TSC2007 I2C触摸驱动有个地方没搞明白,
为什么IRQ引脚和GPIO检测PEN引脚状态可以是同一个,
这样在 IRQ/GPIO 两种复用之间要来回切换吗?
可是驱动代码里面并没有出现这种切换。
https://github.com/torvalds/linux/blob/master/drivers/input/touchscreen/tsc2007_core.c
// SPDX-License-Identifier: GPL-2.0-only
* drivers/input/touchscreen/tsc2007.c
* Copyright (c) 2008 MtekVision Co., Ltd.
* Kwangwoo Lee <kwlee@mtekvision.com>
* Using code from:
* - ads7846.c
* Copyright (c) 2005 David Brownell
* Copyright (c) 2006 Nokia Corporation
* - corgi_ts.c
* Copyright (C) 2004-2005 Richard Purdie
* - omap_ts.[hc], ads7846.h, ts_osk.c
* Copyright (C) 2002 MontaVista Software
* Copyright (C) 2004 Texas Instruments
* Copyright (C) 2005 Dirk Behme
#include <linux/module.h>
#include <linux/slab.h>
#include <linux/gpio/consumer.h>
#include <linux/input.h>
#include <linux/interrupt.h>
#include <linux/i2c.h>
#include <linux/mod_devicetable.h>
#include <linux/property.h>
#include <linux/platform_data/tsc2007.h>
#include "tsc2007.h"
int tsc2007_xfer(struct tsc2007 *tsc, u8 cmd)
s32 data;
u16 val;
data = i2c_smbus_read_word_data(tsc->client, cmd);
if (data < 0) {
dev_err(&tsc->client->dev, "i2c io error: %d\n", data);
return data;
/* The protocol and raw data format from i2c interface:
* S Addr Wr [A] Comm [A] S Addr Rd [A] [DataLow] A [DataHigh] NA P
* Where DataLow has [D11-D4], DataHigh has [D3-D0 << 4 | Dummy 4bit].
val = swab16(data) >> 4;
dev_dbg(&tsc->client->dev, "data: 0x%x, val: 0x%x\n", data, val);
return val;
static void tsc2007_read_values(struct tsc2007 *tsc, struct ts_event *tc)
/* y- still on; turn on only y+ (and ADC) */
tc->y = tsc2007_xfer(tsc, READ_Y);
/* turn y- off, x+ on, then leave in lowpower */
tc->x = tsc2007_xfer(tsc, READ_X);
/* turn y+ off, x- on; we'll use formula #1 */
tc->z1 = tsc2007_xfer(tsc, READ_Z1);
tc->z2 = tsc2007_xfer(tsc, READ_Z2);
/* Prepare for next touch reading - power down ADC, enable PENIRQ */
tsc2007_xfer(tsc, PWRDOWN);
u32 tsc2007_calculate_resistance(struct tsc2007 *tsc, struct ts_event *tc)
u32 rt = 0;
/* range filtering */
if (tc->x == MAX_12BIT)
tc->x = 0;
if (likely(tc->x && tc->z1)) {
/* compute touch resistance using equation #1 */
rt = tc->z2 - tc->z1;
rt *= tc->x;
rt *= tsc->x_plate_ohms;
rt /= tc->z1;
rt = (rt + 2047) >> 12;
return rt;
bool tsc2007_is_pen_down(struct tsc2007 *ts)
* NOTE: We can't rely on the pressure to determine the pen down
* state, even though this controller has a pressure sensor.
* The pressure value can fluctuate for quite a while after
* lifting the pen and in some cases may not even settle at the
* expected value.
* The only safe way to check for the pen up condition is in the
* work function by reading the pen signal state (it's a GPIO
* and IRQ). Unfortunately such callback is not always available,
* in that case we assume that the pen is down and expect caller
* to fall back on the pressure reading.
if (!ts->get_pendown_state)
return true;
return ts->get_pendown_state(&ts->client->dev);
static irqreturn_t tsc2007_soft_irq(int irq, void *handle)
struct tsc2007 *ts = handle;
struct input_dev *input = ts->input;
struct ts_event tc;
u32 rt;
while (!ts->stopped && tsc2007_is_pen_down(ts)) {
/* pen is down, continue with the measurement */
mutex_lock(&ts->mlock);
tsc2007_read_values(ts, &tc);
mutex_unlock(&ts->mlock);
rt = tsc2007_calculate_resistance(ts, &tc);
if (!rt && !ts->get_pendown_state) {
* If pressure reported is 0 and we don't have
* callback to check pendown state, we have to
* assume that pen was lifted up.
break;
if (rt <= ts->max_rt) {
dev_dbg(&ts->client->dev,
"DOWN point(%4d,%4d), resistance (%4u)\n",
tc.x, tc.y, rt);
rt = ts->max_rt - rt;
input_report_key(input, BTN_TOUCH, 1);
input_report_abs(input, ABS_X, tc.x);
input_report_abs(input, ABS_Y, tc.y);
input_report_abs(input, ABS_PRESSURE, rt);
input_sync(input);
} else {
* Sample found inconsistent by debouncing or pressure is
* beyond the maximum. Don't report it to user space,
* repeat at least once more the measurement.
dev_dbg(&ts->client->dev, "ignored pressure %d\n", rt);
wait_event_timeout(ts->wait, ts->stopped, ts->poll_period);
dev_dbg(&ts->client->dev, "UP\n");
input_report_key(input, BTN_TOUCH, 0);
input_report_abs(input, ABS_PRESSURE, 0);
input_sync(input);
if (ts->clear_penirq)
ts->clear_penirq();
return IRQ_HANDLED;
static irqreturn_t tsc2007_hard_irq(int irq, void *handle)
if (tsc2007_is_pen_down(ts))
return IRQ_WAKE_THREAD;
ts->clear_penirq();
return IRQ_HANDLED;
static void tsc2007_stop(struct tsc2007 *ts)
ts->stopped = true;
mb();
wake_up(&ts->wait);
disable_irq(ts->irq);
static int tsc2007_open(struct input_dev *input_dev)
struct tsc2007 *ts = input_get_drvdata(input_dev);
int err;
ts->stopped = false;
mb();
enable_irq(ts->irq);
/* Prepare for touch readings - power down ADC and enable PENIRQ */
err = tsc2007_xfer(ts, PWRDOWN);
if (err < 0) {
tsc2007_stop(ts);
return err;
static void tsc2007_close(struct input_dev *input_dev)
tsc2007_stop(ts);
static int tsc2007_get_pendown_state_gpio(struct device *dev)
struct i2c_client *client = to_i2c_client(dev);
struct tsc2007 *ts = i2c_get_clientdata(client);
return gpiod_get_value(ts->gpiod);
static int tsc2007_probe_properties(struct device *dev, struct tsc2007 *ts)
u32 val32;
u64 val64;
if (!device_property_read_u32(dev, "ti,max-rt", &val32))
ts->max_rt = val32;
ts->max_rt = MAX_12BIT;
if (!device_property_read_u32(dev, "ti,fuzzx", &val32))
ts->fuzzx = val32;
if (!device_property_read_u32(dev, "ti,fuzzy", &val32))
ts->fuzzy = val32;
if (!device_property_read_u32(dev, "ti,fuzzz", &val32))
ts->fuzzz = val32;
if (!device_property_read_u64(dev, "ti,poll-period", &val64))
ts->poll_period = msecs_to_jiffies(val64);
ts->poll_period = msecs_to_jiffies(1);
if (!device_property_read_u32(dev, "ti,x-plate-ohms", &val32)) {
ts->x_plate_ohms = val32;
} else {
dev_err(dev, "Missing ti,x-plate-ohms device property\n");
return -EINVAL;
ts->gpiod = devm_gpiod_get_optional(dev, NULL, GPIOD_IN);
if (IS_ERR(ts->gpiod))
return PTR_ERR(ts->gpiod);
if (ts->gpiod)
ts->get_pendown_state = tsc2007_get_pendown_state_gpio;
dev_warn(dev, "Pen down GPIO is not specified in properties\n");
static int tsc2007_probe_pdev(struct device *dev, struct tsc2007 *ts,
const struct tsc2007_platform_data *pdata,
const struct i2c_device_id *id)
ts->model = pdata->model;
ts->x_plate_ohms = pdata->x_plate_ohms;
ts->max_rt = pdata->max_rt ? : MAX_12BIT;
ts->poll_period = msecs_to_jiffies(pdata->poll_period ? : 1);
ts->get_pendown_state = pdata->get_pendown_state;
ts->clear_penirq = pdata->clear_penirq;
ts->fuzzx = pdata->fuzzx;
ts->fuzzy = pdata->fuzzy;
ts->fuzzz = pdata->fuzzz;
if (pdata->x_plate_ohms == 0) {
dev_err(dev, "x_plate_ohms is not set up in platform data\n");
return -EINVAL;
static void tsc2007_call_exit_platform_hw(void *data)
struct device *dev = data;
const struct tsc2007_platform_data *pdata = dev_get_platdata(dev);
pdata->exit_platform_hw();
static int tsc2007_probe(struct i2c_client *client,
dev_get_platdata(&client->dev);
struct tsc2007 *ts;
struct input_dev *input_dev;
int err;
if (!i2c_check_functionality(client->adapter,
I2C_FUNC_SMBUS_READ_WORD_DATA))
return -EIO;
ts = devm_kzalloc(&client->dev, sizeof(struct tsc2007), GFP_KERNEL);
if (!ts)
return -ENOMEM;
if (pdata)
err = tsc2007_probe_pdev(&client->dev, ts, pdata, id);
err = tsc2007_probe_properties(&client->dev, ts);
if (err)
return err;
input_dev = devm_input_allocate_device(&client->dev);
if (!input_dev)
return -ENOMEM;
i2c_set_clientdata(client, ts);
ts->client = client;
ts->irq = client->irq;
ts->input = input_dev;
init_waitqueue_head(&ts->wait);
mutex_init(&ts->mlock);
snprintf(ts->phys, sizeof(ts->phys),
"%s/input0", dev_name(&client->dev));
input_dev->name = "TSC2007 Touchscreen";
input_dev->phys = ts->phys;
input_dev->id.bustype = BUS_I2C;
input_dev->open = tsc2007_open;
input_dev->close = tsc2007_close;
input_set_drvdata(input_dev, ts);
input_set_capability(input_dev, EV_KEY, BTN_TOUCH);
input_set_abs_params(input_dev, ABS_X, 0, MAX_12BIT, ts->fuzzx, 0);
input_set_abs_params(input_dev, ABS_Y, 0, MAX_12BIT, ts->fuzzy, 0);
input_set_abs_params(input_dev, ABS_PRESSURE, 0, MAX_12BIT,
ts->fuzzz, 0);
if (pdata) {
if (pdata->exit_platform_hw) {
err = devm_add_action(&client->dev,
tsc2007_call_exit_platform_hw,
&client->dev);
if (err) {
dev_err(&client->dev,
"Failed to register exit_platform_hw action, %d\n",
err);
return err;
if (pdata->init_platform_hw)
pdata->init_platform_hw();
err = devm_request_threaded_irq(&client->dev, ts->irq,
tsc2007_hard_irq, tsc2007_soft_irq,
IRQF_ONESHOT,
client->dev.driver->name, ts);
if (err) {
dev_err(&client->dev, "Failed to request irq %d: %d\n",
ts->irq, err);
return err;
tsc2007_stop(ts);
/* power down the chip (TSC2007_SETUP does not ACK on I2C) */
if (err < 0) {
"Failed to setup chip: %d\n", err);
return err; /* chip does not respond */
err = input_register_device(input_dev);
if (err) {
"Failed to register input device: %d\n", err);
return err;
err = tsc2007_iio_configure(ts);
if (err) {
"Failed to register with IIO: %d\n", err);
return err;
static const struct i2c_device_id tsc2007_idtable[] = {
{ "tsc2007", 0 },
MODULE_DEVICE_TABLE(i2c, tsc2007_idtable);
static const struct of_device_id tsc2007_of_match[] = {
{ .compatible = "ti,tsc2007" },
{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, tsc2007_of_match);
static struct i2c_driver tsc2007_driver = {
.driver = {
.name = "tsc2007",
.of_match_table = tsc2007_of_match,
.id_table = tsc2007_idtable,
.probe = tsc2007_probe,
module_i2c_driver(tsc2007_driver);
MODULE_AUTHOR("Kwangwoo Lee <kwlee@mtekvision.com>");
MODULE_DESCRIPTION("TSC2007 TouchScreen Driver");
MODULE_LICENSE("GPL");buildroot-tiny200 (F1C100/200s) 开发包近期更新内容 * 已支持DVP摄像头 *
https://whycan.com/t_5221.html#p54779
rtp@48 {
compatible = "ti,tsc2007";
reg = <0x48>;
interrupt-parent = <&pio>;
interrupts = <4 12 IRQ_TYPE_EDGE_FALLING>;
gpios = <&pio 4 12 GPIO_ACTIVE_LOW>;
pendown-gpio = <&pio 4 12 GPIO_ACTIVE_LOW>;
ti,x-plate-ohms = <660>;
wakeup-source;
};离线
从手册看,gpio输入和外部中断属于不同的复用。
只能这么认为了,中断复用的时候也能读?
