Starting logging: OK
Starting network: OK
[ 13.186727] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.204556] RTL8723BS: module init start
[ 13.208645] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[ 13.215688] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[ 13.222278] pqfeng debug ret = 0
[ 13.227857] pnetdev = c2a38800
[ 13.267472] RTL8723BS: rtw_ndev_init(wlan0)
[ 13.273210] RTL8723BS: module init ret =0
[ 13.293138] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ctrl_interface_group='0'
ap_scan=1
Priority group 5
id=0 ssid='debugdump'
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x179dc8
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0104
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=040a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=040b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=040c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=040d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=090a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=090b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=090c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=090d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0409506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=7f506f9a09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0a07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0a11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0a1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=1101
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=1102
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0505
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x179dc8 match=0500
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
netlink: Operstate: ifindex=4 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 08:d8:33:df:a9:66
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: Setting scan request: 0.100000 sec
wlan0: WPS: UUID based on MAC address: 96327dcd-1712-506e-9df3-babe97102e33
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
ctrl_interface_group=0
wlan0: Added interface wlan0
wlan0: State: DISCONNECTED -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
Daemonize..
[ 24.379799] RTL8723BS: nolinked power save enter
udhcpc: started, v1.27.2
udhcpc: sending discover
[ 29.440492] RTL8723BS: nolinked power save leave
[ 31.639653] RTL8723BS: nolinked power save enter
[ 36.650525] RTL8723BS: nolinked power save leave
[ 38.850279] RTL8723BS: nolinked power save enter
[ 43.860483] RTL8723BS: nolinked power save leave
^C[ 46.059757] RTL8723BS: nolinked power save enter
[ 51.070686] RTL8723BS: nolinked power save leave
[ 53.270313] RTL8723BS: nolinked power save enter
[ 58.280438] RTL8723BS: nolinked power save leave
[ 60.479732] RTL8723BS: nolinked power save enter
[ 65.490646] RTL8723BS: nolinked power save leave
[ 67.689747] RTL8723BS: nolinked power save enter
[ 72.690612] RTL8723BS: nolinked power save leave
[ 74.889774] RTL8723BS: nolinked power save enter
[ 79.900622] RTL8723BS: nolinked power save leave
[ 82.099752] RTL8723BS: nolinked power save enter
[ 87.110626] RTL8723BS: nolinked power save leave
[ 89.309749] RTL8723BS: nolinked power save enter
[ 94.320633] RTL8723BS: nolinked power save leave
[ 96.519755] RTL8723BS: nolinked power save enter
[ 101.530638] RTL8723BS: nolinked power save leave
[ 103.729541] RTL8723BS: nolinked power save enter
[ 108.740614] RTL8723BS: nolinked power save leave
[ 110.939714] RTL8723BS: nolinked power save enter
[ 115.950477] RTL8723BS: nolinked power save leave
[ 118.149736] RTL8723BS: nolinked power save enter
udhcpc: sending discover离线
搜索了一下以前的帖子,还在研究中。。。我现在用的是官方的rootfs
/etc/wpa_supplicant.conf 文件内容:
ap_scan=1
network={
ssid="whycan.cn"
scan_ssid=1
key_mgmt=WPA-EAP WPA-PSK IEEE8021X NONE
pairwise=TKIP CCMP
group=CCMP TKIP WEP104 WEP40
psk="13800138000"
priority=5
看log好像先是Unauthorized,然后休眠了
ap_scan=1
network={
ssid="whycan.cn"
scan_ssid=1
pairwise=TKIP CCMP
psk="13800138000"
priority=5
输出wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf指令后,同样遇到1楼的问题,请问有解决了的吗?
晕哥 说:/etc/wpa_supplicant.conf 文件内容:
ap_scan=1
network={
ssid="whycan.cn"
scan_ssid=1
pairwise=TKIP CCMP
psk="13800138000"
priority=5
}输出wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf指令后,同样遇到1楼的问题,请问有解决了的吗?
已经修改成功,原因是/etc/wpa_supplicant.conf中的ssid和psk要根据实际wifi的名称和密码进行修改
