楼主 #1 2018-04-25 13:55:11
BugActiveDaughter
已发帖子: 118
stm32f429的nand hal 驱动有bug
HAL_NAND_Write_Page函数要多加一句   *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = 0x00U; ,如下
/* Send read page command sequence */
    *(__IO uint8_t *)((uint32_t)(deviceaddress | CMD_AREA)) = NAND_CMD_AREA_A;
    *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = 0x00U; //add
    *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = ADDR_1ST_CYCLE(addressoffset);
    *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = ADDR_2ND_CYCLE(addressoffset);
    *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = ADDR_3RD_CYCLE(addressoffset);
HAL_NAND_Read_Page要改三个地方 ,下边有add就是增加语句
    *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = 0x00U; // 1  add
    /* for 512 and 1 GB devices, 4th cycle is required */
    if(hnand->Info.BlockNbr >= 1024U)
     *(__IO uint8_t *)((uint32_t)(deviceaddress | ADDR_AREA)) = ADDR_4TH_CYCLE(addressoffset);
    *(__IO uint8_t *)((uint32_t)(deviceaddress | CMD_AREA))  = NAND_CMD_AREA_TRUE1;
    for(i = 0; i < 10; i++);//2  add
    if(NAND_WaitRB(1))return HAL_BUSY;    //3//add
#2 2018-04-25 13:56:17
daydayup
已发帖子: 343
Re: stm32f429的nand hal 驱动有bug
谢谢分享!
#3 2018-04-25 13:57:11
qianhao
已发帖子: 135
学到了 活到老学到老
楼主 #4 2018-04-25 13:58:18
BugActiveDaughter
已发帖子: 118
1.6版本的hal库
楼主 #5 2018-04-27 11:02:09
BugActiveDaughter
已发帖子: 118
升级到最新的就不会有bug,兼容性就比较好
#6 2018-04-27 11:15:57
已发帖子: 9,246
BugActiveDaughter 说:
最新是哪个版本?
#7 2018-06-19 18:37:38
19697805
已发帖子: 77
谢谢分享!  活到老学到老
#8 2019-03-09 18:21:13
tink
已发帖子: 32
谢谢分享!
