楼主 # 2023-04-06 10:22:49
ookk303
已发帖子: 38
尝试编译v3s的buildroot文件系统,发现使用4。14和5.2进不去,3.4内核可以进系统
开机的情况如下
[ 0.000000] Linux version 4.10.2-licheepi-zero+ (zp@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #15 SMP Sat Apr 15 21:38:23 CST 2017
[ 0.000000] OF: fdt:Machine model: Lichee Pi Zero
[ 0.000000] percpu: Embedded 14 pages/cpu @c3dea000 s24652 r8192 d24500 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Memory: 53628K/64036K available (6144K kernel code, 213K rwdata, 1472K rodata, 1024K init, 260K bss, 10408K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3e89000 ( 62 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a35600 ( 214 kB)
[ 0.000000] .bss : 0xc0a37000 - 0xc0a781cc ( 261 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000148] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000358] Console: colour dummy device 80x30
[ 0.000784] console [tty0] enabled
[ 0.000824] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000861] pid_max: default: 32768 minimum: 301
[ 0.001020] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001048] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001779] CPU: Testing write buffer coherency: ok
[ 0.002217] /cpus/cpu@0 missing clock-frequency property
[ 0.002261] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002673] Setting up static identity map for 0x40100000 - 0x40100058
[ 0.003475] smp: Bringing up secondary CPUs ...
[ 0.003516] smp: Brought up 1 node, 1 CPU
[ 0.003537] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003556] CPU: All CPU(s) started in SVC mode.
[ 0.004368] devtmpfs: initialized
[ 0.007118] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007457] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007513] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007689] pinctrl core: initialized pinctrl subsystem
[ 0.008700] NET: Registered protocol family 16
[ 0.009202] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010560] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010611] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.022001] SCSI subsystem initialized
[ 0.022325] usbcore: registered new interface driver usbfs
[ 0.022414] usbcore: registered new interface driver hub
[ 0.022526] usbcore: registered new device driver usb
[ 0.022767] pps_core: LinuxPPS API ver. 1 registered
[ 0.022793] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.022843] PTP clock support registered
[ 0.023081] Advanced Linux Sound Architecture Driver Initialized.
[ 0.024952] clocksource: Switched to clocksource arch_sys_counter
[ 0.025797] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4080000
[ 0.025852] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 0.032741] Console: switching to colour frame buffer device 100x30
[ 0.042569] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 0.056620] NET: Registered protocol family 2
[ 0.061045] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.065022] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.068828] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.072655] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.076446] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.080350] NET: Registered protocol family 1
[ 0.084605] RPC: Registered named UNIX socket transport module.
[ 0.088373] RPC: Registered udp transport module.
[ 0.091954] RPC: Registered tcp transport module.
[ 0.095440] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.101184] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.113803] NFS: Registering the id_resolver key type
[ 0.117457] Key type id_resolver registered
[ 0.120834] Key type id_legacy registered
[ 0.124193] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.132152] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.135901] io scheduler noop registered
[ 0.139420] io scheduler deadline registered
[ 0.143072] io scheduler cfq registered (default)
[ 0.150706] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.224321] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.231306] console [ttyS0] disabled
[ 0.255094] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.855506] console [ttyS0] enabled
[ 0.863142] [drm] Initialized
[ 0.871352] libphy: Fixed MDIO Bus: probed
[ 0.879145] usbcore: registered new interface driver r8152
[ 0.887964] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.897745] ehci-platform: EHCI generic platform driver
[ 0.906292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.915733] ohci-platform: OHCI generic platform driver
[ 0.924295] usbcore: registered new interface driver usb-storage
[ 0.933594] usbcore: registered new interface driver ums-freecom
[ 0.943177] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.956137] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 0.966313] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.974058] i2c /dev entries driver
[ 0.982192] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 0.995464] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.065001] sunxi-mmc 1c0f000.mmc: base:0xc405d000 irq:23
[ 1.074852] usbcore: registered new interface driver usbhid
[ 1.083998] usbhid: USB HID core driver
[ 1.093098] NET: Registered protocol family 17
[ 1.101346] Key type dns_resolver registered
[ 1.109235] Registering SWP/SWPB emulation handler
[ 1.126260] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.137819] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.147276] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.160069] hub 1-0:1.0: USB hub found
[ 1.167622] hub 1-0:1.0: 1 port detected
[ 1.175869] using random self ethernet address
[ 1.183741] using random host ethernet address
[ 1.192485] usb0: HOST MAC 06:c7:28:e9:ca:7b
[ 1.200139] usb0: MAC 3a:f5:8c:6e:55:a9
[ 1.207258] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.218095] g_cdc gadget: g_cdc ready
[ 1.225352] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:12 UTC (12)
[ 1.237063] vcc3v0: disabling
[ 1.243370] vcc5v0: disabling
[ 1.249600] ALSA device list:
[ 1.255731] No soundcards found.
[ 1.266011] Waiting for root device /dev/mmcblk0p2...
[ 1.312320] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.326300] mmc0: new high speed SDHC card at address 5048
[ 1.335850] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[ 1.346079] mmcblk0: p1 p2
[ 1.356650] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.369625] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.411377] random: fast init done
[ 1.424697] EXT4-fs (mmcblk0p2): recovery complete
[ 1.437080] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.448434] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.459280] devtmpfs: mounted
[ 1.466785] Freeing unused kernel memory: 1024K
[ 1.580319] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
