搜集了几个开发板配套资料,optee_sun8iw20p1.bin都不一样,这个文件是什么来的呀,大神指点一下方向,现在T113S3没问题,S4一直卡optee
[29]HELLO! BOOT0 is starting!T
[32][AIC600]BOOT0 commit : ec7b977b
[35]set pll start
[41]periph0 has been enabled
[44]set pll end
[46][pmu]: bus read error
[48]board init ok
[50]enable_jtag
[52]ZQ value = 0x2f
[53]get_pmu_exist() = -1
[56]DRAM BOOT DRIVE INFO: V0.34
[59]DRAM CLK = 792 MHz
[61]DRAM Type = 3 (2:DDR2,3:DDR3)
[64]DRAMC read ODT off.
[67]DRAM ODT value: 0x42.
[70]DRAM SIZE =256 M
[72]dram_tpr4:0x0
[74]PLL_DDR_CTRL_REG:0xf8004100
[77]DRAM_CLK_REG:0xc0000000
[80][TIMING DEBUG] MR2= 0x18
[87]DRAM simple test OK.
[89]rtc standby flag is 0x0, super standby flag is 0x0
[94]dram size =256
[97]card no is 2
[98]sdcard 2 line count 4
[101][mmc]: mmc driver ver 2021-05-21 14:47
[110][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
[116][mmc]: ***Try MMC card 2***
[140][mmc]: RMCA OK!
[142][mmc]: mmc 2 bias 0
[145][mmc]: MMC 5.1
[147][mmc]: HSSDR52/SDR25 4 bit
[150][mmc]: 50000000 Hz
[152][mmc]: 7456 MB
[154][mmc]: ***SD/MMC 2 init OK!!!***
[247]Loading boot-pkg Succeed(index=0).
[250]Entry_name = u-boot
[258]Entry_name = optee
[262]Entry_name = dtb
[265]tunning data addr:0x430003e8
[268]Jump to second Boot.
M/TC: OP-TEE version: e9372c9c-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #2 Sat Mar 19 11:09:45 UTC 2022 arm
E/TC:0 0 check_hardware_info:90 hardware check error1
E/TC:0 0 Panic at core/arch/arm/plat-sun8iw20p1/main.c:314 <plat_init>
E/TC:0 0 Call stack:
E/TC:0 0 0x41b0aa29离线
小正太写过tina适配t113s4的教程,卡optee直接把optee关了就行
https://www.gloomyghost.com/live/20230313.aspx
有的问题在awol上搜一下也可以找到
https://bbs.aw-ol.com/
有的问题在awol上搜一下也可以找到
我看到过这个帖子,也尝试了一下,但是内核会崩溃(can总线导致),内核关闭can才可以
请问楼主这个问题解决了吗?现在CAN总线能用吗?
psci是电源管理吧,跟can有关???
我也在用S4替换S3,DRAM这里就直接报错了
全志把Can驱动部分写到了optee里面,除了Can我记得Ve也在里面,不嫌麻烦可以逆向,我记得awol上有can的逻辑支持
