楼主 # 2025-09-08 19:48:50
xfdr0805
已发帖子: 348
有人测试过 d13x 加密方案吗?我试了下结果再也无法启动了
参照文档进行操作,结果再也无法烧录了,也无法运行。
Pre-boot 也看不到输出了 SPL也无法执行。密钥肯定正确,不知道哪个环节出了问题,请玩过的大佬指点一下,谢谢!
keys文件夹下的文件已经正确生成,镜像也打包成功,但是无法运行。
镜像配置文件
    "spi-nor": { // Device, The name should be the same with string in image:info:media:type
        "size": "8m", // Size of SPI NOR
        "partitions": {
            "spl":        { "size": "256k" },
            "os":         { "size": "5m" },
            "rootfs":       { "size": "2m" }
    "image": {
        "info": { // Header information about image
            "platform": "d13x",
            "product": "wif_clock",
            "version": "1.0.0",
            "media": {
                "type": "spi-nor",
                "device_id": 0,
        "updater": { // Image writer which is downloaded to RAM by USB
            "psram": {
                "file": "usbupg-psram-init.aic",
                "attr": ["required", "run"],
                "ram": "0x30044000"
            "spl": {
                "file": "bootloader.aic",
                "ram": "0x30100000"
        "target": { // Image components which will be burn to device's partitions
            "spl": {
                "file": "bootloader.aic.enc",
                "attr": ["mtd", "required"],
                "part": ["spl"]
            "os": {
                "file": "d13x_os.itb.enc",
                "part": ["os"]
            "rootfs": {
                "file": "data.fatfs.enc",
                "attr": ["mtd", "optional"],
                "part": ["rootfs"]
    "pre-process": { // Pre-proccess to generate image components from raw data
        "aicimage": { // Create aic boot image
            "usbupg-psram-init.aic": { // No loader, only PreBootProgram to initialize PSRAM
                "head_ver": "0x00010001",
                "resource": {
                    "private": "pbp_cfg.bin",
                    "pubkey": "keys/rsa_public_key.der",
                    "pbp": "d13x.pbp",
                "encryption": {
                    "algo": "aes-128-cbc",
                    "key": "keys/aes-128-cbc-key.bin",
                    "iv": "keys/aes-128-cbc-iv.bin",
		"ssk_derived_key": "true",
                "signature": {
                    "algo": "rsa,2048",
                    "privkey": "keys/rsa_private_key.der",
            "pbp_ext.aic": {
                "resource": {
                    "pbp": "d13x.pbp",
                "encryption": {
                "signature": {
                    "algo": "rsa,2048",
                // combine to use with loader.aic
                "with_ext": "true",
            "loader.aic": {
                "loader": {
                    "file": "bootloader.bin",
                    "load address": "CONFIG_AIC_BOOTLOADER_LOAD_BASE",
                    "entry point": "CONFIG_AIC_BOOTLOADER_TEXT_BASE", // 256 byte aic header
                "resource": {
                "encryption": {
                "signature": {
                    "algo": "rsa,2048",
        "concatenate": { // cat files in order
            "bootloader.aic": ["pbp_ext.aic", "loader.aic"],
        "itb": { // Create itb image from its
            "d13x_os.itb": {
                "its": "d13x_os.its"
        "data_crypt": {
            "bootloader.aic.enc": {
                "algo": "spienc-aes-128-ecb",
                "file": "bootloader.aic", // File to be encrypted
                "key": "keys/spi_aes.key", // Keys the same in eFuse
                "nonce": "keys/spi_nonce.key", // Nonce the same in eFuse
                "tweak": "0",
            "env.bin.enc": {
                "file": "env.bin", // File to be encrypted
                "tweak": "0",
            "d13x_os.itb.enc": {
                "file": "d13x_os.itb", // File to be encrypted
                "tweak": "0",
            "data.fatfs.enc": {
                "file": "data.fatfs", // File to be encrypted
                "tweak": "0",
楼主 #1 2025-09-09 09:35:28
xfdr0805
已发帖子: 348
Re: 有人测试过 d13x 加密方案吗?我试了下结果再也无法启动了
没人测试过官方提供的加密方案吗?
#2 2025-09-09 19:32:03
gemrisk
@xfdr0805
spienc 的量产安全方案中,是不需要加下面这段代码的
                "encryption": {
楼主 #3 2025-09-09 21:21:13
xfdr0805
已发帖子: 348
@gemrisk
一开始我是没加,但是烧录后不能运行,参照demo就加上了,结果还是不能运行。
我只要固件加密还不需要硬件授权认证,SPI ENC [KEY NONCE ROTPK] 已经烧录好了。
