^_^
打开 glfw 官网: https://www.glfw.org/docs/3.1/quick.html
找到那个三角形 demo 程序
#include <GLFW/glfw3.h>
#include <stdlib.h>
#include <stdio.h>
static void error_callback(int error, const char* description)
    fputs(description, stderr);
static void key_callback(GLFWwindow* window, int key, int scancode, int action, int mods)
    if (key == GLFW_KEY_ESCAPE && action == GLFW_PRESS)
        glfwSetWindowShouldClose(window, GL_TRUE);
int main(void)
    GLFWwindow* window;
    glfwSetErrorCallback(error_callback);
    if (!glfwInit())
        exit(EXIT_FAILURE);
    window = glfwCreateWindow(640, 480, "Simple example", NULL, NULL);
    if (!window)
        glfwTerminate();
        exit(EXIT_FAILURE);
    glfwMakeContextCurrent(window);
    glfwSwapInterval(1);
    glfwSetKeyCallback(window, key_callback);
    while (!glfwWindowShouldClose(window))
        float ratio;
        int width, height;
        glfwGetFramebufferSize(window, &width, &height);
        ratio = width / (float) height;
        glViewport(0, 0, width, height);
        glClear(GL_COLOR_BUFFER_BIT);
        glMatrixMode(GL_PROJECTION);
        glLoadIdentity();
        glOrtho(-ratio, ratio, -1.f, 1.f, 1.f, -1.f);
        glMatrixMode(GL_MODELVIEW);
        glLoadIdentity();
        glRotatef((float) glfwGetTime() * 50.f, 0.f, 0.f, 1.f);
        glBegin(GL_TRIANGLES);
        glColor3f(1.f, 0.f, 0.f);
        glVertex3f(-0.6f, -0.4f, 0.f);
        glColor3f(0.f, 1.f, 0.f);
        glVertex3f(0.6f, -0.4f, 0.f);
        glColor3f(0.f, 0.f, 1.f);
        glVertex3f(0.f, 0.6f, 0.f);
        glEnd();
        glfwSwapBuffers(window);
        glfwPollEvents();
    glfwDestroyWindow(window);
    glfwTerminate();
    exit(EXIT_SUCCESS);
}有链接错误, 所以中间添加两行:
#pragma comment(lib, "glfw3dll.lib")
#pragma comment(lib, "OpenGL32.Lib")离线
运行完全 OK
也可以使用静态链接:
#pragma comment(lib, "glfw3.lib")
这么吊,我也学学。
这么吊,我也学学。
互相学习!
#include <SDL.h>
#include <SDL_opengl.h>
#include <stdlib.h> //rand()
#pragma comment(lib, "SDL2main.lib")
#undef main
//SDL2 flashing random color example
//Should work on iOS/Android/Mac/Windows/Linux
static bool quitting = false;
static float r = 0.0f;
static SDL_Window *window = NULL;
static SDL_GLContext gl_context;
void render() {
	SDL_GL_MakeCurrent(window, gl_context);
	r = static_cast <float> (rand()) / static_cast <float> (RAND_MAX);
	glClearColor(r, 0.4f, 0.1f, 1.0f);
	SDL_GL_SwapWindow(window);
} //render
int SDLCALL watch(void *userdata, SDL_Event* event) {
	if (event->type == SDL_APP_WILLENTERBACKGROUND) {
		quitting = true;
	return 1;
int main(int argc, char *argv[]) {
	if (SDL_Init(SDL_INIT_VIDEO | SDL_INIT_EVENTS) != 0) {
		SDL_Log("Failed to initialize SDL: %s", SDL_GetError());
		return 1;
	window = SDL_CreateWindow("title", SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED, 512, 512, SDL_WINDOW_OPENGL);
	gl_context = SDL_GL_CreateContext(window);
	SDL_AddEventWatch(watch, NULL);
	while (!quitting) {
		SDL_Event event;
		while (SDL_PollEvent(&event)) {
			if (event.type == SDL_QUIT) {
				quitting = true;
		render();
		SDL_Delay(2);
	SDL_DelEventWatch(watch, NULL);
	SDL_GL_DeleteContext(gl_context);
	SDL_DestroyWindow(window);
	SDL_Quit();
	exit(0);
} //mainhttps://gist.github.com/underscorediscovery/46e4f5b4e3e6de7ad50d
三下五除二搞定了sdl2 demo.
好吧, 源码上交: nuget_demo_glfw_sdl2.7z
编译 win32/x64 都很方便,不需要自己手动设置什么。
