From 84a933323d59b27ae85cf16deddc254a0b17e450 Mon Sep 17 00:00:00 2001
From: Shraddha Chaudhari <Shraddha.Chaudhari@imgtec.com>
Date: Tue, 5 Jan 2016 11:16:43 +0530
Subject: mtd: spi-nor: add support for winbond OTP
Few winbond spi nor devices support 3 x 256 bytes
of security registers, add support for read, write, lock
of these registers as user OTP.
Also add support for reading winbond devices unique ID
as factory OTP.
Change-Id: I8bb4d360c5f12b6b927d1135927cef809dee8d51
Signed-off-by: Shraddha Chaudhari <Shraddha.Chaudhari@imgtec.com>
drivers/mtd/spi-nor/Kconfig | 8 +
drivers/mtd/spi-nor/Makefile | 1 +
drivers/mtd/spi-nor/spi-nor-common.h | 8 +
drivers/mtd/spi-nor/spi-nor.c | 14 +-
drivers/mtd/spi-nor/winbond-otp.c | 482 +++++++++++++++++++++++++++++++++++
drivers/mtd/spi-nor/winbond-otp.h | 20 ++
6 files changed, 529 insertions(+), 4 deletions(-)
create mode 100644 drivers/mtd/spi-nor/spi-nor-common.h
create mode 100644 drivers/mtd/spi-nor/winbond-otp.c
create mode 100644 drivers/mtd/spi-nor/winbond-otp.h
diff --git a/drivers/mtd/spi-nor/Kconfig b/drivers/mtd/spi-nor/Kconfig
index 64a4f0e..e157c33 100644
--- a/drivers/mtd/spi-nor/Kconfig
+++ b/drivers/mtd/spi-nor/Kconfig
@@ -28,4 +28,12 @@ config SPI_FSL_QUADSPI
This enables support for the Quad SPI controller in master mode.
We only connect the NOR to this controller now.
+config MTD_SPI_NOR_WINBOND_OTP
+ bool "Support for winbond security register and unique ID"
+ depends on MTD_SPI_NOR
+ default n
+ help
+ This enables support for read/write of winbond security registers
+ as user OTP and also reading of NOR unique ID as factory OTP.
endif # MTD_SPI_NOR
diff --git a/drivers/mtd/spi-nor/Makefile b/drivers/mtd/spi-nor/Makefile
index 6a7ce14..6aba941 100644
--- a/drivers/mtd/spi-nor/Makefile
+++ b/drivers/mtd/spi-nor/Makefile
@@ -1,2 +1,3 @@
obj-$(CONFIG_MTD_SPI_NOR) += spi-nor.o
+obj-$(CONFIG_MTD_SPI_NOR_WINBOND_OTP) += winbond-otp.o
obj-$(CONFIG_SPI_FSL_QUADSPI) += fsl-quadspi.o
diff --git a/drivers/mtd/spi-nor/spi-nor-common.h b/drivers/mtd/spi-nor/spi-nor-common.h
new file mode 100644
index 0000000..ff15d42
--- /dev/null
+++ b/drivers/mtd/spi-nor/spi-nor-common.h
@@ -0,0 +1,8 @@
+#ifndef SPI_NOR_COMMON_H
+#define SPI_NOR_COMMON_H
+int spi_nor_wait_till_ready(struct spi_nor *nor);
+int spi_nor_lock_and_prep(struct spi_nor *nor, enum spi_nor_ops ops);
+void spi_nor_unlock_and_unprep(struct spi_nor *nor, enum spi_nor_ops ops);
+#endif
diff --git a/drivers/mtd/spi-nor/spi-nor.c b/drivers/mtd/spi-nor/spi-nor.c
index 1194f33..46d2f06 100644
--- a/drivers/mtd/spi-nor/spi-nor.c
+++ b/drivers/mtd/spi-nor/spi-nor.c
@@ -22,6 +22,8 @@
#include <linux/of_platform.h>
#include <linux/spi/flash.h>
#include <linux/mtd/spi-nor.h>
+#include "winbond-otp.h"
+#include "spi-nor-common.h"
/* Define max times to check status register before we give up. */
#define MAX_READY_WAIT_JIFFIES (40 * HZ) /* M25P16 specs 40s max chip erase */
@@ -55,6 +57,7 @@ struct flash_info {
#define SPI_NOR_DUAL_READ 0x20 /* Flash supports Dual Read */
#define SPI_NOR_QUAD_READ 0x40 /* Flash supports Quad Read */
#define USE_FSR 0x80 /* use flag status register */
+#define WINBOND_OTP 0x100 /* use winbond security reg as OTP */
#define JEDEC_MFR(info) ((info)->id[0])
@@ -231,7 +234,7 @@ static int spi_nor_ready(struct spi_nor *nor)
* Service routine to read status register until ready, or timeout occurs.
* Returns non-zero if error.
-static int spi_nor_wait_till_ready(struct spi_nor *nor)
unsigned long deadline;
int timeout = 0, ret;
@@ -268,7 +271,7 @@ static int erase_chip(struct spi_nor *nor)
return nor->write_reg(nor, SPINOR_OP_CHIP_ERASE, NULL, 0, 0);
-static int spi_nor_lock_and_prep(struct spi_nor *nor, enum spi_nor_ops ops)
int ret = 0;
@@ -285,7 +288,7 @@ static int spi_nor_lock_and_prep(struct spi_nor *nor, enum spi_nor_ops ops)
return ret;
-static void spi_nor_unlock_and_unprep(struct spi_nor *nor, enum spi_nor_ops ops)
if (nor->unprepare)
nor->unprepare(nor, ops);
@@ -611,7 +614,7 @@ static const struct spi_device_id spi_nor_ids[] = {
{ "s25sl032a", INFO(0x010215, 0, 64 * 1024, 64, 0) },
{ "s25sl064a", INFO(0x010216, 0, 64 * 1024, 128, 0) },
{ "s25fl008k", INFO(0xef4014, 0, 64 * 1024, 16, SECT_4K) },
- { "s25fl016k", INFO(0xef4015, 0, 64 * 1024, 32, SECT_4K) },
+ { "s25fl016k", INFO(0xef4015, 0, 64 * 1024, 32, SECT_4K | WINBOND_OTP) },
{ "s25fl064k", INFO(0xef4017, 0, 64 * 1024, 128, SECT_4K) },
{ "s25fl132k", INFO(0x014016, 0, 64 * 1024, 64, 0) },
@@ -1078,6 +1081,9 @@ int spi_nor_scan(struct spi_nor *nor, const char *name, enum read_mode mode)
mtd->_unlock = spi_nor_unlock;
+ if (info->flags & WINBOND_OTP)
+ winbond_otp_register(mtd);
/* sst nor chips use AAI word program */
if (info->flags & SST_WRITE)
mtd->_write = sst_write;
diff --git a/drivers/mtd/spi-nor/winbond-otp.c b/drivers/mtd/spi-nor/winbond-otp.c
index 0000000..a9db770
--- /dev/null
+++ b/drivers/mtd/spi-nor/winbond-otp.c
@@ -0,0 +1,482 @@
+ * Imagination Technologies
+ * Copyright (c) 2015 Imagination Technologies Ltd.
+ * This program is free software; you can redistribute it and/or modify it
+ * under the terms of the GNU General Public License version 2 as published by
+ * the Free Software Foundation.
+ * This driver provides read/write access to the 3 x 256 bytes security
+ * registers as user OTP and unique ID of the NOR can be read as factory OTP
+#include <linux/types.h>
+#include <linux/mtd/mtd.h>
+#include <linux/mtd/spi-nor.h>
+#include <linux/mutex.h>
+#include <linux/sched.h>
+#include <linux/slab.h>
+#define SECURITY_REG_START_ADDR 0x1000 /*first security register addr*/
+#define SECURITY_REG_ADDR_OFFSET 0x1000 /*diff between consecutive reg*/
+#define SECURITY_REG_NUM 3 /* number of security registers */
+#define SECURITY_REG_SIZE 256 /* bytes per security register */
+#define SECURITY_REG_TOTAL_SIZE (SECURITY_REG_NUM * SECURITY_REG_SIZE)
+#define SPI_NOR_UNIQUE_ID_LEN 8 /*number of bytes of unique ID */
+/* SPI FLASH opcodes */
+#define SPINOR_OP_RD_SR2 0x35 /* Read status register 2 */
+#define SPINOR_OP_PR_SECURITY_REG 0x42 /* Program security register */
+#define SPINOR_OP_ER_SECURITY_REG 0x44 /* Erase security register */
+#define SPINOR_OP_RD_SECURITY_REG 0x48 /* Read security register */
+#define SPINOR_OP_RD_UNIQUE_ID 0x4B /* Read unique id */
+/* Status register 2 */
+#define SR2_LB1_BIT 3 /* security register lock bit 1 */
+/* Get start addr of the security reg*/
+#define SEC_REG_START_ADDR(addr) (addr & 0x3000)
+static inline struct spi_nor *mtd_to_spi_nor(struct mtd_info *mtd)
+ return mtd->priv;
+static inline int write_enable(struct spi_nor *nor)
+ return nor->write_reg(nor, SPINOR_OP_WREN, NULL, 0, 0);
+static inline int write_disable(struct spi_nor *nor)
+ return nor->write_reg(nor, SPINOR_OP_WRDI, NULL, 0, 0);
+static int read_sr(struct spi_nor *nor, u8 opcode, u8 *val)
+ int ret;
+ ret = nor->read_reg(nor, opcode, val, 1);
+ if (ret < 0)
+ pr_err("error %d reading SR\n", ret);
+ return ret;
+ * Converts address range
+ * 0 - 0xFF -> 0x1000 - 0x10FF
+ * 0x100 - 0x1FF -> 0x2000 - 0x20FF
+ * 0x200 - 0x2FF -> 0x3000 - 0x30FF
+ * This func assumes that sanity checks on addr are done and is in valid range
+static loff_t translate_addr(loff_t addr)
+ int i;
+ loff_t new_addr = SECURITY_REG_START_ADDR;
+ for (i = 0; i < SECURITY_REG_NUM; i++) {
+ if (addr < ((i+1)*SECURITY_REG_SIZE)) {
+ new_addr |= addr & (SECURITY_REG_SIZE-1);
+ break;
+ new_addr += SECURITY_REG_ADDR_OFFSET;
+ return new_addr;
+ * Return 3 blocks of 256 bytes security register as user OTP,
+ * address of these blocks will be 0, 0x100, 0x200
+ * driver will convert these address to actual address while doing
+ * read/write
+static int winbond_get_user_otp_info(struct mtd_info *mtd, size_t len,
+ size_t *retlen,
+ struct otp_info *otpinfo)
+ u8 val;
+ int i, ret;
+ struct spi_nor *nor = mtd_to_spi_nor(mtd);
+ mutex_lock(&nor->lock);
+ ret = read_sr(nor, SPINOR_OP_RD_SR2, &val);
+ mutex_unlock(&nor->lock);
+ if (ret < 0)
+ return ret;
+ otpinfo[i].start = i * SECURITY_REG_SIZE;
+ otpinfo[i].length = SECURITY_REG_SIZE;
+ otpinfo[i].locked = !!(val & BIT(SR2_LB1_BIT + i));
+ *retlen = SECURITY_REG_NUM * sizeof(*otpinfo);
+ return 0;
+static int spi_otp_read(struct spi_nor *nor, loff_t from,
+ size_t len, size_t *retlen, u_char *buf)
+ struct spi_nor_xfer_cfg cfg = {
+ .cmd = SPINOR_OP_RD_SECURITY_REG,
+ .addr = from,
+ .addr_width = nor->addr_width,
+ .mode = SPI_NOR_NORMAL,
+ .dummy_cycles = 8,
+ return nor->read_xfer(nor, &cfg, buf, len, retlen);
+static int spi_otp_write(struct spi_nor *nor, loff_t to,
+ .cmd = SPINOR_OP_PR_SECURITY_REG,
+ .addr = to,
+ return nor->write_xfer(nor, &cfg, buf, len, retlen);
+static int spi_otp_erase(struct spi_nor *nor, loff_t offs)
+ size_t temp_retlen;
+ .cmd = SPINOR_OP_ER_SECURITY_REG,
+ .addr = offs,
+ return nor->write_xfer(nor, &cfg, NULL, 0, &temp_retlen);
+static int spi_read_uniqueid(struct spi_nor *nor, u8 *buf)
+ .cmd = SPINOR_OP_RD_UNIQUE_ID,
+ .addr_width = 0,
+ .dummy_cycles = 32,
+ return nor->read_xfer(nor, &cfg, buf, SPI_NOR_UNIQUE_ID_LEN,
+ &temp_retlen);
+static int winbond_read_user_otp(struct mtd_info *mtd, loff_t from,
+ int ret;
+ u32 i, read_len, end_addr, sreg_offset;
+ loff_t temp_addr;
+ *retlen = 0;
+ if (from < 0 || from >= SECURITY_REG_TOTAL_SIZE
+ || (from + len) > SECURITY_REG_TOTAL_SIZE)
+ return -EINVAL;
+ if (!len)
+ return 0;
+ end_addr = from + len;
+ ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_READ);
+ if (ret)
+ return ret;
+ for (i = from; i < end_addr; i += read_len) {
+ sreg_offset = i & (SECURITY_REG_SIZE-1);
+ /* if offset not on boundary, read first few bytes */
+ if (sreg_offset) {
+ /* check if everything has to be read from 1 reg */
+ if ((sreg_offset + len) <= SECURITY_REG_SIZE)
+ read_len = len;
+ else
+ read_len = SECURITY_REG_SIZE - sreg_offset;
+ /* if it is last chunk, read the remaining bytes */
+ else if ((end_addr - i) < SECURITY_REG_SIZE)
+ read_len = end_addr - i;
+ else
+ read_len = SECURITY_REG_SIZE;
+ temp_addr = translate_addr(i);
+ ret = spi_otp_read(nor, temp_addr, read_len, retlen,
+ buf + (i-from));
+ if (ret < 0)
+ goto error;
+error:
+ spi_nor_unlock_and_unprep(nor, SPI_NOR_OPS_READ);
+ return ret;
+ * This func assumes that offset is within valid range of security registers,
+ * valid offset are 0x1000, 0x2000 or 0x3000
+static int winbond_erase_security_reg(struct spi_nor *nor, loff_t offset)
+ int ret;
+ ret = write_enable(nor);
+ if (ret < 0)
+ return ret;
+ ret = spi_nor_wait_till_ready(nor);
+ if (ret)
+ return ret;
+ ret = spi_otp_erase(nor, offset);
+ if (ret < 0)
+ return ret;
+ return ret;
+ * This function does read, modify locally, erase and write to the register to
+ * be written
+ * It doesn't do any range checks on reg_addr, sreg_offset, len
+static int winbond_write_security_reg(struct spi_nor *nor, loff_t reg_addr,
+ u32 sreg_offset, size_t len,
+ size_t *retlen, u_char *buf)
+ int ret;
+ size_t temp_retlen = 0;
+ u8 *reg_buffer;
+ if (unlikely(sreg_offset + len > SECURITY_REG_SIZE))
+ return -EINVAL;
+ reg_buffer = kmalloc(SECURITY_REG_SIZE, GFP_KERNEL);
+ if (!reg_buffer)
+ return -ENOMEM;
+ /* read the security register */
+ ret = spi_otp_read(nor, reg_addr, SECURITY_REG_SIZE, &temp_retlen,
+ reg_buffer);
+ if (ret < 0 || temp_retlen != SECURITY_REG_SIZE)
+ goto error;
+ /* modify the part to be written */
+ memcpy(reg_buffer + sreg_offset, buf, len);
+ /* erase the security register */
+ ret = winbond_erase_security_reg(nor, reg_addr);
+ if (ret < 0)
+ goto error;
+ /* write the security reg*/
+ if (ret < 0)
+ goto error;
+ if (ret)
+ goto error;
+ temp_retlen = 0;
+ ret = spi_otp_write(nor, reg_addr, SECURITY_REG_SIZE, &temp_retlen,
+ reg_buffer);
+ goto error;
+ *retlen += len;
+error:
+ kfree(reg_buffer);
+ return ret;
+static int winbond_write_user_otp(struct mtd_info *mtd, loff_t to,
+ int ret;
+ u32 i, write_len, end_addr, sreg_offset;
+ loff_t temp_addr;
+ *retlen = 0;
+ if (to < 0 || to >= SECURITY_REG_TOTAL_SIZE
+ || (to + len) > SECURITY_REG_TOTAL_SIZE)
+ return -EINVAL;
+ if (!len)
+ return 0;
+ end_addr = to + len;
+ ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_WRITE);
+ if (ret)
+ return ret;
+ for (i = to; i < end_addr; i += write_len) {
+ /* if offset not on boundary, write first few bytes */
+ /* check if everything has to be written in 1 reg */
+ write_len = len;
+ else
+ write_len = SECURITY_REG_SIZE - sreg_offset;
+ /* if it is last chunk, write the remaining bytes */
+ write_len = end_addr - i;
+ else
+ write_len = SECURITY_REG_SIZE;
+ ret = winbond_write_security_reg(nor,
+ SEC_REG_START_ADDR(temp_addr),
+ sreg_offset, write_len,
+ retlen, buf + (i-to));
+ if (ret < 0)
+ goto error;
+error:
+ spi_nor_unlock_and_unprep(nor, SPI_NOR_OPS_WRITE);
+ return ret;
+static int winbond_lock_user_otp(struct mtd_info *mtd, loff_t from, size_t len)
+ int ret;
+ u8 sr1, sr2, security_reg_num;
+ /* allow locking 1 register at a time,
+ * so ensure that len is 256
+ * also check if address is on security register boundary
+ if (len != SECURITY_REG_SIZE || from < 0
+ || from >= SECURITY_REG_TOTAL_SIZE
+ || from & (SECURITY_REG_SIZE - 1))
+ return -EINVAL;
+ /* find out the security reg to set */
+ security_reg_num = from / SECURITY_REG_SIZE;
+ if (unlikely(security_reg_num > (SECURITY_REG_NUM-1)))
+ return -EINVAL;
+ ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_LOCK);
+ if (ret)
+ return ret;
+ /* read status registers */
+ ret = read_sr(nor, SPINOR_OP_RDSR, &sr1);
+ if (ret < 0)
+ goto error;
+ ret = read_sr(nor, SPINOR_OP_RD_SR2, &sr2);
+ if (ret < 0)
+ goto error;
+ if (ret < 0)
+ goto error;
+ /* set the corresponding LB bit in security register 2 */
+ sr2 |= BIT(SR2_LB1_BIT + security_reg_num);
+ /* write status registers */
+ nor->cmd_buf[0] = sr1;
+ nor->cmd_buf[1] = sr2;
+ ret = nor->write_reg(nor, SPINOR_OP_WRSR, nor->cmd_buf, 2, 0);
+ write_disable(nor);
+error:
+ spi_nor_unlock_and_unprep(nor, SPI_NOR_OPS_LOCK);
+ return ret;
+ * Unique ID of NOR device will be reported as factory OTP
+static int winbond_get_fact_otp_info(struct mtd_info *mtd, size_t len,
+ size_t *retlen,
+ otpinfo->start = 0;
+ otpinfo->length = SPI_NOR_UNIQUE_ID_LEN;
+ otpinfo->locked = 1;
+ *retlen = sizeof(*otpinfo);
+ return 0;
+static int winbond_read_fact_otp(struct mtd_info *mtd, loff_t from, size_t len,
+ int ret;
+ char unique_id[SPI_NOR_UNIQUE_ID_LEN] = {0};
+ *retlen = 0;
+ if (from < 0 || from >= SPI_NOR_UNIQUE_ID_LEN
+ || (from + len) > SPI_NOR_UNIQUE_ID_LEN)
+ return -EINVAL;
+ if (!len)
+ return 0;
+ if (ret)
+ return ret;
+ ret = spi_read_uniqueid(nor, unique_id);
+ if (ret < 0)
+ goto error;
+ /* Read complete unique ID,but just copy whatever is requested */
+ memcpy(buf, unique_id + from, len);
+ *retlen = len;
+error:
+ return ret;
+void winbond_otp_register(struct mtd_info *mtd)
+ if (nor->read_xfer && nor->write_xfer) {
+ mtd->_get_user_prot_info = winbond_get_user_otp_info;
+ mtd->_read_user_prot_reg = winbond_read_user_otp;
+ mtd->_write_user_prot_reg = winbond_write_user_otp;
+ mtd->_lock_user_prot_reg = winbond_lock_user_otp;
+ mtd->_get_fact_prot_info = winbond_get_fact_otp_info;
+ mtd->_read_fact_prot_reg = winbond_read_fact_otp;
+ } else
+ dev_err(nor->dev, "Required nor interfaces "
+ "(read_xfer, write_xfer) not defined\n");
diff --git a/drivers/mtd/spi-nor/winbond-otp.h b/drivers/mtd/spi-nor/winbond-otp.h
index 0000000..29cbbcc
--- /dev/null
+++ b/drivers/mtd/spi-nor/winbond-otp.h
@@ -0,0 +1,20 @@
+#ifndef WINBOND_OTP_H
+#define WINBOND_OTP_H
+#ifdef CONFIG_MTD_SPI_NOR_WINBOND_OTP
+void winbond_otp_register(struct mtd_info *mtd);
+#else
+static inline void winbond_otp_register(struct mtd_info *mtd) { return; }
+#endif
+#endif
1.9.1
这个加密好,哈哈。
