楼主 # 2026-01-31 13:43:30
xzyang
已发帖子: 22
编译错误
裸机sdk,提示找不到mk_image.exe  riscv64-unknown-elf-objcopy -O binary output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf output/d13x_demo88-nor_baremetal_helloworld/images/d13x.bin
riscv64-unknown-elf-size output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf
   text    data     bss     dec     hex filename
455832    6580   68232  530644   818d4 output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf
python3 D:\baremetal-master\tools/scripts/fsinstall.py --sdkout D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ --clean rodata/lvgl_data
python3 D:\baremetal-master\tools/scripts/fsinstall.py --sdkout D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ --src D:\baremetal-master\packages\artinchip\lvgl-ui\aic_demo\gif_demo\assets/ --dst rodata/lvgl_data
python3 D:\baremetal-master\tools/scripts/linked_size.py -m D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/d13x.map
python3 D:\baremetal-master\tools/scripts/makefatfs.py --fullpart --volab default --cluster 8 --sector 512 --tooldir D:\baremetal-master\tools/scripts/ --inputdir rodata --outfile D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/rodata.fatfs
D:\baremetal-master\tools/scripts/mk_private_resource.exe -v -l D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/pbp_cfg.json,D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/partition.json -o D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/pbp_cfg.bin
python3 D:\baremetal-master\tools/scripts/elf_parse.py output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ riscv64-unknown-elf-
D:\baremetal-master\tools/scripts/mk_image.exe -v -c D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/image_cfg.json -d D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/
Error in calling command:D:\baremetal-master\tools/scripts/mk_image.exe
Exception: No such file or directory
Please check Toolchains PATH setting.
scons: *** [output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf] Error 2
scons: building terminated because of errors.
