楼主 #1 2019-09-04 16:15:19
还能这么玩
已发帖子: 119
请教Linux下面如何才能对 /dev/input/event* 在应用程序注入数据,用 evtest 可以读出?内核要不要配置什么
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/ioctl.h>
//#include <linux/input.h> // this does not compile
#include <errno.h>
// from <linux/input.h>
struct input_event {
	struct timeval time;
	__u16 type;
	__u16 code;
	__s32 value;
#define EVIOCGVERSION		_IOR('E', 0x01, int)			/* get driver version */
#define EVIOCGID		_IOR('E', 0x02, struct input_id)	/* get device ID */
#define EVIOCGKEYCODE		_IOR('E', 0x04, int[2])			/* get keycode */
#define EVIOCSKEYCODE		_IOW('E', 0x04, int[2])			/* set keycode */
#define EVIOCGNAME(len)		_IOC(_IOC_READ, 'E', 0x06, len)		/* get device name */
#define EVIOCGPHYS(len)		_IOC(_IOC_READ, 'E', 0x07, len)		/* get physical location */
#define EVIOCGUNIQ(len)		_IOC(_IOC_READ, 'E', 0x08, len)		/* get unique identifier */
#define EVIOCGKEY(len)		_IOC(_IOC_READ, 'E', 0x18, len)		/* get global keystate */
#define EVIOCGLED(len)		_IOC(_IOC_READ, 'E', 0x19, len)		/* get all LEDs */
#define EVIOCGSND(len)		_IOC(_IOC_READ, 'E', 0x1a, len)		/* get all sounds status */
#define EVIOCGSW(len)		_IOC(_IOC_READ, 'E', 0x1b, len)		/* get all switch states */
#define EVIOCGBIT(ev,len)	_IOC(_IOC_READ, 'E', 0x20 + ev, len)	/* get event bits */
#define EVIOCGABS(abs)		_IOR('E', 0x40 + abs, struct input_absinfo)		/* get abs value/limits */
#define EVIOCSABS(abs)		_IOW('E', 0xc0 + abs, struct input_absinfo)		/* set abs value/limits */
#define EVIOCSFF		_IOC(_IOC_WRITE, 'E', 0x80, sizeof(struct ff_effect))	/* send a force effect to a force feedback device */
#define EVIOCRMFF		_IOW('E', 0x81, int)			/* Erase a force effect */
#define EVIOCGEFFECTS		_IOR('E', 0x84, int)			/* Report number of effects playable at the same time */
#define EVIOCGRAB		_IOW('E', 0x90, int)			/* Grab/Release device */
// end <linux/input.h>
int sendevent_main(int argc, char *argv[])
    int i;
    int fd;
    int ret;
    int version;
    struct input_event event;
    if(argc != 5) {
        fprintf(stderr, "use: %s device type code value\n", argv[0]);
        return 1;
    fd = open(argv[1], O_RDWR);
    if(fd < 0) {
        fprintf(stderr, "could not open %s, %s\n", argv[optind], strerror(errno));
        return 1;
    if (ioctl(fd, EVIOCGVERSION, &version)) {
        fprintf(stderr, "could not get driver version for %s, %s\n", argv[optind], strerror(errno));
        return 1;
    memset(&event, 0, sizeof(event));
    event.type = atoi(argv[2]);
    event.code = atoi(argv[3]);
    event.value = atoi(argv[4]);
    ret = write(fd, &event, sizeof(event));
    if(ret < sizeof(event)) {
        fprintf(stderr, "write event failed, %s\n", strerror(errno));
        return -1;
https://github.com/joneschrisg/android-system-core/blob/master/toolbox/sendevent.c
网上复制的代码怎么都没搞定
楼主 #2 2019-09-04 17:06:08
还能这么玩
已发帖子: 119
Re: 请教Linux下面如何才能对 /dev/input/event* 在应用程序注入数据,用 evtest 可以读出?内核要不要配置什么
sendevent.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
#include <errno.h>
extern char *optarg;
extern int optind, optopt, opterr;
	uint16_t type;
	uint16_t code;
	int32_t value;
    int i;
    int fd;
    int ret;
    int version;
    if(argc != 5) {
        return 1;
    if(fd < 0) {
        return 1;
        return 1;
        return -1;
getevent.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <dirent.h>
#include <fcntl.h>
#include <sys/inotify.h>
#include <limits.h>
#include <sys/poll.h>
#include <errno.h>
static struct pollfd *ufds;
static char **device_names;
static int nfds;
enum {
    PRINT_DEVICE_ERRORS     = 1U << 0,
    PRINT_DEVICE            = 1U << 1,
    PRINT_DEVICE_NAME       = 1U << 2,
    PRINT_DEVICE_INFO       = 1U << 3,
    PRINT_VERSION           = 1U << 4,
    PRINT_POSSIBLE_EVENTS   = 1U << 5,
static int print_possible_events(int fd)
    uint8_t *bits = NULL;
    ssize_t bits_size = 0;
    const char* label;
    int i, j, k;
    int res, res2;
    printf("  events:\n");
    for(i = 0; i <= EV_MAX; i++) {
        int count = 0;
        while(1) {
            res = ioctl(fd, EVIOCGBIT(i, bits_size), bits);
            if(res < bits_size)
                break;
            bits_size = res + 16;
            bits = realloc(bits, bits_size * 2);
            if(bits == NULL) {
                fprintf(stderr, "failed to allocate buffer of size %d\n", bits_size);
                return 1;
        res2 = 0;
        switch(i) {
            case EV_SYN:
                label = "SYN";
                break;
            case EV_KEY:
                res2 = ioctl(fd, EVIOCGKEY(res), bits + bits_size);
                label = "KEY";
                break;
            case EV_REL:
                label = "REL";
                break;
            case EV_ABS:
                label = "ABS";
                break;
            case EV_MSC:
                label = "MSC";
                break;
            case EV_LED:
                res2 = ioctl(fd, EVIOCGLED(res), bits + bits_size);
                label = "LED";
                break;
            case EV_SND:
                res2 = ioctl(fd, EVIOCGSND(res), bits + bits_size);
                label = "SND";
                break;
            case EV_SW:
                res2 = ioctl(fd, EVIOCGSW(bits_size), bits + bits_size);
                label = "SW ";
                break;
            case EV_REP:
                label = "REP";
                break;
            case EV_FF:
                label = "FF ";
                break;
            case EV_PWR:
                label = "PWR";
                break;
            default:
                res2 = 0;
                label = "???";
        for(j = 0; j < res; j++) {
            for(k = 0; k < 8; k++)
                if(bits[j] & 1 << k) {
                    char down;
                    if(j < res2 && (bits[j + bits_size] & 1 << k))
                        down = '*';
                        down = ' ';
                    if(count == 0)
                        printf("    %s (%04x):", label, i);
                    else if((count & 0x7) == 0 || i == EV_ABS)
                        printf("\n               ");
                    printf(" %04x%c", j * 8 + k, down);
                    if(i == EV_ABS) {
                        struct input_absinfo abs;
                        if(ioctl(fd, EVIOCGABS(j * 8 + k), &abs) == 0) {
                            printf(" value %d, min %d, max %d, fuzz %d flat %d", abs.value, abs.minimum, abs.maximum, abs.fuzz, abs.flat);
                    count++;
        if(count)
            printf("\n");
    free(bits);
static int open_device(const char *device, int print_flags)
    int version;
    int fd;
    struct pollfd *new_ufds;
    char **new_device_names;
    char name[80];
    char location[80];
    char idstr[80];
    struct input_id id;
    fd = open(device, O_RDWR);
    if(fd < 0) {
        if(print_flags & PRINT_DEVICE_ERRORS)
            fprintf(stderr, "could not open %s, %s\n", device, strerror(errno));
        return -1;
    if(ioctl(fd, EVIOCGVERSION, &version)) {
            fprintf(stderr, "could not get driver version for %s, %s\n", device, strerror(errno));
        return -1;
    if(ioctl(fd, EVIOCGID, &id)) {
            fprintf(stderr, "could not get driver id for %s, %s\n", device, strerror(errno));
        return -1;
    name[sizeof(name) - 1] = '\0';
    location[sizeof(location) - 1] = '\0';
    idstr[sizeof(idstr) - 1] = '\0';
    if(ioctl(fd, EVIOCGNAME(sizeof(name) - 1), &name) < 1) {
        //fprintf(stderr, "could not get device name for %s, %s\n", device, strerror(errno));
        name[0] = '\0';
    if(ioctl(fd, EVIOCGPHYS(sizeof(location) - 1), &location) < 1) {
        //fprintf(stderr, "could not get location for %s, %s\n", device, strerror(errno));
        location[0] = '\0';
    if(ioctl(fd, EVIOCGUNIQ(sizeof(idstr) - 1), &idstr) < 1) {
        //fprintf(stderr, "could not get idstring for %s, %s\n", device, strerror(errno));
        idstr[0] = '\0';
    new_ufds = realloc(ufds, sizeof(ufds[0]) * (nfds + 1));
    if(new_ufds == NULL) {
        fprintf(stderr, "out of memory\n");
        return -1;
    ufds = new_ufds;
    new_device_names = realloc(device_names, sizeof(device_names[0]) * (nfds + 1));
    if(new_device_names == NULL) {
        return -1;
    device_names = new_device_names;
    if(print_flags & PRINT_DEVICE)
        printf("add device %d: %s\n", nfds, device);
    if(print_flags & PRINT_DEVICE_INFO)
        printf("  bus:      %04x\n"
               "  vendor    %04x\n"
               "  product   %04x\n"
               "  version   %04x\n",
               id.bustype, id.vendor, id.product, id.version);
    if(print_flags & PRINT_DEVICE_NAME)
        printf("  name:     \"%s\"\n", name);
        printf("  location: \"%s\"\n"
               "  id:       \"%s\"\n", location, idstr);
    if(print_flags & PRINT_VERSION)
        printf("  version:  %d.%d.%d\n",
               version >> 16, (version >> 8) & 0xff, version & 0xff);
    if(print_flags & PRINT_POSSIBLE_EVENTS) {
        print_possible_events(fd);
    ufds[nfds].fd = fd;
    ufds[nfds].events = POLLIN;
    device_names[nfds] = strdup(device);
    nfds++;
int close_device(const char *device, int print_flags)
    int i;
    for(i = 1; i < nfds; i++) {
        if(strcmp(device_names[i], device) == 0) {
            int count = nfds - i - 1;
                printf("remove device %d: %s\n", i, device);
            free(device_names[i]);
            memmove(device_names + i, device_names + i + 1, sizeof(device_names[0]) * count);
            memmove(ufds + i, ufds + i + 1, sizeof(ufds[0]) * count);
            nfds--;
        fprintf(stderr, "remote device: %s not found\n", device);
    return -1;
static int read_notify(const char *dirname, int nfd, int print_flags)
    int res;
    char devname[PATH_MAX];
    char *filename;
    char event_buf[512];
    int event_size;
    int event_pos = 0;
    struct inotify_event *event;
    res = read(nfd, event_buf, sizeof(event_buf));
    if(res < (int)sizeof(*event)) {
        if(errno == EINTR)
        fprintf(stderr, "could not get event, %s\n", strerror(errno));
        return 1;
    //printf("got %d bytes of event information\n", res);
    strcpy(devname, dirname);
    filename = devname + strlen(devname);
    *filename++ = '/';
    while(res >= (int)sizeof(*event)) {
        event = (struct inotify_event *)(event_buf + event_pos);
        //printf("%d: %08x \"%s\"\n", event->wd, event->mask, event->len ? event->name : "");
        if(event->len) {
            strcpy(filename, event->name);
            if(event->mask & IN_CREATE) {
                open_device(devname, print_flags);
            else {
                close_device(devname, print_flags);
        event_size = sizeof(*event) + event->len;
        res -= event_size;
        event_pos += event_size;
static int scan_dir(const char *dirname, int print_flags)
    char *filename;
    DIR *dir;
    struct dirent *de;
    dir = opendir(dirname);
    if(dir == NULL)
        return -1;
    *filename++ = '/';
    while((de = readdir(dir))) {
        if(de->d_name[0] == '.' &&
           (de->d_name[1] == '\0' ||
            (de->d_name[1] == '.' && de->d_name[2] == '\0')))
            continue;
        strcpy(filename, de->d_name);
    closedir(dir);
static void usage(int argc, char *argv[])
    fprintf(stderr, "Usage: %s [-t] [-n] [-s switchmask] [-S] [-v [mask]] [-p] [-q] [-c count] [-r] [device]\n", argv[0]);
    fprintf(stderr, "    -t: show time stamps\n");
    fprintf(stderr, "    -n: don't print newlines\n");
    fprintf(stderr, "    -s: print switch states for given bits\n");
    fprintf(stderr, "    -S: print all switch states\n");
    fprintf(stderr, "    -v: verbosity mask (errs=1, dev=2, name=4, info=8, vers=16, pos. events=32)\n");
    fprintf(stderr, "    -p: show possible events (errs, dev, name, pos. events)\n");
    fprintf(stderr, "    -q: quiet (clear verbosity mask)\n");
    fprintf(stderr, "    -c: print given number of events then exit\n");
    fprintf(stderr, "    -r: print rate events are received\n");
    int c;
    int i;
    int res;
    int pollres;
    int get_time = 0;
    int print_device = 0;
    char *newline = "\n";
    uint16_t get_switch = 0;
    int version;
    int print_flags = PRINT_DEVICE_ERRORS | PRINT_DEVICE | PRINT_DEVICE_NAME;
    int print_flags_set = 0;
    int dont_block = -1;
    int event_count = 0;
    int sync_rate = 0;
    int64_t last_sync_time = 0;
    const char *device = NULL;
    const char *device_path = "/dev/input";
    opterr = 0;
    do {
        c = getopt(argc, argv, "tns:Sv::pqc:rh");
        if (c == EOF)
            break;
        switch (c) {
        case 't':
            get_time = 1;
            break;
        case 'n':
            newline = "";
            break;
        case 's':
            get_switch = strtoul(optarg, NULL, 0);
            if(dont_block == -1)
                dont_block = 1;
            break;
        case 'S':
            get_switch = ~0;
                dont_block = 1;
            break;
        case 'v':
            if(optarg)
                print_flags =  strtoul(optarg, NULL, 0);
                print_flags |= PRINT_DEVICE | PRINT_DEVICE_NAME | PRINT_DEVICE_INFO | PRINT_VERSION;
            print_flags_set = 1;
            break;
        case 'p':
            print_flags = PRINT_DEVICE_ERRORS | PRINT_DEVICE | PRINT_DEVICE_NAME | PRINT_POSSIBLE_EVENTS;
                dont_block = 1;
            break;
        case 'q':
            print_flags = 0;
            break;
        case 'c':
            event_count = atoi(optarg);
            dont_block = 0;
            break;
        case 'r':
            sync_rate = 1;
            break;
        case '?':
            fprintf(stderr, "%s: invalid option -%c\n",
                argv[0], optopt);
        case 'h':
            usage(argc, argv);
            exit(1);
    } while (1);
        dont_block = 0;
    if (optind + 1 == argc) {
        device = argv[optind];
        optind++;
    if (optind != argc) {
        usage(argc, argv);
        exit(1);
    nfds = 1;
    ufds = calloc(1, sizeof(ufds[0]));
    ufds[0].fd = inotify_init();
    ufds[0].events = POLLIN;
    if(device) {
        if(!print_flags_set)
            print_flags = PRINT_DEVICE_ERRORS;
        res = open_device(device, print_flags);
        if(res < 0) {
            return 1;
    else {
        print_device = 1;
		res = inotify_add_watch(ufds[0].fd, device_path, IN_DELETE | IN_CREATE);
        if(res < 0) {
            fprintf(stderr, "could not add watch for %s, %s\n", device_path, strerror(errno));
            return 1;
        res = scan_dir(device_path, print_flags);
        if(res < 0) {
            fprintf(stderr, "scan dir failed for %s\n", device_path);
            return 1;
    if(get_switch) {
            uint16_t sw;
            res = ioctl(ufds[i].fd, EVIOCGSW(1), &sw);
            if(res < 0) {
                fprintf(stderr, "could not get switch state, %s\n", strerror(errno));
                return 1;
            sw &= get_switch;
            printf("%04x%s", sw, newline);
    if(dont_block)
    while(1) {
        pollres = poll(ufds, nfds, -1);
        //printf("poll %d, returned %d\n", nfds, pollres);
        if(ufds[0].revents & POLLIN) {
            read_notify(device_path, ufds[0].fd, print_flags);
            if(ufds[i].revents) {
                if(ufds[i].revents & POLLIN) {
                    res = read(ufds[i].fd, &event, sizeof(event));
                    if(res < (int)sizeof(event)) {
                        fprintf(stderr, "could not get event\n");
                        return 1;
                    if(get_time) {
                        printf("%ld-%ld: ", event.time.tv_sec, event.time.tv_usec);
                    if(print_device)
                        printf("%s: ", device_names[i]);
                    printf("%04x %04x %08x", event.type, event.code, event.value);
                    if(sync_rate && event.type == 0 && event.code == 0) {
                        int64_t now = event.time.tv_sec * 1000000LL + event.time.tv_usec;
                        if(last_sync_time)
                            printf(" rate %lld", 1000000LL / (now - last_sync_time));
                        last_sync_time = now;
                    printf("%s", newline);
                    if(event_count && --event_count == 0)
改了几行代码, 通过编译, 试了一下, 居然可以了.
Ubuntu 模拟鼠标中键上下滚动:
sudo ./sendevent /dev/input/event3 2 8 -1
sudo ./sendevent /dev/input/event3 2 8  1
@ubuntu:/disk2/licheepi/linux$ sudo ./getevent /dev/input/event3
0002 0008 ffffffff
0000 0000 00000000
0002 0008 00000001
0000 0000 00000000
居然可以用了
楼主 #3 2019-09-04 17:27:24
还能这么玩
已发帖子: 119
pc ubuntu 用得好好的, 居然在嵌入式Linux下面不能用,悲剧.
无论 sendevent 怎么发送数据, getevent / evtest 都纹丝不动。
楼主 #4 2019-09-04 17:36:04
还能这么玩
已发帖子: 119
感觉驱动配置应该没有问题, /dev/uinput 设备也有了。
楼主 #5 2019-09-05 11:44:32
还能这么玩
已发帖子: 119
终于搞定, 原来并没有问题, 而是命令没有发全:
正确的姿势是, 先用 evtest 记录按键或者触摸屏的触发记录
比如这个是按下电阻屏某个点:
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value      0
      Min        0
      Max     4095
      Fuzz      32
    Event code 1 (ABS_Y)
      Value      0
      Min        0
      Max     4095
      Fuzz      16
Properties:
Testing ... (interrupt to exit)
Event: time 13499.431064, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 13499.431064, type 3 (EV_ABS), code 0 (ABS_X), value 2558
Event: time 13499.431064, type 3 (EV_ABS), code 1 (ABS_Y), value 357
Event: time 13499.431064, -------------- SYN_REPORT ------------
Event: time 13499.483417, type 3 (EV_ABS), code 1 (ABS_Y), value 365
Event: time 13499.483417, -------------- SYN_REPORT ------------
Event: time 13499.524761, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 13499.524761, -------------- SYN_REPORT ------------
这样模拟发送就妥妥的了:
./sendevent /dev/input/event1 1 330 1
./sendevent /dev/input/event1 3 0 2558
./sendevent /dev/input/event1 3 1 357
./sendevent /dev/input/event1 0 0 0
./sendevent /dev/input/event1 3 1 365
./sendevent /dev/input/event1 1 330 0
楼主 #6 2019-09-05 11:49:08
还能这么玩
已发帖子: 119
再来一个, 比如evtest 采集到的按下按键是以下数据:
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "1c22800.lradc"
Supported events:
  Event type 0 (Sync)
  Event type 1 (Key)
    Event code 114 (VolumeDown)
    Event code 115 (VolumeUp)
    Event code 352 (Ok)
    Event code 353 (Select)
Event: time 228.055444, type 1 (Key), code 352 (Ok), value 1
Event: time 228.055444, -------------- Report Sync ------------
Event: time 228.251432, type 1 (Key), code 352 (Ok), value 0
Event: time 228.251432, -------------- Report Sync ------------
那么sendevent模拟事件注入:
./sendevent /dev/input/event0 1 352 1;./sendevent /dev/input/event0 0 0 0
./sendevent /dev/input/event0 1 352 0;./sendevent /dev/input/event0 0 0 0
仍然妥妥的
#7 2019-09-05 14:24:49
我思故我在
已发帖子: 244
Event: time 1567662318.369695, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1e
Event: time 1567662318.369695, type 1 (EV_KEY), code 30 (KEY_A), value 1
Event: time 1567662318.369695, -------------- SYN_REPORT ------------
aEvent: time 1567662318.461093, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1e
Event: time 1567662318.461093, type 1 (EV_KEY), code 30 (KEY_A), value 0
Event: time 1567662318.461093, -------------- SYN_REPORT ------------
Event: time 1567662326.488377, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1d
Event: time 1567662326.488377, type 1 (EV_KEY), code 29 (KEY_LEFTCTRL), value 1
Event: time 1567662326.488377, -------------- SYN_REPORT ------------
sudo ./sendevent /dev/input/event1 4 4 1
sudo ./sendevent /dev/input/event1 1 30 1
sudo ./sendevent /dev/input/event1 0 0 0
sudo ./sendevent /dev/input/event1 4 4 1e
sudo ./sendevent /dev/input/event1 1 30 0
感谢楼主分享, 我在Ubuntu 试了一下模拟按键输入字母 a, 果然好用
ssh 登陆才好用, 不要问我为什么 ;(
楼主 #8 2019-09-05 15:16:11
还能这么玩
已发帖子: 119
终于通过event injecting 把按键整合到 vnc 协议里面了 ^_^
vnc 可以用键盘控制 ubuntu 的 framebuffer 了。
#9 2019-09-06 06:54:36
jiangchun9981
已发帖子: 170
读写event 设备需要ROOT权限吗
#10 2019-09-06 08:06:10
所在地: 微信 whycan_cn
已发帖子: 9,250
jiangchun9981 说:
读写event 设备需要ROOT权限吗
嗯, 一定要 root
#11 2019-09-06 09:53:56
firstman
已发帖子: 279
刚刚试了一下安卓机, 用 adb shell 命令注入或者读取 event* 设备不需要 root, 可以直接操作, 怪不得那么多游戏外挂
可以试一试这个 https://stackoverflow.com/questions/4386449/send-touch-events-to-a-device-via-adb
最近编辑记录 firstman (2019-09-06 09:55:28)
楼主 #12 2019-09-06 11:07:36
还能这么玩
已发帖子: 119
好麻烦哦,终于搞定了Ubuntu 下面 VNC 操作 littlevgl@Framebuffer, 我用的是鼠标的 ABS_X/ABS_Y/BTN_LEFT组合,想着去君正X1000下面把BTN_LEFT改为 BTN_TOUCH就可以了,结果根本不触发,最后使用 evtest才发现,还得还原成原始 ADC 值,今晚还得加班。
楼主 #13 2019-09-15 10:35:52
还能这么玩
已发帖子: 119
VNC 操作 Framebuffer, 基本OK, 但是vnc 客户端的刷新有点不正常,但是不影响使用。
如果有强制刷新的vnc客户端, 按下强制刷新显示就正常了。
#14 2019-09-16 10:04:44
真的是很烦
已发帖子: 154
为了做类似 teamview 之类的东东?
楼主 #15 2019-09-16 10:20:53
还能这么玩
已发帖子: 119
终于搞定在局域网下用 VNC 控制 君正X1000E soc 了, 挺流畅的, 接着整合一个 frp 进去, 可以远程随时控制了, 舒服舒服。
楼主 #16 2019-11-09 11:48:20
还能这么玩
已发帖子: 119
真的是很烦 说:
对的, 就是这样,配合FRP内网穿透, 可以在家VNC操作地球上任何一台机器。
楼主 #17 2019-11-09 11:50:37
还能这么玩
已发帖子: 119
发现连续两次用sendevent 发送x,y绝对坐标, 这样触发才比较精确,否则有可能变成了长按。
./sendevent /dev/input/event1 3 0 1246
./sendevent /dev/input/event1 3 1 376
#18 2020-12-07 10:09:20
歌以咏志
已发帖子: 219
请问你 adb 连手机, 触摸屏点击注入也是这个原理吗?
#19 2021-03-01 22:35:47
马前卒
已发帖子: 60
第一次看到这么新奇的玩法, 搬小板凳学习!
#20 2022-01-07 13:08:22
JUNJIAN
这个和xdesktop有啥区别吗
