请教一下 ,
是4个核心 ,累计起来,一共1.2G主频 ,
还是每个核心1.2G主频 ???
当然是单核1.2
当然是每个核1.2G啦
多谢楼上两位的解答
今天我尝试编译A33的SDK了
入坑失败
make[3]: arch/arm/mach-sunxi/pm/standby/gen_check_code:命令未找到
/home/xxmm/A33/dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/standby/Makefile:85: recipe for target 'arch/arm/mach-sunxi/pm/standby/resume1.code' failed
make[3]: *** [arch/arm/mach-sunxi/pm/standby/resume1.code] Error 127
/home/xxmm/A33/dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/Makefile:70: recipe for target 'arch/arm/mach-sunxi/pm/standby/standby.code' failed
make[2]: *** [arch/arm/mach-sunxi/pm/standby/standby.code] Error 2
scripts/Makefile.build:443: recipe for target 'arch/arm/mach-sunxi/pm' failed
make[1]: *** [arch/arm/mach-sunxi/pm] Error 2
Makefile:945: recipe for target 'arch/arm/mach-sunxi' failed
make: *** [arch/arm/mach-sunxi] Error 2缺少 gen_check_code:命令
@0123456789
file dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/standby/gen_check_code
/opt/a33/a33_linux_sdk/dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/standby/gen_check_code: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.15, BuildID[sha1]=75051867a5f308694a001a210f2f7f2bcd31904e, not stripped是不是这个文件 dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/standby/gen_check_code 不存在?
回答是的
今天早上再次编译全志A33 vstar , 再次失败 ,
信息 , 操作命令在下面
root@xxmm:/home/xxmm/A33/dragonboard/linux-3.4# cp a33_vstar_defconfig .config
root@xxmm:/home/xxmm/A33/dragonboard/linux-3.4# cd ..
root@xxmm:/home/xxmm/A33/dragonboard# ./build.sh config
Welcome to mkscript setup progress
All available chips:
0. sun8iw5p1
Choice: 0
All available platforms:
0. android
1. dragonboard
2. linux
Choice: 1
All available kernel:
0. linux-3.4
Choice: 1
Invalid input ...
Choice: 0
All available boards:
0. evb
1. maple
2. redwood
3. vstar
4. y2
5. y3
Choice: 3
INFO: ----------------------------------------
INFO: build lichee ...
INFO: chip: sun8iw5p1
INFO: platform: dragonboard
INFO: kernel: linux-3.4
INFO: board: vstar
INFO: output: out/sun8iw5p1/dragonboard/vstar
INFO: build buildroot ...
external toolchain has been installed
INFO: build buildroot OK.
INFO: build kernel ...
INFO: prepare toolchain ...
Building kernel
scripts/kconfig/conf --silentoldconfig Kconfig
drivers/net/wireless/bcmdhd/Kconfig:43:warning: defaults for choice values not supported
CHK include/linux/version.h
CHK include/generated/utsrelease.h
make[1]: 'include/generated/mach-types.h' is up to date.
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CC kernel/fork.o
CC arch/arm/mach-sunxi/pm/standby/common.o
CC arch/arm/mach-sunxi/pm/standby/standby_clock.o
在这里,省略了若干信息
CC arch/arm/mach-sunxi/pm/standby/./../mem_hwspinlock.o
CC kernel/exec_domain.o
CC arch/arm/mach-sunxi/pm/standby/standby.o
rm -rf *.o arch/arm/mach-sunxi/pm/standby/../*.o
CC arch/arm/mach-sunxi/pm/standby/super/common.o
在这里,省略了若干信息
CC kernel/printk.o
AS arch/arm/mach-sunxi/pm/standby/../mem_mmu_pc_asm.o
在这里,省略了若干信息
CC arch/arm/mach-sunxi/pm/standby/../mem_hwspinlock.o
CC arch/arm/mach-sunxi/pm/standby/../mem_clk.o
/home/xxmm/A33/dragonboard/linux-3.4/arch/arm/mach-sunxi/pm/standby/Makefile:89: recipe for target 'arch/arm/mach-sunxi/pm/standby/resume1.code' failed
make: *** 正在等待未完成的任务....
CC kernel/cpu.o
在这里,省略了若干信息
CC kernel/sched/fair.o
kernel/time/alarmtimer.c: In function ‘alarmtimer_shutdown’:
kernel/time/alarmtimer.c:298:13: warning: unused variable ‘i’ [-Wunused-variable]
CC kernel/time/clockevents.o
在这里,省略了若干信息
CHK kernel/config_data.h
UPD kernel/config_data.h
CC kernel/configs.o
LD kernel/built-in.o
ERROR: build kernel Failed
0. sun8iw5p1
Choice: 0
0. android
1. dragonboard
2. linux
Choice: 1
0. linux-3.4
Choice: 1
Invalid input ...
Choice: 0
0. evb
1. maple
2. redwood
3. vstar
4. y2
5. y3
Choice: 3
编译选项 0 1 0 3 , 失败
0. sun8iw5p1
Choice: 0
0. android
1. dragonboard
2. linux
Choice: 2
0. linux-3.4
Choice: 0
0. evb
1. maple
2. redwood
3. vstar
4. y2
5. y3
Choice: 3
编译选项 0 2 0 3 , 失败
编译选项 0 1 0 5 , 失败
编译选项 0 1 0 4 , 失败
编译选项 0 1 0 2 , 失败
编译选项 0 1 0 0 , 失败
编译选项 0 2 0 5 , 失败
ERROR: build buildroot Failed
编译选项 0 2 0 4 , 失败
编译选项 0 2 0 3 , 失败
编译选项 0 2 0 2 , 失败
编译选项 0 2 0 1 , 失败
编译选项 0 2 0 0 , 失败
感觉你的SDK不全, 或者解压的时候丢了文件? 你是不是windows解压,然后复制过去的?
我是在 UBUNTU,使用提取到此处来解压的
我已经再次下载 A33_vstar_linux.tar
再次解压,
再次编译
再次失败
失败的信息
arch/arm/mach-sunxi/pm/standby/gen_check_code: 1: arch/arm/mach-sunxi/pm/standby/gen_check_code: Syntax error: end of file unexpected (expecting ")")
make[3]: *** [arch/arm/mach-sunxi/pm/standby/resume1.code] Error 2
上一次失败
我已经100%按照深圳锐尔威视的说明书来操作了
再次失败
root@xxmm:/home/xxmm/A33# cd dragonboard
root@xxmm:/home/xxmm/A33/dragonboard# ls
brandy buildroot build.sh clean.sh linux-3.4 README tools
root@xxmm:/home/xxmm/A33/dragonboard# cd linux-3.4
root@xxmm:/home/xxmm/A33/dragonboard/linux-3.4# ls
a33_vstar_defconfig e_build.sh MAINTAINERS samples
android firmware Makefile scripts
arch fs mm security
block include modules sound
build.sh init net tinyandroid.tar.gz
COPYING ipc old_config tools
CREDITS Kbuild output usr
crypto Kconfig README virt
Documentation kernel REPORTING-BUGS
drivers lib rootfs.cpio.gz
0. sun8iw5p1
Choice: 0
0. android
1. dragonboard
2. linux
Choice: 1
0. linux-3.4
Choice: 0
0. evb
1. maple
2. redwood
3. vstar
4. y2
5. y3
Choice: 3
brandy buildroot build.sh clean.sh linux-3.4 out README tools
INFO: board: vstar
installing external toolchain
please wait for a few minutes ...
Building kernel
HOSTCC scripts/basic/fixdep
SHIPPED scripts/kconfig/zconf.tab.c
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
WRAP arch/arm/include/generated/asm/auxvec.h
WRAP arch/arm/include/generated/asm/bitsperlong.h
WRAP arch/arm/include/generated/asm/cputime.h
WRAP arch/arm/include/generated/asm/emergency-restart.h
WRAP arch/arm/include/generated/asm/errno.h
WRAP arch/arm/include/generated/asm/ioctl.h
UPD include/linux/version.h
WRAP arch/arm/include/generated/asm/irq_regs.h
WRAP arch/arm/include/generated/asm/kdebug.h
WRAP arch/arm/include/generated/asm/local.h
WRAP arch/arm/include/generated/asm/local64.h
WRAP arch/arm/include/generated/asm/percpu.h
WRAP arch/arm/include/generated/asm/poll.h
WRAP arch/arm/include/generated/asm/resource.h
WRAP arch/arm/include/generated/asm/sections.h
WRAP arch/arm/include/generated/asm/siginfo.h
WRAP arch/arm/include/generated/asm/sizes.h
UPD include/generated/utsrelease.h
HOSTCC scripts/genksyms/genksyms.o
Generating include/generated/mach-types.h
CC kernel/bounds.s
GEN include/generated/bounds.h
CC arch/arm/kernel/asm-offsets.s
SHIPPED scripts/genksyms/lex.lex.c
SHIPPED scripts/genksyms/keywords.hash.c
SHIPPED scripts/genksyms/parse.tab.h
SHIPPED scripts/genksyms/parse.tab.c
HOSTCC scripts/genksyms/lex.lex.o
GEN include/generated/asm-offsets.h
HOSTCC scripts/genksyms/parse.tab.o
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
HOSTLD scripts/genksyms/genksyms
HOSTCC scripts/selinux/genheaders/genheaders
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/selinux/mdp/mdp
HOSTCC scripts/kallsyms
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/mod/sumversion.o
HOSTCC scripts/conmakehash
HOSTCC scripts/bin2c
HOSTCC scripts/recordmcount
HOSTLD scripts/mod/modpost
CC init/main.o
HOSTCC usr/gen_init_cpio
GEN usr/initramfs_data.cpio
AS usr/initramfs_data.o
LD usr/built-in.o
CC arch/arm/vfp/vfpmodule.o
AS arch/arm/vfp/entry.o
AS arch/arm/vfp/vfphw.o
CC arch/arm/vfp/vfpsingle.o
UPD include/generated/compile.h
CC init/do_mounts.o
CC arch/arm/vfp/vfpdouble.o
root@xxmm:/home/xxmm/A33/dragonboard#最近编辑记录 0123456789 (2021-10-21 11:23:48)
INFO: board: vstar
Building kernel
CC mm/fadvise.o
LD mm/built-in.o
其中很关键的几个信息
scripts/Makefile.build:443: recipe for target 'arch/arm/mach-sunxi/pm' failed离线
你的Linux发行版是什么版本?
我前面是使用UBUNTU 16.04 32位版本
我是在下面的连接下载软件包的 ,下载 A33_vstar_linux.tar
https://whycan.com/t_3617.html
https://blog.csdn.net/jklinux/article/details/78108623
BSP开发包下载链接: https://pan.baidu.com/s/1jIvJiOu 密码: p6w7
据说这个 A33 vstar 开发板不错.
淘宝购买地址: https://item.taobao.com/item.htm?id=541595349035
得到
文件大小 1.26 GB (1,361,456,761 字节)
文件占用空间 1.26 GB (1,361,457,152 字节)
另外我按照你提供的连接
链接: https://pan.baidu.com/s/11M0L00b4Mjwulp71-5u5eA 提取码: 417j
得到
所以我感觉我在深圳锐尔威视下载的 A33_vstar_linux.tar
和 你提供的 A33_vstar_linux.tar , 都是同一个文件。
你的Linux发行版是什么版本?
试一下这个:
所以邀请你帮我下载 A33_vstar_linux.tar 一次 ,
下载了之后,看看这个文件的大小事多少。
四个核心加起来1.2G?只有路由器带宽才会这么干。
现在解压都发生错误
多试验几次,虽然解压没有错误,
但是 arch/arm/mach-sunxi/pm/standby/gen_check_code: 1: arch/arm/mach-sunxi/pm/standby/gen_check_code: Syntax error: end of file unexpected (expecting ")")
语法错误
我已经使用另外一台WIN7下载 A33_vstar_linux.tar ,
再次编译 ,还是
语法错误
0123456789 说:用命令行解压 tar xvf xxx.tagz
我现在解压没有错误 ,但是编译有错误
@0123456789
感觉你没有装32bit的c库
参考这个帖子:
https://bbs.aw-ol.com/topic/501/ubuntu18-04-打包img时出错/3
sudo apt-get install git-core gnupg flex bison gperf build-essential \
zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 \
lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z1-dev ccache \
libgl1-mesa-dev libxml2-utils xsltproc unzip u-boot-tools gawk \
build-essential subversion libncurses5-dev zlib1g-dev gawk gcc-multilib flex git-core gettext libssl-dev -y运行这个命令试一试
从早上忙碌到现在 , 还没有编译成功 。
安装了一个叫KALI的linux 系统,然后编译 , 没有成功。
还是 Syntax error: end of file unexpected (expecting ")")
然后安装一个叫做 deepin 深度系统
还是失败
Ubuntu 21版本 64位
CENTOS7
你的问题貌似就是缺一个32bit c库兼容包,20楼的方法试了吗?
由于历史问题,全志bsp包里面的二进制工具都是32bit的,而比较新的linux发行版本里面基本都是64bit,所以需要安装一个兼容包。
晚一些时间,再试验。
A33环境搭建编译手册
oria2006 2015-11-16 14:09:08 3092 收藏
A33环境搭建编译手册
说明
目录
Ubuntu安装 4
制作Ubuntu的USB启动盘 4
安装Ubuntu 6
配置ssh 15
配置vim 15
开启Ubuntu图形界面的root权限 16
配置WINDOWS可用XRDP远程桌面 17
搭建安卓编译开发环境 18
JAVA库下载、安装与配置 19
编译器下载、安装与配置 19
Uboot镜像制作工具下载安装 20
安装编译环境需要的库 20
编译指南 21
编译内核 21
编译lichee 22
编译brandy 23
编译android 24
Android打包 25
Ubuntu安装
制作Ubuntu的USB启动盘
登陆http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/,下载USB启动盘制作工具
找到DOWNLOAD UUI,下载
下载后,插入U盘运行(Universal-USB-Installer-1.9.5.9.exe 目前在技术部服务器有提供)
同意协议,下一步
如下图设置,
Step1:选着Linux发行版
Step2:选择ubuntu镜像所在的路径
Step3:选择插入的U盘
Step4:默认选项
确认
制作完成
安装Ubuntu
插入制作好的U盘到电脑,重启,按F12(根据实际情况)进入启动选项菜单,选择从U盘启动。
一路不用操作,默认的“ Try Ubuntu without Installing ”
直至进入Ubuntu试用系统,双击Install Ubuntu图标开始安装,如下图
选择中文
勾选下载更新,勾选安装第三方软件
询问安装类型,建议使用其他选项,可以更好的进行自定义
选择要安装的硬盘进行分区,这里安排是:
500G大小的硬盘
分区
挂载点
容量
第一个分区
/ (根分区)
30G
第二个分区
SWAP
4G
第三个分区
/opt
466G(即剩余的容量)
这么处理,考虑到以后开发相关的都放在opt上,如需重装、升级操作系统,无需破坏开发的资料
操作如下,点击选择目标硬盘的空闲空间,点击添加
如下图设置第一个分区
重复上一步,再添加第二个分区
重复上一步,再添加第三个分区
选择安装启动引导器的设备为硬盘的引导区,点击现在安装
接下来设置时区
设置键盘布局
设置账户信息和计算机信息
等待安装完成
直至提示安装完成,点击重启
重启之后进入系统,弹出更新管理器,选择不升级为14.04,选择安装更新
更新完重启系统
配置ssh
Ctrl+Alt+T打开终端
自动下载配置ssh
sudo apt-get install ssh
在Windows下使用PuTTY即可使用SSH远程登录
配置vim
vm是vi的升级版本
自动下载配置vim
sudo apt-get install vim
开启Ubuntu图形界面的root权限
快捷键打开终端
Ctrl+Alt+T
获取root权限
输入sudo -s 输入普通用户登陆的密码,回车获得root权限
修改配置文件/etc/lightdm/lightdm.conf
试用vim打开或者试用gedit打开
vim /etc/lightdm/lightdm.conf
或:
gdit /etc/lightdm/lightdm.conf
编辑后文档内容如下(添加下面加底纹内容):
[SeatDefaults]
greeter-session=unity-greeter
user-session=Ubuntu
greeter-show-manual-login=true
allow-guest=false
设置root用户密码
sudo passwd root
重启后选择登陆root登陆帐号
注:下文开始,如无特殊说明都是在root用户下进行操作
配置WINDOWS可用XRDP远程桌面
打开终端,自动配置安装xrdp和vnc
apt-get install xrdp vnc4server tightvncserver
打开要远程登录用户的home目录,root用户即/root
cd ~
创建.xsession文件
echo "gnome-session --session=ubuntu-2d" > .xsession
重启xrdp
/etc/init.d/xrdp restart
在Windows下使用远程桌面连接(请根据实际情况输入ip)
输入账号密码
即可登录
搭建安卓编译开发环境
JAVA库下载、安装与配置
登陆:http://www.oracle.com/technetwork/java/javase/downloads/java-archive-downloads-javase6-419409.html
下载jdk-6u45-linux-x64.bin (技术部服务器上有保存)
需要注意的是,现在官方网站上最新的版本的JDK7, 但是这个这个版本是不能用于Android的编译的,一定要去下载JDK6
下载后,修改权限
chmod 777 jdk-6u45-linux-x64.bin
./jdk-6u45-linux-x64.bin
安装后产生jdk1.6.0_45目录,把它拷贝到/opt/lib/jvm/jdk6/下面
设置环境变量
vim /etc/environment
添加上底纹部分内容
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/opt/lib/jvm/jdk6/jdk1.6.0_45/bin:/opt/lib/jvm/jdk6/jdk1.6.0_45/jre/bin"
JAVA_HOME=/opt/lib/jvm/jdk6/jdk1.6.0_45
CLASSPATH=/opt/lib/jvm/jdk6/jdk1.6.0_45/lib
Source环境变量
source /etc/environment
查看JAVA版本验证安装,若能看到版本信息则一般安装完成
java -version
版本信息如下
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01, mixed mode)
Uboot镜像制作工具下载安装
apt-get install uboot-mkimage
安装编译环境需要的库
apt-get install git gnupg flex bison gperf build-essential zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx-lts-trusty:i386 libgl1-mesa-dev g++-multilib mingw32 tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386
ln -s /usr/lib/i386-linux-gnu/mesa/libGL.so.1 /usr/lib/i386-linux-gnu/libGL.so
编译器下载、安装与配置
编译器下载、替换4.4版本
apt-get install gcc-4.4 g++-4.4 g++-4.4-multilib
mv -f /usr/bin/gcc /usr/bin/bak_gcc
mv -f /usr/bin/g++ /usr/bin/bak_g++
ln -s /usr/bin/gcc-4.4 /usr/bin/gcc
ln -s /usr/bin/g++-4.4 /usr/bin/g++
测试一下gcc版本号
gcc -v
版本信息如下
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.4.7-1ubuntu2' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.4 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.4.7 (Ubuntu/Linaro 4.4.7-1ubuntu2)
编译指南
创建项目文件夹
mkdir /opt/item_A33
解压lichee.tar.gz压缩包
tar -zxvf lichee.tar.gz -C /opt/item_A33/
解压android.tar.gz压缩包
tar -zxvf android.tar.gz -C /opt/item_A33/
进入lichee目录
cd /opt/item_A33/lichee
编译内核
source buildroot/scripts/mksetup.sh
出现以下设置选项,请依照设置
0. sun8iw5p1
Choice: 0
0. android
1. dragonboard
2. linux
Choice: 0
0. linux-3.4
Choice: 0
0. evb
1. maple
2. redwood
3. y2
4. y3
Choice: 4
编译lichee
mklichee
编译过程
INFO: platform: android
INFO: board: y3
INFO: output: out/sun8iw5p1/android/y3
Building kernel
make[1]: “include/generated/mach-types.h”是最新的。
省略大部分编译过程...
make: Leaving directory `/opt/item_A33/lichee/linux-3.4/modules/mali'
regenerate rootfs cpio
8772 blocks
9475 blocks
build_ramfs
Copy boot.img to output directory ...
Copy modules to target ...
INFO: build kernel OK.
INFO: build rootfs ...
INFO: skip make rootfs for android
INFO: build rootfs OK.
INFO: build lichee OK.
(至此编译成功)
单独编译buildroot
mkbr
编译过程
单独编译内核
mkkernel
编译过程
Building kernel
CC arch/arm/mach-sunxi/pm/standby/standby_ir.o
CC arch/arm/mach-sunxi/pm/standby/standby_key.o
CC arch/arm/mach-sunxi/pm/standby/standby_power.o
CC arch/arm/mach-sunxi/pm/standby/standby_twi.o
CC arch/arm/mach-sunxi/pm/standby/standby_usb.o
AS arch/arm/mach-sunxi/pm/standby/standby_delay.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/standby_arisc.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/arisc_hwmsgbox.o
(省略编译过程.,.)
8772 blocks
9475 blocks
build_ramfs
(至此,内核编译完成)
编译brandy
Bandy目录中存放的是A33平台的bootloader,该目录为A33启动代码,默认不编译。
编译u-boot
cd lichee/brandy/u-boot-2011.09/
make distclean
make sun8iw5p1_config
make -j2
当编译成功,生成的u-boot-sun8iw5pl.bin文件会自动拷贝到对应的tool目录下,这时候可以直接打包或者其他操作。U-boot-sun8iw5pl.bin启动时是uboot核心可执行程序。
"u-boot-sun8iw5p1.bin" -> "/opt/item_A33/lichee/brandy/u-boot-2011.09/../../tools/pack/chips/sun8iw5p1/bin/u-boot-sun8iw5p1.bin"
编译android
编译android前请先编译内核
选择方案
souece build/envsetup.sh
lunch
出现以下设置选项,请依照设置
You're building on Linux
Lunch menu... pick a combo:
1. aosp_arm-eng
2. aosp_x86-eng
3. aosp_mips-eng
4. vbox_x86-eng
5. aosp_manta-userdebug
6. aosp_deb-userdebug
7. aosp_flo-userdebug
8. aosp_grouper-userdebug
9. aosp_tilapia-userdebug
10. mini_armv7a_neon-userdebug
11. mini_x86-userdebug
12. mini_mips-userdebug
13. aosp_mako-userdebug
14. aosp_hammerhead-userdebug
15. astar_y3-eng
16. astar_y3-user
Which would you like? [aosp_arm-eng] 15
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=4.4.2
TARGET_PRODUCT=astar_y3
TARGET_BUILD_VARIANT=eng
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=cortex-a7
HOST_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-3.13.0-46-generic-x86_64-with-Ubuntu-12.04-precise
HOST_BUILD_TYPE=release
BUILD_ID=KVT49L
OUT_DIR=out
============================================拷贝kenrel和modules
extract-bsp
编译android
make -j?
(?表示启用几个进程编译,一般不要超过cpu的核数)
最后显示信息
Install system fs image: out/target/product/astar-y3/system.img
out/target/product/astar-y3/system.img+out/target/product/astar-y3/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p maxsize=822163584 blocksize=4224 total=591028141 reserve=8308608
Android打包
cd到android根目录用pack打包
pack
显示以下信息
copying tools file
copying configs file
copying boot resource
copying boot file
packing for android
normal
/opt/item_A33/lichee/tools/pack/pctools/linux/eDragonEx/
/opt/item_A33/lichee/tools/pack/out
Begin Parse sys_partion.fex
Add partion boot-resource.fex BOOT-RESOURCE_FEX
Add partion very boot-resource.fex BOOT-RESOURCE_FEX
FilePath: boot-resource.fex
FileLength=4bec00Add partion env.fex ENV_FEX000000000
Add partion very env.fex ENV_FEX000000000
FilePath: env.fex
FileLength=20000Add partion boot.fex BOOT_FEX00000000
Add partion very boot.fex BOOT_FEX00000000
FilePath: boot.fex
FileLength=afa000Add partion system.fex SYSTEM_FEX000000
Add partion very system.fex SYSTEM_FEX000000
FilePath: system.fex
FileLength=23175bdcAdd partion recovery.fex RECOVERY_FEX0000
Add partion very recovery.fex RECOVERY_FEX0000
FilePath: recovery.fex
FileLength=db2000Add partion diskfs.fex DISKFS_FEX000000
Add partion very diskfs.fex DISKFS_FEX000000
FilePath: diskfs.fex
FileLength=200sys_config.fex Len: 0xf397
config.fex Len: 0x9ac4
split_xxxx.fex Len: 0x200
sys_partition.fex Len: 0xf0a
boot0_nand.fex Len: 0x8000
boot0_sdcard.fex Len: 0x8000
u-boot.fex Len: 0xbc000
fes1.fex Len: 0x1f60
usbtool.fex Len: 0x20600
aultools.fex Len: 0x25d92
aultls32.fex Len: 0x2295a
cardtool.fex Len: 0x14000
cardscript.fex Len: 0x6ea
sunxi_mbr.fex Len: 0x10000
dlinfo.fex Len: 0x4000
arisc.fex Len: 0x2bee9
boot-resource.fex Len: 0x4bec00
Vboot-resource.fex Len: 0x4
env.fex Len: 0x20000
Venv.fex Len: 0x4
boot.fex Len: 0xafa000
Vboot.fex Len: 0x4
system.fex Len: 0x23175bdc
Vsystem.fex Len: 0x4
recovery.fex Len: 0xdb2000
Vrecovery.fex Len: 0x4
diskfs.fex Len: 0x200
Vdiskfs.fex Len: 0x4
BuildImg 0
Dragon execute image.cfg SUCCESS !
----------image is at----------
/opt/item_A33/lichee/tools/pack/sun8iw5p1_android_y3.img
pack finish离线
大概知道是什么回事了 。
前面说到 gen_check_code , 这是一个工具软件 ,相当于WINDOWS的EXE ,
这个工具是由厂家以源代码的形式提供的,
然后用户用 GCC 编译产生 gen_check_code 这个工具
用户编译 gen_check_code 的过程当中,又需要某个库文件 ,
这个库文件需要用户自己下载 。
再运行 gen_check_code , 由gen_check_code去产生内核的影像文件 。
差不多是这样吧 !!!
如果有人能帮忙裁减内核 ,
删除全志特有的功能 ,
跳过 gen_check_code 的步骤 ,
那就该多好啊 ! ! !
有没有裁减过的 A33 SDK ? ?
可以付费
可以尝试主线 u-boot 和 linux kernel
楼主有没有成功入坑了啊?一起学习一下???
A33 SDK已深度定制,连设备树都不用了
