我用全志Allwinner V3s荔枝派zero开发板,请问这是buildroot配置错误吗?生成的mplayer和Qt应用程序一跑起来就挂
# mplayer Amped_W51BS_5.8G_OOPS.mp4
MPlayer 1.3.0-6.3.1 (C) 2000-2016 MPlayer TeamPlaying Amped_W51BS_5.8G_OOPS.mp4.
libavformat version 57.25.100 (internal)
libavformat file format detected.
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x6c8fc8]Protocol name not provided, cannot determine if input is local or a network protocol, buffers and access patterns cannot be configured optimally without knowing the protocol
# analogclock -platform linuxfb
就上面这样控制台没有任何响应了,肯定是死了
配置是这样的:
# Buildroot 2017.08.1 Configuration
BR2_HAVE_DOT_CONFIG=y
BR2_HOST_GCC_AT_LEAST_4_5=y
BR2_HOST_GCC_AT_LEAST_4_6=y
BR2_HOST_GCC_AT_LEAST_4_7=y
BR2_HOST_GCC_AT_LEAST_4_8=y
# Target options
BR2_ARCH_HAS_MMU_OPTIONAL=y
# BR2_arcle is not set
# BR2_arceb is not set
BR2_arm=y
# BR2_armeb is not set
# BR2_aarch64 is not set
# BR2_aarch64_be is not set
# BR2_bfin is not set
# BR2_csky is not set
# BR2_i386 is not set
# BR2_m68k is not set
# BR2_microblazeel is not set
# BR2_microblazebe is not set
# BR2_mips is not set
# BR2_mipsel is not set
# BR2_mips64 is not set
# BR2_mips64el is not set
# BR2_nios2 is not set
# BR2_or1k is not set
# BR2_powerpc is not set
# BR2_powerpc64 is not set
# BR2_powerpc64le is not set
# BR2_sh is not set
# BR2_sparc is not set
# BR2_sparc64 is not set
# BR2_x86_64 is not set
# BR2_xtensa is not set
BR2_ARCH="arm"
BR2_ENDIAN="LITTLE"
BR2_GCC_TARGET_ABI="aapcs-linux"
BR2_GCC_TARGET_CPU="cortex-a7"
BR2_GCC_TARGET_FPU="vfpv4-d16"
BR2_GCC_TARGET_FLOAT_ABI="hard"
BR2_GCC_TARGET_MODE="arm"
BR2_BINFMT_SUPPORTS_SHARED=y
BR2_READELF_ARCH_NAME="ARM"
BR2_BINFMT_ELF=y
BR2_ARM_CPU_HAS_NEON=y
BR2_ARM_CPU_HAS_VFPV2=y
BR2_ARM_CPU_HAS_VFPV3=y
BR2_ARM_CPU_HAS_VFPV4=y
BR2_ARM_CPU_HAS_ARM=y
BR2_ARM_CPU_HAS_THUMB2=y
BR2_ARM_CPU_ARMV7A=y
# BR2_arm920t is not set
# BR2_arm922t is not set
# BR2_arm926t is not set
# BR2_arm1136j_s is not set
# BR2_arm1136jf_s is not set
# BR2_arm1176jz_s is not set
# BR2_arm1176jzf_s is not set
# BR2_arm11mpcore is not set
# BR2_cortex_a5 is not set
BR2_cortex_a7=y
# BR2_cortex_a8 is not set
# BR2_cortex_a9 is not set
# BR2_cortex_a12 is not set
# BR2_cortex_a15 is not set
# BR2_cortex_a15_a7 is not set
# BR2_cortex_a17 is not set
# BR2_cortex_a17_a7 is not set
# BR2_cortex_a53 is not set
# BR2_cortex_a57 is not set
# BR2_cortex_a57_a53 is not set
# BR2_cortex_a72 is not set
# BR2_cortex_a72_a53 is not set
# BR2_cortex_m3 is not set
# BR2_cortex_m4 is not set
# BR2_fa526 is not set
# BR2_pj4 is not set
# BR2_strongarm is not set
# BR2_xscale is not set
# BR2_iwmmxt is not set
# BR2_ARM_EABI is not set
BR2_ARM_EABIHF=y
# BR2_ARM_FPU_VFPV2 is not set
# BR2_ARM_FPU_VFPV3 is not set
# BR2_ARM_FPU_VFPV3D16 is not set
# BR2_ARM_FPU_VFPV4 is not set
BR2_ARM_FPU_VFPV4D16=y
# BR2_ARM_FPU_NEON is not set
# BR2_ARM_FPU_NEON_VFPV4 is not set
BR2_ARM_INSTRUCTIONS_ARM=y
# BR2_ARM_INSTRUCTIONS_THUMB2 is not set
# Build options
# Commands
BR2_WGET="wget --passive-ftp -nd -t 3"
BR2_SVN="svn"
BR2_BZR="bzr"
BR2_GIT="git"
BR2_CVS="cvs"
BR2_LOCALFILES="cp"
BR2_SCP="scp"
BR2_SSH="ssh"
BR2_HG="hg"
BR2_ZCAT="gzip -d -c"
BR2_BZCAT="bzcat"
BR2_XZCAT="xzcat"
BR2_LZCAT="lzip -d -c"
BR2_TAR_OPTIONS=""
BR2_DEFCONFIG="$(CONFIG_DIR)/defconfig"
BR2_DL_DIR="/disk4/buildroot-2017.08.1/dl/"
BR2_HOST_DIR="$(BASE_DIR)/host"
# Mirrors and Download locations
BR2_PRIMARY_SITE=""
BR2_BACKUP_SITE="http://sources.buildroot.net"
BR2_KERNEL_MIRROR="https://cdn.kernel.org/pub"
BR2_GNU_MIRROR="http://ftpmirror.gnu.org"
BR2_LUAROCKS_MIRROR="http://rocks.moonscript.org"
BR2_CPAN_MIRROR="http://cpan.metacpan.org"
BR2_JLEVEL=0
# BR2_CCACHE is not set
# BR2_ENABLE_DEBUG is not set
BR2_STRIP_strip=y
BR2_STRIP_EXCLUDE_FILES=""
BR2_STRIP_EXCLUDE_DIRS=""
# BR2_OPTIMIZE_0 is not set
# BR2_OPTIMIZE_1 is not set
# BR2_OPTIMIZE_2 is not set
# BR2_OPTIMIZE_3 is not set
# BR2_OPTIMIZE_G is not set
BR2_OPTIMIZE_S=y
# BR2_GOOGLE_BREAKPAD_ENABLE is not set
BR2_SSP_NONE=y
# BR2_SSP_REGULAR is not set
# BR2_SSP_STRONG is not set
# BR2_SSP_ALL is not set
# BR2_STATIC_LIBS is not set
BR2_SHARED_LIBS=y
# BR2_SHARED_STATIC_LIBS is not set
BR2_PACKAGE_OVERRIDE_FILE="$(CONFIG_DIR)/local.mk"
BR2_GLOBAL_PATCH_DIR=""
# Advanced
BR2_COMPILER_PARANOID_UNSAFE_PATH=y
# BR2_REPRODUCIBLE is not set
# Toolchain
BR2_TOOLCHAIN=y
BR2_TOOLCHAIN_USES_GLIBC=y
# BR2_TOOLCHAIN_BUILDROOT is not set
BR2_TOOLCHAIN_EXTERNAL=y
# Toolchain External Options
BR2_TOOLCHAIN_EXTERNAL_LINARO_ARM=y
# Sourcery CodeBench toolchains available for the EABI ABI
# BR2_TOOLCHAIN_EXTERNAL_CUSTOM is not set
BR2_TOOLCHAIN_EXTERNAL_DOWNLOAD=y
# BR2_TOOLCHAIN_EXTERNAL_PREINSTALLED is not set
BR2_TOOLCHAIN_EXTERNAL_GLIBC=y
BR2_PACKAGE_HAS_TOOLCHAIN_EXTERNAL=y
BR2_PACKAGE_PROVIDES_TOOLCHAIN_EXTERNAL="toolchain-external-linaro-arm"
BR2_TOOLCHAIN_EXTERNAL_PREFIX="arm-linux-gnueabihf"
BR2_TOOLCHAIN_EXTERNAL_GDB_SERVER_COPY=y
# Host GDB Options
# Toolchain Generic Options
BR2_TOOLCHAIN_HAS_NATIVE_RPC=y
BR2_USE_WCHAR=y
BR2_ENABLE_LOCALE=y
BR2_INSTALL_LIBSTDCPP=y
BR2_TOOLCHAIN_HAS_FORTRAN=y
BR2_TOOLCHAIN_HAS_THREADS=y
BR2_TOOLCHAIN_HAS_THREADS_DEBUG=y
BR2_TOOLCHAIN_HAS_THREADS_NPTL=y
BR2_TOOLCHAIN_HAS_SHADOW_PASSWORDS=y
BR2_TOOLCHAIN_HAS_SSP=y
BR2_TOOLCHAIN_SUPPORTS_PIE=y
# BR2_TOOLCHAIN_GLIBC_GCONV_LIBS_COPY is not set
BR2_TOOLCHAIN_HAS_FULL_GETTEXT=y
BR2_USE_MMU=y
BR2_TARGET_OPTIMIZATION=""
BR2_TARGET_LDFLAGS=""
# BR2_ECLIPSE_REGISTER is not set
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_7=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_8=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_9=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_10=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_11=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_12=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_13=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_14=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_15=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_16=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_17=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_18=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_3_19=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_0=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_1=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_2=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_3=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_4=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_5=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST_4_6=y
BR2_TOOLCHAIN_HEADERS_AT_LEAST="4.6"
BR2_TOOLCHAIN_GCC_AT_LEAST_4_3=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_4=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_7=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_8=y
BR2_TOOLCHAIN_GCC_AT_LEAST_4_9=y
BR2_TOOLCHAIN_GCC_AT_LEAST_5=y
BR2_TOOLCHAIN_GCC_AT_LEAST_6=y
BR2_TOOLCHAIN_GCC_AT_LEAST="6"
BR2_TOOLCHAIN_HAS_MNAN_OPTION=y
BR2_TOOLCHAIN_HAS_MFPXX_OPTION=y
BR2_TOOLCHAIN_HAS_SYNC_1=y
BR2_TOOLCHAIN_HAS_SYNC_2=y
BR2_TOOLCHAIN_HAS_SYNC_4=y
BR2_TOOLCHAIN_ARM_HAS_SYNC_8=y
BR2_TOOLCHAIN_HAS_SYNC_8=y
BR2_TOOLCHAIN_HAS_LIBATOMIC=y
BR2_TOOLCHAIN_HAS_ATOMIC=y
# System configuration
BR2_ROOTFS_SKELETON_DEFAULT=y
# BR2_ROOTFS_SKELETON_CUSTOM is not set
# BR2_ROOTFS_MERGED_USR is not set
BR2_TARGET_GENERIC_HOSTNAME="buildroot"
BR2_TARGET_GENERIC_ISSUE="Welcome to Buildroot"
BR2_TARGET_GENERIC_PASSWD_MD5=y
# BR2_TARGET_GENERIC_PASSWD_SHA256 is not set
# BR2_TARGET_GENERIC_PASSWD_SHA512 is not set
BR2_TARGET_GENERIC_PASSWD_METHOD="md5"
BR2_INIT_BUSYBOX=y
# BR2_INIT_SYSV is not set
# BR2_INIT_SYSTEMD is not set
# BR2_INIT_NONE is not set
# BR2_ROOTFS_DEVICE_CREATION_STATIC is not set
BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_DEVTMPFS=y
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_MDEV is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_EUDEV is not set
BR2_ROOTFS_DEVICE_TABLE="system/device_table.txt"
# BR2_ROOTFS_DEVICE_TABLE_SUPPORTS_EXTENDED_ATTRIBUTES is not set
BR2_TARGET_ENABLE_ROOT_LOGIN=y
BR2_TARGET_GENERIC_ROOT_PASSWD=""
BR2_SYSTEM_BIN_SH_BUSYBOX=y
# bash, dash, mksh, zsh need BR2_PACKAGE_BUSYBOX_SHOW_OTHERS
# BR2_SYSTEM_BIN_SH_NONE is not set
BR2_TARGET_GENERIC_GETTY=y
BR2_TARGET_GENERIC_GETTY_PORT="console"
BR2_TARGET_GENERIC_GETTY_BAUDRATE_KEEP=y
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_9600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_19200 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_38400 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_57600 is not set
# BR2_TARGET_GENERIC_GETTY_BAUDRATE_115200 is not set
BR2_TARGET_GENERIC_GETTY_BAUDRATE="0"
BR2_TARGET_GENERIC_GETTY_TERM="vt100"
BR2_TARGET_GENERIC_GETTY_OPTIONS=""
BR2_TARGET_GENERIC_REMOUNT_ROOTFS_RW=y
BR2_SYSTEM_DHCP=""
BR2_ENABLE_LOCALE_PURGE=y
BR2_ENABLE_LOCALE_WHITELIST="C en_US"
BR2_GENERATE_LOCALE=""
# BR2_SYSTEM_ENABLE_NLS is not set
# BR2_TARGET_TZ_INFO is not set
BR2_ROOTFS_USERS_TABLES=""
BR2_ROOTFS_OVERLAY=""
BR2_ROOTFS_POST_BUILD_SCRIPT=""
BR2_ROOTFS_POST_FAKEROOT_SCRIPT=""
BR2_ROOTFS_POST_IMAGE_SCRIPT=""
# Kernel
# BR2_LINUX_KERNEL is not set
# Target packages
BR2_PACKAGE_BUSYBOX=y
BR2_PACKAGE_BUSYBOX_CONFIG="package/busybox/busybox.config"
BR2_PACKAGE_BUSYBOX_CONFIG_FRAGMENT_FILES=""
# BR2_PACKAGE_BUSYBOX_SHOW_OTHERS is not set
# BR2_PACKAGE_BUSYBOX_SELINUX is not set
# BR2_PACKAGE_BUSYBOX_INDIVIDUAL_BINARIES is not set
# BR2_PACKAGE_BUSYBOX_WATCHDOG is not set
BR2_PACKAGE_SKELETON=y
BR2_PACKAGE_HAS_SKELETON=y
BR2_PACKAGE_PROVIDES_SKELETON="skeleton-init-sysv"
BR2_PACKAGE_SKELETON_INIT_COMMON=y
BR2_PACKAGE_SKELETON_INIT_SYSV=y
# Audio and video applications
BR2_PACKAGE_ALSA_UTILS=y
BR2_PACKAGE_ALSA_UTILS_ALSACONF=y
BR2_PACKAGE_ALSA_UTILS_ACONNECT=y
BR2_PACKAGE_ALSA_UTILS_ALSACTL=y
BR2_PACKAGE_ALSA_UTILS_ALSALOOP=y
BR2_PACKAGE_ALSA_UTILS_ALSAMIXER=y
# BR2_PACKAGE_ALSA_UTILS_ALSAUCM is not set
# BR2_PACKAGE_ALSA_UTILS_ALSATPLG is not set
# BR2_PACKAGE_ALSA_UTILS_AMIDI is not set
# BR2_PACKAGE_ALSA_UTILS_AMIXER is not set
BR2_PACKAGE_ALSA_UTILS_APLAY=y
# BR2_PACKAGE_ALSA_UTILS_APLAYMIDI is not set
# BR2_PACKAGE_ALSA_UTILS_ARECORDMIDI is not set
# BR2_PACKAGE_ALSA_UTILS_ASEQDUMP is not set
# BR2_PACKAGE_ALSA_UTILS_ASEQNET is not set
# BR2_PACKAGE_ALSA_UTILS_BAT is not set
# BR2_PACKAGE_ALSA_UTILS_IECSET is not set
BR2_PACKAGE_ALSA_UTILS_SPEAKER_TEST=y
# BR2_PACKAGE_ATEST is not set
# BR2_PACKAGE_AUMIX is not set
# BR2_PACKAGE_BELLAGIO is not set
# BR2_PACKAGE_DVBLAST is not set
# BR2_PACKAGE_DVDAUTHOR is not set
# BR2_PACKAGE_DVDRW_TOOLS is not set
# BR2_PACKAGE_ESPEAK is not set
# BR2_PACKAGE_FAAD2 is not set
BR2_PACKAGE_FFMPEG_ARCH_SUPPORTS=y
BR2_PACKAGE_FFMPEG=y
BR2_PACKAGE_FFMPEG_GPL=y
BR2_PACKAGE_FFMPEG_NONFREE=y
BR2_PACKAGE_FFMPEG_FFMPEG=y
BR2_PACKAGE_FFMPEG_FFPLAY=y
BR2_PACKAGE_FFMPEG_FFSERVER=y
BR2_PACKAGE_FFMPEG_FFPROBE=y
BR2_PACKAGE_FFMPEG_AVRESAMPLE=y
# BR2_PACKAGE_FFMPEG_POSTPROC is not set
BR2_PACKAGE_FFMPEG_SWSCALE=y
BR2_PACKAGE_FFMPEG_ENCODERS="all"
BR2_PACKAGE_FFMPEG_DECODERS="all"
BR2_PACKAGE_FFMPEG_MUXERS="all"
BR2_PACKAGE_FFMPEG_DEMUXERS="all"
BR2_PACKAGE_FFMPEG_PARSERS="all"
BR2_PACKAGE_FFMPEG_BSFS="all"
BR2_PACKAGE_FFMPEG_PROTOCOLS="all"
BR2_PACKAGE_FFMPEG_FILTERS="all"
BR2_PACKAGE_FFMPEG_INDEVS=y
BR2_PACKAGE_FFMPEG_OUTDEVS=y
BR2_PACKAGE_FFMPEG_EXTRACONF=""
BR2_PACKAGE_FLAC=y
# BR2_PACKAGE_FLITE is not set
# BR2_PACKAGE_GMRENDER_RESURRECT is not set
# BR2_PACKAGE_GSTREAMER is not set
# BR2_PACKAGE_GSTREAMER1 is not set
# BR2_PACKAGE_JACK2 is not set
BR2_PACKAGE_KODI_ARCH_SUPPORTS=y
# kodi needs python w/ .py modules, a uClibc or glibc toolchain w/ C++, locale, threads, wchar, dynamic library, gcc >= 4.8, host gcc >= 4.6
# kodi needs an OpenGL EGL with either an openGL or an OpenGL ES backend
BR2_PACKAGE_LAME=y
BR2_PACKAGE_MADPLAY=y
BR2_PACKAGE_MADPLAY_ALSA=y
# BR2_PACKAGE_MIMIC is not set
# miraclecast needs systemd and a glibc toolchain w/ threads and wchar
# BR2_PACKAGE_MJPEGTOOLS is not set
# BR2_PACKAGE_MODPLUGTOOLS is not set
# BR2_PACKAGE_MOTION is not set
# BR2_PACKAGE_MPD is not set
# BR2_PACKAGE_MPD_MPC is not set
# BR2_PACKAGE_MPG123 is not set
BR2_PACKAGE_MPLAYER_ARCH_SUPPORTS=y
BR2_PACKAGE_MPLAYER=y
BR2_PACKAGE_MPLAYER_MPLAYER=y
# BR2_PACKAGE_MPLAYER_MENCODER is not set
# BR2_PACKAGE_MPV is not set
# BR2_PACKAGE_MULTICAT is not set
# BR2_PACKAGE_MUSEPACK is not set
# BR2_PACKAGE_NCMPC is not set
# BR2_PACKAGE_OPUS_TOOLS is not set
# BR2_PACKAGE_PULSEAUDIO is not set
# BR2_PACKAGE_SOX is not set
# BR2_PACKAGE_SQUEEZELITE is not set
# tovid depends on python or python3
# BR2_PACKAGE_TSTOOLS is not set
# BR2_PACKAGE_TWOLAME is not set
# BR2_PACKAGE_UDPXY is not set
# BR2_PACKAGE_UPMPDCLI is not set
# BR2_PACKAGE_V4L2GRAB is not set
# v4l2loopback needs a Linux kernel to be built
# BR2_PACKAGE_VLC is not set
# BR2_PACKAGE_VORBIS_TOOLS is not set
# BR2_PACKAGE_WAVPACK is not set
# BR2_PACKAGE_YAVTA is not set
# BR2_PACKAGE_YMPD is not set
# Compressors and decompressors
# BR2_PACKAGE_BZIP2 is not set
# BR2_PACKAGE_LZ4 is not set
# BR2_PACKAGE_LZIP is not set
# BR2_PACKAGE_LZOP is not set
# BR2_PACKAGE_P7ZIP is not set
# BR2_PACKAGE_PIXZ is not set
# BR2_PACKAGE_UNRAR is not set
# BR2_PACKAGE_XZ is not set
# BR2_PACKAGE_ZIP is not set
# BR2_PACKAGE_ZSTD is not set
# Debugging, profiling and benchmark
# BR2_PACKAGE_BLKTRACE is not set
# BR2_PACKAGE_BONNIE is not set
# BR2_PACKAGE_CACHE_CALIBRATOR is not set
# BR2_PACKAGE_DHRYSTONE is not set
# BR2_PACKAGE_DIEHARDER is not set
# BR2_PACKAGE_DMALLOC is not set
# BR2_PACKAGE_DROPWATCH is not set
# BR2_PACKAGE_DSTAT is not set
# BR2_PACKAGE_DT is not set
# BR2_PACKAGE_DUMA is not set
# BR2_PACKAGE_FIO is not set
BR2_PACKAGE_GDB_ARCH_SUPPORTS=y
# BR2_PACKAGE_GDB is not set
BR2_PACKAGE_GOOGLE_BREAKPAD_ARCH_SUPPORTS=y
# BR2_PACKAGE_GOOGLE_BREAKPAD is not set
# BR2_PACKAGE_IOZONE is not set
# BR2_PACKAGE_KEXEC is not set
# ktap needs a Linux kernel to be built
BR2_PACKAGE_KVM_UNIT_TESTS_ARCH_SUPPORTS=y
# BR2_PACKAGE_KVM_UNIT_TESTS is not set
# BR2_PACKAGE_LATENCYTOP is not set
# BR2_PACKAGE_LMBENCH is not set
BR2_PACKAGE_LTP_TESTSUITE_ARCH_SUPPORTS=y
# BR2_PACKAGE_LTP_TESTSUITE is not set
# BR2_PACKAGE_LTRACE is not set
# BR2_PACKAGE_LTTNG_BABELTRACE is not set
# lttng-modules needs a Linux kernel to be built
# BR2_PACKAGE_LTTNG_TOOLS is not set
# BR2_PACKAGE_MEMSTAT is not set
# BR2_PACKAGE_NETPERF is not set
# BR2_PACKAGE_NETSNIFF_NG is not set
# BR2_PACKAGE_NMON is not set
BR2_PACKAGE_OPROFILE_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPROFILE is not set
# BR2_PACKAGE_PAX_UTILS is not set
# BR2_PACKAGE_PV is not set
# BR2_PACKAGE_RAMSMP is not set
# BR2_PACKAGE_RAMSPEED is not set
# BR2_PACKAGE_RT_TESTS is not set
# BR2_PACKAGE_SPIDEV_TEST is not set
# BR2_PACKAGE_STRACE is not set
# BR2_PACKAGE_STRESS is not set
# BR2_PACKAGE_STRESS_NG is not set
# sysdig needs a toolchain w/ C++, gcc >= 4.7, dynamic library and a Linux kernel to be built
# BR2_PACKAGE_TINYMEMBENCH is not set
# BR2_PACKAGE_TRACE_CMD is not set
BR2_PACKAGE_TRINITY_ARCH_SUPPORTS=y
# BR2_PACKAGE_TRINITY is not set
# BR2_PACKAGE_UCLIBC_NG_TEST is not set
BR2_PACKAGE_VALGRIND_ARCH_SUPPORTS=y
# BR2_PACKAGE_VALGRIND is not set
# BR2_PACKAGE_WHETSTONE is not set
# Development tools
# BR2_PACKAGE_BINUTILS is not set
# BR2_PACKAGE_BSDIFF is not set
# BR2_PACKAGE_CHECK is not set
BR2_PACKAGE_CMAKE_ARCH_SUPPORTS=y
# BR2_PACKAGE_CMAKE_CTEST is not set
# BR2_PACKAGE_CPPUNIT is not set
# BR2_PACKAGE_CVS is not set
# BR2_PACKAGE_CXXTEST is not set
BR2_PACKAGE_FLEX=y
# BR2_PACKAGE_GETTEXT is not set
# BR2_PACKAGE_GIT is not set
# BR2_PACKAGE_GIT_CRYPT is not set
# BR2_PACKAGE_GPERF is not set
# BR2_PACKAGE_JO is not set
# BR2_PACKAGE_JQ is not set
# BR2_PACKAGE_LIBTOOL is not set
# BR2_PACKAGE_MAKE is not set
# BR2_PACKAGE_PKGCONF is not set
# BR2_PACKAGE_SUBVERSION is not set
# BR2_PACKAGE_TREE is not set
# Filesystem and flash utilities
# aufs-util needs a linux kernel and a toolchain w/ threads
# BR2_PACKAGE_AUTOFS is not set
# BR2_PACKAGE_BTRFS_PROGS is not set
# BR2_PACKAGE_CIFS_UTILS is not set
# BR2_PACKAGE_CPIO is not set
# BR2_PACKAGE_CRAMFS is not set
# BR2_PACKAGE_CURLFTPFS is not set
# BR2_PACKAGE_DOSFSTOOLS is not set
# BR2_PACKAGE_E2FSPROGS is not set
# BR2_PACKAGE_E2TOOLS is not set
# BR2_PACKAGE_ECRYPTFS_UTILS is not set
# BR2_PACKAGE_EXFAT is not set
# BR2_PACKAGE_EXFAT_UTILS is not set
# BR2_PACKAGE_F2FS_TOOLS is not set
# BR2_PACKAGE_FLASHBENCH is not set
# BR2_PACKAGE_FWUP is not set
# BR2_PACKAGE_GENEXT2FS is not set
# BR2_PACKAGE_GENPART is not set
# BR2_PACKAGE_GENROMFS is not set
# BR2_PACKAGE_MMC_UTILS is not set
# BR2_PACKAGE_MTD is not set
# BR2_PACKAGE_MTOOLS is not set
# BR2_PACKAGE_NFS_UTILS is not set
# BR2_PACKAGE_NTFS_3G is not set
# BR2_PACKAGE_SP_OOPS_EXTRACT is not set
# BR2_PACKAGE_SQUASHFS is not set
# BR2_PACKAGE_SSHFS is not set
# BR2_PACKAGE_SUNXI_TOOLS is not set
# BR2_PACKAGE_UNIONFS is not set
# BR2_PACKAGE_XFSPROGS is not set
# Fonts, cursors, icons, sounds and themes
# Cursors
# BR2_PACKAGE_COMIX_CURSORS is not set
# BR2_PACKAGE_OBSIDIAN_CURSORS is not set
# Fonts
# BR2_PACKAGE_BITSTREAM_VERA is not set
# BR2_PACKAGE_CANTARELL is not set
# BR2_PACKAGE_DEJAVU is not set
# BR2_PACKAGE_FONT_AWESOME is not set
# BR2_PACKAGE_GHOSTSCRIPT_FONTS is not set
# BR2_PACKAGE_INCONSOLATA is not set
# BR2_PACKAGE_LIBERATION is not set
# Icons
# BR2_PACKAGE_GOOGLE_MATERIAL_DESIGN_ICONS is not set
# BR2_PACKAGE_HICOLOR_ICON_THEME is not set
# Sounds
# BR2_PACKAGE_SOUND_THEME_BOREALIS is not set
# BR2_PACKAGE_SOUND_THEME_FREEDESKTOP is not set
# Themes
# Games
BR2_PACKAGE_CHOCOLATE_DOOM=y
BR2_PACKAGE_DOOM_WAD=y
BR2_PACKAGE_GNUCHESS=y
BR2_PACKAGE_LBREAKOUT2=y
BR2_PACKAGE_LBREAKOUT2_AUDIO=y
BR2_PACKAGE_LBREAKOUT2_NET=y
BR2_PACKAGE_LTRIS=y
BR2_PACKAGE_LTRIS_AUDIO=y
BR2_PACKAGE_OPENTYRIAN=y
BR2_PACKAGE_OPENTYRIAN_NET=y
BR2_PACKAGE_OPENTYRIAN_DATA=y
BR2_PACKAGE_PRBOOM=y
BR2_PACKAGE_SL=y
BR2_PACKAGE_STELLA=y
# Graphic libraries and applications (graphic/text)
# Graphic applications
# BR2_PACKAGE_FSWEBCAM is not set
# BR2_PACKAGE_GHOSTSCRIPT is not set
# glmark2 needs an OpenGL or an openGL ES and EGL backend provided by mesa3d
# BR2_PACKAGE_GNUPLOT is not set
# BR2_PACKAGE_JHEAD is not set
# BR2_PACKAGE_LIBVA_UTILS is not set
# BR2_PACKAGE_PNGQUANT is not set
# qt5cinex needs an Open(E)GL-capable backend
# BR2_PACKAGE_RRDTOOL is not set
# BR2_PACKAGE_TESSERACT_OCR is not set
# Graphic libraries
# BR2_PACKAGE_CEGUI06 is not set
# BR2_PACKAGE_DIRECTFB is not set
# BR2_PACKAGE_EFL is not set
# BR2_PACKAGE_FBDUMP is not set
# BR2_PACKAGE_FBGRAB is not set
# BR2_PACKAGE_FB_TEST_APP is not set
# BR2_PACKAGE_FBTERM is not set
# BR2_PACKAGE_FBV is not set
# BR2_PACKAGE_FREERDP is not set
# BR2_PACKAGE_IMAGEMAGICK is not set
# linux-fusion needs a Linux kernel to be built
# BR2_PACKAGE_MESA3D is not set
# BR2_PACKAGE_OCRAD is not set
# BR2_PACKAGE_PSPLASH is not set
BR2_PACKAGE_SDL=y
BR2_PACKAGE_SDL_FBCON=y
# BR2_PACKAGE_SDL_GFX is not set
# BR2_PACKAGE_SDL_IMAGE is not set
BR2_PACKAGE_SDL_MIXER=y
BR2_PACKAGE_SDL_NET=y
# BR2_PACKAGE_SDL_SOUND is not set
# BR2_PACKAGE_SDL_TTF is not set
BR2_PACKAGE_SDL2=y
# DirectFB video driver needs directfb
# X11 video driver needs X.org
# OpenGL support needs X11 and an OpenGL provider
# OpenGL ES support needs an OpenGL ES provider
# BR2_PACKAGE_SDL2_GFX is not set
# BR2_PACKAGE_SDL2_IMAGE is not set
# BR2_PACKAGE_SDL2_MIXER is not set
# BR2_PACKAGE_SDL2_NET is not set
# BR2_PACKAGE_SDL2_TTF is not set
# Other GUIs
# BR2_PACKAGE_QT is not set
BR2_PACKAGE_QT5_JSCORE_AVAILABLE=y
BR2_PACKAGE_QT5=y
BR2_PACKAGE_QT5_VERSION_LATEST=y
# BR2_PACKAGE_QT5_VERSION_5_6 is not set
# qt53d module needs an OpenGL-capable backend
BR2_PACKAGE_QT5BASE=y
BR2_PACKAGE_QT5BASE_CUSTOM_CONF_OPTS=""
BR2_PACKAGE_QT5BASE_CONFIG_FILE=""
# BR2_PACKAGE_QT5BASE_EXAMPLES is not set
BR2_PACKAGE_QT5BASE_NETWORK=y
# BR2_PACKAGE_QT5BASE_CONCURRENT is not set
BR2_PACKAGE_QT5BASE_SQL=y
# BR2_PACKAGE_QT5BASE_MYSQL is not set
# BR2_PACKAGE_QT5BASE_PSQL is not set
BR2_PACKAGE_QT5BASE_SQLITE_NONE=y
# BR2_PACKAGE_QT5BASE_SQLITE_QT is not set
# BR2_PACKAGE_QT5BASE_SQLITE_SYSTEM is not set
BR2_PACKAGE_QT5BASE_TEST=y
BR2_PACKAGE_QT5BASE_XML=y
BR2_PACKAGE_QT5BASE_GUI=y
BR2_PACKAGE_QT5BASE_WIDGETS=y
# OpenGL support needs an OpenGL-capable backend
BR2_PACKAGE_QT5BASE_LINUXFB=y
# directfb backend available if directfb is enabled
# X.org XCB backend available if X.org is enabled
# eglfs backend available if OpenGL and EGL are enabled
BR2_PACKAGE_QT5BASE_DEFAULT_QPA=""
BR2_PACKAGE_QT5BASE_PRINTSUPPORT=y
# BR2_PACKAGE_QT5BASE_FONTCONFIG is not set
# BR2_PACKAGE_QT5BASE_GIF is not set
# BR2_PACKAGE_QT5BASE_JPEG is not set
# BR2_PACKAGE_QT5BASE_PNG is not set
# BR2_PACKAGE_QT5BASE_DBUS is not set
# BR2_PACKAGE_QT5BASE_ICU is not set
BR2_PACKAGE_QT5BASE_TSLIB=y
# qt5canvas3d needs an OpenGL-capable backend
# qt5connectivity needs neard and/or bluez(5)_utils
# BR2_PACKAGE_QT5DECLARATIVE is not set
# BR2_PACKAGE_QT5ENGINIO is not set
# qt5graphicaleffects needs an OpenGL-capable backend
# BR2_PACKAGE_QT5IMAGEFORMATS is not set
# BR2_PACKAGE_QT5LOCATION is not set
# BR2_PACKAGE_QT5MULTIMEDIA is not set
# qt5quickcontrols needs an OpenGL-capable backend
# qt5quickcontrols2 needs an OpenGL-capable backend
# BR2_PACKAGE_QT5SCRIPT is not set
# BR2_PACKAGE_QT5SENSORS is not set
# BR2_PACKAGE_QT5SERIALBUS is not set
# BR2_PACKAGE_QT5SERIALPORT is not set
# BR2_PACKAGE_QT5SVG is not set
# BR2_PACKAGE_QT5TOOLS is not set
# qt5virtualkeyboard needs at least qt-5.7 and an OpenGL backend
# BR2_PACKAGE_QT5WEBCHANNEL is not set
# BR2_PACKAGE_QT5WEBKIT is not set
# BR2_PACKAGE_QT5WEBSOCKETS is not set
# BR2_PACKAGE_QT5XMLPATTERNS is not set
# QT libraries and helper libraries
# BR2_PACKAGE_GRANTLEE is not set
# BR2_PACKAGE_QEXTSERIALPORT is not set
# BR2_PACKAGE_QJSON is not set
# BR2_PACKAGE_QUAZIP is not set
# BR2_PACKAGE_QWT is not set
# tekui needs a Lua interpreter and a toolchain w/ threads, dynamic library
# weston needs udev and a toolchain w/ locale, threads, dynamic library, headers >= 3.0
# BR2_PACKAGE_XORG7 is not set
# midori needs libgtk3 and a glibc toolchain w/ C++, gcc >= 5, host gcc >= 4.8
# BR2_PACKAGE_QT_WEBKIT_KIOSK is not set
# BR2_PACKAGE_XKEYBOARD_CONFIG is not set
# Hardware handling
# Firmware
# BR2_PACKAGE_AM33X_CM3 is not set
# BR2_PACKAGE_B43_FIRMWARE is not set
# BR2_PACKAGE_LINUX_FIRMWARE is not set
# BR2_PACKAGE_RPI_BT_FIRMWARE is not set
# BR2_PACKAGE_RPI_FIRMWARE is not set
# BR2_PACKAGE_RPI_WIFI_FIRMWARE is not set
# BR2_PACKAGE_SUNXI_BOARDS is not set
# BR2_PACKAGE_TS4900_FPGA is not set
# BR2_PACKAGE_UX500_FIRMWARE is not set
# BR2_PACKAGE_WILC1000_FIRMWARE is not set
# BR2_PACKAGE_WILINK_BT_FIRMWARE is not set
# BR2_PACKAGE_ZD1211_FIRMWARE is not set
# a10disp needs a Linux kernel to be built
# BR2_PACKAGE_ACPICA is not set
# BR2_PACKAGE_ACPITOOL is not set
# BR2_PACKAGE_AER_INJECT is not set
# BR2_PACKAGE_AM335X_PRU_PACKAGE is not set
# BR2_PACKAGE_AVRDUDE is not set
# bcache-tools needs udev /dev management
# BR2_PACKAGE_CBOOTIMAGE is not set
# BR2_PACKAGE_CC_TOOL is not set
# BR2_PACKAGE_CDRKIT is not set
# BR2_PACKAGE_CRYPTSETUP is not set
# BR2_PACKAGE_CWIID is not set
# BR2_PACKAGE_DBUS is not set
# BR2_PACKAGE_DMRAID is not set
# dt-utils needs udev /dev management
# BR2_PACKAGE_DTV_SCAN_TABLES is not set
# BR2_PACKAGE_DVB_APPS is not set
# BR2_PACKAGE_DVBSNOOP is not set
# BR2_PACKAGE_EDID_DECODE is not set
# BR2_PACKAGE_EEPROG is not set
# eudev needs eudev /dev management
# BR2_PACKAGE_EVEMU is not set
# BR2_PACKAGE_EVTEST is not set
# BR2_PACKAGE_FAN_CTRL is not set
# BR2_PACKAGE_FCONFIG is not set
# BR2_PACKAGE_FIS is not set
# BR2_PACKAGE_FMTOOLS is not set
# BR2_PACKAGE_FREESCALE_IMX is not set
# BR2_PACKAGE_FXLOAD is not set
# BR2_PACKAGE_GADGETFS_TEST is not set
# BR2_PACKAGE_GPM is not set
# BR2_PACKAGE_GPSD is not set
# BR2_PACKAGE_GPTFDISK is not set
# BR2_PACKAGE_GVFS is not set
# BR2_PACKAGE_HWDATA is not set
# BR2_PACKAGE_HWLOC is not set
# BR2_PACKAGE_INPUT_EVENT_DAEMON is not set
# BR2_PACKAGE_IOSTAT is not set
# BR2_PACKAGE_IPMITOOL is not set
# iqvlinux needs a Linux kernel to be built
# BR2_PACKAGE_IRDA_UTILS is not set
# BR2_PACKAGE_KBD is not set
# BR2_PACKAGE_LCDPROC is not set
# BR2_PACKAGE_LIBUIO is not set
# BR2_PACKAGE_LIBUMP is not set
# BR2_PACKAGE_LINUXCONSOLETOOLS is not set
# linux-backports needs a Linux kernel to be built
# BR2_PACKAGE_LIRC_TOOLS is not set
# BR2_PACKAGE_LM_SENSORS is not set
# BR2_PACKAGE_LSHW is not set
# BR2_PACKAGE_LSSCSI is not set
# BR2_PACKAGE_LSUIO is not set
# BR2_PACKAGE_LVM2 is not set
# BR2_PACKAGE_MALI_T76X is not set
# BR2_PACKAGE_MDADM is not set
# BR2_PACKAGE_MEMTESTER is not set
# BR2_PACKAGE_MEMTOOL is not set
# BR2_PACKAGE_MINICOM is not set
# BR2_PACKAGE_NANOCOM is not set
# BR2_PACKAGE_NEARD is not set
# BR2_PACKAGE_NVME is not set
# BR2_PACKAGE_ODROID_MALI is not set
# BR2_PACKAGE_ODROID_SCRIPTS is not set
# BR2_PACKAGE_OFONO is not set
# BR2_PACKAGE_OPEN2300 is not set
# BR2_PACKAGE_OPENIPMI is not set
# BR2_PACKAGE_OPENOCD is not set
# owl-linux needs a Linux kernel to be built
# owl-linux is only supported on ARM9 architecture
# BR2_PACKAGE_PARTED is not set
# BR2_PACKAGE_PCIUTILS is not set
# BR2_PACKAGE_PDBG is not set
# BR2_PACKAGE_PICOCOM is not set
# BR2_PACKAGE_PIFMRDS is not set
# BR2_PACKAGE_POWERTOP is not set
# BR2_PACKAGE_PPS_TOOLS is not set
# BR2_PACKAGE_PRU_SOFTWARE_SUPPORT is not set
# BR2_PACKAGE_PULSEVIEW is not set
# BR2_PACKAGE_READ_EDID is not set
# BR2_PACKAGE_RFKILL is not set
# BR2_PACKAGE_RNG_TOOLS is not set
# BR2_PACKAGE_RPI_USERLAND is not set
# BR2_PACKAGE_RS485CONF is not set
# rtl8188eu needs a Linux kernel to be built
# rtl8723bs needs a Linux kernel to be built
# rtl8821au needs a Linux kernel to be built
# BR2_PACKAGE_SANE_BACKENDS is not set
# BR2_PACKAGE_SDPARM is not set
# BR2_PACKAGE_SETSERIAL is not set
# BR2_PACKAGE_SG3_UTILS is not set
# BR2_PACKAGE_SIGROK_CLI is not set
# BR2_PACKAGE_SISPMCTL is not set
# BR2_PACKAGE_SMARTMONTOOLS is not set
# BR2_PACKAGE_SMSTOOLS3 is not set
# BR2_PACKAGE_SPI_TOOLS is not set
# BR2_PACKAGE_SREDIRD is not set
# BR2_PACKAGE_STATSERIAL is not set
# BR2_PACKAGE_STM32FLASH is not set
# BR2_PACKAGE_SUNXI_CEDARX is not set
# BR2_PACKAGE_SUNXI_MALI is not set
# BR2_PACKAGE_SYSSTAT is not set
# targetcli-fb depends on Python
# ti-gfx needs a glibc toolchain and a Linux kernel to be built
# ti-sgx-km needs a Linux kernel to be built
# ti-sgx-um needs the ti-sgx-km driver
# BR2_PACKAGE_TI_UIM is not set
# BR2_PACKAGE_TI_UTILS is not set
# BR2_PACKAGE_TRIGGERHAPPY is not set
# BR2_PACKAGE_UBOOT_TOOLS is not set
# BR2_PACKAGE_UBUS is not set
# uccp420wlan needs a Linux kernel >= 4.2 to be built
# udisks needs udev /dev management
# upower needs udev /dev management
# BR2_PACKAGE_USB_MODESWITCH is not set
# BR2_PACKAGE_USB_MODESWITCH_DATA is not set
# usbmount requires udev to be enabled
# usbutils needs udev /dev management and toolchain w/ threads
# BR2_PACKAGE_W_SCAN is not set
# BR2_PACKAGE_WIPE is not set
# BR2_PACKAGE_XORRISO is not set
# xr819-xradio driver needs a Linux kernel to be built
# Interpreter languages and scripting
# BR2_PACKAGE_4TH is not set
# BR2_PACKAGE_ENSCRIPT is not set
BR2_PACKAGE_ERLANG_ARCH_SUPPORTS=y
# BR2_PACKAGE_ERLANG is not set
# BR2_PACKAGE_EXECLINE is not set
# BR2_PACKAGE_FICL is not set
BR2_PACKAGE_GAUCHE_ARCH_SUPPORTS=y
# BR2_PACKAGE_GAUCHE is not set
# BR2_PACKAGE_GUILE is not set
# BR2_PACKAGE_HASERL is not set
# BR2_PACKAGE_JAMVM is not set
# BR2_PACKAGE_JIMTCL is not set
# BR2_PACKAGE_LUA is not set
BR2_PACKAGE_LUAJIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_LUAJIT is not set
# BR2_PACKAGE_MICROPYTHON is not set
# BR2_PACKAGE_MOARVM is not set
BR2_PACKAGE_MONO_ARCH_SUPPORTS=y
# BR2_PACKAGE_MONO is not set
BR2_PACKAGE_NODEJS_ARCH_SUPPORTS=y
# BR2_PACKAGE_NODEJS is not set
# BR2_PACKAGE_PERL is not set
# BR2_PACKAGE_PHP is not set
# BR2_PACKAGE_PYTHON is not set
# BR2_PACKAGE_PYTHON3 is not set
# BR2_PACKAGE_RUBY is not set
# BR2_PACKAGE_TCL is not set
# Libraries
# Audio/Sound
BR2_PACKAGE_ALSA_LIB=y
BR2_PACKAGE_ALSA_LIB_DEVDIR="/dev/snd"
BR2_PACKAGE_ALSA_LIB_PCM_PLUGINS="all"
BR2_PACKAGE_ALSA_LIB_CTL_PLUGINS="all"
BR2_PACKAGE_ALSA_LIB_ALOAD=y
BR2_PACKAGE_ALSA_LIB_MIXER=y
BR2_PACKAGE_ALSA_LIB_PCM=y
BR2_PACKAGE_ALSA_LIB_RAWMIDI=y
BR2_PACKAGE_ALSA_LIB_HWDEP=y
BR2_PACKAGE_ALSA_LIB_SEQ=y
BR2_PACKAGE_ALSA_LIB_ALISP=y
BR2_PACKAGE_ALSA_LIB_OLD_SYMBOLS=y
# BR2_PACKAGE_AUBIO is not set
# BR2_PACKAGE_AUDIOFILE is not set
# BR2_PACKAGE_CELT051 is not set
BR2_PACKAGE_FDK_AAC_ARCH_SUPPORTS=y
# BR2_PACKAGE_FDK_AAC is not set
# BR2_PACKAGE_LIBAO is not set
# BR2_PACKAGE_LIBASPLIB is not set
# BR2_PACKAGE_LIBBROADVOICE is not set
# BR2_PACKAGE_LIBCDAUDIO is not set
# BR2_PACKAGE_LIBCDDB is not set
# BR2_PACKAGE_LIBCDIO is not set
# BR2_PACKAGE_LIBCODEC2 is not set
# BR2_PACKAGE_LIBCUE is not set
# BR2_PACKAGE_LIBCUEFILE is not set
# BR2_PACKAGE_LIBEBUR128 is not set
# BR2_PACKAGE_LIBG7221 is not set
# BR2_PACKAGE_LIBGSM is not set
BR2_PACKAGE_LIBID3TAG=y
# BR2_PACKAGE_LIBILBC is not set
# BR2_PACKAGE_LIBLO is not set
BR2_PACKAGE_LIBMAD=y
BR2_PACKAGE_LIBMAD_OPTIMIZATION_DEFAULT=y
# BR2_PACKAGE_LIBMAD_OPTIMIZATION_SPEED is not set
# BR2_PACKAGE_LIBMAD_OPTIMIZATION_ACCURACY is not set
# BR2_PACKAGE_LIBMAD_SSO is not set
BR2_PACKAGE_LIBMAD_ASO=y
# BR2_PACKAGE_LIBMAD_STRICT_ISO is not set
# BR2_PACKAGE_LIBMODPLUG is not set
# BR2_PACKAGE_LIBMPD is not set
# BR2_PACKAGE_LIBMPDCLIENT is not set
# BR2_PACKAGE_LIBREPLAYGAIN is not set
# BR2_PACKAGE_LIBSAMPLERATE is not set
# BR2_PACKAGE_LIBSIDPLAY2 is not set
# BR2_PACKAGE_LIBSILK is not set
# BR2_PACKAGE_LIBSNDFILE is not set
# BR2_PACKAGE_LIBSOUNDTOUCH is not set
# BR2_PACKAGE_LIBSOXR is not set
# BR2_PACKAGE_LIBVORBIS is not set
# BR2_PACKAGE_MP4V2 is not set
BR2_PACKAGE_OPENAL_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENAL is not set
# BR2_PACKAGE_OPENCORE_AMR is not set
# BR2_PACKAGE_OPUS is not set
# BR2_PACKAGE_OPUSFILE is not set
# BR2_PACKAGE_PORTAUDIO is not set
# BR2_PACKAGE_SBC is not set
# BR2_PACKAGE_SPEEX is not set
# BR2_PACKAGE_TAGLIB is not set
# BR2_PACKAGE_TINYALSA is not set
# BR2_PACKAGE_TREMOR is not set
# BR2_PACKAGE_VO_AACENC is not set
BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING_ARCH_SUPPORTS=y
# BR2_PACKAGE_WEBRTC_AUDIO_PROCESSING is not set
# Compression and decompression
# BR2_PACKAGE_LIBARCHIVE is not set
# BR2_PACKAGE_LIBSQUISH is not set
# BR2_PACKAGE_LIBZIP is not set
# BR2_PACKAGE_LZO is not set
# BR2_PACKAGE_MINIZIP is not set
# BR2_PACKAGE_SNAPPY is not set
# BR2_PACKAGE_SZIP is not set
BR2_PACKAGE_ZLIB=y
# Crypto
# BR2_PACKAGE_BEECRYPT is not set
BR2_PACKAGE_BOTAN_ARCH_SUPPORTS=y
# BR2_PACKAGE_BOTAN is not set
# BR2_PACKAGE_CA_CERTIFICATES is not set
# cryptodev needs a Linux kernel to be built
# BR2_PACKAGE_GCR is not set
# BR2_PACKAGE_GNUTLS is not set
# BR2_PACKAGE_LIBASSUAN is not set
# BR2_PACKAGE_LIBGCRYPT is not set
BR2_PACKAGE_LIBGPG_ERROR_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBGPG_ERROR is not set
BR2_PACKAGE_LIBGPG_ERROR_SYSCFG="arm-unknown-linux-gnueabi"
# BR2_PACKAGE_LIBGPGME is not set
# BR2_PACKAGE_LIBKCAPI is not set
# BR2_PACKAGE_LIBKSBA is not set
# BR2_PACKAGE_LIBMCRYPT is not set
# BR2_PACKAGE_LIBMHASH is not set
# BR2_PACKAGE_LIBNSS is not set
# BR2_PACKAGE_LIBSCRYPT is not set
# BR2_PACKAGE_LIBSECRET is not set
# BR2_PACKAGE_LIBSHA1 is not set
# BR2_PACKAGE_LIBSODIUM is not set
# BR2_PACKAGE_LIBSSH is not set
# BR2_PACKAGE_LIBSSH2 is not set
# BR2_PACKAGE_LIBTOMCRYPT is not set
# BR2_PACKAGE_LIBUECC is not set
# BR2_PACKAGE_MBEDTLS is not set
# BR2_PACKAGE_NETTLE is not set
# BR2_PACKAGE_LIBRESSL is not set
# BR2_PACKAGE_OPENSSL is not set
# BR2_PACKAGE_RHASH is not set
# BR2_PACKAGE_TINYDTLS is not set
# BR2_PACKAGE_TROUSERS is not set
# BR2_PACKAGE_USTREAM_SSL is not set
# Database
# BR2_PACKAGE_BERKELEYDB is not set
# BR2_PACKAGE_GDBM is not set
# BR2_PACKAGE_HIREDIS is not set
# BR2_PACKAGE_KOMPEXSQLITE is not set
# BR2_PACKAGE_LEVELDB is not set
BR2_PACKAGE_MONGODB_ARCH_SUPPORTS=y
# BR2_PACKAGE_MONGODB is not set
# BR2_PACKAGE_MYSQL is not set
# BR2_PACKAGE_POSTGRESQL is not set
# BR2_PACKAGE_REDIS is not set
# BR2_PACKAGE_SQLCIPHER is not set
# BR2_PACKAGE_SQLITE is not set
# BR2_PACKAGE_UNIXODBC is not set
# Filesystem
# BR2_PACKAGE_GAMIN is not set
# BR2_PACKAGE_LIBCONFIG is not set
# BR2_PACKAGE_LIBCONFUSE is not set
# BR2_PACKAGE_LIBFUSE is not set
# BR2_PACKAGE_LIBLOCKFILE is not set
# BR2_PACKAGE_LIBNFS is not set
# BR2_PACKAGE_LIBSYSFS is not set
# BR2_PACKAGE_LOCKDEV is not set
# BR2_PACKAGE_PHYSFS is not set
# Graphics
# BR2_PACKAGE_ASSIMP is not set
# BR2_PACKAGE_ATK is not set
# BR2_PACKAGE_ATKMM is not set
# BR2_PACKAGE_BULLET is not set
# BR2_PACKAGE_CAIRO is not set
# BR2_PACKAGE_CAIROMM is not set
# BR2_PACKAGE_EXIV2 is not set
# BR2_PACKAGE_FONTCONFIG is not set
BR2_PACKAGE_FREETYPE=y
# BR2_PACKAGE_GD is not set
# BR2_PACKAGE_GDK_PIXBUF is not set
# BR2_PACKAGE_GIFLIB is not set
# granite needs libgtk3 and a toolchain w/ wchar, threads
# BR2_PACKAGE_GRAPHITE2 is not set
# gtkmm3 needs libgtk3 and a toolchain w/ C++, wchar, threads, gcc >= 4.8
# BR2_PACKAGE_HARFBUZZ is not set
# BR2_PACKAGE_IJS is not set
# irrlicht needs X11 and an OpenGL provider
# BR2_PACKAGE_IMLIB2 is not set
# BR2_PACKAGE_JASPER is not set
# BR2_PACKAGE_JPEG is not set
BR2_PACKAGE_JPEG_SIMD_SUPPORT=y
# BR2_PACKAGE_KMSXX is not set
# BR2_PACKAGE_LCMS2 is not set
# BR2_PACKAGE_LENSFUN is not set
# BR2_PACKAGE_LEPTONICA is not set
# BR2_PACKAGE_LIBART is not set
# BR2_PACKAGE_LIBDMTX is not set
# BR2_PACKAGE_LIBDRM is not set
# libepoxy needs an OpenGL and/or OpenGL EGL backend
# BR2_PACKAGE_LIBEXIF is not set
# libfm needs X.org and a toolchain w/ wchar, threads, C++
# BR2_PACKAGE_LIBFM_EXTRA is not set
# libfreeglut depends on X.org and needs an OpenGL backend
# BR2_PACKAGE_LIBFREEIMAGE is not set
# BR2_PACKAGE_LIBGEOTIFF is not set
# libglew depends on X.org and needs an OpenGL backend
# libglfw depends on X.org and needs an OpenGL backend
# libglu needs an OpenGL backend
# libgtk3 needs an OpenGL or an OpenGL-EGL/wayland backend
# BR2_PACKAGE_LIBMEDIAART is not set
# BR2_PACKAGE_LIBMNG is not set
BR2_PACKAGE_LIBPNG=y
# BR2_PACKAGE_LIBQRENCODE is not set
# BR2_PACKAGE_LIBRAW is not set
# BR2_PACKAGE_LIBRSVG is not set
# libsoil needs an OpenGL backend and a toolchain w/ dynamic library
# BR2_PACKAGE_LIBSVG is not set
# BR2_PACKAGE_LIBSVG_CAIRO is not set
# BR2_PACKAGE_LIBSVGTINY is not set
# BR2_PACKAGE_LIBVA is not set
# BR2_PACKAGE_LIBVIPS is not set
# BR2_PACKAGE_MENU_CACHE is not set
# BR2_PACKAGE_OPENCV is not set
# BR2_PACKAGE_OPENCV3 is not set
# BR2_PACKAGE_OPENJPEG is not set
# BR2_PACKAGE_PANGO is not set
# BR2_PACKAGE_PANGOMM is not set
# BR2_PACKAGE_PIXMAN is not set
# BR2_PACKAGE_POPPLER is not set
# BR2_PACKAGE_TIFF is not set
# BR2_PACKAGE_WAYLAND is not set
BR2_PACKAGE_WEBKITGTK_ARCH_SUPPORTS=y
# webkitgtk needs libgtk3 and a glibc toolchain w/ C++, gcc >= 5, host gcc >= 4.8
# BR2_PACKAGE_WEBP is not set
# BR2_PACKAGE_ZBAR is not set
# BR2_PACKAGE_ZXING_CPP is not set
# Hardware handling
# BR2_PACKAGE_ACSCCID is not set
# BR2_PACKAGE_BCM2835 is not set
# BR2_PACKAGE_C_PERIPHERY is not set
# BR2_PACKAGE_CCID is not set
# BR2_PACKAGE_DTC is not set
# BR2_PACKAGE_GNU_EFI is not set
# hidapi needs udev /dev management and a toolchain w/ NPTL threads
# BR2_PACKAGE_LCDAPI is not set
# BR2_PACKAGE_LET_ME_CREATE is not set
BR2_PACKAGE_LIBAIO_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBAIO is not set
# libatasmart requires udev to be enabled
# BR2_PACKAGE_LIBCEC is not set
# BR2_PACKAGE_LIBFREEFARE is not set
# BR2_PACKAGE_LIBFTDI is not set
# BR2_PACKAGE_LIBFTDI1 is not set
# BR2_PACKAGE_LIBGPHOTO2 is not set
# libgpiod needs kernel headers >= 4.8
# libgudev needs udev /dev handling and a toolchain w/ wchar, threads
# BR2_PACKAGE_LIBHID is not set
# BR2_PACKAGE_LIBIIO is not set
# libinput needs udev /dev management and a toolchain w/ locale
# BR2_PACKAGE_LIBIQRF is not set
# BR2_PACKAGE_LIBLLCP is not set
# libmbim needs udev /dev management and a toolchain w/ wchar, threads
# BR2_PACKAGE_LIBNFC is not set
# BR2_PACKAGE_LIBPCIACCESS is not set
# BR2_PACKAGE_LIBPHIDGET is not set
# BR2_PACKAGE_LIBQMI is not set
# BR2_PACKAGE_LIBRAW1394 is not set
# BR2_PACKAGE_LIBRTLSDR is not set
# BR2_PACKAGE_LIBSERIAL is not set
# BR2_PACKAGE_LIBSERIALPORT is not set
# BR2_PACKAGE_LIBSIGROK is not set
# BR2_PACKAGE_LIBSIGROKDECODE is not set
# BR2_PACKAGE_LIBSOC is not set
# BR2_PACKAGE_LIBUSB is not set
# BR2_PACKAGE_LIBUSBGX is not set
# BR2_PACKAGE_LIBV4L is not set
# BR2_PACKAGE_LIBXKBCOMMON is not set
# BR2_PACKAGE_MRAA is not set
# BR2_PACKAGE_MTDEV is not set
# ne10 needs a toolchain w/ neon
# BR2_PACKAGE_NEARDAL is not set
# BR2_PACKAGE_OWFS is not set
# BR2_PACKAGE_PCSC_LITE is not set
BR2_PACKAGE_TSLIB=y
# BR2_PACKAGE_URG is not set
# BR2_PACKAGE_WIRINGPI is not set
# Javascript
# BR2_PACKAGE_ANGULARJS is not set
# BR2_PACKAGE_BOOTSTRAP is not set
# BR2_PACKAGE_EXPLORERCANVAS is not set
# BR2_PACKAGE_FLOT is not set
# BR2_PACKAGE_JQUERY is not set
# BR2_PACKAGE_JSMIN is not set
# BR2_PACKAGE_JSON_JAVASCRIPT is not set
# JSON/XML
# BR2_PACKAGE_BENEJSON is not set
# BR2_PACKAGE_CJSON is not set
# BR2_PACKAGE_EXPAT is not set
# BR2_PACKAGE_EZXML is not set
# BR2_PACKAGE_JANSSON is not set
# BR2_PACKAGE_JSMN is not set
# BR2_PACKAGE_JSON_C is not set
# BR2_PACKAGE_JSON_GLIB is not set
# BR2_PACKAGE_JSONCPP is not set
# BR2_PACKAGE_LIBBSON is not set
# BR2_PACKAGE_LIBFASTJSON is not set
# BR2_PACKAGE_LIBJSON is not set
# BR2_PACKAGE_LIBROXML is not set
# BR2_PACKAGE_LIBUCL is not set
# BR2_PACKAGE_LIBXML2 is not set
# BR2_PACKAGE_LIBXMLPP is not set
# BR2_PACKAGE_LIBXMLRPC is not set
# BR2_PACKAGE_LIBXSLT is not set
# BR2_PACKAGE_LIBYAML is not set
# BR2_PACKAGE_MXML is not set
# BR2_PACKAGE_PUGIXML is not set
# BR2_PACKAGE_RAPIDJSON is not set
# BR2_PACKAGE_RAPIDXML is not set
# BR2_PACKAGE_RAPTOR is not set
# BR2_PACKAGE_TINYXML is not set
# BR2_PACKAGE_TINYXML2 is not set
# BR2_PACKAGE_VALIJSON is not set
# BR2_PACKAGE_XERCES is not set
# BR2_PACKAGE_YAJL is not set
# BR2_PACKAGE_YAML_CPP is not set
# Logging
# BR2_PACKAGE_EVENTLOG is not set
# BR2_PACKAGE_GLOG is not set
# BR2_PACKAGE_LIBLOG4C_LOCALTIME is not set
# BR2_PACKAGE_LIBLOGGING is not set
# BR2_PACKAGE_LOG4CPLUS is not set
# BR2_PACKAGE_LOG4CPP is not set
# BR2_PACKAGE_LOG4CXX is not set
# BR2_PACKAGE_ZLOG is not set
# Multimedia
# BR2_PACKAGE_BITSTREAM is not set
# BR2_PACKAGE_KVAZAAR is not set
# BR2_PACKAGE_LIBAACS is not set
# BR2_PACKAGE_LIBAMCODEC is not set
# BR2_PACKAGE_LIBASS is not set
# BR2_PACKAGE_LIBBDPLUS is not set
# BR2_PACKAGE_LIBBLURAY is not set
# BR2_PACKAGE_LIBDCADEC is not set
# BR2_PACKAGE_LIBDVBCSA is not set
# BR2_PACKAGE_LIBDVBPSI is not set
# BR2_PACKAGE_LIBDVBSI is not set
# BR2_PACKAGE_LIBDVDCSS is not set
# BR2_PACKAGE_LIBDVDNAV is not set
# BR2_PACKAGE_LIBDVDREAD is not set
# BR2_PACKAGE_LIBEBML is not set
# BR2_PACKAGE_LIBHDHOMERUN is not set
# libimxvpuapi needs an i.MX platform with VPU support
# BR2_PACKAGE_LIBMATROSKA is not set
# BR2_PACKAGE_LIBMMS is not set
# BR2_PACKAGE_LIBMPEG2 is not set
# BR2_PACKAGE_LIBOGG is not set
BR2_PACKAGE_LIBOPENH264_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBOPENH264 is not set
# BR2_PACKAGE_LIBPLAYER is not set
# BR2_PACKAGE_LIBTHEORA is not set
# BR2_PACKAGE_LIBVPX is not set
# BR2_PACKAGE_LIBYUV is not set
# BR2_PACKAGE_LIVE555 is not set
# BR2_PACKAGE_MEDIASTREAMER is not set
# BR2_PACKAGE_X264 is not set
# BR2_PACKAGE_X265 is not set
# Networking
# BR2_PACKAGE_AGENTPP is not set
# BR2_PACKAGE_ALLJOYN is not set
# BR2_PACKAGE_ALLJOYN_BASE is not set
# BR2_PACKAGE_ALLJOYN_TCL is not set
# BR2_PACKAGE_ALLJOYN_TCL_BASE is not set
# BR2_PACKAGE_AZURE_IOT_SDK_C is not set
# batman-adv needs a Linux kernel to be built
# BR2_PACKAGE_C_ARES is not set
BR2_PACKAGE_CANFESTIVAL_ARCH_SUPPORTS=y
# BR2_PACKAGE_CANFESTIVAL is not set
# BR2_PACKAGE_CGIC is not set
# BR2_PACKAGE_CPPZMQ is not set
# BR2_PACKAGE_CZMQ is not set
# BR2_PACKAGE_FILEMQ is not set
# BR2_PACKAGE_FLICKCURL is not set
# BR2_PACKAGE_FREERADIUS_CLIENT is not set
# BR2_PACKAGE_GEOIP is not set
# BR2_PACKAGE_GLIB_NETWORKING is not set
# BR2_PACKAGE_GSSDP is not set
# BR2_PACKAGE_GUPNP is not set
# BR2_PACKAGE_GUPNP_AV is not set
# BR2_PACKAGE_GUPNP_DLNA is not set
# BR2_PACKAGE_IBRCOMMON is not set
# BR2_PACKAGE_IBRDTN is not set
# BR2_PACKAGE_LIBCGI is not set
# BR2_PACKAGE_LIBCGICC is not set
# BR2_PACKAGE_LIBCOAP is not set
# BR2_PACKAGE_LIBCURL is not set
# BR2_PACKAGE_LIBDNET is not set
# BR2_PACKAGE_LIBEXOSIP2 is not set
# BR2_PACKAGE_LIBFCGI is not set
# BR2_PACKAGE_LIBGSASL is not set
# BR2_PACKAGE_LIBHTTPPARSER is not set
# BR2_PACKAGE_LIBIDN is not set
# BR2_PACKAGE_LIBISCSI is not set
# BR2_PACKAGE_LIBLDNS is not set
# BR2_PACKAGE_LIBMAXMINDDB is not set
# BR2_PACKAGE_LIBMBUS is not set
# BR2_PACKAGE_LIBMEMCACHED is not set
# BR2_PACKAGE_LIBMICROHTTPD is not set
# BR2_PACKAGE_LIBMINIUPNPC is not set
# BR2_PACKAGE_LIBMNL is not set
# BR2_PACKAGE_LIBMODBUS is not set
# BR2_PACKAGE_LIBNATPMP is not set
# BR2_PACKAGE_LIBNDP is not set
# BR2_PACKAGE_LIBNET is not set
# BR2_PACKAGE_LIBNETFILTER_ACCT is not set
# BR2_PACKAGE_LIBNETFILTER_CONNTRACK is not set
# BR2_PACKAGE_LIBNETFILTER_CTHELPER is not set
# BR2_PACKAGE_LIBNETFILTER_CTTIMEOUT is not set
# BR2_PACKAGE_LIBNETFILTER_LOG is not set
# BR2_PACKAGE_LIBNETFILTER_QUEUE is not set
# BR2_PACKAGE_LIBNFNETLINK is not set
# BR2_PACKAGE_LIBNFTNL is not set
# BR2_PACKAGE_LIBNICE is not set
# BR2_PACKAGE_LIBNL is not set
# BR2_PACKAGE_LIBOAUTH is not set
# BR2_PACKAGE_LIBOPING is not set
# BR2_PACKAGE_LIBOSIP2 is not set
# BR2_PACKAGE_LIBPCAP is not set
# BR2_PACKAGE_LIBPJSIP is not set
# BR2_PACKAGE_LIBRSYNC is not set
# BR2_PACKAGE_LIBSHAIRPLAY is not set
# BR2_PACKAGE_LIBSHOUT is not set
# BR2_PACKAGE_LIBSOCKETCAN is not set
# BR2_PACKAGE_LIBSOUP is not set
# BR2_PACKAGE_LIBSRTP is not set
# BR2_PACKAGE_LIBSTROPHE is not set
# BR2_PACKAGE_LIBTIRPC is not set
# BR2_PACKAGE_LIBTORRENT is not set
# BR2_PACKAGE_LIBUPNP is not set
# BR2_PACKAGE_LIBUPNPP is not set
# BR2_PACKAGE_LIBURIPARSER is not set
# BR2_PACKAGE_LIBVNCSERVER is not set
# BR2_PACKAGE_LIBWEBSOCK is not set
# BR2_PACKAGE_LIBWEBSOCKETS is not set
# BR2_PACKAGE_LKSCTP_TOOLS is not set
# BR2_PACKAGE_MONGOOSE is not set
# BR2_PACKAGE_NANOMSG is not set
# BR2_PACKAGE_NEON is not set
# BR2_PACKAGE_NORM is not set
# BR2_PACKAGE_NSS_PAM_LDAPD is not set
# BR2_PACKAGE_OMNIORB is not set
# BR2_PACKAGE_OPENLDAP is not set
# BR2_PACKAGE_OPENMPI is not set
# BR2_PACKAGE_OPENPGM is not set
# openzwave needs udev and a toolchain w/ C++, threads, wchar
# BR2_PACKAGE_ORTP is not set
# BR2_PACKAGE_PAHO_MQTT_C is not set
# BR2_PACKAGE_QDECODER is not set
# BR2_PACKAGE_QPID_PROTON is not set
# BR2_PACKAGE_RABBITMQ_C is not set
# BR2_PACKAGE_RTMPDUMP is not set
# BR2_PACKAGE_SLIRP is not set
# BR2_PACKAGE_SNMPPP is not set
# BR2_PACKAGE_SOFIA_SIP is not set
# BR2_PACKAGE_THRIFT is not set
# BR2_PACKAGE_USBREDIR is not set
# BR2_PACKAGE_ZEROMQ is not set
# BR2_PACKAGE_ZMQPP is not set
# BR2_PACKAGE_ZYRE is not set
# Other
# BR2_PACKAGE_APR is not set
# BR2_PACKAGE_APR_UTIL is not set
# BR2_PACKAGE_ARMADILLO is not set
# BR2_PACKAGE_ATF is not set
# BR2_PACKAGE_BCTOOLBOX is not set
# BR2_PACKAGE_BDWGC is not set
# BR2_PACKAGE_BOOST is not set
# BR2_PACKAGE_CLAPACK is not set
BR2_PACKAGE_CLASSPATH_ARCH_SUPPORTS=y
# BR2_PACKAGE_CLASSPATH is not set
# BR2_PACKAGE_CPPCMS is not set
# BR2_PACKAGE_CRACKLIB is not set
# BR2_PACKAGE_DAWGDIC is not set
# BR2_PACKAGE_DING_LIBS is not set
# BR2_PACKAGE_EIGEN is not set
# BR2_PACKAGE_ELFUTILS is not set
# BR2_PACKAGE_FFTW is not set
# BR2_PACKAGE_FLANN is not set
# BR2_PACKAGE_GFLAGS is not set
# BR2_PACKAGE_GLIBMM is not set
# BR2_PACKAGE_GLM is not set
# BR2_PACKAGE_GMP is not set
# BR2_PACKAGE_GSL is not set
# BR2_PACKAGE_GTEST is not set
BR2_PACKAGE_JEMALLOC_ARCH_SUPPORTS=y
# BR2_PACKAGE_JEMALLOC is not set
# BR2_PACKAGE_LAPACK is not set
# BR2_PACKAGE_LIBARGTABLE2 is not set
BR2_PACKAGE_LIBATOMIC_OPS_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBATOMIC_OPS is not set
BR2_PACKAGE_LIBBSD_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBBSD is not set
# BR2_PACKAGE_LIBCAP is not set
# BR2_PACKAGE_LIBCAP_NG is not set
# BR2_PACKAGE_LIBCGROUP is not set
# BR2_PACKAGE_LIBCOFI is not set
# BR2_PACKAGE_LIBCROCO is not set
# BR2_PACKAGE_LIBCROSSGUID is not set
# BR2_PACKAGE_LIBCSV is not set
# BR2_PACKAGE_LIBDAEMON is not set
# BR2_PACKAGE_LIBEE is not set
# BR2_PACKAGE_LIBEV is not set
# BR2_PACKAGE_LIBEVDEV is not set
# BR2_PACKAGE_LIBEVENT is not set
# BR2_PACKAGE_LIBFFI is not set
# BR2_PACKAGE_LIBGEE is not set
# BR2_PACKAGE_LIBGLIB2 is not set
# BR2_PACKAGE_LIBGLOB is not set
# BR2_PACKAGE_LIBICAL is not set
# BR2_PACKAGE_LIBITE is not set
# BR2_PACKAGE_LIBLINEAR is not set
# BR2_PACKAGE_LIBLOKI is not set
# BR2_PACKAGE_LIBNPTH is not set
BR2_PACKAGE_LIBNSPR_ARCH_SUPPORT=y
# BR2_PACKAGE_LIBNSPR is not set
# BR2_PACKAGE_LIBPFM4 is not set
# BR2_PACKAGE_LIBPLIST is not set
# BR2_PACKAGE_LIBPTHREAD_STUBS is not set
# BR2_PACKAGE_LIBPTHSEM is not set
# BR2_PACKAGE_LIBPWQUALITY is not set
BR2_PACKAGE_LIBSECCOMP_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSECCOMP is not set
# BR2_PACKAGE_LIBSIGC is not set
BR2_PACKAGE_LIBSIGSEGV_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBSIGSEGV is not set
# BR2_PACKAGE_LIBSPATIALINDEX is not set
# BR2_PACKAGE_LIBTASN1 is not set
# BR2_PACKAGE_LIBTOMMATH is not set
# BR2_PACKAGE_LIBTPL is not set
# BR2_PACKAGE_LIBUBOX is not set
# BR2_PACKAGE_LIBUCI is not set
BR2_PACKAGE_LIBUNWIND_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBUNWIND is not set
BR2_PACKAGE_LIBURCU_ARCH_SUPPORTS=y
# BR2_PACKAGE_LIBURCU is not set
# BR2_PACKAGE_LIBUV is not set
# BR2_PACKAGE_LIGHTNING is not set
# BR2_PACKAGE_LINUX_PAM is not set
# BR2_PACKAGE_LIQUID_DSP is not set
# BR2_PACKAGE_LTTNG_LIBUST is not set
# BR2_PACKAGE_MPC is not set
# BR2_PACKAGE_MPDECIMAL is not set
# BR2_PACKAGE_MPFR is not set
# BR2_PACKAGE_MPIR is not set
# BR2_PACKAGE_MSGPACK is not set
# BR2_PACKAGE_MTDEV2TUIO is not set
BR2_PACKAGE_OPENBLAS_DEFAULT_TARGET="ARMV7"
BR2_PACKAGE_OPENBLAS_ARCH_SUPPORTS=y
# BR2_PACKAGE_OPENBLAS is not set
# BR2_PACKAGE_ORC is not set
# BR2_PACKAGE_P11_KIT is not set
# BR2_PACKAGE_POCO is not set
BR2_PACKAGE_PROTOBUF_ARCH_SUPPORTS=y
# BR2_PACKAGE_PROTOBUF is not set
# BR2_PACKAGE_PROTOBUF_C is not set
# BR2_PACKAGE_QHULL is not set
# BR2_PACKAGE_QLIBC is not set
# BR2_PACKAGE_RIEMANN_C_CLIENT is not set
# BR2_PACKAGE_SHAPELIB is not set
# BR2_PACKAGE_SKALIBS is not set
# BR2_PACKAGE_SPHINXBASE is not set
# BR2_PACKAGE_TINYCBOR is not set
# Security
# BR2_PACKAGE_LIBSELINUX is not set
# BR2_PACKAGE_LIBSEMANAGE is not set
# BR2_PACKAGE_LIBSEPOL is not set
# Text and terminal handling
# BR2_PACKAGE_AUGEAS is not set
# BR2_PACKAGE_ENCHANT is not set
# BR2_PACKAGE_FMT is not set
# BR2_PACKAGE_ICU is not set
# BR2_PACKAGE_LIBCLI is not set
# BR2_PACKAGE_LIBEDIT is not set
# BR2_PACKAGE_LIBENCA is not set
# BR2_PACKAGE_LIBESTR is not set
# BR2_PACKAGE_LIBFRIBIDI is not set
# BR2_PACKAGE_LIBUNISTRING is not set
# BR2_PACKAGE_LINENOISE is not set
BR2_PACKAGE_NCURSES=y
# BR2_PACKAGE_NCURSES_WCHAR is not set
# BR2_PACKAGE_NCURSES_TARGET_PROGS is not set
# BR2_PACKAGE_NEWT is not set
# BR2_PACKAGE_PCRE is not set
BR2_PACKAGE_PCRE2=y
BR2_PACKAGE_PCRE2_16=y
# BR2_PACKAGE_PCRE2_32 is not set
# BR2_PACKAGE_POPT is not set
# BR2_PACKAGE_READLINE is not set
# BR2_PACKAGE_SLANG is not set
# BR2_PACKAGE_TCLAP is not set
# BR2_PACKAGE_USTR is not set
# Mail
# BR2_PACKAGE_DOVECOT is not set
# BR2_PACKAGE_EXIM is not set
# BR2_PACKAGE_FETCHMAIL is not set
# BR2_PACKAGE_HEIRLOOM_MAILX is not set
# BR2_PACKAGE_LIBESMTP is not set
# BR2_PACKAGE_MSMTP is not set
# BR2_PACKAGE_MUTT is not set
# Miscellaneous
# BR2_PACKAGE_AESPIPE is not set
# BR2_PACKAGE_BC is not set
# BR2_PACKAGE_CLAMAV is not set
# BR2_PACKAGE_COLLECTD is not set
# domoticz needs lua >= 5.2 and a toolchain w/ C++, threads, wchar, dynamic library
# BR2_PACKAGE_EMPTY is not set
# BR2_PACKAGE_GNURADIO is not set
# BR2_PACKAGE_GOOGLEFONTDIRECTORY is not set
# gqrx needs qt5, gnuradio, fftw's single precision
# BR2_PACKAGE_GSETTINGS_DESKTOP_SCHEMAS is not set
# BR2_PACKAGE_HAVEGED is not set
# BR2_PACKAGE_LINUX_SYSCALL_SUPPORT is not set
# BR2_PACKAGE_MCRYPT is not set
# BR2_PACKAGE_MOBILE_BROADBAND_PROVIDER_INFO is not set
BR2_PACKAGE_QEMU_ARCH_SUPPORTS_TARGET=y
# BR2_PACKAGE_QEMU is not set
# BR2_PACKAGE_QPDF is not set
# BR2_PACKAGE_SHARED_MIME_INFO is not set
# BR2_PACKAGE_TASKD is not set
# BR2_PACKAGE_XUTIL_UTIL_MACROS is not set
# Networking applications
# BR2_PACKAGE_AICCU is not set
# BR2_PACKAGE_AIRCRACK_NG is not set
# BR2_PACKAGE_APACHE is not set
# BR2_PACKAGE_ARGUS is not set
# BR2_PACKAGE_ARP_SCAN is not set
# BR2_PACKAGE_ARPTABLES is not set
# BR2_PACKAGE_ATFTP is not set
# BR2_PACKAGE_AVAHI is not set
# BR2_PACKAGE_AXEL is not set
# BR2_PACKAGE_BABELD is not set
# BR2_PACKAGE_BANDWIDTHD is not set
# BR2_PACKAGE_BATCTL is not set
# BR2_PACKAGE_BCUSDK is not set
# BR2_PACKAGE_BIND is not set
# BR2_PACKAGE_BLUEZ_UTILS is not set
# BR2_PACKAGE_BLUEZ5_UTILS is not set
# BR2_PACKAGE_BMON is not set
# BR2_PACKAGE_BOA is not set
# BR2_PACKAGE_BRIDGE_UTILS is not set
# BR2_PACKAGE_BWM_NG is not set
# BR2_PACKAGE_C_ICAP is not set
# BR2_PACKAGE_CAN_UTILS is not set
# BR2_PACKAGE_CANNELLONI is not set
# BR2_PACKAGE_CHRONY is not set
# BR2_PACKAGE_CIVETWEB is not set
# BR2_PACKAGE_CONNMAN is not set
# connman-gtk needs libgtk3 and a glibc or uClibc toolchain w/ wchar, threads, resolver, dynamic library
# BR2_PACKAGE_CONNTRACK_TOOLS is not set
# BR2_PACKAGE_CRDA is not set
# BR2_PACKAGE_CTORRENT is not set
# BR2_PACKAGE_CUPS is not set
# BR2_PACKAGE_DANTE is not set
# BR2_PACKAGE_DARKHTTPD is not set
# BR2_PACKAGE_DHCPCD is not set
# BR2_PACKAGE_DHCPDUMP is not set
# BR2_PACKAGE_DNSMASQ is not set
# BR2_PACKAGE_DRBD_UTILS is not set
# BR2_PACKAGE_DROPBEAR is not set
# BR2_PACKAGE_EBTABLES is not set
# ebtables needs a glibc or uClibc toolchain
# ejabberd needs erlang, toolchain w/ C++
# BR2_PACKAGE_ETHTOOL is not set
# BR2_PACKAGE_FAIFA is not set
# BR2_PACKAGE_FASTD is not set
# BR2_PACKAGE_FCGIWRAP is not set
# BR2_PACKAGE_FLANNEL is not set
# BR2_PACKAGE_FPING is not set
# BR2_PACKAGE_FREESWITCH is not set
# BR2_PACKAGE_GESFTPSERVER is not set
# gupnp-tools needs libgtk3
# BR2_PACKAGE_HANS is not set
# BR2_PACKAGE_HIAWATHA is not set
# BR2_PACKAGE_HOSTAPD is not set
# BR2_PACKAGE_HTTPING is not set
# BR2_PACKAGE_IBRDTN_TOOLS is not set
# BR2_PACKAGE_IBRDTND is not set
# BR2_PACKAGE_IFTOP is not set
BR2_PACKAGE_IFUPDOWN_SCRIPTS=y
# BR2_PACKAGE_IGD2_FOR_LINUX is not set
# igh-ethercat needs a Linux kernel to be built
# BR2_PACKAGE_IGMPPROXY is not set
# BR2_PACKAGE_INADYN is not set
# BR2_PACKAGE_IODINE is not set
# BR2_PACKAGE_IPERF is not set
# BR2_PACKAGE_IPERF3 is not set
# BR2_PACKAGE_IPROUTE2 is not set
# BR2_PACKAGE_IPSEC_TOOLS is not set
# BR2_PACKAGE_IPSET is not set
# BR2_PACKAGE_IPTABLES is not set
# BR2_PACKAGE_IPTRAF_NG is not set
# BR2_PACKAGE_IPUTILS is not set
# BR2_PACKAGE_IRSSI is not set
# BR2_PACKAGE_IW is not set
# BR2_PACKAGE_JANUS_GATEWAY is not set
# BR2_PACKAGE_KEEPALIVED is not set
# BR2_PACKAGE_KISMET is not set
# BR2_PACKAGE_KNOCK is not set
# BR2_PACKAGE_LEAFNODE2 is not set
# BR2_PACKAGE_LFT is not set
# BR2_PACKAGE_LFTP is not set
# BR2_PACKAGE_LIGHTTPD is not set
# BR2_PACKAGE_LINKNX is not set
# BR2_PACKAGE_LINKS is not set
# BR2_PACKAGE_LINPHONE is not set
# BR2_PACKAGE_LINUX_ZIGBEE is not set
# BR2_PACKAGE_LINUXPTP is not set
# BR2_PACKAGE_LLDPD is not set
# BR2_PACKAGE_LRZSZ is not set
# BR2_PACKAGE_MACCHANGER is not set
# BR2_PACKAGE_MEMCACHED is not set
# BR2_PACKAGE_MII_DIAG is not set
# BR2_PACKAGE_MINIDLNA is not set
# BR2_PACKAGE_MINISSDPD is not set
# BR2_PACKAGE_MJPG_STREAMER is not set
# modemmanager needs udev /dev management and a toolchain w/ wchar, threads
BR2_PACKAGE_MONGREL2_LIBC_SUPPORTS=y
# BR2_PACKAGE_MONGREL2 is not set
# BR2_PACKAGE_MONKEY is not set
# BR2_PACKAGE_MOSH is not set
# BR2_PACKAGE_MOSQUITTO is not set
# BR2_PACKAGE_MROUTED is not set
# BR2_PACKAGE_MTR is not set
# BR2_PACKAGE_NBD is not set
# BR2_PACKAGE_NCFTP is not set
# BR2_PACKAGE_NDISC6 is not set
# BR2_PACKAGE_NETATALK is not set
# BR2_PACKAGE_NETPLUG is not set
# BR2_PACKAGE_NETSNMP is not set
# BR2_PACKAGE_NETSTAT_NAT is not set
# NetworkManager needs udev /dev management and a glibc toolchain w/ headers >= 3.7, dynamic library
# BR2_PACKAGE_NFACCT is not set
# BR2_PACKAGE_NFTABLES is not set
# BR2_PACKAGE_NGINX is not set
# BR2_PACKAGE_NGIRCD is not set
# BR2_PACKAGE_NGREP is not set
# BR2_PACKAGE_NLOAD is not set
# BR2_PACKAGE_NMAP is not set
# BR2_PACKAGE_NOIP is not set
# BR2_PACKAGE_NTP is not set
# BR2_PACKAGE_NUTTCP is not set
# BR2_PACKAGE_ODHCP6C is not set
# BR2_PACKAGE_ODHCPLOC is not set
# BR2_PACKAGE_OLSR is not set
# BR2_PACKAGE_OPEN_PLC_UTILS is not set
# BR2_PACKAGE_OPENNTPD is not set
# BR2_PACKAGE_OPENOBEX is not set
# BR2_PACKAGE_OPENSSH is not set
# BR2_PACKAGE_OPENSWAN is not set
# BR2_PACKAGE_OPENVPN is not set
# BR2_PACKAGE_P910ND is not set
# BR2_PACKAGE_PHIDGETWEBSERVICE is not set
# BR2_PACKAGE_PHYTOOL is not set
# BR2_PACKAGE_POUND is not set
# BR2_PACKAGE_PPPD is not set
# BR2_PACKAGE_PPTP_LINUX is not set
# BR2_PACKAGE_PRIVOXY is not set
# BR2_PACKAGE_PROFTPD is not set
# BR2_PACKAGE_PROXYCHAINS_NG is not set
# BR2_PACKAGE_PTPD is not set
# BR2_PACKAGE_PTPD2 is not set
# BR2_PACKAGE_PURE_FTPD is not set
# BR2_PACKAGE_PUTTY is not set
# BR2_PACKAGE_QUAGGA is not set
# rabbitmq-server needs erlang
# BR2_PACKAGE_RADVD is not set
# BR2_PACKAGE_RP_PPPOE is not set
# BR2_PACKAGE_RPCBIND is not set
# BR2_PACKAGE_RSH_REDONE is not set
# BR2_PACKAGE_RSYNC is not set
# BR2_PACKAGE_RTORRENT is not set
# BR2_PACKAGE_RTPTOOLS is not set
# BR2_PACKAGE_S6_DNS is not set
# BR2_PACKAGE_S6_NETWORKING is not set
# BR2_PACKAGE_SAMBA4 is not set
# BR2_PACKAGE_SCONESERVER is not set
# BR2_PACKAGE_SER2NET is not set
# BR2_PACKAGE_SHAIRPORT_SYNC is not set
# BR2_PACKAGE_SHELLINABOX is not set
# BR2_PACKAGE_SMCROUTE is not set
# BR2_PACKAGE_SNGREP is not set
# BR2_PACKAGE_SOCAT is not set
# BR2_PACKAGE_SOCKETCAND is not set
# BR2_PACKAGE_SOFTETHER is not set
# BR2_PACKAGE_SPAWN_FCGI is not set
# BR2_PACKAGE_SPICE_PROTOCOL is not set
# BR2_PACKAGE_SQUID is not set
# BR2_PACKAGE_SSHPASS is not set
# BR2_PACKAGE_SSLH is not set
# BR2_PACKAGE_STRONGSWAN is not set
# BR2_PACKAGE_STUNNEL is not set
# BR2_PACKAGE_TCPDUMP is not set
# BR2_PACKAGE_TCPING is not set
# BR2_PACKAGE_TCPREPLAY is not set
# BR2_PACKAGE_THTTPD is not set
# BR2_PACKAGE_TINC is not set
# BR2_PACKAGE_TINYHTTPD is not set
# BR2_PACKAGE_TN5250 is not set
# BR2_PACKAGE_TOR is not set
# BR2_PACKAGE_TRANSMISSION is not set
# BR2_PACKAGE_TUNCTL is not set
# BR2_PACKAGE_TVHEADEND is not set
# BR2_PACKAGE_UDPCAST is not set
# BR2_PACKAGE_UHTTPD is not set
# BR2_PACKAGE_ULOGD is not set
# BR2_PACKAGE_USHARE is not set
# BR2_PACKAGE_USSP_PUSH is not set
# BR2_PACKAGE_VDE2 is not set
# BR2_PACKAGE_VDR is not set
# BR2_PACKAGE_VNSTAT is not set
# BR2_PACKAGE_VPNC is not set
# BR2_PACKAGE_VSFTPD is not set
# BR2_PACKAGE_VTUN is not set
# BR2_PACKAGE_WAVEMON is not set
# BR2_PACKAGE_WIRELESS_REGDB is not set
# BR2_PACKAGE_WIRELESS_TOOLS is not set
# BR2_PACKAGE_WIRESHARK is not set
# BR2_PACKAGE_WPA_SUPPLICANT is not set
# BR2_PACKAGE_WPAN_TOOLS is not set
# BR2_PACKAGE_XINETD is not set
# BR2_PACKAGE_XL2TP is not set
# xtables-addons needs a Linux kernel to be built
# BR2_PACKAGE_ZNC is not set
# Package managers
# Please note:
# - Buildroot does *not* generate binary packages,
# - Buildroot does *not* install any package database.
# It is up to you to provide those by yourself if you
# want to use any of those package managers.
# See the manual:
# http://buildroot.org/manual.html#faq-no-binary-packages
# BR2_PACKAGE_OPKG is not set
# Real-Time
BR2_PACKAGE_XENOMAI_ARCH_SUPPORTS=y
# BR2_PACKAGE_XENOMAI is not set
# Security
# BR2_PACKAGE_CHECKPOLICY is not set
# BR2_PACKAGE_PAXTEST is not set
# BR2_PACKAGE_POLICYCOREUTILS is not set
# BR2_PACKAGE_REFPOLICY is not set
# BR2_PACKAGE_SEPOLGEN is not set
# BR2_PACKAGE_SETOOLS is not set
# Shell and utilities
# Shells
# BR2_PACKAGE_MKSH is not set
# Utilities
# BR2_PACKAGE_AT is not set
# BR2_PACKAGE_CCRYPT is not set
# BR2_PACKAGE_DIALOG is not set
# BR2_PACKAGE_DTACH is not set
# BR2_PACKAGE_FILE is not set
# BR2_PACKAGE_EASY_RSA is not set
# BR2_PACKAGE_GNUPG is not set
# BR2_PACKAGE_GNUPG2 is not set
# BR2_PACKAGE_INOTIFY_TOOLS is not set
# BR2_PACKAGE_LOCKFILE_PROGS is not set
# BR2_PACKAGE_LOGROTATE is not set
# BR2_PACKAGE_LOGSURFER is not set
# BR2_PACKAGE_PINENTRY is not set
# BR2_PACKAGE_RANGER is not set
# BR2_PACKAGE_SCREEN is not set
# BR2_PACKAGE_SUDO is not set
# BR2_PACKAGE_TMUX is not set
# BR2_PACKAGE_XMLSTARLET is not set
# BR2_PACKAGE_XXHASH is not set
# System tools
# BR2_PACKAGE_ACL is not set
# BR2_PACKAGE_ANDROID_TOOLS is not set
# BR2_PACKAGE_ATOP is not set
# BR2_PACKAGE_ATTR is not set
BR2_PACKAGE_AUDIT_ARCH_SUPPORTS=y
# BR2_PACKAGE_AUDIT is not set
# BR2_PACKAGE_CGROUPFS_MOUNT is not set
# circus needs Python and a toolchain w/ C++, threads
# BR2_PACKAGE_CPULOAD is not set
# BR2_PACKAGE_DAEMON is not set
# BR2_PACKAGE_DC3DD is not set
# BR2_PACKAGE_DDRESCUE is not set
# BR2_PACKAGE_DOCKER_CONTAINERD is not set
# BR2_PACKAGE_DOCKER_ENGINE is not set
# BR2_PACKAGE_EFIBOOTMGR is not set
BR2_PACKAGE_EFIVAR_ARCH_SUPPORTS=y
# BR2_PACKAGE_EFIVAR is not set
# emlog needs a Linux kernel to be built
# BR2_PACKAGE_FTOP is not set
# BR2_PACKAGE_GETENT is not set
# BR2_PACKAGE_HTOP is not set
BR2_PACKAGE_INITSCRIPTS=y
# iotop depends on python or python3
# BR2_PACKAGE_IPRUTILS is not set
# BR2_PACKAGE_IRQBALANCE is not set
# BR2_PACKAGE_KEYUTILS is not set
# BR2_PACKAGE_KMOD is not set
# BR2_PACKAGE_KVMTOOL is not set
# BR2_PACKAGE_LXC is not set
# BR2_PACKAGE_MONIT is not set
# BR2_PACKAGE_NCDU is not set
# BR2_PACKAGE_NUT is not set
# BR2_PACKAGE_POLKIT is not set
# BR2_PACKAGE_PROCRANK_LINUX is not set
# BR2_PACKAGE_PWGEN is not set
# BR2_PACKAGE_QUOTA is not set
# BR2_PACKAGE_RAUC is not set
# BR2_PACKAGE_RUNC is not set
# BR2_PACKAGE_S6 is not set
# BR2_PACKAGE_S6_LINUX_INIT is not set
# BR2_PACKAGE_S6_LINUX_UTILS is not set
# BR2_PACKAGE_S6_PORTABLE_UTILS is not set
# BR2_PACKAGE_S6_RC is not set
# BR2_PACKAGE_SCRUB is not set
# BR2_PACKAGE_SCRYPT is not set
# BR2_PACKAGE_SMACK is not set
# supervisor needs the python interpreter
# BR2_PACKAGE_SWUPDATE is not set
BR2_PACKAGE_SYSTEMD_ARCH_SUPPORTS=y
# BR2_PACKAGE_TPM_TOOLS is not set
# BR2_PACKAGE_UNSCD is not set
# BR2_PACKAGE_UTIL_LINUX is not set
# BR2_PACKAGE_XEN is not set
BR2_PACKAGE_XVISOR_ARCH_SUPPORTS=y
# BR2_PACKAGE_XVISOR is not set
# Text editors and viewers
# BR2_PACKAGE_ED is not set
# BR2_PACKAGE_JOE is not set
# BR2_PACKAGE_MC is not set
# BR2_PACKAGE_NANO is not set
# BR2_PACKAGE_UEMACS is not set
# Filesystem images
# BR2_TARGET_ROOTFS_AXFS is not set
# BR2_TARGET_ROOTFS_CLOOP is not set
# BR2_TARGET_ROOTFS_CPIO is not set
# BR2_TARGET_ROOTFS_CRAMFS is not set
# BR2_TARGET_ROOTFS_EXT2 is not set
# initramfs needs a Linux kernel to be built
# BR2_TARGET_ROOTFS_JFFS2 is not set
# BR2_TARGET_ROOTFS_ROMFS is not set
# BR2_TARGET_ROOTFS_SQUASHFS is not set
BR2_TARGET_ROOTFS_TAR=y
BR2_TARGET_ROOTFS_TAR_NONE=y
# BR2_TARGET_ROOTFS_TAR_GZIP is not set
# BR2_TARGET_ROOTFS_TAR_BZIP2 is not set
# BR2_TARGET_ROOTFS_TAR_LZMA is not set
# BR2_TARGET_ROOTFS_TAR_LZO is not set
# BR2_TARGET_ROOTFS_TAR_XZ is not set
BR2_TARGET_ROOTFS_TAR_OPTIONS=""
# BR2_TARGET_ROOTFS_UBIFS is not set
# BR2_TARGET_ROOTFS_YAFFS2 is not set
# Bootloaders
# BR2_TARGET_AFBOOT_STM32 is not set
# BR2_TARGET_BAREBOX is not set
# BR2_TARGET_MXS_BOOTLETS is not set
# BR2_TARGET_S500_BOOTLOADER is not set
# BR2_TARGET_TS4800_MBRBOOT is not set
# BR2_TARGET_UBOOT is not set
# Host utilities
# BR2_PACKAGE_HOST_AESPIPE is not set
# BR2_PACKAGE_HOST_ANDROID_TOOLS is not set
# BR2_PACKAGE_HOST_CBOOTIMAGE is not set
# BR2_PACKAGE_HOST_CHECKPOLICY is not set
# BR2_PACKAGE_HOST_CRAMFS is not set
# BR2_PACKAGE_HOST_DFU_UTIL is not set
# BR2_PACKAGE_HOST_DOS2UNIX is not set
# BR2_PACKAGE_HOST_DOSFSTOOLS is not set
# BR2_PACKAGE_HOST_DTC is not set
# BR2_PACKAGE_HOST_E2FSPROGS is not set
# BR2_PACKAGE_HOST_E2TOOLS is not set
# BR2_PACKAGE_HOST_FAKETIME is not set
# BR2_PACKAGE_HOST_FWUP is not set
# BR2_PACKAGE_HOST_GENEXT2FS is not set
# BR2_PACKAGE_HOST_GENIMAGE is not set
# BR2_PACKAGE_HOST_GENPART is not set
BR2_PACKAGE_HOST_GO_ARCH_SUPPORTS=y
BR2_PACKAGE_HOST_GO_CGO_LINKING_SUPPORTS=y
# BR2_PACKAGE_HOST_GPTFDISK is not set
# BR2_PACKAGE_HOST_IMX_USB_LOADER is not set
# BR2_PACKAGE_HOST_JQ is not set
# BR2_PACKAGE_HOST_JSMIN is not set
# BR2_PACKAGE_HOST_LPC3250LOADER is not set
# BR2_PACKAGE_HOST_LTTNG_BABELTRACE is not set
# BR2_PACKAGE_HOST_MFGTOOLS is not set
# BR2_PACKAGE_HOST_MKPASSWD is not set
# BR2_PACKAGE_HOST_MTD is not set
# BR2_PACKAGE_HOST_MTOOLS is not set
# BR2_PACKAGE_HOST_MXSLDR is not set
# BR2_PACKAGE_HOST_OMAP_U_BOOT_UTILS is not set
# BR2_PACKAGE_HOST_OPENOCD is not set
# BR2_PACKAGE_HOST_OPKG_UTILS is not set
# BR2_PACKAGE_HOST_PARTED is not set
BR2_PACKAGE_HOST_PATCHELF=y
# BR2_PACKAGE_HOST_PRU_SOFTWARE_SUPPORT is not set
# BR2_PACKAGE_HOST_PWGEN is not set
# BR2_PACKAGE_HOST_PYTHON_LXML is not set
# BR2_PACKAGE_HOST_QEMU is not set
# BR2_PACKAGE_HOST_RASPBERRYPI_USBBOOT is not set
# BR2_PACKAGE_HOST_RAUC is not set
# BR2_PACKAGE_HOST_SAM_BA is not set
# BR2_PACKAGE_HOST_SQUASHFS is not set
# BR2_PACKAGE_HOST_SUNXI_TOOLS is not set
# BR2_PACKAGE_HOST_TEGRARCM is not set
BR2_PACKAGE_HOST_TI_CGT_PRU_ARCH_SUPPORTS=y
# BR2_PACKAGE_HOST_TI_CGT_PRU is not set
# BR2_PACKAGE_HOST_UBOOT_TOOLS is not set
# BR2_PACKAGE_HOST_UTIL_LINUX is not set
# BR2_PACKAGE_HOST_VBOOT_UTILS is not set
# BR2_PACKAGE_HOST_XORRISO is not set
# BR2_PACKAGE_HOST_ZIP is not set
# Legacy config options
# Legacy options removed in 2017.08
# BR2_PACKAGE_SIMICSFS is not set
# BR2_BINUTILS_VERSION_2_26_X is not set
BR2_XTENSA_OVERLAY_DIR=""
BR2_XTENSA_CUSTOM_NAME=""
# BR2_PACKAGE_HOST_MKE2IMG is not set
BR2_TARGET_ROOTFS_EXT2_BLOCKS=0
BR2_TARGET_ROOTFS_EXT2_EXTRA_INODES=0
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_CDXAPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DATAURISRC is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_DCCP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_HDVPARSE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MVE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_NUVDEMUX is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_PATCHDETECT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDI is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_TTA is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_VIDEOMEASURE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_APEXSINK is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_SDL is not set
# BR2_PACKAGE_GST1_PLUGINS_UGLY_PLUGIN_MAD is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_WEBRTC is not set
# BR2_STRIP_none is not set
# BR2_PACKAGE_BEECRYPT_CPP is not set
# BR2_PACKAGE_SPICE_CLIENT is not set
# BR2_PACKAGE_SPICE_GUI is not set
# BR2_PACKAGE_SPICE_TUNNEL is not set
# BR2_PACKAGE_INPUT_TOOLS is not set
# BR2_PACKAGE_INPUT_TOOLS_INPUTATTACH is not set
# BR2_PACKAGE_INPUT_TOOLS_JSCAL is not set
# BR2_PACKAGE_INPUT_TOOLS_JSTEST is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_SH is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_X86 is not set
# BR2_GCC_VERSION_4_8_X is not set
# Legacy options removed in 2017.05
# BR2_PACKAGE_SUNXI_MALI_R2P4 is not set
# BR2_PACKAGE_NODEJS_MODULES_COFFEESCRIPT is not set
# BR2_PACKAGE_NODEJS_MODULES_EXPRESS is not set
# BR2_PACKAGE_BLUEZ5_UTILS_GATTTOOL is not set
# BR2_PACKAGE_OPENOCD_FT2XXX is not set
# BR2_PACKAGE_KODI_RTMPDUMP is not set
# BR2_PACKAGE_KODI_VISUALISATION_FOUNTAIN is not set
# BR2_PACKAGE_PORTMAP is not set
# BR2_BINUTILS_VERSION_2_25_X is not set
# BR2_TOOLCHAIN_BUILDROOT_INET_RPC is not set
BR2_TARGET_ROOTFS_EXT2_EXTRA_BLOCKS=0
# BR2_PACKAGE_SYSTEMD_KDBUS is not set
# BR2_PACKAGE_POLARSSL is not set
# BR2_NBD_CLIENT is not set
# BR2_NBD_SERVER is not set
# BR2_PACKAGE_GMOCK is not set
# BR2_KERNEL_HEADERS_4_8 is not set
# BR2_KERNEL_HEADERS_3_18 is not set
# BR2_GLIBC_VERSION_2_22 is not set
# Legacy options removed in 2017.02
# BR2_PACKAGE_PERL_DB_FILE is not set
# BR2_KERNEL_HEADERS_4_7 is not set
# BR2_KERNEL_HEADERS_4_6 is not set
# BR2_KERNEL_HEADERS_4_5 is not set
# BR2_KERNEL_HEADERS_3_14 is not set
# BR2_TOOLCHAIN_EXTERNAL_MUSL_CROSS is not set
# BR2_UCLIBC_INSTALL_TEST_SUITE is not set
# BR2_TOOLCHAIN_EXTERNAL_BLACKFIN_UCLINUX is not set
# BR2_PACKAGE_MAKEDEVS is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV7A is not set
# BR2_TOOLCHAIN_EXTERNAL_ARAGO_ARMV5TE is not set
# BR2_PACKAGE_SNOWBALL_HDMISERVICE is not set
# BR2_PACKAGE_SNOWBALL_INIT is not set
# BR2_GDB_VERSION_7_9 is not set
# Legacy options removed in 2016.11
# BR2_PACKAGE_PHP_SAPI_CLI_CGI is not set
# BR2_PACKAGE_PHP_SAPI_CLI_FPM is not set
# BR2_PACKAGE_WVSTREAMS is not set
# BR2_PACKAGE_WVDIAL is not set
# BR2_PACKAGE_WEBKITGTK24 is not set
# BR2_PACKAGE_TORSMO is not set
# BR2_PACKAGE_SSTRIP is not set
# BR2_KERNEL_HEADERS_4_3 is not set
# BR2_KERNEL_HEADERS_4_2 is not set
# BR2_PACKAGE_KODI_ADDON_XVDR is not set
# BR2_PACKAGE_IPKG is not set
# BR2_GCC_VERSION_4_7_X is not set
# BR2_BINUTILS_VERSION_2_24_X is not set
# BR2_PACKAGE_WESTON_RPI is not set
# BR2_GCC_VERSION_4_8_ARC is not set
# BR2_KERNEL_HEADERS_4_0 is not set
# BR2_KERNEL_HEADERS_3_19 is not set
# BR2_PACKAGE_LIBEVAS_GENERIC_LOADERS is not set
# BR2_PACKAGE_ELEMENTARY is not set
# BR2_LINUX_KERNEL_CUSTOM_LOCAL is not set
# Legacy options removed in 2016.08
# BR2_PACKAGE_EFL_JP2K is not set
# BR2_PACKAGE_SYSTEMD_COMPAT is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_LIVEADDER is not set
# BR2_PACKAGE_LIBFSLVPUWRAP is not set
# BR2_PACKAGE_LIBFSLPARSER is not set
# BR2_PACKAGE_LIBFSLCODEC is not set
# BR2_PACKAGE_UBOOT_TOOLS_MKIMAGE_FIT_SIGNATURE_SUPPORT is not set
# BR2_PTHREADS_OLD is not set
# BR2_BINUTILS_VERSION_2_23_X is not set
# BR2_TOOLCHAIN_BUILDROOT_EGLIBC is not set
# BR2_GDB_VERSION_7_8 is not set
# Legacy options removed in 2016.05
# BR2_PACKAGE_OPENVPN_CRYPTO_POLARSSL is not set
# BR2_PACKAGE_NGINX_HTTP_SPDY_MODULE is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_RTP is not set
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_MPG123 is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC is not set
# BR2_TOOLCHAIN_EXTERNAL_CODESOURCERY_POWERPC_E500V2 is not set
# BR2_x86_i386 is not set
# BR2_PACKAGE_QT5WEBKIT_EXAMPLES is not set
# BR2_PACKAGE_QT5QUICK1 is not set
BR2_TARGET_UBOOT_CUSTOM_PATCH_DIR=""
# BR2_PACKAGE_XDRIVER_XF86_INPUT_VOID is not set
# BR2_KERNEL_HEADERS_3_17 is not set
# BR2_GDB_VERSION_7_7 is not set
# BR2_PACKAGE_FOOMATIC_FILTERS is not set
# BR2_PACKAGE_SAMBA is not set
# BR2_PACKAGE_KODI_WAVPACK is not set
# BR2_PACKAGE_KODI_RSXS is not set
# BR2_PACKAGE_KODI_GOOM is not set
# BR2_PACKAGE_SYSTEMD_ALL_EXTRAS is not set
# BR2_GCC_VERSION_4_5_X is not set
# BR2_PACKAGE_SQLITE_READLINE is not set
# Legacy options removed in 2016.02
# BR2_PACKAGE_DOVECOT_BZIP2 is not set
# BR2_PACKAGE_DOVECOT_ZLIB is not set
# BR2_PACKAGE_E2FSPROGS_FINDFS is not set
# BR2_PACKAGE_OPENPOWERLINK_DEBUG_LEVEL is not set
# BR2_PACKAGE_OPENPOWERLINK_KERNEL_MODULE is not set
# BR2_PACKAGE_OPENPOWERLINK_LIBPCAP is not set
# BR2_LINUX_KERNEL_SAME_AS_HEADERS is not set
# BR2_PACKAGE_CUPS_PDFTOPS is not set
# BR2_KERNEL_HEADERS_3_16 is not set
# BR2_PACKAGE_PYTHON_PYXML is not set
# BR2_ENABLE_SSP is not set
# BR2_PACKAGE_DIRECTFB_CLE266 is not set
# BR2_PACKAGE_DIRECTFB_UNICHROME is not set
# BR2_PACKAGE_LIBELEMENTARY is not set
# BR2_PACKAGE_LIBEINA is not set
# BR2_PACKAGE_LIBEET is not set
# BR2_PACKAGE_LIBEVAS is not set
# BR2_PACKAGE_LIBECORE is not set
# BR2_PACKAGE_LIBEDBUS is not set
# BR2_PACKAGE_LIBEFREET is not set
# BR2_PACKAGE_LIBEIO is not set
# BR2_PACKAGE_LIBEMBRYO is not set
# BR2_PACKAGE_LIBEDJE is not set
# BR2_PACKAGE_LIBETHUMB is not set
# BR2_PACKAGE_INFOZIP is not set
# BR2_BR2_PACKAGE_NODEJS_0_10_X is not set
# BR2_BR2_PACKAGE_NODEJS_0_12_X is not set
# BR2_BR2_PACKAGE_NODEJS_4_X is not set
# Legacy options removed in 2015.11
# BR2_PACKAGE_GST1_PLUGINS_BAD_PLUGIN_REAL is not set
# BR2_PACKAGE_MEDIA_CTL is not set
# BR2_PACKAGE_SCHIFRA is not set
# BR2_PACKAGE_ZXING is not set
# BR2_PACKAGE_BLACKBOX is not set
# BR2_KERNEL_HEADERS_3_0 is not set
# BR2_KERNEL_HEADERS_3_11 is not set
# BR2_KERNEL_HEADERS_3_13 is not set
# BR2_KERNEL_HEADERS_3_15 is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_ANDI is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_BLTLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_CPULOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DATABUFFER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DIOLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DOK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_DRIVERTEST is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FIRE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FLIP is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_FONTS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_INPUT is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_JOYSTICK is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_KNUCKLES is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_LAYER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_MATRIX_WATER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_NETLOAD is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PALETTE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_PORTER is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_STRESS is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_TEXTURE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_VIDEO_PARTICLE is not set
# BR2_PACKAGE_DIRECTFB_EXAMPLES_WINDOW is not set
# BR2_PACKAGE_KOBS_NG is not set
# BR2_PACKAGE_SAWMAN is not set
# BR2_PACKAGE_DIVINE is not set
# Legacy options removed in 2015.08
# BR2_PACKAGE_KODI_PVR_ADDONS is not set
# BR2_BINUTILS_VERSION_2_23_2 is not set
# BR2_BINUTILS_VERSION_2_24 is not set
# BR2_BINUTILS_VERSION_2_25 is not set
# BR2_PACKAGE_PERF is not set
# BR2_BINUTILS_VERSION_2_22 is not set
# BR2_PACKAGE_GPU_VIV_BIN_MX6Q is not set
# BR2_TARGET_UBOOT_NETWORK is not set
# Legacy options removed in 2015.05
# BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_512_16K is not set
# BR2_TARGET_ROOTFS_JFFS2_NANDFLASH_2K_128K is not set
# BR2_PACKAGE_MONO_20 is not set
# BR2_PACKAGE_MONO_40 is not set
# BR2_PACKAGE_MONO_45 is not set
# BR2_CIVETWEB_WITH_LUA is not set
# BR2_PACKAGE_TIFF_TIFF2PDF is not set
# BR2_PACKAGE_TIFF_TIFFCP is not set
# BR2_LINUX_KERNEL_EXT_RTAI_PATCH is not set
# BR2_TARGET_GENERIC_PASSWD_DES is not set
# BR2_PACKAGE_GTK2_THEME_HICOLOR is not set
# BR2_PACKAGE_VALGRIND_PTRCHECK is not set
# Legacy options removed in 2015.02
# BR2_PACKAGE_LIBGC is not set
# BR2_PACKAGE_WDCTL is not set
# BR2_PACKAGE_UTIL_LINUX_ARCH is not set
# BR2_PACKAGE_UTIL_LINUX_DDATE is not set
# BR2_PACKAGE_RPM_BZIP2_PAYLOADS is not set
# BR2_PACKAGE_RPM_XZ_PAYLOADS is not set
# BR2_PACKAGE_M4 is not set
# BR2_PACKAGE_FLEX_BINARY is not set
# BR2_PACKAGE_BISON is not set
# BR2_PACKAGE_GOB2 is not set
# BR2_PACKAGE_DISTCC is not set
# BR2_PACKAGE_HASERL_VERSION_0_8_X is not set
# BR2_PACKAGE_STRONGSWAN_TOOLS is not set
# BR2_PACKAGE_XBMC_ADDON_XVDR is not set
# BR2_PACKAGE_XBMC_PVR_ADDONS is not set
# BR2_PACKAGE_XBMC is not set
# BR2_PACKAGE_XBMC_ALSA_LIB is not set
# BR2_PACKAGE_XBMC_AVAHI is not set
# BR2_PACKAGE_XBMC_DBUS is not set
# BR2_PACKAGE_XBMC_LIBBLURAY is not set
# BR2_PACKAGE_XBMC_GOOM is not set
# BR2_PACKAGE_XBMC_RSXS is not set
# BR2_PACKAGE_XBMC_LIBCEC is not set
# BR2_PACKAGE_XBMC_LIBMICROHTTPD is not set
# BR2_PACKAGE_XBMC_LIBNFS is not set
# BR2_PACKAGE_XBMC_RTMPDUMP is not set
# BR2_PACKAGE_XBMC_LIBSHAIRPLAY is not set
# BR2_PACKAGE_XBMC_LIBSMBCLIENT is not set
# BR2_PACKAGE_XBMC_LIBTHEORA is not set
# BR2_PACKAGE_XBMC_LIBUSB is not set
# BR2_PACKAGE_XBMC_LIBVA is not set
# BR2_PACKAGE_XBMC_WAVPACK is not set
# BR2_PREFER_STATIC_LIB is not set
# Legacy options removed in 2014.11
# BR2_x86_generic is not set
# BR2_GCC_VERSION_4_4_X is not set
# BR2_sparc_sparchfleon is not set
# BR2_sparc_sparchfleonv8 is not set
# BR2_sparc_sparcsfleon is not set
# BR2_sparc_sparcsfleonv8 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_XC5000 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_CXGB4 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_7 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_IWLWIFI_3160_7260_8 is not set
# Legacy options removed in 2014.08
# BR2_PACKAGE_LIBELF is not set
# BR2_KERNEL_HEADERS_3_8 is not set
# BR2_PACKAGE_GETTEXT_TOOLS is not set
# BR2_PACKAGE_PROCPS is not set
# BR2_BINUTILS_VERSION_2_20_1 is not set
# BR2_BINUTILS_VERSION_2_21 is not set
# BR2_BINUTILS_VERSION_2_23_1 is not set
# BR2_UCLIBC_VERSION_0_9_32 is not set
# BR2_GCC_VERSION_4_3_X is not set
# BR2_GCC_VERSION_4_6_X is not set
# BR2_GDB_VERSION_7_4 is not set
# BR2_GDB_VERSION_7_5 is not set
# BR2_BUSYBOX_VERSION_1_19_X is not set
# BR2_BUSYBOX_VERSION_1_20_X is not set
# BR2_BUSYBOX_VERSION_1_21_X is not set
# BR2_PACKAGE_LIBV4L_DECODE_TM6000 is not set
# BR2_PACKAGE_LIBV4L_IR_KEYTABLE is not set
# BR2_PACKAGE_LIBV4L_V4L2_COMPLIANCE is not set
# BR2_PACKAGE_LIBV4L_V4L2_CTL is not set
# BR2_PACKAGE_LIBV4L_V4L2_DBG is not set
# Legacy options removed in 2014.05
# BR2_PACKAGE_EVTEST_CAPTURE is not set
# BR2_KERNEL_HEADERS_3_6 is not set
# BR2_KERNEL_HEADERS_3_7 is not set
# BR2_PACKAGE_VALA is not set
BR2_PACKAGE_TZDATA_ZONELIST=""
# BR2_PACKAGE_LUA_INTERPRETER_EDITING_NONE is not set
# BR2_PACKAGE_LUA_INTERPRETER_READLINE is not set
# BR2_PACKAGE_LUA_INTERPRETER_LINENOISE is not set
# BR2_PACKAGE_DVB_APPS_UTILS is not set
# BR2_KERNEL_HEADERS_SNAP is not set
# BR2_ROOTFS_DEVICE_CREATION_DYNAMIC_UDEV is not set
# BR2_PACKAGE_UDEV is not set
# BR2_PACKAGE_UDEV_RULES_GEN is not set
# BR2_PACKAGE_UDEV_ALL_EXTRAS is not set
# Legacy options removed in 2014.02
# BR2_sh2 is not set
# BR2_sh3 is not set
# BR2_sh3eb is not set
# BR2_KERNEL_HEADERS_3_1 is not set
# BR2_KERNEL_HEADERS_3_3 is not set
# BR2_KERNEL_HEADERS_3_5 is not set
# BR2_GDB_VERSION_7_2 is not set
# BR2_GDB_VERSION_7_3 is not set
# BR2_PACKAGE_CCACHE is not set
# BR2_HAVE_DOCUMENTATION is not set
# BR2_PACKAGE_AUTOMAKE is not set
# BR2_PACKAGE_AUTOCONF is not set
# BR2_PACKAGE_XSTROKE is not set
# BR2_PACKAGE_LZMA is not set
# BR2_PACKAGE_TTCP is not set
# BR2_PACKAGE_LIBNFC_LLCP is not set
# BR2_PACKAGE_MYSQL_CLIENT is not set
# BR2_PACKAGE_SQUASHFS3 is not set
# BR2_TARGET_ROOTFS_SQUASHFS3 is not set
# BR2_PACKAGE_NETKITBASE is not set
# BR2_PACKAGE_NETKITTELNET is not set
# BR2_PACKAGE_LUASQL is not set
# BR2_PACKAGE_LUACJSON is not set
# Legacy options removed in 2013.11
# BR2_PACKAGE_LVM2_DMSETUP_ONLY is not set
# BR2_PACKAGE_QT_JAVASCRIPTCORE is not set
# BR2_PACKAGE_MODULE_INIT_TOOLS is not set
BR2_TARGET_UBOOT_CUSTOM_GIT_REPO_URL=""
BR2_TARGET_UBOOT_CUSTOM_GIT_VERSION=""
BR2_LINUX_KERNEL_CUSTOM_GIT_REPO_URL=""
BR2_LINUX_KERNEL_CUSTOM_GIT_VERSION=""
# Legacy options removed in 2013.08
# BR2_ARM_OABI is not set
# BR2_PACKAGE_DOSFSTOOLS_DOSFSCK is not set
# BR2_PACKAGE_DOSFSTOOLS_DOSFSLABEL is not set
# BR2_PACKAGE_DOSFSTOOLS_MKDOSFS is not set
# BR2_ELF2FLT is not set
# BR2_VFP_FLOAT is not set
# BR2_PACKAGE_GCC_TARGET is not set
# BR2_HAVE_DEVFILES is not set
# Legacy options removed in 2013.05
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_8192 is not set
# BR2_PACKAGE_LINUX_FIRMWARE_RTL_8712 is not set
# Legacy options removed in 2013.02
# BR2_sa110 is not set
# BR2_sa1100 is not set
# BR2_PACKAGE_GDISK is not set
# BR2_PACKAGE_GDISK_GDISK is not set
# BR2_PACKAGE_GDISK_SGDISK is not set
# BR2_PACKAGE_GDB_HOST is not set
# BR2_PACKAGE_DIRECTB_DITHER_RGB16 is not set
# BR2_PACKAGE_DIRECTB_TESTS is not set
# Legacy options removed in 2012.11
# BR2_PACKAGE_CUSTOMIZE is not set
# BR2_PACKAGE_XSERVER_xorg is not set
# BR2_PACKAGE_XSERVER_tinyx is not set
# BR2_PACKAGE_PTHREAD_STUBS is not set
# Legacy options removed in 2012.08
# BR2_PACKAGE_GETTEXT_STATIC is not set
# BR2_PACKAGE_LIBINTL is not set
# BR2_PACKAGE_INPUT_TOOLS_EVTEST is not set
# BR2_BFIN_FDPIC is not set
# BR2_BFIN_FLAT is not set离线
麻烦帮我看看是不是指令集什么的设置不对?
貌似有点不对哦,
看看这个网站 http://linux-sunxi.org/V3s
Main components of the V3s:
CPU: Cortex-A7 1.2GHz (ARM v7-A) Processor which have both VFPv3 and NEON co-processors:
FPU: Vector Floating Point Unit (standard ARM VFPv4 FPU Floating Point Unit)
SIMD: NEON (ARM's extended general-purpose SIMD vector processing extension engine)
Integrated 64MB DRAM
Target Architecture (ARM (little endian)) --->
│ │ Target Binary Format (ELF) --->
│ │ Target Architecture Variant (cortex-A7) --->
│ │ Target ABI (EABIhf) --->
│ │ Floating point strategy (VFPv3) --->
│ │ ARM instruction set (ARM) --->
这样之后编译出来的文件系统和mplayer播放暂时不死机了,稳定性待观察
接着编译一个Qt试一试,
应该不会死机了.
