参考: http://bbs.21ic.com/icview-2592254-1-1.html
# -*- coding: utf-8 -*-
# Form implementation generated from reading ui file 'c:\pp\pyt1.ui'
# Created by: PyQt5 UI code generator 5.10.1
# WARNING! All changes made in this file will be lost!
from PyQt5 import QtCore, QtGui, QtWidgets
from PyQt5.QtWidgets import QApplication , QMainWindow
from PyQt5.QtGui import QPainter, QColor, QPen
from PyQt5.QtCore import Qt
from PyQt5.QtCore import *
from PyQt5.QtGui import *
from PyQt5.QtWidgets import *
import usb.core
import usb.util
import struct
import sys
import time
import serial
class ISP_USB:
      AP_FILE=[]
      AP_CHECKSUM=0
      PacketNumber=0
      dev=None
      ep_in=None
      name=""
      def __init__(self):
            #self.name=name
            #print(name)
            self.PacketNumber=0;
      def USB_TRANSFER(self, thelist, PN):
            thelist[4]=PN&0xff
            thelist[5]=PN>>8&0xff
            thelist[6]=PN>>16&0xff
            thelist[7]=PN>>24&0xff
            self.dev = serial.Serial("COM15", 115200, timeout=100);
            test=self.dev.write(thelist)
            return_str=self.dev.read(64) #return by string
            self.dev.close();
            return_buffer=bytearray(return_str)
 #print 'rx package'
 #print '[{}]'.format(', '.join(hex(x) for x in return_buffer))
            checksum=0
            for i in range(64):
                checksum=checksum+thelist[i]
 #print "checksum=0x%x"%checksum
            packege_checksum=0
            packege_checksum=return_buffer[0]
            packege_checksum=(return_buffer[1]<<8)|packege_checksum
            if checksum!=packege_checksum:
                #print("checksum error")
                error_return()
            RPN=0
            RPN=return_buffer[4]
            RPN=(return_buffer[5]<<8)|RPN
            RPN=(return_buffer[6]<<16)|RPN
            RPN=(return_buffer[7]<<24)|RPN
            if RPN!=(PN+1):
                #print("package number error")
                error_return()
            return return_buffer
      def LINK_FUN(self):
            LINK = [0 for i in range(64)] # 64 byte data buffer is all zero
            self.PacketNumber=0x01
            LINK[0]=0xae
            self.USB_TRANSFER(LINK,self.PacketNumber)
      def SN_FUN(self):
            self.PacketNumber =self.PacketNumber+2
            SN_PACKAGE = [0 for i in range(64)]
            SN_PACKAGE[0]=0xa4
            SN_PACKAGE[8]=self.PacketNumber&0xff
            SN_PACKAGE[9]=self.PacketNumber>>8&0xff
            SN_PACKAGE[10]=self.PacketNumber>>16&0xff
            SN_PACKAGE[11]=self.PacketNumber>>24&0xff
            self.USB_TRANSFER(SN_PACKAGE,self.PacketNumber)
      def READ_fW_FUN(self):
            self.PacketNumber=self.PacketNumber+2
            READFW_VERSION = [0 for i in range(64)]
            READFW_VERSION[0]=0xa6
            buf=self.USB_TRANSFER(READFW_VERSION,self.PacketNumber)
            FW_VERSION=buf[8]
            #print("FW_VERSION=0x%8x" % FW_VERSION)
      def RUN_TO_APROM_FUN(self):
            RUN_TO_APROM = [0 for i in range(64)]
            RUN_TO_APROM[0]=0xab
            self.USB_TRANSFER(RUN_TO_APROM,self.PacketNumber)
      def READ_PID_FUN(self):
            READ_PID = [0 for i in range(64)]
            READ_PID[0]=0xB1
            buf=self.USB_TRANSFER(READ_PID,self.PacketNumber)
            PID=buf[8]|buf[9]<<8|buf[10]<<16|buf[11]<<24
            #print("PID=0x%8x" % PID)
      def READ_CONFIG_FUN(self):
            READ_CONFIG = [0 for i in range(64)]
            READ_CONFIG[0]=0xa2
            buf=self.USB_TRANSFER(READ_CONFIG,self.PacketNumber)
            CONFIG0=buf[8]|buf[9]<<8|buf[10]<<16|buf[11]<<24
            CONFIG1=buf[12]|buf[13]<<8|buf[14]<<16|buf[15]<<24
            #print("CONFIG0=0x%8x" % CONFIG0)
            #print("CONFIG1=0x%8x" % CONFIG1)
      def READ_APROM_BIN_FILE(self, FILENAME):
            f=open(FILENAME, 'rb')
            self.AP_CHECKSUM=0
            while True:
                x=f.read(1)
                if not x:
                    break
                temp=struct.unpack('B',x)
                self.AP_FILE.append(temp[0])
                self.AP_CHECKSUM=self.AP_CHECKSUM+temp[0]
            f.close()
            #print(len(self.AP_FILE))
            #print(self.AP_CHECKSUM)
      def USB_TRANSFER_ERASE(self, thelist, PN):
            thelist[4]=PN&0xff
            time.sleep(5)
            self.dev.close();
 #print 'rx package'
            checksum=0
            for i in range(64):
            packege_checksum=0
                error_return()
            RPN=0
            if RPN!=(PN+1):
                error_return()
      def UPDATE_APROM(self):
            AP_ADRESS=0;
            AP_SIZE=len(self.AP_FILE)
            PAP_COMMNAD = [0 for i in range(64)]
            PAP_COMMNAD[0]=0xa0
            #APROM START ADDRESS
            PAP_COMMNAD[8]=AP_ADRESS&0xff
            PAP_COMMNAD[9]=AP_ADRESS>>8&0xff
            PAP_COMMNAD[10]=AP_ADRESS>>16&0xff
            PAP_COMMNAD[11]=AP_ADRESS>>24&0xff
            #APROM SIZE
            PAP_COMMNAD[12]=AP_SIZE&0xff
            PAP_COMMNAD[13]=AP_SIZE>>8&0xff
            PAP_COMMNAD[14]=AP_SIZE>>16&0xff
            PAP_COMMNAD[15]=AP_SIZE>>24&0xff
            PAP_COMMNAD[16:64]=self.AP_FILE[0:48] #first package to copy
            #print '[{}]'.format(', '.join(hex(x) for x in PAP_COMMNAD))
            self.USB_TRANSFER_ERASE(PAP_COMMNAD,self.PacketNumber)
            for i in range(48,AP_SIZE,56):
                #print(i)
                PAP1_COMMNAD = [0 for j in range(64)]
                PAP1_COMMNAD[8:64]=self.AP_FILE[i:(i+56)]
                #print "test len: %d" % len(PAP1_COMMNAD)
                if len(PAP1_COMMNAD) < 64:
                    for k in range(64-len(PAP1_COMMNAD)):
                        PAP1_COMMNAD.append(0xFF)
                        #print '[{}]'.format(', '.join(hex(x) for x in PAP1_COMMNAD))
                if (((AP_SIZE-i)<56) or ((AP_SIZE-i)==56)):
                    #print "end"
                    buf=self.USB_TRANSFER(PAP1_COMMNAD,self.PacketNumber)
                    d_checksum=buf[8]|buf[9]<<8
                    if(d_checksum==(self.AP_CHECKSUM&0xffff)):
                        error_return()
                        #print("checksum pass")
                else:
                        #print "loop"
class Ui_Form(object):
    def setupUi(self, Form):
        Form.setObjectName("Form")
        Form.resize(400, 200)
        Form.setFixedSize(400, 200);
        Form.setStyleSheet("")
        self.progressBar = QtWidgets.QProgressBar(Form)
        self.progressBar.setGeometry(QtCore.QRect(90, 60, 271, 23))
        self.progressBar.setMinimumSize(QtCore.QSize(0, 0))
        self.progressBar.setProperty("value", 0)
        self.progressBar.setObjectName("progressBar")
        self.pushButton_1 = QtWidgets.QPushButton(Form)
        self.pushButton_1.setGeometry(QtCore.QRect(90, 140, 75, 23))
        self.pushButton_1.setMinimumSize(QtCore.QSize(0, 0))
        self.pushButton_1.setObjectName("pushButton_1")
        self.pushButton_1.clicked.connect(self.getFilename)
        self.pushButton_2 = QtWidgets.QPushButton(Form)
        self.pushButton_2.setGeometry(QtCore.QRect(240, 140, 75, 23))
        self.pushButton_2.setMinimumSize(QtCore.QSize(0, 0))
        self.pushButton_2.setObjectName("pushButton_2")
        self.pushButton_2.clicked.connect(self.startISP)
        self.pushButton_2.setEnabled(False)
        self.textEdit = QtWidgets.QTextEdit(Form)
        self.textEdit.setEnabled(False)
        self.textEdit.setGeometry(QtCore.QRect(90, 90, 231, 31))
        self.textEdit.setMinimumSize(QtCore.QSize(0, 0))
        self.textEdit.setObjectName("textEdit")
        self.thread = Worker()
        self.thread.sinOut.connect(self.slotAdd)
        #goable variable
        self.findname=""
        self.retranslateUi(Form)
        QtCore.QMetaObject.connectSlotsByName(Form)
    def retranslateUi(self, Form):
        _translate = QtCore.QCoreApplication.translate
        Form.setWindowTitle(_translate("Form", "Nuvoton ISP"))
        self.pushButton_1.setText(_translate("Form", "Load Bin File"))
        self.pushButton_2.setText(_translate("Form", "Start ISP"))
    def getFilename(self):
        fname, _  = QFileDialog.getOpenFileName(self, 'Open file', 'c:\\',"Bin file (*.bin)")
        if (fname==""):
            return
        self.findname=fname
        self.textEdit.setText(fname)
        self.pushButton_2.setEnabled(True)
    def startISP(self):
        self.progressBar.setValue(0)
        self.pushButton_1.setEnabled(False)
        self.thread.setfilename(self.findname)
        self.thread.start()
    def slotAdd(self,count):
        if(int(count)<=100):
             self.progressBar.setValue(int(count))
        if(int(count)==100):
           self.pushButton_1.setEnabled(True)
class Worker(QThread):
        sinOut = pyqtSignal(str)
        def __init__(self,parent=None):
                super(Worker,self).__init__(parent)
                self.working = True
                self.num = 0
                self.ISP = ISP_USB()
                self.filename=""
        def __del__(self):
                self.working = False
                self.wait()
        def setfilename(self,msg):
                self.filename=msg
        def Thread_UPDATE_APROM(self):
            self.ISP.PacketNumber=self.ISP.PacketNumber+2
            AP_ADRESS=0;
            AP_SIZE=len(self.ISP.AP_FILE)
            PAP_COMMNAD[0]=0xa0
            #APROM SIZE
            PAP_COMMNAD[16:64]=self.ISP.AP_FILE[0:48] #first package to copy
            self.ISP.USB_TRANSFER_ERASE(PAP_COMMNAD,self.ISP.PacketNumber)
                #print(int(i/AP_SIZE*100))
                self.sinOut.emit(str(int(i/AP_SIZE*100)))
                #if(int(i/AP_SIZE)%10==0):
                #    print(int(i/AP_SIZE))
                #    self.sleep(0.5)
                PAP1_COMMNAD[8:64]=self.ISP.AP_FILE[i:(i+56)]
                    #print "end"
                    buf=self.ISP.USB_TRANSFER(PAP1_COMMNAD,self.ISP.PacketNumber)
                    if(d_checksum==(self.ISP.AP_CHECKSUM&0xffff)):
                        self.sinOut.emit("100")
                else:
                        #print "loop"
        def run(self):
         self.ISP.LINK_FUN()
         self.ISP.SN_FUN()
         self.ISP.READ_fW_FUN()
         self.ISP.READ_PID_FUN()
         self.ISP.READ_CONFIG_FUN()
         self.ISP.READ_APROM_BIN_FILE(self.filename)
         self.Thread_UPDATE_APROM()
         #self.sinOut.emit("100")
class MyMainWindow(QMainWindow, Ui_Form):
    def __init__(self, parent=None):
        super(MyMainWindow, self).__init__(parent)
        self.setupUi(self)
        self.setWindowFlags(QtCore.Qt.WindowCloseButtonHint)  #only keep close button
if __name__=="__main__":
    test=ISP_USB()
    test.LINK_FUN()
    test.SN_FUN()
    test.READ_PID_FUN()
    test.READ_fW_FUN()
    test.READ_APROM_BIN_FILE("c:\\t1.bin")
    test.UPDATE_APROM()
    app = QApplication(sys.argv)
    myWin = MyMainWindow()
    myWin.show()
    sys.exit(app.exec_())原链接是 USB ISP 刷机, 但是 N76E003 并没有 USB 外设,所以改成了 串口下载,
Windows7 64bit Python3 测试通过,
写得不是很严谨, 有些地方还需要推敲。
新唐nuvoton ISP上位机/下位机代码: https://github.com/OpenNuvoton/ISPTool
在win下复制了21论坛的代码并运行,报错,无法导入usb.core模块,然后用pip安装了pyusb,import usb.core这一步不报错了。但self.dev = usb.core.find(idVendor=0x0416, idProduct=0x3F00)这一行出现了异常:
usb.core.nobackenderror。
https://blog.stackoverflow.club/109/
问题解决方案
在这里找到了解决方案.
原因在于pyinstaller没有把一些外部的库包含进来,导致报错。一个可行的解决方案如下:
将.spec修改至如下所示(.spec文件会在第一次运行pyinstaller后出现):
binaries = [
('C:\\Windows\\System32\\libusb0.dll', '.'),
]a = Analysis(['myscript.py'],
binaries=binaries,
datas=[],
hiddenimports=['usb'],
我也觉得是缺 libusb0.dll
这个协议貌似有问题,发出去的数据没有校验。
64字节是为了兼容USB协议吧?
话说我最近研究了以下。前次提到的那个下载器 已经可以在keil里面直接一键下载了
这个可以用 wheel 打包成 wheel 包更时候跨平台安装,此代码在 linux 下能运行吗?
