大佬们,我参照
https://whycan.cn/t_3138.html
进行配置,烧录后,u-boot起来了,但是内核没加载进去
u-boot中,bootargs bootcmd 都按照要求输入了
linux内核中,spi-nor.c已修改 dts已修改 mtd已经选了
打包脚本如下:
#!/bin/sh
dd if=/dev/zero of=f1c100s_spiflash_16M.bin bs=1M count=16 &&\
dd if=u-boot/u-boot-sunxi-with-spl.bin of=f1c100s_spiflash_16M.bin bs=1K conv=notrunc &&\
dd if=linux/arch/arm/boot/dts/suniv-f1c100s-licheepi-nano.dtb of=f1c100s_spiflash_16M.bin bs=1K seek=1024 conv=notrunc &&\
dd if=linux/arch/arm/boot/zImage of=f1c100s_spiflash_16M.bin bs=1K seek=1088 conv=notrunc &&\
mkfs.jffs2 -s 0x100 -e 0x10000 --pad=0xAF0000 -d rootfs/ -o rootfs.jffs2 &&\
dd if=rootfs.jffs2 of=f1c100s_spiflash_16M.bin bs=1k seek=5184 conv=notrunc &&\
sync烧录命令如下
sudo sunxi-fel -p spiflash-write 0 f1c100s_spiflash_16M.binlog如下
U-Boot SPL 2018.01-05679-g013ca45-dirty (Jan 20 2020 - 14:19:46)
DRAM: 32 MiB
Trying to boot from MMC1
mmc_init: -95, time 22
Trying to boot from sunxi SPI
U-Boot 2018.01-05679-g013ca45-dirty (Jan 20 2020 - 14:19:46 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
SF: unrecognized JEDEC id bytes: 0b, 40, 18
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
No SPI flash selected. Please run `sf probe'
Unknown command '' - try 'help'
=> printenv bootcmd
bootcmd=sf probe 0 50000000; sf read 0x80C00000 0x100000 0x4000; sf read 0x80008000 0x110000 0x400000; bootz 0x80008000 - 0x80C00000
=> printenv bootargs
bootargs=console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
=>.......不知道是啥米问题...求助......:):):):):):)
