {
/* DOUT0 */
pins = "PG15";
function = "i2s1_dout";
bias-disable;
daudio1_pins_d: daudio1_sleep@0 {
pins = "PG12", "PG13", "PG14", "PG15";
bias-disable;
daudio2_pins_a: daudio2@0 {
/* I2S_PIN: MCLK, BCLK, LRCK */
pins = "PB7", "PB6", "PB5";
function = "i2s2";
bias-disable;
daudio2_pins_b: daudio2@1 {
/* I2S_PIN: DIN0 */
pins = "PB3";
function = "i2s2_din";
bias-disable;
daudio2_pins_c: daudio2@2 {
/* I2S_PIN: DOUT0 */
pins = "PB4";
function = "i2s2_dout";
bias-disable;
daudio2_pins_d: daudio2_sleep@0 {
pins = "PB7", "PB6", "PB5", "PB4", "PB3";
bias-disable;
spdif_pins_a: spdif@0 {
/* SPDIF_PIN: SPDIF_OUT */
pins = "PG18";
function = "spdif";
bias-disable;
spdif_pins_b: spdif_sleep@0 {
pins = "PG18";
bias-disable;
gmac0_pins_a: gmac@0 {
allwinner,pins = "PE0", "PE1", "PE2", "PE3", "PE4",
"PE5", "PE6", "PE7","PE8", "PE9", "PE10";
allwinner,function = "gmac0";
allwinner,muxsel = <8>;
allwinner,drive = <1>;
gmac0_pins_b: gmac@1 {
allwinner,function = "gpio_in";
allwinner,muxsel = <0>;
spi0_pins_a: spi0@0 {
pins = "PC2", "PC4", "PC5","PC7", "PC6";
function = "spi0";
spi0_pins_b: spi0@1 {
pins = "PC3";
function = "spi0";
bias-pull-up;
spi0_pins_c: spi0@2 {
pins = "PC2", "PC3", "PC4", "PC5","PC6", "PC7";
spi1_pins_a: spi1@0 {
pins = "PD11", "PD12", "PD13";
function = "spi1";
spi1_pins_b: spi1@1 {
pins = "PD10";
function = "spi1";
bias-pull-up; // only CS should be pulled up
spi1_pins_c: spi1@2 {
allwinner,pins = /*"PD10",*/ "PD11", "PD12", "PD13";
pwm3_pin_a: pwm3@0 {
pins = "PB0";
function = "pwm3";
bias-pull-up;
pwm3_pin_b: pwm3@1 {
pins = "PB0";
pwm7_pin_a: pwm7@0 {
pins = "PD22";
function = "pwm7";
bias-pull-up;
pwm7_pin_b: pwm7@1 {
pins = "PD22";
can0_pins_a: can0@0 {
function = "can0";
can0_pins_b: can0@1 {
can1_pins_a: can1@0 {
pins = "PB4", "PB5";
function = "can1";
can1_pins_b: can1@1 {
ledc_pins_a: ledc@0 {
pins = "PG13";
function = "ledc";
ledc_pins_b: ledc@1 {
pins = "PG13";
rgb24_pins_a: rgb24@0 {
allwinner,pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
"PD18", "PD19", "PD20", "PD21";
allwinner,pname = "lcdd0", "lcdd1", "lcdd2", "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7", \
"lcdd8", "lcdd9", "lcdd10", "lcdd11", "lcdd12", "lcdd13", "lcdd14", "lcdd15", \
"lcdd16", "lcdd17", "lcdd18", "lcdd19", "lcdd20", "lcdd21", "lcdd22", "lcdd23", \
"lcdclk", "lcdde", "lcdhsync", "lcdvsync";
allwinner,function = "lcd0";
rgb24_pins_b: rgb24@1 {
dsi4lane_pins_a: dsi4lane@0 {
allwinner,function = "dsi4lane";
allwinner,muxsel = <4>;
dsi4lane_pins_b: dsi4lane@1 {
allwinner,function = "dsi4lane_suspend";
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
pinctrl-1 = <&uart0_pins_b>;
status = "disabled";
&uart1 {
pinctrl-0 = <&uart1_pins_a>;
pinctrl-1 = <&uart1_pins_b>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
pinctrl-1 = <&uart2_pins_b>;
&uart3 {
pinctrl-0 = <&uart3_pins_a>;
pinctrl-1 = <&uart3_pins_b>;
&uart4 {
pinctrl-0 = <&uart4_pins_a>;
pinctrl-1 = <&uart4_pins_b>;
&uart5 {
pinctrl-0 = <&uart5_pins_a>;
pinctrl-1 = <&uart5_pins_b>;
&sdc2 {
non-removable;
bus-width = <4>;
mmc-hs200-3_3v;
/* mmc-ddr-1_8v; mmc-hs200-3_3v; */
/* no-sdio; */
no-mmc;
no-sd;
ctl-spec-caps = <0x8>;
/* cap-mmc-highspeed; */
/* sunxi-power-save-mode;*/
keep-power-in-suspend;
ignore-pm-notify;
/* sunxi-dis-signal-vol-sw;*/
/* mmc-bootpart-noacc; */
max-frequency = <50000000>;
/*vmmc-supply = <®_dcdc1>;*/
/*emmc io vol 3.3v*/
/*vqmmc-supply = <®_aldo1>;*/
/*emmc io vol 1.8v*/
/*vqmmc-supply = <®_eldo1>;*/
&sdc0 {
bus-width = <4>;
/*cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;*/
non-removable;
broken-cd;
/*cd-inverted*/
/*data3-detect;*/
/*card-pwr-gpios = <&pio PH 14 1 1 2 0xffffffff>;*/
/*cd-used-24M;*/
cap-mmc-highspeed;
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
no-sdio;
no-sd;
mmc-bootpart-noacc;
ctl-spec-caps = <0x308>;
sdc_tm4_sm0_freq0 = <0>;
sdc_tm4_sm0_freq1 = <0>;
sdc_tm4_sm1_freq0 = <0x00000000>;
sdc_tm4_sm1_freq1 = <0>;
sdc_tm4_sm2_freq0 = <0x00000000>;
sdc_tm4_sm2_freq1 = <0>;
sdc_tm4_sm3_freq0 = <0x05000000>;
sdc_tm4_sm3_freq1 = <0x00000005>;
sdc_tm4_sm4_freq0 = <0x00050000>;
sdc_tm4_sm4_freq1 = <0x00000004>;
sdc_tm4_sm4_freq0_cmd = <0>;
sdc_tm4_sm4_freq1_cmd = <0>;
/delete-property/ cap-sd-highspeed;
/delete-property/ cap-wait-while-busy;
/delete-property/ no-mmc;
/*vqmmc33sw-supply = <®_dcdc1>;*/
/*vdmmc33sw-supply = <®_dcdc1>;*/
/*vqmmc18sw-supply = <®_eldo1>;*/
/*vdmmc18sw-supply = <®_eldo1>;*/
&sdc1 {
bus-width = <4>;
no-mmc;
no-sd;
cap-sd-highspeed;
/*sd-uhs-sdr12*/
/*sd-uhs-sdr25;*/
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
/*sunxi-power-save-mode;*/
/*sunxi-dis-signal-vol-sw;*/
cap-sdio-irq;
ignore-pm-notify;
max-frequency = <150000000>;
&twi0 {
clock-frequency = <400000>;
pinctrl-0 = <&twi0_pins_a>;
pinctrl-1 = <&twi0_pins_b>;
twi_drv_used = <0>;
dmas = <&dma 43>, <&dma 43>;
dma-names = "tx", "rx";
ctp@14 {
compatible = "allwinner,goodix";
device_type = "ctp";
reg = <0x14>;
ctp_name = "gt9xxnew_ts";
ctp_twi_id = <0x2>;
ctp_twi_addr = <0x14>;
ctp_screen_max_x = <0x320>;
ctp_screen_max_y = <0x1e0>;
ctp_revert_x_flag = <0x0>;
ctp_revert_y_flag = <0x0>;
ctp_exchange_x_y_flag = <0x0>;
ctp_int_port = <&pio PB 6 GPIO_ACTIVE_HIGH>;
ctp_wakeup = <&pio PB 7 GPIO_ACTIVE_HIGH>;
/*ctp-supply = <®_aldo2>;*/
/*ctp_power_ldo = <®_aldo2>;*/
/*ctp_power_ldo_vol = <3300>;*/
&twi1 {
pinctrl-0 = <&twi1_pins_a>;
pinctrl-1 = <&twi1_pins_b>;
&twi2 {
pinctrl-0 = <&twi2_pins_a>;
pinctrl-1 = <&twi2_pins_b>;
twi_drv_used = <1>;
dmas = <&dma 45>, <&dma 45>;
rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
&twi3 {
pinctrl-0 = <&twi3_pins_a>;
pinctrl-1 = <&twi3_pins_b>;
ac108: ac108@3B {
#sound-dai-cells = <0>;
compatible = "Allwinner,MicArray_0";
device_type = "MicArray_0";
reg = <0x3B>;
regulator_used = <0x0>;
power_voltage = <3300000>;
regulator_name = "vcc-3v3";
power_gpio_used = <0x0>;
reset_gpio_used = <0x0>;
twi_bus = <0x1>;
pga_gain = <0x1F>;
slot_width = <0x20>;
lrck_period = <0x80>;
ref_pga_used = <0x1>;
ref_pga_gain = <0x10>;
ref_channel = <0x3>;
debug_mode = <0x0>;
&spi0 {
clock-frequency = <10000000>;
pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
pinctrl-1 = <&spi0_pins_c>;
spi_slave_mode = <0>;
spi0_cs_number = <1>;
spi0_cs_bitmap = <1>;
&spi1 {
clock-frequency = <100000000>;
pinctrl-0 = <&spi1_pins_a /*&spi1_pins_b*/>;
pinctrl-1 = <&spi1_pins_c>;
spi1_cs_number = <1>;
spi1_cs_bitmap = <1>;
spi_board1@0 {
device_type = "spi_board1";
compatible = "rohm,dh2228fv";
spi-max-frequency = <16000000>;
reg = <0x0>;
spi-rx-bus-width = <0x4>;
spi-tx-bus-width = <0x4>;
&ledc {
pinctrl-0 = <&ledc_pins_a>;
pinctrl-1 = <&ledc_pins_b>;
led_count = <48>;
output_mode = "GRB";
reset_ns = <84>;
t1h_ns = <800>;
t1l_ns = <450>;
t0h_ns = <400>;
t0l_ns = <850>;
wait_time0_ns = <84>;
wait_time1_ns = <84>;
wait_data_time_ns = <600000>;
&s_cir0 {
pinctrl-names = "default";
pinctrl-0 = <&s_cir0_pins_a>;
&ir1 {
pinctrl-0 = <&ir1_pins_a>;
...............离线
发现把 sys_config.fex 文件中有关SDC2启动的内容注释掉后
内核启动就正常了
但是XR829模块加载失败
# insmod xr829.ko ====
[ 54.421021] 000: [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
[ 54.421088] 000: [XRADIO] Allocated hw_priv @ (ptrval)
[ 54.421099] 000: [ sunxi-rfkill soc@3000000:rfkill@0: bus_index: 2
[ 54.432535] 000: sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[ 54.637542] 000: sunxi_hosts[2] should not be null
[ 54.637545] 000: [XRADIO] Detect SDIO card 2
[ 56.677542] 001: sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
[ 56.782583] 000: sunxi_hosts[2] should not be null
[ 56.782586] 000: [XRADIO] Remove SDIO card 2
[ 56.792597] 000: [SBUS_ERR] sdio probe timeout!
[ 56.792606] 000: [XRADIO_ERR] sbus_sdio_init failed
[ 56.793190] 000: xradio_core_init failed (-110)!
[ 56.838258] 001: ======== XRADIO WIFI OPEN ========
[ 56.844273] 000: [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
[ 56.844412] 000: [XRADIO] Alloc hw_priv @ (ptrval)
[ 56.844426] 000: [ADDR_MGT] get_addr_by_name: t->addr:
[ 56.845719] 00an power on success
55831] 000: [XRADIO] Detect SDIO card 2
[ 59.214616] 001: sunxi_hosts[2] should not be null
[ 59.214619] 001: [XRADIO] Remove SDIO card 2
[ 59.224724] 001: [SBUS_ERR] sdio probe timeout!
[ 59.224734] 001: [XRADIO_ERR] sbus_sdio_init failed
[ 59.225713] 001: xradio_core_init failed (-110)!
insmod: can't insert 'xr829.ko': Connection timed out
