楼主 # 2024-10-16 16:33:51
海绵宝宝
D133使用JTAG调试昆仑派时,使用T-Head Debugger Server出现以上报错,已经断开CTP线
WARNING: Your CKLINK's version is newer than Your DebugServer, please update Your DebugServer!
T-HEAD: CKLink_Lite_V2, App_ver 2.37, Bit_ver null, Clock 2526.316KHz,
       5-wire, With DDC, Cache Flush On, SN CKLink_Lite_V2-33781375E4.
Extra Info: hacr width is 8.
ERROR: Fail to check had module of CPU 0, please check:
    1. the physical connection;
    2. the power of the target;
    3. the link clock (link clock <= (CPU clock/2));
    4. the reference voltage of link, default 3.3v;
For more information, please run Debugserver with connect log:
     Console: run Debugserver with arguments "--debug connect".
     UI     : select "Connect" from menu "Setting->Verbose Setting".
#1 2024-10-17 13:49:05
AICxia
已发帖子: 68
Re: D133使用JTAG调试昆仑派时,使用T-Head Debugger Server出现以上报错,已经断开CTP线
您可以去升级下 DebugServer 版本,我们Gitee仓库中 tools中有安装包
楼主 #2 2024-10-17 15:17:18
海绵宝宝
AICxia 说:
https://whycan.com/files/members/15073/lQLPJxxC4QEGImchzQGbsIuUUeEWvbU5BvffED5wRAA_411_33.png
DebugServer 已经升级了
       5-wire, With DDC, Cache Flush On, SN CKLink_Lite_V2-T000000B0000033781375E4.
#3 2024-10-17 17:04:11
506826164@qq.com
已发帖子: 65
连接问题,debugger server检测到了cklink,但没检测到目标芯片
