楼主 # 2026-01-31 13:43:30
xzyang
已发帖子: 30
编译错误
裸机sdk,提示找不到mk_image.exe riscv64-unknown-elf-objcopy -O binary output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf output/d13x_demo88-nor_baremetal_helloworld/images/d13x.bin
riscv64-unknown-elf-size output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf
text data bss dec hex filename
455832 6580 68232 530644 818d4 output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf
python3 D:\baremetal-master\tools/scripts/fsinstall.py --sdkout D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ --clean rodata/lvgl_data
python3 D:\baremetal-master\tools/scripts/fsinstall.py --sdkout D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ --src D:\baremetal-master\packages\artinchip\lvgl-ui\aic_demo\gif_demo\assets/ --dst rodata/lvgl_data
python3 D:\baremetal-master\tools/scripts/linked_size.py -m D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/d13x.map
python3 D:\baremetal-master\tools/scripts/makefatfs.py --fullpart --volab default --cluster 8 --sector 512 --tooldir D:\baremetal-master\tools/scripts/ --inputdir rodata --outfile D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/rodata.fatfs
D:\baremetal-master\tools/scripts/mk_private_resource.exe -v -l D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/pbp_cfg.json,D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/partition.json -o D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/pbp_cfg.bin
python3 D:\baremetal-master\tools/scripts/elf_parse.py output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/ riscv64-unknown-elf-
D:\baremetal-master\tools/scripts/mk_image.exe -v -c D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/image_cfg.json -d D:\baremetal-master\output/d13x_demo88-nor_baremetal_helloworld/images/
Error in calling command:D:\baremetal-master\tools/scripts/mk_image.exe
Exception: No such file or directory
Please check Toolchains PATH setting.
scons: *** [output\d13x_demo88-nor_baremetal_helloworld\images\d13x.elf] Error 2
scons: building terminated because of errors.
#1 2026-02-02 16:05:23
AICxia
已发帖子: 101
Re: 编译错误
https://gitee.com/artinchip/baremetal/tree/master/tools/scripts,gitee 上是有的,需要看一下对应目录上是否有这个文件
楼主 #2 2026-02-02 19:06:12
xzyang
已发帖子: 30
Re: 编译错误
是的,gitee上看到有,试了git和直接下载zip解压后,均没有mk_image.exe,后来从立创的泰山派的gitee上获取的正常,有这个文件,ok了。
