(defun size(s1 s2) 0)
(defun font(f) 0)
(defun effects(f) 0)
(defun number(a1 a2) a1)
(defun name(a1 a2) a1)
#| (defun at(a1 a2 a3) (princ (ceiling (/ a1 2.54))) (princ " ") (princ (ceiling (/ a2 2.54))) (princ " ") (princ a3) (princ " ")) |#
(defun at(a1 a2 a3) a3)
(defun length(f) 0)
(defun rotate(r)
(if (= r 0) (setq ro "Left"))
(if (= r 270) (setq ro "Top"))
(if (= r 180) (setq ro "Right"))
(if (= r 90) (setq ro "Bottom"))
ro
;(defun pin(a1 a2 a3 a4 a5 a6) (princ a6) (princ " ") (write-line a5))
(defun pin(a1 a2 a3 a4 a5 a6) (format t "~A ~A Passive 1 Line ~S ~A 1~%" a6 a5 " " (rotate a3)))
(defvar passive 0)
(defvar line 0)
(pin passive line (at -7.62 -7.62 0) (length 7.62)
(name "PG6" (effects (font (size 1.27 1.27))))
(number "1" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -33.02 0) (length 7.62)
(name "PF3/CMD" (effects (font (size 1.27 1.27))))
(number "10" (effects (font (size 1.27 1.27))))
(pin passive line (at 104.14 7.62 270) (length 7.62)
(name "HPOUTFB" (effects (font (size 1.27 1.27))))
(number "100" (effects (font (size 1.27 1.27))))
(pin passive line (at 91.44 7.62 270) (length 7.62)
(name "GPADC0" (effects (font (size 1.27 1.27))))
(number "101" (effects (font (size 1.27 1.27))))
(pin passive line (at 88.9 7.62 270) (length 7.62)
(name "TP-X1" (effects (font (size 1.27 1.27))))
(number "102" (effects (font (size 1.27 1.27))))
(pin passive line (at 86.36 7.62 270) (length 7.62)
(name "TP-X2" (effects (font (size 1.27 1.27))))
(number "103" (effects (font (size 1.27 1.27))))
(pin passive line (at 83.82 7.62 270) (length 7.62)
(name "TP-Y1" (effects (font (size 1.27 1.27))))
(number "104" (effects (font (size 1.27 1.27))))
(pin passive line (at 81.28 7.62 270) (length 7.62)
(name "TP-Y2" (effects (font (size 1.27 1.27))))
(number "105" (effects (font (size 1.27 1.27))))
(pin passive line (at 76.2 7.62 270) (length 7.62)
(name "NC0" (effects (font (size 1.27 1.27))))
(number "106" (effects (font (size 1.27 1.27))))
(pin passive line (at 73.66 7.62 270) (length 7.62)
(name "VCC-TVIN" (effects (font (size 1.27 1.27))))
(number "107" (effects (font (size 1.27 1.27))))
(pin passive line (at 71.12 7.62 270) (length 7.62)
(name "TVIN0" (effects (font (size 1.27 1.27))))
(number "108" (effects (font (size 1.27 1.27))))
(pin passive line (at 68.58 7.62 270) (length 7.62)
(name "TVIN1" (effects (font (size 1.27 1.27))))
(number "109" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -35.56 0) (length 7.62)
(name "PF4/D3" (effects (font (size 1.27 1.27))))
(number "11" (effects (font (size 1.27 1.27))))
(pin passive line (at 66.04 7.62 270) (length 7.62)
(name "TVIN-VRP" (effects (font (size 1.27 1.27))))
(number "110" (effects (font (size 1.27 1.27))))
(pin passive line (at 63.5 7.62 270) (length 7.62)
(name "TVIN-VRN" (effects (font (size 1.27 1.27))))
(number "111" (effects (font (size 1.27 1.27))))
(pin passive line (at 58.42 7.62 270) (length 7.62)
(name "USB1-DP" (effects (font (size 1.27 1.27))))
(number "112" (effects (font (size 1.27 1.27))))
(pin passive line (at 55.88 7.62 270) (length 7.62)
(name "USB1-DM" (effects (font (size 1.27 1.27))))
(number "113" (effects (font (size 1.27 1.27))))
(pin passive line (at 53.34 7.62 270) (length 7.62)
(name "USB0-DM" (effects (font (size 1.27 1.27))))
(number "114" (effects (font (size 1.27 1.27))))
(pin passive line (at 50.8 7.62 270) (length 7.62)
(name "USB0-DP" (effects (font (size 1.27 1.27))))
(number "115" (effects (font (size 1.27 1.27))))
(pin passive line (at 45.72 7.62 270) (length 7.62)
(name "VDD-CORE0" (effects (font (size 1.27 1.27))))
(number "116" (effects (font (size 1.27 1.27))))
(pin passive line (at 43.18 7.62 270) (length 7.62)
(name "VDD-CORE1" (effects (font (size 1.27 1.27))))
(number "117" (effects (font (size 1.27 1.27))))
(pin passive line (at 38.1 7.62 270) (length 7.62)
(name "PG1" (effects (font (size 1.27 1.27))))
(number "118" (effects (font (size 1.27 1.27))))
(pin passive line (at 35.56 7.62 270) (length 7.62)
(name "PG2" (effects (font (size 1.27 1.27))))
(number "119" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -38.1 0) (length 7.62)
(name "PF5/D2" (effects (font (size 1.27 1.27))))
(number "12" (effects (font (size 1.27 1.27))))
(pin passive line (at 33.02 7.62 270) (length 7.62)
(name "PG0" (effects (font (size 1.27 1.27))))
(number "120" (effects (font (size 1.27 1.27))))
(pin passive line (at 30.48 7.62 270) (length 7.62)
(name "PG3" (effects (font (size 1.27 1.27))))
(number "121" (effects (font (size 1.27 1.27))))
(pin passive line (at 27.94 7.62 270) (length 7.62)
(name "PG5" (effects (font (size 1.27 1.27))))
(number "122" (effects (font (size 1.27 1.27))))
(pin passive line (at 25.4 7.62 270) (length 7.62)
(name "PG4" (effects (font (size 1.27 1.27))))
(number "123" (effects (font (size 1.27 1.27))))
(pin passive line (at 22.86 7.62 270) (length 7.62)
(name "PG12" (effects (font (size 1.27 1.27))))
(number "124" (effects (font (size 1.27 1.27))))
(pin passive line (at 20.32 7.62 270) (length 7.62)
(name "PG13" (effects (font (size 1.27 1.27))))
(number "125" (effects (font (size 1.27 1.27))))
(pin passive line (at 17.78 7.62 270) (length 7.62)
(name "PG14" (effects (font (size 1.27 1.27))))
(number "126" (effects (font (size 1.27 1.27))))
(pin passive line (at 15.24 7.62 270) (length 7.62)
(name "PG15" (effects (font (size 1.27 1.27))))
(number "127" (effects (font (size 1.27 1.27))))
(pin passive line (at 12.7 7.62 270) (length 7.62)
(name "VCC-PG" (effects (font (size 1.27 1.27))))
(number "128" (effects (font (size 1.27 1.27))))
(pin passive line (at 7.62 7.62 270) (length 7.62)
(name "EPAD" (effects (font (size 1.27 1.27))))
(number "129" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -40.64 0) (length 7.62)
(name "PF6/OWA/IR-RX/PWM5" (effects (font (size 1.27 1.27))))
(number "13" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -45.72 0) (length 7.62)
(name "PC7/HOLD/D3" (effects (font (size 1.27 1.27))))
(number "14" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -48.26 0) (length 7.62)
(name "PC6/WP/D0" (effects (font (size 1.27 1.27))))
(number "15" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -50.8 0) (length 7.62)
(name "PC5/MISO/D1/SEL1" (effects (font (size 1.27 1.27))))
(number "16" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -53.34 0) (length 7.62)
(name "PC4/MOSI/D2/SEL0" (effects (font (size 1.27 1.27))))
(number "17" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -55.88 0) (length 7.62)
(name "PC3/SPI0-CS0/SDC2-CMD" (effects (font (size 1.27 1.27))))
(number "18" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -58.42 0) (length 7.62)
(name "PC2/SPI0-CLK/SDC2-CLK" (effects (font (size 1.27 1.27))))
(number "19" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -10.16 0) (length 7.62)
(name "PG7" (effects (font (size 1.27 1.27))))
(number "2" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -66.04 0) (length 7.62)
(name "VCC-PLL" (effects (font (size 1.27 1.27))))
(number "20" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -68.58 0) (length 7.62)
(name "REFCLK-OUT" (effects (font (size 1.27 1.27))))
(number "21" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -71.12 0) (length 7.62)
(name "DXOUT" (effects (font (size 1.27 1.27))))
(number "22" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -73.66 0) (length 7.62)
(name "DXIN" (effects (font (size 1.27 1.27))))
(number "23" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -76.2 0) (length 7.62)
(name "X32KOUT" (effects (font (size 1.27 1.27))))
(number "24" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -78.74 0) (length 7.62)
(name "X32KIN" (effects (font (size 1.27 1.27))))
(number "25" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -81.28 0) (length 7.62)
(name "VCC-RTC" (effects (font (size 1.27 1.27))))
(number "26" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -83.82 0) (length 7.62)
(name "RESET" (effects (font (size 1.27 1.27))))
(number "27" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -91.44 0) (length 7.62)
(name "LDOA-OUT" (effects (font (size 1.27 1.27))))
(number "28" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -93.98 0) (length 7.62)
(name "LDO-IN" (effects (font (size 1.27 1.27))))
(number "29" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -12.7 0) (length 7.62)
(name "PG8" (effects (font (size 1.27 1.27))))
(number "3" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -96.52 0) (length 7.62)
(name "LDOB-OUT" (effects (font (size 1.27 1.27))))
(number "30" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -106.68 0) (length 7.62)
(name "PE13" (effects (font (size 1.27 1.27))))
(number "31" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -109.22 0) (length 7.62)
(name "PE12" (effects (font (size 1.27 1.27))))
(number "32" (effects (font (size 1.27 1.27))))
(pin passive line (at 7.62 -127 90) (length 7.62)
(name "PE3" (effects (font (size 1.27 1.27))))
(number "33" (effects (font (size 1.27 1.27))))
(pin passive line (at 10.16 -127 90) (length 7.62)
(name "VCC-PE" (effects (font (size 1.27 1.27))))
(number "34" (effects (font (size 1.27 1.27))))
(pin passive line (at 12.7 -127 90) (length 7.62)
(name "PE2" (effects (font (size 1.27 1.27))))
(number "35" (effects (font (size 1.27 1.27))))
(pin passive line (at 15.24 -127 90) (length 7.62)
(name "PE11" (effects (font (size 1.27 1.27))))
(number "36" (effects (font (size 1.27 1.27))))
(pin passive line (at 17.78 -127 90) (length 7.62)
(name "PE10" (effects (font (size 1.27 1.27))))
(number "37" (effects (font (size 1.27 1.27))))
(pin passive line (at 20.32 -127 90) (length 7.62)
(name "PE9" (effects (font (size 1.27 1.27))))
(number "38" (effects (font (size 1.27 1.27))))
(pin passive line (at 22.86 -127 90) (length 7.62)
(name "PE8" (effects (font (size 1.27 1.27))))
(number "39" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -15.24 0) (length 7.62)
(name "PG9" (effects (font (size 1.27 1.27))))
(number "4" (effects (font (size 1.27 1.27))))
(pin passive line (at 25.4 -127 90) (length 7.62)
(name "PE7" (effects (font (size 1.27 1.27))))
(number "40" (effects (font (size 1.27 1.27))))
(pin passive line (at 27.94 -127 90) (length 7.62)
(name "PE6" (effects (font (size 1.27 1.27))))
(number "41" (effects (font (size 1.27 1.27))))
(pin passive line (at 30.48 -127 90) (length 7.62)
(name "PE5" (effects (font (size 1.27 1.27))))
(number "42" (effects (font (size 1.27 1.27))))
(pin passive line (at 33.02 -127 90) (length 7.62)
(name "PE4" (effects (font (size 1.27 1.27))))
(number "43" (effects (font (size 1.27 1.27))))
(pin passive line (at 35.56 -127 90) (length 7.62)
(name "PE0" (effects (font (size 1.27 1.27))))
(number "44" (effects (font (size 1.27 1.27))))
(pin passive line (at 38.1 -127 90) (length 7.62)
(name "PE1" (effects (font (size 1.27 1.27))))
(number "45" (effects (font (size 1.27 1.27))))
(pin passive line (at 43.18 -127 90) (length 7.62)
(name "VDD-SYS0" (effects (font (size 1.27 1.27))))
(number "46" (effects (font (size 1.27 1.27))))
(pin passive line (at 50.8 -127 90) (length 7.62)
(name "DZQ" (effects (font (size 1.27 1.27))))
(number "47" (effects (font (size 1.27 1.27))))
(pin passive line (at 53.34 -127 90) (length 7.62)
(name "VCC-DRAM0" (effects (font (size 1.27 1.27))))
(number "48" (effects (font (size 1.27 1.27))))
(pin passive line (at 55.88 -127 90) (length 7.62)
(name "VCC-DRAM1" (effects (font (size 1.27 1.27))))
(number "49" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -17.78 0) (length 7.62)
(name "PG10" (effects (font (size 1.27 1.27))))
(number "5" (effects (font (size 1.27 1.27))))
(pin passive line (at 58.42 -127 90) (length 7.62)
(name "VDD18-DRAM" (effects (font (size 1.27 1.27))))
(number "50" (effects (font (size 1.27 1.27))))
(pin passive line (at 68.58 -127 90) (length 7.62)
(name "VDD-SYS1" (effects (font (size 1.27 1.27))))
(number "51" (effects (font (size 1.27 1.27))))
(pin passive line (at 73.66 -127 90) (length 7.62)
(name "PD22/OWA/PWM7" (effects (font (size 1.27 1.27))))
(number "52" (effects (font (size 1.27 1.27))))
(pin passive line (at 76.2 -127 90) (length 7.62)
(name "PD21/VSYNC" (effects (font (size 1.27 1.27))))
(number "53" (effects (font (size 1.27 1.27))))
(pin passive line (at 78.74 -127 90) (length 7.62)
(name "PD20/HSYNC" (effects (font (size 1.27 1.27))))
(number "54" (effects (font (size 1.27 1.27))))
(pin passive line (at 81.28 -127 90) (length 7.62)
(name "PD0/D2/V0P/D0P" (effects (font (size 1.27 1.27))))
(number "55" (effects (font (size 1.27 1.27))))
(pin passive line (at 83.82 -127 90) (length 7.62)
(name "PD1/D3/V0N/D0N" (effects (font (size 1.27 1.27))))
(number "56" (effects (font (size 1.27 1.27))))
(pin passive line (at 86.36 -127 90) (length 7.62)
(name "PD2/D4/V1P/D1P" (effects (font (size 1.27 1.27))))
(number "57" (effects (font (size 1.27 1.27))))
(pin passive line (at 88.9 -127 90) (length 7.62)
(name "PD3/D5/V1N/D1N" (effects (font (size 1.27 1.27))))
(number "58" (effects (font (size 1.27 1.27))))
(pin passive line (at 91.44 -127 90) (length 7.62)
(name "PD4/D6/V2P/CKP" (effects (font (size 1.27 1.27))))
(number "59" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -20.32 0) (length 7.62)
(name "PG11" (effects (font (size 1.27 1.27))))
(number "6" (effects (font (size 1.27 1.27))))
(pin passive line (at 93.98 -127 90) (length 7.62)
(name "PD5/D7/V2N/CKN" (effects (font (size 1.27 1.27))))
(number "60" (effects (font (size 1.27 1.27))))
(pin passive line (at 96.52 -127 90) (length 7.62)
(name "PD6/D10/CKP/D2P" (effects (font (size 1.27 1.27))))
(number "61" (effects (font (size 1.27 1.27))))
(pin passive line (at 99.06 -127 90) (length 7.62)
(name "PD7/D11/CKN/D2N" (effects (font (size 1.27 1.27))))
(number "62" (effects (font (size 1.27 1.27))))
(pin passive line (at 101.6 -127 90) (length 7.62)
(name "PD8/D12/V3P/D3P" (effects (font (size 1.27 1.27))))
(number "63" (effects (font (size 1.27 1.27))))
(pin passive line (at 104.14 -127 90) (length 7.62)
(name "PD9/D13/V3N/D3N" (effects (font (size 1.27 1.27))))
(number "64" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -109.22 180) (length 7.62)
(name "LVDS1.8" (effects (font (size 1.27 1.27))))
(number "65" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -106.68 180) (length 7.62)
(name "VCC-PD" (effects (font (size 1.27 1.27))))
(number "66" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -104.14 180) (length 7.62)
(name "D14/PD10" (effects (font (size 1.27 1.27))))
(number "67" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -101.6 180) (length 7.62)
(name "D15/PD11" (effects (font (size 1.27 1.27))))
(number "68" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -99.06 180) (length 7.62)
(name "D19/PD13" (effects (font (size 1.27 1.27))))
(number "69" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -25.4 0) (length 7.62)
(name "PF0/D1" (effects (font (size 1.27 1.27))))
(number "7" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -96.52 180) (length 7.62)
(name "D18/PD12" (effects (font (size 1.27 1.27))))
(number "70" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -93.98 180) (length 7.62)
(name "D20/PD14" (effects (font (size 1.27 1.27))))
(number "71" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -91.44 180) (length 7.62)
(name "D21/PD15" (effects (font (size 1.27 1.27))))
(number "72" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -88.9 180) (length 7.62)
(name "D22/PD16" (effects (font (size 1.27 1.27))))
(number "73" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -86.36 180) (length 7.62)
(name "D23/PD17" (effects (font (size 1.27 1.27))))
(number "74" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -83.82 180) (length 7.62)
(name "CLK/PD18" (effects (font (size 1.27 1.27))))
(number "75" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -81.28 180) (length 7.62)
(name "DE/PD19" (effects (font (size 1.27 1.27))))
(number "76" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -76.2 180) (length 7.62)
(name "VCC-TVOUT" (effects (font (size 1.27 1.27))))
(number "77" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -73.66 180) (length 7.62)
(name "TVOUT0" (effects (font (size 1.27 1.27))))
(number "78" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -68.58 180) (length 7.62)
(name "PB7" (effects (font (size 1.27 1.27))))
(number "79" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -27.94 0) (length 7.62)
(name "PF1/D0" (effects (font (size 1.27 1.27))))
(number "8" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -66.04 180) (length 7.62)
(name "PB6" (effects (font (size 1.27 1.27))))
(number "80" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -60.96 180) (length 7.62)
(name "VDD-SYS2" (effects (font (size 1.27 1.27))))
(number "81" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -55.88 180) (length 7.62)
(name "PB5" (effects (font (size 1.27 1.27))))
(number "82" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -53.34 180) (length 7.62)
(name "VCC-IO" (effects (font (size 1.27 1.27))))
(number "83" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -50.8 180) (length 7.62)
(name "PB4" (effects (font (size 1.27 1.27))))
(number "84" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -48.26 180) (length 7.62)
(name "PB3" (effects (font (size 1.27 1.27))))
(number "85" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -45.72 180) (length 7.62)
(name "PB2" (effects (font (size 1.27 1.27))))
(number "86" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -40.64 180) (length 7.62)
(name "MICIN3P" (effects (font (size 1.27 1.27))))
(number "87" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -38.1 180) (length 7.62)
(name "MICIN3N" (effects (font (size 1.27 1.27))))
(number "88" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -33.02 180) (length 7.62)
(name "AVCC" (effects (font (size 1.27 1.27))))
(number "89" (effects (font (size 1.27 1.27))))
(pin passive line (at -7.62 -30.48 0) (length 7.62)
(name "PF2/CLK" (effects (font (size 1.27 1.27))))
(number "9" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -30.48 180) (length 7.62)
(name "VRA2" (effects (font (size 1.27 1.27))))
(number "90" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -27.94 180) (length 7.62)
(name "AGND" (effects (font (size 1.27 1.27))))
(number "91" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -25.4 180) (length 7.62)
(name "VRA1" (effects (font (size 1.27 1.27))))
(number "92" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -22.86 180) (length 7.62)
(name "FMINR" (effects (font (size 1.27 1.27))))
(number "93" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -20.32 180) (length 7.62)
(name "FMINL" (effects (font (size 1.27 1.27))))
(number "94" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -17.78 180) (length 7.62)
(name "LINEINR" (effects (font (size 1.27 1.27))))
(number "95" (effects (font (size 1.27 1.27))))
(pin passive line (at 124.46 -15.24 180) (length 7.62)
(name "LINEINL" (effects (font (size 1.27 1.27))))
(number "96" (effects (font (size 1.27 1.27))))
(pin passive line (at 111.76 7.62 270) (length 7.62)
(name "HPVCC" (effects (font (size 1.27 1.27))))
(number "97" (effects (font (size 1.27 1.27))))
(pin passive line (at 109.22 7.62 270) (length 7.62)
(name "HPOUTR" (effects (font (size 1.27 1.27))))
(number "98" (effects (font (size 1.27 1.27))))
(pin passive line (at 106.68 7.62 270) (length 7.62)
(name "HPOUTL" (effects (font (size 1.27 1.27))))
(number "99" (effects (font (size 1.27 1.27))))
)最近编辑记录 Cadence (2022-05-15 09:46:15)
安装 lisp
apt install clisp -y执行
root@i9-10920:/data# clisp kicad_sch
WARNING: DEFUN/DEFMACRO(NUMBER): #<PACKAGE COMMON-LISP> is locked
Ignore the lock and proceed
WARNING: DEFUN/DEFMACRO(LENGTH): #<PACKAGE COMMON-LISP> is locked
WARNING: DEFUN/DEFMACRO: redefining function LENGTH in /data/eMv/MQ/1.Hardware/kicad_sch, was defined in C
1 PG6 Passive 1 Line " " Left 1
10 PF3/CMD Passive 1 Line " " Left 1
100 HPOUTFB Passive 1 Line " " Top 1
101 GPADC0 Passive 1 Line " " Top 1
102 TP-X1 Passive 1 Line " " Top 1
103 TP-X2 Passive 1 Line " " Top 1
104 TP-Y1 Passive 1 Line " " Top 1
105 TP-Y2 Passive 1 Line " " Top 1
106 NC0 Passive 1 Line " " Top 1
107 VCC-TVIN Passive 1 Line " " Top 1
108 TVIN0 Passive 1 Line " " Top 1
109 TVIN1 Passive 1 Line " " Top 1
11 PF4/D3 Passive 1 Line " " Left 1
110 TVIN-VRP Passive 1 Line " " Top 1
111 TVIN-VRN Passive 1 Line " " Top 1
112 USB1-DP Passive 1 Line " " Top 1
113 USB1-DM Passive 1 Line " " Top 1
114 USB0-DM Passive 1 Line " " Top 1
115 USB0-DP Passive 1 Line " " Top 1
116 VDD-CORE0 Passive 1 Line " " Top 1
117 VDD-CORE1 Passive 1 Line " " Top 1
118 PG1 Passive 1 Line " " Top 1
119 PG2 Passive 1 Line " " Top 1
12 PF5/D2 Passive 1 Line " " Left 1
120 PG0 Passive 1 Line " " Top 1
121 PG3 Passive 1 Line " " Top 1
122 PG5 Passive 1 Line " " Top 1
123 PG4 Passive 1 Line " " Top 1
124 PG12 Passive 1 Line " " Top 1
125 PG13 Passive 1 Line " " Top 1
126 PG14 Passive 1 Line " " Top 1
127 PG15 Passive 1 Line " " Top 1
128 VCC-PG Passive 1 Line " " Top 1
129 EPAD Passive 1 Line " " Top 1
13 PF6/OWA/IR-RX/PWM5 Passive 1 Line " " Left 1
14 PC7/HOLD/D3 Passive 1 Line " " Left 1
15 PC6/WP/D0 Passive 1 Line " " Left 1
16 PC5/MISO/D1/SEL1 Passive 1 Line " " Left 1
17 PC4/MOSI/D2/SEL0 Passive 1 Line " " Left 1
18 PC3/SPI0-CS0/SDC2-CMD Passive 1 Line " " Left 1
19 PC2/SPI0-CLK/SDC2-CLK Passive 1 Line " " Left 1
2 PG7 Passive 1 Line " " Left 1
20 VCC-PLL Passive 1 Line " " Left 1
21 REFCLK-OUT Passive 1 Line " " Left 1
22 DXOUT Passive 1 Line " " Left 1
23 DXIN Passive 1 Line " " Left 1
24 X32KOUT Passive 1 Line " " Left 1
25 X32KIN Passive 1 Line " " Left 1
26 VCC-RTC Passive 1 Line " " Left 1
27 RESET Passive 1 Line " " Left 1
28 LDOA-OUT Passive 1 Line " " Left 1
29 LDO-IN Passive 1 Line " " Left 1
3 PG8 Passive 1 Line " " Left 1
30 LDOB-OUT Passive 1 Line " " Left 1
31 PE13 Passive 1 Line " " Left 1
32 PE12 Passive 1 Line " " Left 1
33 PE3 Passive 1 Line " " Bottom 1
34 VCC-PE Passive 1 Line " " Bottom 1
35 PE2 Passive 1 Line " " Bottom 1
36 PE11 Passive 1 Line " " Bottom 1
37 PE10 Passive 1 Line " " Bottom 1
38 PE9 Passive 1 Line " " Bottom 1
39 PE8 Passive 1 Line " " Bottom 1
4 PG9 Passive 1 Line " " Left 1
40 PE7 Passive 1 Line " " Bottom 1
41 PE6 Passive 1 Line " " Bottom 1
42 PE5 Passive 1 Line " " Bottom 1
43 PE4 Passive 1 Line " " Bottom 1
44 PE0 Passive 1 Line " " Bottom 1
45 PE1 Passive 1 Line " " Bottom 1
46 VDD-SYS0 Passive 1 Line " " Bottom 1
47 DZQ Passive 1 Line " " Bottom 1
48 VCC-DRAM0 Passive 1 Line " " Bottom 1
49 VCC-DRAM1 Passive 1 Line " " Bottom 1
5 PG10 Passive 1 Line " " Left 1
50 VDD18-DRAM Passive 1 Line " " Bottom 1
51 VDD-SYS1 Passive 1 Line " " Bottom 1
52 PD22/OWA/PWM7 Passive 1 Line " " Bottom 1
53 PD21/VSYNC Passive 1 Line " " Bottom 1
54 PD20/HSYNC Passive 1 Line " " Bottom 1
55 PD0/D2/V0P/D0P Passive 1 Line " " Bottom 1
56 PD1/D3/V0N/D0N Passive 1 Line " " Bottom 1
57 PD2/D4/V1P/D1P Passive 1 Line " " Bottom 1
58 PD3/D5/V1N/D1N Passive 1 Line " " Bottom 1
59 PD4/D6/V2P/CKP Passive 1 Line " " Bottom 1
6 PG11 Passive 1 Line " " Left 1
60 PD5/D7/V2N/CKN Passive 1 Line " " Bottom 1
61 PD6/D10/CKP/D2P Passive 1 Line " " Bottom 1
62 PD7/D11/CKN/D2N Passive 1 Line " " Bottom 1
63 PD8/D12/V3P/D3P Passive 1 Line " " Bottom 1
64 PD9/D13/V3N/D3N Passive 1 Line " " Bottom 1
65 LVDS1.8 Passive 1 Line " " Right 1
66 VCC-PD Passive 1 Line " " Right 1
67 D14/PD10 Passive 1 Line " " Right 1
68 D15/PD11 Passive 1 Line " " Right 1
69 D19/PD13 Passive 1 Line " " Right 1
7 PF0/D1 Passive 1 Line " " Left 1
70 D18/PD12 Passive 1 Line " " Right 1
71 D20/PD14 Passive 1 Line " " Right 1
72 D21/PD15 Passive 1 Line " " Right 1
73 D22/PD16 Passive 1 Line " " Right 1
74 D23/PD17 Passive 1 Line " " Right 1
75 CLK/PD18 Passive 1 Line " " Right 1
76 DE/PD19 Passive 1 Line " " Right 1
77 VCC-TVOUT Passive 1 Line " " Right 1
78 TVOUT0 Passive 1 Line " " Right 1
79 PB7 Passive 1 Line " " Right 1
8 PF1/D0 Passive 1 Line " " Left 1
80 PB6 Passive 1 Line " " Right 1
81 VDD-SYS2 Passive 1 Line " " Right 1
82 PB5 Passive 1 Line " " Right 1
83 VCC-IO Passive 1 Line " " Right 1
84 PB4 Passive 1 Line " " Right 1
85 PB3 Passive 1 Line " " Right 1
86 PB2 Passive 1 Line " " Right 1
87 MICIN3P Passive 1 Line " " Right 1
88 MICIN3N Passive 1 Line " " Right 1
89 AVCC Passive 1 Line " " Right 1
9 PF2/CLK Passive 1 Line " " Left 1
90 VRA2 Passive 1 Line " " Right 1
91 AGND Passive 1 Line " " Right 1
92 VRA1 Passive 1 Line " " Right 1
93 FMINR Passive 1 Line " " Right 1
94 FMINL Passive 1 Line " " Right 1
95 LINEINR Passive 1 Line " " Right 1
96 LINEINL Passive 1 Line " " Right 1
97 HPVCC Passive 1 Line " " Top 1
98 HPOUTR Passive 1 Line " " Top 1
99 HPOUTL Passive 1 Line " " Top 1
clisp ./kicad_sch > orcad转换成 orcad 元件库
最近编辑记录 Cadence (2022-05-15 09:51:12)
以前只知道是Lisp,没想到居然是符合Common Lisp标准的。
想在UOS上编译安装kicad6.0.5
结果 跟目录 / 容量不够
扩容造成UOS启动进入busybox
做个备忘
cd /host/UOS/
cp root.disk root1.disk
dd if=/dev/zero of=root1.disk bs=1G conv=notrunc oflag=append count=30 扩容增加 30G
losetup -f ----> /dev/loop1
losetup /dev/loop1 root1.disk
losetup -c /dev/loop1
e2fsck -f /dev/loop1
resize2fs -p /dev/loop1
losetup -d /dev/loop1
mv root.disk root2.disk
mv root1.disk root.diskreboot
最近编辑记录 Cadence (2022-05-16 16:20:59)
-- KiCad install dir: </usr/local>
-- Enabling warning -Wsuggest-override
-- Enabling warning -Wduplicated-branches
-- Enabling warning -Wduplicated-cond
-- Enabling error for -Wvla
-- Enabling warning -Wimplicit-fallthrough
-- Enabling error for -Wreturn-type
-- Enabling warning -Wshadow
-- Enabling warning -Wsign-compare
-- Enabling warning -Wmissing-field-initializers
-- Enabling warning -Wempty-body
-- Enabling warning -Wreorder
-- Disabling warning -Wpsabi
-- Check for installed GLEW -- found
-- Check for installed ZLIB -- found
-- Boost version: 1.67.0
-- Found OpenCASCADE Standard Edition version: 7.7.0
-- ++ OpenCASCADE Standard Edition include directory: /usr/local/include/opencascade
-- ++ OpenCASCADE Standard Edition shared libraries directory: /usr/local/lib
-- pybind11 v2.7.1
-- Found PythonInterp: /usr/bin/python3 (found version "3.7.3")
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.7.3", minimum required is "3.6")
-- Check for installed Python Interpreter -- found
-- Python module install path: lib/python3/dist-packages
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'wx'
CMake Error at CMakeModules/FindwxPython.cmake:56 (message):
wxPython/Phoenix does not appear to be installed on the system
Call Stack (most recent call first):
CMakeLists.txt:837 (find_package)好像是没有 wxPython/Phoenix
最近编辑记录 Cadence (2022-05-16 16:32:03)
pip3 install -U wxPython离线
Collecting wxPython
Using cached https://files.pythonhosted.org/packages/b0/4d/80d65c37ee60a479d338d27a2895fb15bbba27a3e6bb5b6d72bb28246e99/wxPython-4.1.1.tar.gz
Requirement already satisfied, skipping upgrade: pillow in /usr/lib/python3/dist-packages (from wxPython) (5.4.1)
Requirement already satisfied, skipping upgrade: six in /usr/lib/python3/dist-packages (from wxPython) (1.12.0)
Requirement already satisfied, skipping upgrade: numpy in /usr/local/lib/python3.7/dist-packages (from wxPython) (1.21.6)
Building wheels for collected packages: wxPython
Running setup.py bdist_wheel for wxPython ... done
Stored in directory: /root/.cache/pip/wheels/54/32/da/dc5c828a12bc9a1ca58d5555f1076fd7d2984ae9c0e03eb510
Successfully built wxPython
Installing collected packages: wxPython
Successfully installed wxPython-4.1.1最近编辑记录 Cadence (2022-05-16 20:23:14)
-- pybind11 v2.7.1
-- Found wxPython Phoenix 4.1.1/gtk3 (wxWidgets 3.1.5)
CMake Error at /usr/share/cmake-3.13/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
Could NOT find wxWidgets: Found unsuitable version "3.0.4", but required is
at least "3.1.5" (found
-L/usr/lib/x86_64-linux-gnu;-pthread;;;-lwx_gtk3u_gl-3.0;-lwx_gtk3u_aui-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_html-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu_net-3.0;-lwx_baseu-3.0;-lwx_gtk3u_propgrid-3.0;-lwx_baseu_xml-3.0;-lwx_gtk3u_stc-3.0;-lwx_gtk3u_richtext-3.0)
/usr/share/cmake-3.13/Modules/FindPackageHandleStandardArgs.cmake:376 (_FPHSA_FAILURE_MESSAGE)
CMakeModules/FindwxWidgets.cmake:947 (find_package_handle_standard_args)
CMakeLists.txt:888 (find_package)离线
git clone https://hub.fastgit.xyz/wxWidgets/wxWidgets
cd wxWidgets/
apt-get install libgtk-3-dev build-essential checkinstall
mkdir gtk-build
cd gtk-build/
sed 's/github.com/hub.fastgit.xyz/g' .gitmodules -i
git submodule update --init
cd gtk-build/
../configure --disable-shared --enable-unicode
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for toolkit... gtk
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether we are using the Intel C compiler... no
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking whether gcc needs -traditional... no
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether we are using the Intel C++ compiler... no
checking whether we are using the Sun C++ compiler... no
checking for ar... ar
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for langinfo.h... yes
checking for wchar.h... yes
checking for sys/select.h... yes
checking for cxxabi.h... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking size of short... 2
checking size of void *... 8
checking size of int... 4
checking size of long... 8
checking size of size_t... 8
checking size of long long... 8
checking size of wchar_t... 4
checking for va_copy... yes
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking if large file support is available... yes
checking for _LARGEFILE_SOURCE value needed for large files... no
checking whether byte ordering is bigendian... no
checking for std::wstring in <string>... yes
checking for std::istream... yes
checking for std::ostream... yes
checking for type_traits... yes
checking for __sync_xxx_and_fetch builtins... yes
checking for libraries directories... /usr/lib/x86_64-linux-gnu /usr/lib
checking for cos... no
checking for floor... no
checking if floating point functions link without -lm... no
checking for sin... yes
checking for ceil... yes
checking if floating point functions link with -lm... yes
checking for strtoull... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for LIBPCRE... checking whether pcre submodule exists... yes
checking for zlib.h >= 1.1.4... yes
checking for zlib.h... (cached) yes
checking for deflate in -lz... yes
checking for png.h > 0.90... yes
checking for png.h... (cached) yes
checking for png_sig_cmp in -lpng... yes
checking for jpeglib.h... no
configure: WARNING: system jpeg library not found, will use built-in instead
checking whether jpeglib.h file exists... yes
checking for jbg_dec_init in -ljbig... no
checking for LIBTIFF... not found via pkg-config
checking for tiffio.h... no
configure: WARNING: system tiff library not found, will use built-in instead
checking whether tiff.h file exists... yes
checking for expat.h... yes
checking if expat.h is valid C++ header... yes
checking for XML_ParserCreate in -lexpat... yes
checking for LIBCURL... yes
checking for GTK+ version...
checking for pkg-config... (cached) /usr/bin/pkg-config
checking pkg-config is at least version 0.16... yes
checking for GTK+ - version >= 3.0.0... yes (version 3.24.5)
checking for GDK Wayland backend... yes
checking for X11/Xlib.h... yes
checking for X11/XKBlib.h... yes
checking for Xxf86vm... yes
checking for X11/extensions/xf86vmode.h... yes
checking for SM... yes
checking for OpenGL headers... found in /usr/include
checking for GL/gl.h... yes
checking for GL/glu.h... yes
checking for GL... yes
checking for GLU... yes
checking for EGL... yes
checking for WAYLAND_EGL... yes
checking for ssize_t... yes
checking if size_t is unsigned int... no
checking if size_t is unsigned long... yes
checking if wchar_t is separate type... yes
checking for pw_gecos in struct passwd... yes
checking for wcslen... yes
checking for wcsftime... yes
checking for strnlen... yes
checking for wcsdup... yes
checking for wcsnlen... yes
checking for wcscasecmp... yes
checking for wcsncasecmp... yes
checking for mbstate_t... yes
checking for wcsrtombs... yes
checking for snprintf... yes
checking for vsnprintf... yes
checking for vsscanf... yes
checking if vsnprintf declaration is broken... no
checking if snprintf supports positional arguments... yes
checking if vsscanf() declaration is broken... no
checking for putws... no
checking for fputws... yes
checking for wprintf... yes
checking for vswprintf... yes
checking for vswscanf... yes
checking for _vsnwprintf... no
checking for fsync... yes
checking for round... yes
checking for iconv... yes
checking if iconv needs const... no
checking for sigaction... yes
checking for sa_handler type... int
checking for backtrace()... yes
checking for library containing backtrace... none required
checking for __cxa_demangle() in <cxxabi.h>... yes
checking for mkstemp... yes
checking for statfs... yes
checking for statfs declaration... yes
checking for fcntl... yes
checking for setenv... yes
checking for unsetenv... yes
checking for nanosleep... yes
checking for uname... yes
checking for strtok_r... yes
checking for inet_addr... yes
checking for inet_aton... yes
checking for fdopen... yes
checking for sysconf... yes
checking for getpwuid_r... yes
checking for getgrgid_r... yes
checking whether pthreads work with -pthread... yes
checking if more special flags are required for pthreads... no
checking for pthread_setconcurrency... yes
checking for pthread_cleanup_push/pop... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for pthread_attr_getschedpolicy... yes
checking for pthread_attr_setschedparam... yes
checking for sched_get_priority_max... yes
checking for pthread_cancel... yes
checking for pthread_mutex_timedlock... yes
checking for pthread_attr_setstacksize... yes
checking for pthread_mutexattr_t... yes
checking for pthread_mutexattr_settype declaration... yes
checking for abi::__forced_unwind() in <cxxabi.h>... yes
checking for localtime_r... yes
checking for gmtime_r... yes
checking how many arguments gethostbyname_r() takes... six
checking how many arguments getservbyname_r() takes... six
checking for dlopen... no
checking for dlopen in -ldl... yes
checking for dladdr... no
checking for dladdr in -ldl... yes
checking whether inotify is usable... yes
checking for LIBSECRET... configure: WARNING: libsecret not found, wxSecretStore won't be available
checking for GSPELL... configure: WARNING: gspell-1 not found, spell checking in wxTextCtrl won't be available
checking for SNDCTL_DSP_SPEED in sys/soundcard.h... yes
checking for GTKPRINT... yes
checking for LIBNOTIFY... checking for LIBNOTIFY... configure: WARNING: libnotify not found, wxNotificationMessage will use generic implementation.
checking xlocale.h usability... no
checking xlocale.h presence... no
checking for xlocale.h... no
checking for locale_t... yes
checking for sys/epoll.h... yes
checking for gettimeofday... yes
checking whether gettimeofday takes two arguments... yes
checking for timezone variable in <time.h>... timezone
checking for localtime... yes
checking for tm_gmtoff in struct tm... yes
checking for _NL_TIME_FIRST_WEEKDAY in langinfo.h... yes
checking for setpriority... yes
checking for socket... yes
checking what is the type of the third argument of getsockname... socklen_t
checking what is the type of the fifth argument of getsockopt... socklen_t
checking whether we have sockaddr_in6... yes
checking for linux/joystick.h... yes
checking for XTST... yes
checking for PRIVATE_FONTS... yes
checking for python... /usr/bin/python
checking for WEBKIT... configure: WARNING: webkit2gtk not found, falling back to webkitgtk
checking for WEBKIT... configure: WARNING: webkitgtk not found.
configure: WARNING: WebKit not available, disabling wxWebView
checking for CAIRO... yes
checking for cairo_push_group... yes
checking for GST... configure: GStreamer 1.7.2+ not available. Not using GstPlayer and falling back to 1.0
checking for GST... configure: WARNING: GStreamer 1.0 not available, falling back to 0.10
checking for GST... configure: WARNING: GStreamer 0.10 not available
configure: WARNING: GStreamer not available... disabling wxMediaCtrl
checking CXXWARNINGS for gcc -Woverloaded-virtual... -Woverloaded-virtual
checking for a BSD-compatible install... /usr/bin/install -c
checking for ranlib... ranlib
checking whether ln -s works... yes
checking whether make sets $(MAKE)... yes
checking for ar... (cached) ar
checking for strip... strip
checking for nm... nm
checking if make is GNU make... yes
checking for dependency tracking method... gcc
checking whether make sets $(MAKE)... (cached) yes
checking whether catch.hpp file exists... yes
=== configuring in 3rdparty/pcre (/host/eMv/wxWidgets/gtk-build/3rdparty/pcre)
configure: running /bin/bash ../../../3rdparty/pcre/configure '--prefix=/usr/local' --disable-option-checking '--disable-shared' '--enable-unicode' '--disable-pcre2-8' '--enable-pcre2-32' '--srcdir=../../../3rdparty/pcre' --cache-file=
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking the archiver (ar) interface... ar
checking for int64_t... yes
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether the -Werror option is usable... yes
checking for simple visibility declarations... yes
checking for __attribute__((uninitialized))... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking for size_t... yes
checking for bcopy... yes
checking for memfd_create... yes
checking for memmove... yes
checking for mkostemp... yes
checking for secure_getenv... yes
checking for strerror... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for gzopen in -lz... yes
checking bzlib.h usability... no
checking bzlib.h presence... no
checking for bzlib.h... no
checking for libbz2... no
checking whether Intel CET is enabled... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating libpcre2-8.pc
config.status: creating libpcre2-16.pc
config.status: creating libpcre2-32.pc
config.status: creating libpcre2-posix.pc
config.status: creating pcre2-config
config.status: creating src/pcre2.h
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing script-chmod commands
config.status: executing delete-old-chartables commands
pcre2-10.37 configuration summary:
Install prefix ..................... : /usr/local
C preprocessor ..................... : gcc -E
C compiler ......................... : gcc
Linker ............................. : /usr/bin/ld -m elf_x86_64
C preprocessor flags ............... :
C compiler flags ................... : -O2 -fvisibility=hidden
Linker flags ....................... :
Extra libraries .................... :
Build 8-bit pcre2 library .......... : no
Build 16-bit pcre2 library ......... : no
Build 32-bit pcre2 library ......... : yes
Include debugging code ............. : no
Enable JIT compiling support ....... : no
Use SELinux allocator in JIT ....... : no
Enable Unicode support ............. : yes
Newline char/sequence .............. : lf
\R matches only ANYCRLF ............ : no
\C is disabled ..................... : no
EBCDIC coding ...................... : no
EBCDIC code for NL ................. : n/a
Rebuild char tables ................ : no
Internal link size ................. : 2
Nested parentheses limit ........... : 250
Heap limit ......................... : 20000000 kibibytes
Match limit ........................ : 10000000
Match depth limit .................. : MATCH_LIMIT
Build shared libs .................. : no
Build static libs .................. : yes
Use JIT in pcre2grep ............... : no
Enable callouts in pcre2grep ....... : yes
Enable fork in pcre2grep callouts .. : yes
Initial buffer size for pcre2grep .. : 20480
Maximum buffer size for pcre2grep .. : 1048576
Link pcre2grep with libz ........... : no
Link pcre2grep with libbz2 ......... : no
Link pcre2test with libedit ........ : no
Link pcre2test with libreadline .... : no
Valgrind support ................... : no
Code coverage ...................... : no
Fuzzer support ..................... : no
Use %zu and %td .................... : auto
=== configuring in src/tiff (/host/eMv/wxWidgets/gtk-build/src/tiff)
configure: running /bin/bash ../../../src/tiff/configure '--prefix=/usr/local' --disable-option-checking '--disable-shared' '--enable-unicode' '--disable-jbig' '--disable-libdeflate' '--disable-webp' '--disable-zstd' '--disable-lzma' '--enable-jpeg' '--srcdir=../../../src/tiff' --cache-file=
checking whether UID '0' is supported by ustar format... yes
checking whether GID '0' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking for C compiler warning flags... -Wall -W
checking for cmake... /usr/bin/cmake
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for sin in -lm... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking io.h usability... no
checking io.h presence... no
checking for io.h... no
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for unistd.h... (cached) yes
checking for off_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking whether optarg is declared... yes
checking size of signed int... 4
checking size of unsigned int... 4
checking size of signed long... 8
checking size of unsigned long... 8
checking size of signed long long... 8
checking size of unsigned long long... 8
checking size of unsigned char *... 8
checking for signed 8-bit type... signed char
checking for unsigned 8-bit type... unsigned char
checking for signed 16-bit type... signed short
checking for unsigned 16-bit type... unsigned short
checking for signed 32-bit type... signed int
checking for unsigned 32-bit type... unsigned int
checking for signed 64-bit type... signed long
checking for unsigned 64-bit type... unsigned long
checking for 'size_t' format specifier... "%lu"
checking for signed size type... signed long
checking for ptrdiff_t... yes
checking for pointer difference type... ptrdiff_t
checking for mmap... yes
checking for setmode... no
checking for getopt... yes
checking for strcasecmp... yes
checking for strtol... yes
checking for strtoll... yes
checking for strtoul... yes
checking for lfind... yes
checking native cpu bit order... lsb2msb
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for inflateEnd in -lz... yes
checking for jpeg_read_scanlines in -ljpeg... no
checking jpeglib.h usability... no
checking jpeglib.h presence... no
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking whether we are using the Microsoft C compiler... no
checking GL/gl.h usability... yes
checking GL/gl.h presence... yes
checking OpenGL/gl.h usability... no
checking OpenGL/gl.h presence... no
checking for OpenGL/gl.h... no
checking for OpenGL library... -lGL
checking GL/glu.h usability... yes
checking GL/glu.h presence... yes
checking OpenGL/glu.h usability... no
checking OpenGL/glu.h presence... no
checking for OpenGL/glu.h... no
checking for OpenGL Utility library... -lGLU
checking for varargs GLU tesselator callback function type... no
checking GL/glut.h usability... no
checking GL/glut.h presence... no
checking for GL/glut.h... no
checking GLUT/glut.h usability... no
checking GLUT/glut.h presence... no
checking for GLUT/glut.h... no
checking for GLUT library... no
config.status: creating build/Makefile
config.status: creating contrib/Makefile
config.status: creating contrib/addtiffo/Makefile
config.status: creating contrib/dbs/Makefile
config.status: creating contrib/dbs/xtiff/Makefile
config.status: creating contrib/iptcutil/Makefile
config.status: creating contrib/mfs/Makefile
config.status: creating contrib/pds/Makefile
config.status: creating contrib/ras/Makefile
config.status: creating contrib/stream/Makefile
config.status: creating contrib/tags/Makefile
config.status: creating contrib/win_dib/Makefile
config.status: creating html/Makefile
config.status: creating html/images/Makefile
config.status: creating html/man/Makefile
config.status: creating libtiff-4.pc
config.status: creating libtiff/Makefile
config.status: creating man/Makefile
config.status: creating port/Makefile
config.status: creating test/Makefile
config.status: creating tools/Makefile
config.status: creating libtiff/tif_config.h
config.status: libtiff/tif_config.h is unchanged
config.status: creating libtiff/tiffconf.h
config.status: libtiff/tiffconf.h is unchanged
Libtiff is now configured for x86_64-pc-linux-gnu
Installation directory: /usr/local
Documentation directory: ${prefix}/share/doc/tiff-4.2.0
C compiler: gcc -g -O2 -Wall -W
C++ compiler: g++ -g -O2
Enable runtime linker paths: no
Enable linker symbol versioning: no
Support Microsoft Document Imaging: yes
Use win32 IO: no
Support for internal codecs:
CCITT Group 3 & 4 algorithms: yes
Macintosh PackBits algorithm: yes
LZW algorithm: yes
ThunderScan 4-bit RLE algorithm: yes
NeXT 2-bit RLE algorithm: yes
LogLuv high dynamic range encoding: yes
Support for external codecs:
ZLIB support: yes
libdeflate support: no
Pixar log-format algorithm: yes
JPEG support: no
Old JPEG support: no
JPEG 8/12 bit dual mode: no
ISO JBIG support: no
LZMA2 support: no
ZSTD support: no
WEBP support: no
C++ support: yes
OpenGL support: no
config.status: creating lib/wx/config/gtk3-unicode-static-3.1
config.status: creating lib/wx/config/inplace-gtk3-unicode-static-3.1
config.status: creating utils/ifacecheck/rungccxml.sh
config.status: creating samples/html/Makefile
config.status: creating samples/opengl/Makefile
config.status: creating samples/xrc/Makefile
config.status: creating samples/wrapsizer/Makefile
config.status: creating samples/wizard/Makefile
config.status: creating samples/widgets/Makefile
config.status: creating samples/webrequest/Makefile
config.status: creating samples/vscroll/Makefile
config.status: creating samples/validate/Makefile
config.status: creating samples/uiaction/Makefile
config.status: creating samples/typetest/Makefile
config.status: creating samples/treelist/Makefile
config.status: creating samples/treectrl/Makefile
config.status: creating samples/toolbar/Makefile
config.status: creating samples/thread/Makefile
config.status: creating samples/text/Makefile
config.status: creating samples/taskbar/Makefile
config.status: creating samples/taborder/Makefile
config.status: creating samples/svg/Makefile
config.status: creating samples/stc/Makefile
config.status: creating samples/statbar/Makefile
config.status: creating samples/splitter/Makefile
config.status: creating samples/splash/Makefile
config.status: creating samples/sound/Makefile
config.status: creating samples/sockets/Makefile
config.status: creating samples/shaped/Makefile
config.status: creating samples/scroll/Makefile
config.status: creating samples/sashtest/Makefile
config.status: creating samples/richtext/Makefile
config.status: creating samples/ribbon/Makefile
config.status: creating samples/render/Makefile
config.status: creating samples/propgrid/Makefile
config.status: creating samples/printing/Makefile
config.status: creating samples/preferences/Makefile
config.status: creating samples/power/Makefile
config.status: creating samples/popup/Makefile
config.status: creating samples/opengl/pyramid/Makefile
config.status: creating samples/opengl/penguin/Makefile
config.status: creating samples/opengl/isosurf/Makefile
config.status: creating samples/opengl/cube/Makefile
config.status: creating samples/notebook/Makefile
config.status: creating samples/minimal/Makefile
config.status: creating samples/menu/Makefile
config.status: creating samples/mdi/Makefile
config.status: creating samples/listctrl/Makefile
config.status: creating samples/layout/Makefile
config.status: creating samples/keyboard/Makefile
config.status: creating samples/joytest/Makefile
config.status: creating samples/ipc/Makefile
config.status: creating samples/internat/Makefile
config.status: creating samples/image/Makefile
config.status: creating samples/html/zip/Makefile
config.status: creating samples/html/widget/Makefile
config.status: creating samples/html/virtual/Makefile
config.status: creating samples/html/test/Makefile
config.status: creating samples/html/printing/Makefile
config.status: creating samples/html/helpview/Makefile
config.status: creating samples/html/help/Makefile
config.status: creating samples/html/about/Makefile
config.status: creating samples/htlbox/Makefile
config.status: creating samples/help/Makefile
config.status: creating samples/grid/Makefile
config.status: creating samples/fswatcher/Makefile
config.status: creating samples/font/Makefile
config.status: creating samples/exec/Makefile
config.status: creating samples/except/Makefile
config.status: creating samples/event/Makefile
config.status: creating samples/erase/Makefile
config.status: creating samples/drawing/Makefile
config.status: creating samples/dragimag/Makefile
config.status: creating samples/docview/Makefile
config.status: creating samples/dnd/Makefile
config.status: creating samples/display/Makefile
config.status: creating samples/dialup/Makefile
config.status: creating samples/dialogs/Makefile
config.status: creating samples/debugrpt/Makefile
config.status: creating samples/dataview/Makefile
config.status: creating samples/console/Makefile
config.status: creating samples/config/Makefile
config.status: creating samples/combo/Makefile
config.status: creating samples/collpane/Makefile
config.status: creating samples/clipboard/Makefile
config.status: creating samples/caret/Makefile
config.status: creating samples/calendar/Makefile
config.status: creating samples/aui/Makefile
config.status: creating samples/artprov/Makefile
config.status: creating samples/archive/Makefile
config.status: creating samples/animate/Makefile
config.status: creating samples/Makefile
config.status: creating demos/bombs/Makefile
config.status: creating demos/forty/Makefile
config.status: creating demos/fractal/Makefile
config.status: creating demos/life/Makefile
config.status: creating demos/Makefile
config.status: creating demos/poem/Makefile
config.status: creating utils/emulator/Makefile
config.status: creating utils/emulator/src/Makefile
config.status: creating utils/execmon/Makefile
config.status: creating utils/helpview/Makefile
config.status: creating utils/helpview/src/Makefile
config.status: creating utils/hhp2cached/Makefile
config.status: creating utils/ifacecheck/src/Makefile
config.status: creating utils/Makefile
config.status: creating utils/screenshotgen/Makefile
config.status: creating utils/screenshotgen/src/Makefile
config.status: creating utils/wxrc/Makefile
config.status: creating tests/benchmarks/Makefile
config.status: creating tests/Makefile
config.status: creating lib/wx/include/gtk3-unicode-static-3.1/wx/setup.h
config.status: lib/wx/include/gtk3-unicode-static-3.1/wx/setup.h is unchanged
config.status: executing wx-config commands
Configured wxWidgets 3.1.7 for `x86_64-pc-linux-gnu'
Which GUI toolkit should wxWidgets use? GTK+ 3 with support for GTK+ printing
Should wxWidgets be compiled into single library? no
Should wxWidgets be linked as a shared library? no
Should wxWidgets support Unicode? yes (using wchar_t)
What level of wxWidgets compatibility should be enabled?
wxWidgets 2.8 no
wxWidgets 3.0 yes
Which libraries should wxWidgets use?
STL no
jpeg builtin
png sys
regex builtin
tiff builtin
lzma no
zlib sys
expat sys
libmspack no
sdl no最近编辑记录 Cadence (2022-05-16 21:55:23)
