楼主 #1 2019-05-31 09:11:38
已发帖子: 9,251
玩华嵌HQEmbed S3 开发板, 在核心板引脚焊接了杜邦线, 不小心拉断了铜皮
楼主 #2 2019-05-31 09:11:56
已发帖子: 9,251
Re: 玩华嵌HQEmbed S3 开发板, 在核心板引脚焊接了杜邦线, 不小心拉断了铜皮
楼主 #3 2019-05-31 09:12:39
已发帖子: 9,251
变成了这样了,
这种孔板子中间出线, 想修估计都修不好了。
I2C0_SCL, I2C0_SDA (PB6, PB7)彻底阵亡了
楼主 #4 2019-05-31 09:16:57
已发帖子: 9,251
把 I2C1 强行怼上去 试一试
楼主 #5 2019-05-31 09:22:29
已发帖子: 9,251
这样怼上去之后, 触摸屏是使用是 I2C1 (PE21, PE22) 了。
楼主 #6 2019-05-31 09:24:53
已发帖子: 9,251
接下来修改设备树:
sun8i-v3s.dtsi
i2c1_pins: i2c1 {
        pins = "PE21", "PE22";
        function = "i2c1";
i2c1: i2c@01c2b000 {
        compatible = "allwinner,sun6i-a31-i2c";
        reg = <0x01c2b000 0x400>;
        interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
        clocks = <&ccu CLK_BUS_I2C1>;
        resets = <&ccu RST_BUS_I2C1>;
        pinctrl-names = "default";
        pinctrl-0 = <&i2c1_pins>;
        status = "disabled";
        #address-cells = <1>;
        #size-cells = <0>;
arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
&i2c1 {
        ft6x06@38 {
                compatible = "focaltech,ft6236";
                reg = <0x38>;
                interrupt-parent = <&pio>;
                interrupts = <1 4 IRQ_TYPE_EDGE_FALLING>;
                reset-gpios = <&pio 4 23 GPIO_ACTIVE_LOW>;
                touchscreen-size-x = <480>;
                touchscreen-size-y = <854>;
                touchscreen-inverted-x;
                touchscreen-swapped-x-y;
驱动配置开启:
CONFIG_TOUCHSCREEN_EDT_FT5X06=y
楼主 #7 2019-05-31 09:45:26
已发帖子: 9,251
Linux 启动 log:
[    1.180920] i2c /dev entries driver
[    1.512203] input: EP0110M09 as /devices/platform/soc/1c2b000.i2c/i2c-0/0-0038/input/input1
evtest 正常:
# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      1c22800.lradc
/dev/input/event1:      EP0110M09
Select the device event number [0-1]: 1
Input driver version is 1.0.1
Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0
Input device name: "EP0110M09"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value      0
      Min        0
      Max      853
    Event code 1 (ABS_Y)
      Value      0
      Min        0
      Max      479
    Event code 47 (ABS_MT_SLOT)
      Value      0
      Min        0
      Max        1
    Event code 53 (ABS_MT_POSITION_X)
      Value      0
      Min        0
      Max      853
    Event code 54 (ABS_MT_POSITION_Y)
      Value      0
      Min        0
      Max      479
    Event code 57 (ABS_MT_TRACKING_ID)
      Value      0
      Min        0
      Max    65535
Properties:
  Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
Event: time 4744.532688, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 0
Event: time 4744.532688, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 642
Event: time 4744.532688, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 38
Event: time 4744.532688, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 4744.532688, type 3 (EV_ABS), code 0 (ABS_X), value 642
Event: time 4744.532688, type 3 (EV_ABS), code 1 (ABS_Y), value 38
Event: time 4744.532688, -------------- SYN_REPORT ------------
Event: time 4744.715007, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 698
Event: time 4744.715007, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 44
Event: time 4744.715007, type 3 (EV_ABS), code 0 (ABS_X), value 698
Event: time 4744.715007, type 3 (EV_ABS), code 1 (ABS_Y), value 44
Event: time 4744.715007, -------------- SYN_REPORT ------------
Event: time 4745.571258, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 705
Event: time 4745.571258, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 55
Event: time 4745.571258, type 3 (EV_ABS), code 0 (ABS_X), value 705
Event: time 4745.571258, type 3 (EV_ABS), code 1 (ABS_Y), value 55
Event: time 4745.571258, -------------- SYN_REPORT ------------
Event: time 4745.593439, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 712
#8 2019-06-01 09:55:05
zhenfanhei
已发帖子: 296
晕哥威武,GT9xx再弄上就都齐活了
