刚开始我实现主线的uboot和主线的内核发现dts中缺少很多设备,根本没法使用,只能简单测试一下。
后来转向了 BSP kernel
使用@晕哥 提供的 f1c100s_c600sdk_16M_micropython.bin 启动发现有一个声卡,但是该镜像文件系统中没有alsa工具。
为了简便处理,我直接把晕哥这个镜像中的rootfs更换成我的带有alsa工具的rootfs。
替换rootfs后的镜像如下:
 https://whycan.com/files/members/961/f1c100.rar
发现 aplay能使用的 rootfs中的 /usr下已经有一个400HZ的测试音频,但是发现arecord 不能录音不知道内核默认是line in 还是 mic 我两个都测试了没有声音,大家一起测试解决问题。
最近编辑记录 fly_to_bluesky@126.com (2018-06-20 11:10:50)
@晕哥,昨天启动的问题已经搞定了。
   是我rootfs的地址错误了,修改正确了,就能正常启动了。
现在就是声卡不能正常录音,我使用alsamix配置了mic 开启,还是不能正常录音。
@晕哥 麻烦您了
@晕哥,非常感谢,问题已经解决了,确实是我的配置问题。
  amixer list 打出来大家看看。
Simple mixer control 'ADC FM volume',0
  Capabilities: volume volume-joined
  Playback channels: Mono
  Capture channels: Mono
  Limits: 0 - 7
  Mono: 0 [0%]
Simple mixer control 'ADC INPUT GAIN control',0
  Limits: 0 - 7
  Mono: 0 [0%]
Simple mixer control 'ADC MIC Boost AMP en',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [on]
Simple mixer control 'ADC MIC Boost AMP gain control',0
  Limits: 0 - 7
  Mono: 0 [0%]
Simple mixer control 'ADC PA speed select',0
  Mono: Playback [off]
Simple mixer control 'ADC mixer mute for FML',0
Simple mixer control 'ADC mixer mute for FMR',0
Simple mixer control 'ADC mixer mute for left ouput',0
Simple mixer control 'ADC mixer mute for linein',0
Simple mixer control 'ADC mixer mute for mic',0
  Mono: Playback [on]
Simple mixer control 'ADC mixer mute for right ouput',0
Simple mixer control 'COS slop time control for Anti-pop',0
  Limits: 0 - 3
  Mono: 1 [33%]
Simple mixer control 'LINEIN GAIN control',0
  Limits: 0 - 7
  Mono: 0 [0%]
Simple mixer control 'MICIN GAIN control',0
  Limits: 0 - 7
  Mono: 3 [43%]
Simple mixer control 'dac digital volume',0
  Limits: 0 - 63
  Mono: 0 [0%]
Simple mixer control 'dac: left analog output mixer en',0
Simple mixer control 'dac: left chanle en',0
  Mono: Playback [on]
Simple mixer control 'dac: left hpout to right hpout',0
Simple mixer control 'dac: left mixer mute: FM',0
Simple mixer control 'dac: left mixer mute: left dac',0
  Mono: Playback [on]
Simple mixer control 'dac: left mixer mute: linein',0
Simple mixer control 'dac: left mixer mute: mic',0
Simple mixer control 'dac: left mixer mute: right dac',0
  Mono: Playback [on]
Simple mixer control 'dac: left mute',0
  Mono: Playback [on]
Simple mixer control 'dac: right analog output mixer en',0
Simple mixer control 'dac: right chanel en',0
  Mono: Playback [on]
Simple mixer control 'dac: right hpout to left hpout',0
Simple mixer control 'dac: right mixer mute: FM',0
Simple mixer control 'dac: right mixer mute: left dac',0
  Mono: Playback [on]
Simple mixer control 'dac: right mixer mute: linein',0
Simple mixer control 'dac: right mixer mute: mic',0
Simple mixer control 'dac: right mixer mute: right dac',0
  Mono: Playback [on]
Simple mixer control 'dac: right mute',0
  Mono: Playback [on]
Simple mixer control 'head phone power',0
  Mono: Playback [on]
Simple mixer control 'head phone volume',0
  Limits: 0 - 63
  Mono: 63 [100%]
Simple mixer control 'hp left source select: 0-dac, 1-mixer',0
Simple mixer control 'hp right source select: 0-dac, 1-mixer',0
  Mono: Playback [off]amixer 参数调整后不能自动保存的,需要特别保存一下。
alsactl store -f /var/lib/alsa/asound.state
重启后alsactl restore -f /var/lib/alsa/asound.state
多谢 @fly_to_bluesky 分享!
可以详细列出来调用了哪些命令吗?
这样方便后来到这个帖子的同学参考.
直接把我保存好的文件发到这里:
https://whycan.com/files/members/961/asound.zip
下载解压后 直接restore就可以了
我上面提供的镜像里面已经有lsz 和 lrz工具,可以通过串口使用zmodern传进去。
谢楼主分享!
测试可用
@fly_to_bluesky
我想请教您一个问题,就是我在linux4.19的内核配置中应该怎么配置才能够配置好荔枝派nano的测试声卡呢?
我怎么配置都配置不出你的镜像中:
                        #cat /proc/asound/cards
                          0  [audiocodec     ]:   audiocodec  -   audiocodec
                                                          audiocodec
而我配来配去都没有出现这个声卡的信息,下面是我的声卡信息:
                          0  [Dummy    ] : Dummy     - Dummy
                                                   Dummy  1
                          1  [Loopback  ] : Loopback   -  Loopback
                                                   Loopback  1
                          2   [VirMIDI    ] : VirMIDI  -  VirMIDI
                                                    Virtual MIDI  Card 1
 想请教下我的内核需要怎么配置的呢?还是需要自己编写驱动的呢?
@fly_to_bluesky
我怎么配置都配置不出你的镜像中:
audiocodec
Dummy 1
Loopback 1
Virtual MIDI Card 1
前面讨论的是 bsp linux 3.10 的声卡驱动, 与 linux 4.19 的套路不同。
@晕哥
晕哥,那linux4.19的话需要怎么配置的呢?
@晕哥
晕哥在官网上面没有呢,目前我的情况是在linux 4.19 上 make ARCH=arm menuconfig 后,到了选择sound card 时就不知选择哪个驱动和声卡才能够适应荔枝派nano的使用呢?想请教下晕哥,我该如何选择呢,或者是如果在linux3.10里我应该选择哪个声卡配置呢?
@晕哥
晕哥,想问下我按照上面的C600的套路,因为上面的C600的帖子上没有配置声卡的问题,是不是说C600的套路里的默认声卡配置已经能够实现在f1c100s上发出声音的了?
@晕哥
      好的,我试一下用C600的套路
@晕哥
晕哥,我想问下按照C600的套路,配置时输入:./build.sh config ,之后出现
All available boards:
   0. aw_w01
   1. aw_w02
   2. evb
   3. qc
对于荔枝派f1c100这块板子需要选择哪个选项的呢?
@晕哥
晕哥你好,目前我按照C600的套路来,我能得到的dtb文件是sunivw1p1-evb.dtb,但是没有能够得到suniv-f1c100s-licheepi-nano.dtb;因为之前用的是linux4.19和打上补丁后就能够得到suniv-f1c100s-licheepi-nano.dtb,现在使用linux3.10就没办法得到了,这个问题我该怎么解决呢?
@晕哥
套路不同,有 sunivw1p1-evb.dtb 就可以了.
@晕哥
晕哥,在使用C600的套路里面我遇到了几个问题呢,不知道怎么解决,请大神分析下:
1.单独编译linux3.10时,想提取出dtb和zImage文件,但是make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- dtbs -j4,之后出现了错误:
      include/linux/compiler-gcc.h:106:1: fatal error: linux/compiler-gcc7.h: No such file or directory
      #include gcc_header(__GNUC__)
      这个我尝试安装了gcc7.0还是没能解决。
2.为什么按照C600的套路我,我把镜像下载到板子之中,输入cat /proc/asound/cards之后还是提示no soundcards
   请问下这个问题是不是跟我没有将alsa库移植进系统有关呢?
3.晕哥我还想请教下在C600的套路里面我想修改根文件系统,但是不知在哪个地方可以修改根文件系统?
@晕哥
晕哥,是的,我是参考这个帖子的呢
标记一下,等有空了按照这个方法测试下
