现在x3的播放已经正常了,但是录音一直有问题:
# tinymix contents
Number of controls: 21
ctl type num name value
0 INT 1 Headphone Playback Volume 30 (range 0->63)
1 BOOL 2 Headphone Playback Switch On, On
2 INT 1 Line In Playback Volume 0 (range 0->7)
3 INT 1 Mic2 Playback Volume 3 (range 0->7)
4 INT 1 Mic2 Boost Volume 7 (range 0->7)
5 INT 1 Mic1 Playback Volume 7 (range 0->7)
6 INT 1 Mic1 Boost Volume 4 (range 0->7)
7 INT 1 ADC Gain Capture Volume 3 (range 0->7)
8 BOOL 2 AIF1 Slot 0 Digital DAC Playback Switch On, On
9 BOOL 2 AIF1 Data Digital ADC Capture Switch On, On
10 BOOL 2 DAC Playback Switch On, On
11 BOOL 2 DAC Reversed Playback Switch On, On
12 BOOL 2 Line In Playback Switch On, On
13 BOOL 2 Mic1 Playback Switch On, On
14 BOOL 2 Mic2 Playback Switch On, On
15 BOOL 2 Mixer Capture Switch On, On
16 BOOL 2 Mixer Reversed Capture Switch On, On
17 BOOL 2 Line In Capture Switch On, On
18 BOOL 2 Mic1 Capture Switch On, On
19 BOOL 2 Mic2 Capture Switch On, On
20 ENUM 2 Headphone Source Playback Route DAC, Mixer, DAC, Mixer
# tinycap 1111.wav -d 0 -c 2 -r 44100 -b 16
Capturing sample: 2 ch, 44100 hz, 16 bit
Error capturing sample
Captured 4294967295 frames论坛的帖子我也参考过了,一直解决不了,麻烦知道的给点意见,非常感谢!!!
采样率的问题,你试试看 8000 16000 等采样率。
好的,我试试
还是不行,感觉不是这个问题:
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 48000 -b 16
Capturing sample: 2 ch, 48000 hz, 16 bit
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 8000 -b 16
Capturing sample: 2 ch, 8000 hz, 16 bit
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 16000 -b 16
Capturing sample: 2 ch, 16000 hz, 16 bit
