楼主 # 2023-03-03 09:59:01
wills
T113主线u-boot/kernel支持代码
T113主线u-boot支持代码:
https://github.com/willswang/u-boot/tree/t113-2022.10.y
Tested on mangopi-dual board with PE uart0
Support boot from spi-nand/mmc
Support heyangtek spi nand
Support usb/mmc/eth
Support env storage on mtd
Support boot mainline kernel
Build for mangopi-dual board:
    make mangopi_dual_defconfig
    make
Burn to spi nand:
    xfel spinand write 0 u-boot-sunxi-with-spl.bin
T113主线kernel支持patch:
arch/arm/mach-sunxi/platsmp.c
 #define PRCM_CPU_PWROFF_REG			0x100
 #define PRCM_CPU_PWR_CLAMP_REG(cpu)		(((cpu) * 4) + 0x140)
+ * T113 is different from other SoCs.
+#define T113_CPUCFG_RST_CTRL_REG		0x0000
+#define T113_CPUCTRL_ENTRY_REG(cpu)		(0x5c0 + ((cpu) + 1) * 4)
 static void __iomem *cpucfg_membase;
 static void __iomem *prcm_membase;
@@ -194,3 +200,61 @@ static const struct smp_operations sun8i_smp_ops __initconst = {
 	.smp_boot_secondary	= sun8i_smp_boot_secondary,
 CPU_METHOD_OF_DECLARE(sun8i_a23_smp, "allwinner,sun8i-a23", &sun8i_smp_ops);
+static void __init sun8i_t113_smp_prepare_cpus(unsigned int max_cpus)
+	struct device_node *node;
+	node = of_find_compatible_node(NULL, NULL, "allwinner,sun8i-t113-cpucontrol");
+	if (!node) {
+		pr_err("Missing T113 CPU contrl node in the device tree\n");
+		return;
+	prcm_membase = of_iomap(node, 0);
+	of_node_put(node);
+	if (!prcm_membase) {
+		pr_err("Couldn't map T113 CPU contrl registers\n");
+		return;
+				       "allwinner,sun8i-t113-cpuconfig");
+	if (!node) {
+		pr_err("Missing T113 CPU config node in the device tree\n");
+		return;
+	cpucfg_membase = of_iomap(node, 0);
+	if (!cpucfg_membase)
+		pr_err("Couldn't map T113 CPU config registers\n");
+static int sun8i_t113_smp_boot_secondary(unsigned int cpu,
+				    struct task_struct *idle)
+	u32 reg;
+	if (!(prcm_membase && cpucfg_membase))
+		return -EFAULT;
+	spin_lock(&cpu_lock);
+	/* Set CPU boot address */
+	writel(__pa_symbol(secondary_startup), prcm_membase + T113_CPUCTRL_ENTRY_REG(cpu));
+	/* Deassert the CPU core reset */
+	reg = readl(cpucfg_membase + T113_CPUCFG_RST_CTRL_REG);
+	writel(reg | BIT(cpu), cpucfg_membase + T113_CPUCFG_RST_CTRL_REG);
+	spin_unlock(&cpu_lock);
+	return 0;
+static const struct smp_operations sun8i_t113_smp_ops __initconst = {
+	.smp_prepare_cpus	= sun8i_t113_smp_prepare_cpus,
+	.smp_boot_secondary	= sun8i_t113_smp_boot_secondary,
+CPU_METHOD_OF_DECLARE(sun8i_t113_smp, "allwinner,sun8i-t113", &sun8i_t113_smp_ops);
在dts中增加下列节点:
arch/arm/boot/dts/sun8i-t113.dtsi
        cpus {
                enable-method = "allwinner,sun8i-t113";
                #address-cells = <1>;
                #size-cells = <0>;
                cpu0: cpu@0 {
                        device_type = "cpu";
                        compatible = "arm,cortex-a7","arm,armv7";
                        reg = <0x0>;
                        clocks = <&ccu CLK_CPUX>;
                        clock-frequency = <1200000000>;
                        #cooling-cells = <2>;
                cpu1: cpu@1 {
                        reg = <0x1>;
        soc {
                cpuctrl: cpuctrl@7000000 {
                        compatible = "allwinner,sun8i-t113-cpucontrol";
                        reg = <0x07000000 0x1000>;
                cpucfg: cpucfg@9010000 {
                        compatible = "allwinner,sun8i-t113-cpuconfig";
                        reg = <0x09010000 0x100>;
最近编辑记录 wills (2023-03-03 10:22:15)
#1 2023-03-03 12:01:49
tango_zhu
已发帖子: 130
Re: T113主线u-boot/kernel支持代码
内核是哪个版本? mango pi 怎么接spi nand ? 自己焊接吗 ?
楼主 #2 2023-03-06 09:09:04
wills
tango_zhu 说:
mangopi-dual预留有spi flash焊盘,自己焊接一个就可以
主线内核6.0以上应该就都可以,只是支持外设驱动多少的问题
下面sun8i-t113.dtsi供大家参考:
https://whycan.com/files/members/11464/sun8i-t113.dtsi.zip
最近编辑记录 wills (2023-03-06 09:18:31)
#3 2023-03-21 23:13:17
chenfengmcu
starting kernel 卡住 内核设备树确认正常,能否开放一个内核测试版本
楼主 #5 2023-03-29 12:22:37
wills
chenfengmcu 说:
有启动log吗?注意console是PE uart0
最近编辑记录 wills (2023-03-29 14:04:05)
楼主 #6 2023-03-29 12:24:52
wills
内核改动不多,比较简单,所以没有专门放上去
楼主 #7 2023-03-29 14:12:58
wills
基于主线Linux 6.3-rc4的 mangopi-dual板的patch文件
linux-t113-6.3-rc4.patch.zip
#9 2023-04-03 19:17:37
vigour1000
已发帖子: 103
内核版本升级太快
#10 2023-04-03 21:34:35
chenfengmcu
楼主提供的主线源码非常好,大家可以偿试一下,生成的debian系统很方便
#11 2023-10-23 17:41:57
vvpnet
@wills
告诉我。 你是如何将linux写入nand flash的? 通过xfel? 给我举个例子。 谢谢!
楼主 #12 2023-10-24 08:55:15
wills
u-boot用xfel写到spi-nand里面
kernel如果放在单独的分区,也是一样
或者把kernel放在ubi/ubifs里面,用u-boot烧写
#13 2023-11-20 16:59:53
ueiia
已发帖子: 30
之前试的大佬的AWBOOT+6.0.1内核,启动没成功,试试6.3的版本
#14 2023-11-20 23:41:07
HunanJLR
同样是T113,S3是商业级,-i工业级。官方搞2种干嘛
#15 2023-11-25 17:19:36
暗水天狼
我克隆下来后,编译报错:
配置:
make ARCH=arm CROSS_COMPILE=../gcc-linaro-7.5.0-2019.12-rc1-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf- mangopi_dual_defconfig
编译:
报错:
  LD      spl/u-boot-spl
/bin/sh: 1: ../gcc-linaro-7.5.0-2019.12-rc1-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: not found
scripts/Makefile.spl:526: recipe for target 'spl/u-boot-spl' failed
make[1]: *** [spl/u-boot-spl] Error 127
Makefile:2075: recipe for target 'spl/u-boot-spl' failed
make: *** [spl/u-boot-spl] Error 2
楼主 #16 2023-11-28 09:27:58
wills
设置工具链 export PATH=<绝对路径>/gcc-linaro-7.5.0-2019.12-rc1-x86_64_arm-linux-gnueabihf/bin/:$PATH,然后再用make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 编译
#17 2023-12-01 10:54:46
暗水天狼
@wills 已经解决,谢谢!
#18 2023-12-03 09:32:00
ueiia
已发帖子: 30
主线代码还有很多驱动都没有,不如用tina来的省心,不过tina的编译好复杂,学起来真要命
楼主 #19 2023-12-04 16:13:22
wills
如果你需要做一些原厂无法覆盖到的差异化的东西,你就知道tina到底省不省心?
话说回来,除了turnkey和大厂,用全志的啥时候省心过,主要还是图便宜
#20 2024-07-19 12:05:34
weed_hz
wills 说:
给个下载连接吧,那个6。0的编译过了起动不了
#21 2024-07-19 12:17:08
weed_hz
@wills
内核SPI驱动都我看没有呀,怎么会支持SPI flash,能否发一个内核的连接,谢谢
#22 2024-09-24 23:18:37
dangvitin
如何使用uart3而不是uart0,我改变了dts文件,但没有显示在控制台上,当我使用uart0时它很好
最近编辑记录 dangvitin (2024-09-24 23:23:16)
楼主 #23 2024-09-25 10:45:04
wills
最新的u-boot和kernel主线已经支持了T113,只不过里面的用的型号是R528
#24 2025-07-01 14:57:19
KoGu
现在可以支持s4吗
#25 2025-08-01 15:37:27
ZUOYOU
我看好多人使用TINA,TINA到底有哪些很特色的东西?
#26 2025-08-20 17:27:00
曹晓宁
wills 说:
外设支持的很全了么,还是有好多补丁要打呢
#27 2025-09-03 11:24:05
曹晓宁
dangvitin 说:
https://whycan.com/files/members/15310/221227.png
https://whycan.com/files/members/15310/221154.png
你要修改board.c呀
#28 2025-10-18 21:09:17
quangtn82
The file "u-boot-sunxi-with-spl.bin" includes 2 parts SPL and uboot. Can anyone show me the address of SPL and uboot when writing to spi nand (SPL is probably at address 0x00)?
