芯片70,板子269,你这板子保熟吗?
为啥不是h136.... 求h136 h135,哈哈哈
奇怪有一块板启动正常,但是烧录不了:
[128]HELLO! BOOT0 is starting!
[131]BOOT0 commit : {0a84c8b0}
[135][pmu]: bus read error
[137]enable vdd sys auto set
[140]fdt err returned -9
[142]not find dvfs config in spl.dts, default vdd_sys set 0.95V
[148]set pll start
[150]set pll end
[152]dram para13 invalid use default para
[156]vaild para:1 select dram para0
[159]ic board init ok
[161]rtc[7] value = 0x6
[163]enable_jtag
[165]set spi freq:50000000
[169]spi sample_mode:0 sample_delay:1f
[173]spinor id is: ef 40 18, read cmd: 6b
[177]DRAM BOOT DRIVE INFO: V0.21
[180]DRAM use external ZQ
[183]DRAM CLK = 933 MHz
[185]DRAM Type = 3 (3:DDR3,4:DDR4)
[215]DRAM SIZE = 256 MBytes, para1 = 30ea, para2 = 1000001, dram_tpr13 = 8207071
[225]DRAM simple test OK.
[227]dram size = 256
[230]set spi freq:50000000
[234]spi sample_mode:0 sample_delay:1f
[238]spinor id is: ef 40 18, read cmd: 6b
[242]Succeed in reading toc file head.
[245]The size of toc is 1ac000.
[319]Entry_name = u-boot
[328]Entry_name = optee
[333]Jump to OPTEE: optee_base = 0x42900000, uboot_base = 0x43500000
M/TC: OP-TEE version: 807754be (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Aug 5 10:07:52 UTC 2025 arm
M/TC: OP-TEE 32bit
[00.516]ns16550_serial serial@2600000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2023.04-rc4 (Aug 06 2026 - 15:21:00 +0800) Allwinner Technology
U-Boot bsp (Aug 06 2026 - 15:21:00 +0800) Allwinner Technology
14/40 CPU: SUNXI Family
Model: sun8iw22
DRAM: 256 MiB
[00.547]Relocation Offset is: 0c9a3000
Working FDT set to 4de9b310
[00.603]secure enable bit: 0
E/TC:0 fdt_getprop_u32:388 prop trace_level not found
[00.619]CPU=1008MHz, PLL6=600Mhz, AHB=200Mhz, APB1=100Mhz, MBus=480Mhz
[00.625]workmode = 0,storage type = nor
[00.631]sunxi-spif spif@2800000: frequency no in range, use default value 150000000
[00.638]sunxi-spif spif@2800000: sample_mode:aaaaffff sample_delay:aaaaffff
sunxi_get_spif_mode()222 - get dtr_mode_enable fail -13
sunxi_get_spif_mode()231 - get io_mode_enable fail -13
[00.655]sunxi-spif spif@2800000: probe succeed (Version 1.0.0)
[00.660]sunxi-spif spif@2800000: sspi->mode:0x2400 mode:0x0
[00.676]sunxi-spif spif@2800000: spi sample_mode:0 sample_delay:1f
[00.682]sunxi-spif spif@2800000: spif sspi->speed_hz:50000000
SF: Detected w25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB
[00.695]sunxi-spif spif@2800000: sunxi_spif_release_bus()
[00.700]set_sunxi_flash_curdev...45:cur_sunxi_flash :spif-nor.sunxi_flash
Core: 165 devices, 24 uclasses, devicetree: separate
WDT: Not starting watchdog@0x02050000
MMC:
[00.719]Loading Environment from SUNXI_FLASH... [00.747]OK
In: serial
Out: serial
Err: serial
[00.752]skip update boot_param
[00.755]update bootcmd
Net: [00.758]No ethernet found.
[00.761]do sunxi preboot
[00.763]root_partition is rootfs
[00.767]set root to /dev/mtdblock4
[00.770]update part info
[00.774]sunxi bmp info error : unable to open logo file bootlogo.bmp
[00.780]Get sunxi drm device fail!
Working FDT set to 42000000
[00.806]change working_fdt 0x4de9b310 to 0x42000000
[00.813]enable node spi0/spi_board0 error: FDT_ERR_NOTFOUND
[00.823]spinor update sample_mode:0 right_sample_mod:1f
[00.833]update dts
[00.836]Item0 (Map) magic is bad
[01.129]try to update
[01.463]do sunxi update
## Booting Android Image at 0x40007800 ...
Android's image name: sun8i_arm
Kernel load addr 0x40008000 size 5305 KiB
## Flattened Device Tree blob at 42000000
Booting using the fdt blob at 0x42000000
XIP Kernel Image
Using Device Tree in place at 42000000, end 42042fff
[02.429]can`t not get hyper image base in /chosen/hyper
[02.433]Starting kernel ...
[ 0.000000] Linux version 5.10.198 (xulu@mylinux) (arm-linux-gnueabihf-gcc (GCC) 11.3.1 20220604 [releases/gcc-11 revision 591c0f4b92548e3ae2e8173f4f93984b1c7f62bb], GNU ld (Linaro_Binutils-2022.06) 2.37.20220122) #6 SMP PREEMPT Thu Aug 6 15:25:29 CST 2026
[ 0.000000] OF: fdt: Machine model: sun8iw22
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x42100000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@42100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x42144000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node e907_rpbuf@42144000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x4e800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000040000000-0x000000004fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000420fffff]
[ 0.000000] node 0: [mem 0x0000000042100000-0x00000000424c4fff]
[ 0.000000] node 0: [mem 0x00000000424c5000-0x000000004fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000004fffffff]
[ 0.000000] On node 0 totalpages: 65536
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 65536 pages, LIFO batch:15
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30156 r8192 d23092 u61440
[ 0.000000] pcpu-alloc: s30156 r8192 d23092 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02600000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mtdblock4 rootwait init=/init partitions=boot-resource@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:private@mtdblock5:rootfs_data@mtdblock6:UDISK@mtdblock7 cma=24M snum= coherent_pool=16K ion_carveout_list= boot_type=3 gpt=1 uboot_message=2023.04-rc4 mbr_offset=2080768
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Memory: 201196K/262144K available (7168K kernel code, 1674K rwdata, 2572K rodata, 1024K init, 245K bss, 36372K reserved, 24576K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] AW BSP version: 4b15cb14e7, 2025-11-27 13:57:40 +0800
[ 0.000000] sunxi:ccu-ng:[INFO]: ccu: sunxi ccu init OK
[ 0.000000] sunxi:ccu-ng:[INFO]: sunxi ccu common driver version: 1.2.6
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.007973] Switching to timer-based delay loop, resolution 41ns
[ 0.014363] sunxi:hstimer:[INFO]: sun50i timer init:0x7, driver version: 1.1.6
[ 0.021149] clocksource: timer0: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.032019] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.041335] CPU: Testing write buffer coherency: ok
[ 0.046208] pid_max: default: 32768 minimum: 301
[ 0.050898] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.058079] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.066665] /cpus/cpu@0 missing clock-frequency property
[ 0.071109] /cpus/cpu@1 missing clock-frequency property
[ 0.076361] /cpus/cpu@2 missing clock-frequency property
[ 0.081662] /cpus/cpu@3 missing clock-frequency property
[ 0.086926] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.093283] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.099191] rcu: Hierarchical SRCU implementation.
[ 0.104748] smp: Bringing up secondary CPUs ...
[ 0.109521] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.110819] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.112052] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.112167] smp: Brought up 1 node, 4 CPUs
[ 0.129325] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.135556] CPU: All CPU(s) started in SVC mode.
[ 0.140598] devtmpfs: initialized
[ 0.164518] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.166768] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.176373] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.184200] pinctrl core: initialized pinctrl subsystem
[ 0.189901] NET: Registered protocol family 16
[ 0.194090] DMA: preallocated 16 KiB pool for atomic coherent allocations
[ 0.200500] thermal_sys: Registered thermal governor 'fair_share'
[ 0.200508] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.205697] thermal_sys: Registered thermal governor 'step_wise'
[ 0.211630] thermal_sys: Registered thermal governor 'user_space'
[ 0.242327] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.255478] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.262538] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.269598] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.276658] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.283717] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.290777] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.297837] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.304896] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.311956] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.319016] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.326084] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.333144] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.340206] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.347266] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.354325] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.361386] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.368446] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.375505] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.382565] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.389625] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.396693] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.403753] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.410812] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.417872] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.424931] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.431991] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.439051] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.446110] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.453170] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.460230] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.467299] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.474359] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.481419] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.488479] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.495538] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.502598] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.509658] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.516717] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.523777] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.530837] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.537905] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.544965] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.552025] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.559084] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.566143] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.573203] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.580263] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.587323] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.594382] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.601442] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.608510] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.615570] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.622629] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.629689] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.636748] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.643808] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.650868] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.657927] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.664987] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.672047] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.679115] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.686174] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.693234] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.700294] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.707354] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.714414] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.721473] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.728533] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.735593] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.742652] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.749721] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.756781] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.763841] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.770900] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.777960] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.785020] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.792079] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.799138] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.806198] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.813258] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.820332] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.827392] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.834452] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.841512] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.848571] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.855631] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.862690] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.869750] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.876810] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.883869] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.890937] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.897997] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.905057] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.912117] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.919176] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.926237] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.933296] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.940356] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.947416] sunxi:ccu-nglosc not stable, 32K clk will use 16M as parent!
[ 0.948788] sunxi:ccu-ng:[INFO]: rtc_ccu: sunxi ccu init OK
[ 0.954605] sunxi:ccu-ng:[INFO]: cpupll_ccu: sunxi ccu init OK
[ 0.959871] sunxi:ccu-ng:[INFO]: sunxi cpupll driver version: 0.0.1
[ 0.966414] sunxi:ccu-ng:[INFO]: r_ccu: sunxi ccu init OK
[ 0.971718] sunxi:ccu-ng:[INFO]: drampll_ccu: sunxi ccu init OK
[ 0.977341] sun8iw22-pll-dram 3130000.drampll_ccu: sunxi:ccu-ngsun8iw22 pll clk init OK
[ 1.005333] SCSI subsystem initialized
[ 1.005645] usbcore: registered new interface driver usbfs
[ 1.008960] usbcore: registered new interface driver hub
[ 1.014242] usbcore: registered new device driver usb
[ 1.019357] mc: Linux media interface: v0.10
[ 1.023618] videodev: Linux video capture interface: v2.00
[ 1.028985] pps_core: LinuxPPS API ver. 1 registered
[ 1.033926] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.042993] PTP clock support registered
[ 1.047182] Advanced Linux Sound Architecture Driver Initialized.
[ 1.058464] sun6i-dma 3001000.dma-controller: sunxi:dmasunxi dma probed, driver version: 1.2.15
[ 1.063052] sunxi:pwmcs-20a0000.pwmcs0:[INFO]: start probe
[ 1.063092] sunxi:pwmcs-20a0000.pwmcs0:[INFO]: chip->pwmcs_num:0
[ 1.073088] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: base is 0, num is 8
[ 1.079667] sunxi:pwmcs-20a0000.pwmcs0:[INFO]: pwmcschip probe success
[ 1.086017] sunxi:pwmcs-20b0000.pwmcs1:[INFO]: start probe
[ 1.086052] sunxi:pwmcs-20b0000.pwmcs1:[INFO]: chip->pwmcs_num:1
[ 1.097115] sunxi:pwmcs-20b0000.pwmcs1:[ERR]: base is 8, num is 8
[ 1.103578] sunxi:pwmcs-20b0000.pwmcs1:[INFO]: pwmcschip probe success
[ 1.110096] sunxi:pwm-20c0000.pwm2:[INFO]: start probe
[ 1.110139] sunxi:pwm-20c0000.pwm2:[WARN]: invalid PWM alias format: pwmcs0
[ 1.121673] sunxi:pwm-20c0000.pwm2:[WARN]: invalid PWM alias format: pwmcs1
[ 1.129222] sunxi:pwm-20c0000.pwm2:[INFO]: pwmchip probe success
[ 1.134889] clocksource: Switched to clocksource arch_sys_counter
[ 1.153444] sunxi:pin-3604000.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
[ 1.156379] sunxi:pin:[INFO]: sunxi pinctrl core driver version: 1.4.19
[ 1.164775] sunxi:pin-7096500.pinctrl:[INFO]: pinctrl withstand voltage config mode=auto_hard
[ 1.171921] NET: Registered protocol family 2
[ 1.175979] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.183863] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.191335] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 1.198927] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 1.206200] TCP: Hash tables configured (established 2048 bind 2048)
[ 1.212417] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.218884] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.225942] NET: Registered protocol family 1
[ 1.231343] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[ 1.240718] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.242311] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.246994] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.253253] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 1.260106] io scheduler mq-deadline registered
[ 1.264582] io scheduler kyber registered
[ 1.277587] scsi host0: scsi_debug: version 0190 [20200710]
[ 1.277587] dev_size_mb=8, opts=0x0, submit_queues=1, statistics=0
[ 1.284501] scsi 0:0:0:0: Direct-Access Linux scsi_debug 0190 PQ: 0 ANSI: 7
[ 1.292546] sd 0:0:0:0: Power-on or device reset occurred
[ 1.298676] CAN device driver interface
[ 1.301777] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.307745] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.314040] usbcore: registered new interface driver uas
[ 1.319284] sd 0:0:0:0: [sda] 16384 512-byte logical blocks: (8.39 MB/8.00 MiB)
[ 1.326460] usbcore: registered new interface driver usb-storage
[ 1.332340] usbcore: registered new interface driver ums-alauda
[ 1.336429] sd 0:0:0:0: [sda] Write Protect is off
[ 1.338245] usbcore: registered new interface driver ums-cypress
[ 1.342970] sd 0:0:0:0: [sda] Mode Sense: 73 00 10 08
[ 1.348991] usbcore: registered new interface driver ums-datafab
[ 1.359997] usbcore: registered new interface driver ums_eneub6250
[ 1.366149] usbcore: registered new interface driver ums-freecom
[ 1.372114] usbcore: registered new interface driver ums-isd200
[ 1.374074] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 1.378022] usbcore: registered new interface driver ums-jumpshot
[ 1.392571] usbcore: registered new interface driver ums-karma
[ 1.398407] usbcore: registered new interface driver ums-realtek
[ 1.404355] usbcore: registered new interface driver ums-sddr09
[ 1.410261] usbcore: registered new interface driver ums-sddr55
[ 1.416156] usbcore: registered new interface driver ums-usbat
[ 1.416613] sd 0:0:0:0: [sda] Optimal transfer size 524288 bytes
[ 1.422207] i2c /dev entries driver
[ 1.431477] usbcore: registered new interface driver uvcvideo
[ 1.437109] USB Video Class driver (1.1.1)
[ 1.441365] sunxi:pin-3604000.pinctrl:[INFO]: Auto power withstand voltage configuration detected, automatically exit!
[ 1.452222] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.457985] usbcore: registered new interface driver usbhid
[ 1.463346] usbhid: USB HID core driver
[ 1.467224] optee: probing for conduit method.
[ 1.471596] optee: revision 3.7 (807754be)
[ 1.472149] optee: initialized driver
[ 1.480329] uart-ng uart-ng0: supply uart not found, using dummy regulator
[ 1.486353] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the TX DMA channel!
[ 1.492905] sunxi:uart-ng-uart-ng0:[INFO]: cannot get the RX DMA channel!
[ 1.499730] sunxi:uart-ng:[INFO]: sunxi uart-ng driver version: 1.1.21
[ 1.506207] uart-ng0: ttyAS0 at MMIO 0x2600000 (irq = 46, base_baud = 1500000) is a SUNXI
[ 1.514326] sunxi:uart-ng-uart-ng0:[INFO]: console setup baud 115200 parity n bits 8, flow n
[ 1.522834] printk: console [ttyAS0] enabled
[ 1.533195] printk: bootconsole [earlycon0] disabled
[ 1.543841] sunxi:rtc:[INFO]: Saving SoC boot-reason: OTHERS
[ 1.554389] sunxi:rtc:[INFO]: Saving SoC boot-reason: HARDREST-BOOT
[ 1.561637] sunxi:rtc-7090000.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.572976] sunxi:rtc-7090000.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.584227] sunxi:rtc-7090000.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.595759] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.601425] sunxi:rtc-7090000.rtc:[WARN]: Warning: Using internal RC 16M clock source. Time may be inaccurate!
[ 1.612697] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:03:37 UTC (217)
[ 1.614030] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.621793] sunxi:rtc-7090000.rtc:[INFO]: sunxi rtc probed
[ 1.634104] sunxi-wdt 2050000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0), driver version: 1.0.4
[ 1.646295] sunxi:sunxi_spif-2800000.spif:[INFO]: sample_mode:0 sample_delay:1f
[ 1.654914] sunxi:sunxi_spif-2800000.spif:[INFO]: [spi-flash0] mclk 25000000
[ 1.664478] sunxi:sunxi_spif-2800000.spif:[INFO]: [spi-flash0] working clk 80000000
[ 1.674092] sunxi_spif 2800000.spif: w25q128 (16384 Kbytes)
[ 1.682065] 8 sunxipart partitions found on MTD device spif
[ 1.688330] Creating 8 MTD partitions on "spif":
[ 1.693509] 0x000000000000-0x000000200000 : "uboot"
[ 1.705812] 0x000000200000-0x000000220000 : "boot-resource"
[ 1.715786] 0x000000220000-0x000000240000 : "env"
[ 1.725759] 0x000000240000-0x0000007e0000 : "boot"
[ 1.735748] 0x0000007e0000-0x000001070000 : "rootfs"
[ 1.741320] mtd: partition "rootfs" extends beyond the end of device "spif" -- size truncated to 0x820000
[ 1.755729] 0x000001070000-0x000001080000 : "private"
[ 1.761395] mtd: partition "private" is out of reach -- disabled
[ 1.775746] 0x000001080000-0x000001100000 : "rootfs_data"
[ 1.781802] mtd: partition "rootfs_data" is out of reach -- disabled
[ 1.795719] 0x000001100000-0x0000011fc000 : "UDISK"
[ 1.801188] mtd: partition "UDISK" is out of reach -- disabled
[ 1.815740] sunxi:sunxi_spif-2800000.spif:[INFO]: probe succeed (Version 2.0.0)
[ 1.824840] sunxi:g2d_sunxi:[INFO]: [G2D]: current_thread_id=0
[ 1.831513] sunxi:g2d_sunxi:[INFO]: [G2D]: rcq version initialized.major:242
[ 1.839432] sunxi:g2d_sunxi:[INFO]: [G2D]: g2d_module_init
[ 1.845593] [drm] [DSI-PANEL] panel_dsi_init start
[ 1.851097] [drm] [DSI-PANEL] dsi driver regsiter finsh
[ 1.857666] [drm] [PHY] sunxi_dsi_combophy_probe start
[ 1.863790] [drm] [PHY]sunxi_dsi_combophy_probe finish
[ 1.870328] [drm] sunxi_drm_platform_probe start
[ 1.875533] [drm] sunxi_drm_match_add start
[ 1.881185] [drm] sunxi_drm_match_add finish
[ 1.886021] [drm] sunxi_drm_bind start
[ 1.890567] sunxi-drm soc@3000000:sunxi-drm: bound 5507000.phy (ops sunxi_cphy_component_ops)
[ 1.900160] [drm:sunxi_drm_bind] *ERROR* connector conut zero
[ 1.906615] [drm:sunxi_drm_bind] *ERROR* setup bootloader connecting failed.Skip commit_init_connecting.
[ 1.917546] [drm] Initialized sunxi-drm 3.0.0 20230901 for soc@3000000:sunxi-drm on minor 0
[ 1.926946] [drm] sunxi_drm_bind ok
[ 1.931900] awphy u2-phy0: init awphy sysfs for u2-phy0, ret: 0
[ 1.938671] awphy u2-phy1: init awphy sysfs for u2-phy1, ret: 0
[ 1.945339] sunxi-plat-awphy 4100000.phy: Allwinner USB2.0 PHY Version v1.0.0
[ 1.953449] sunxi:gpadc:[INFO]: sunxi_gpadc_init(): 2349: gpadc class register success
[ 1.963260] input: sunxi-rtp as /devices/platform/soc@3000000/208c000.rtp/input/input0
[ 1.972739] sunxi_dram_info module loaded
[ 1.979232] vdd_cpu: supplied by regulator-dummy
[ 1.985055] sunxi:sunxi_sid:[ERR]: Fail to read 'dvfs2_ori' in dts
[ 1.993420] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.003451] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000)
[ 2.011613] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.021604] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000)
[ 2.029771] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.039759] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000)
[ 2.047907] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.057901] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
[ 2.066048] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.076035] cpu cpu0: _opp_add: OPP not supported by regulators (1464000000)
[ 2.084060] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.094049] cpu cpu0: _opp_add: OPP not supported by regulators (1512000000)
[ 2.102089] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.112054] cpu cpu0: _opp_add: OPP not supported by regulators (1560000000)
[ 2.120128] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.130092] cpu cpu0: _opp_add: OPP not supported by regulators (1608000000)
[ 2.138151] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.148116] cpu cpu0: _opp_add: OPP not supported by regulators (1704000000)
[ 2.156162] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[ 2.166124] cpu cpu0: _opp_add: OPP not supported by regulators (1752000000)
[ 2.174235] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.181441] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.188586] cpu cpu0: _set_opp_voltage: failed to set voltage (1100000 1100000 1100000 mV): -19
[ 2.198402] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.205565] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.212691] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
[ 2.222186] cpufreq: __target_index: Failed to change cpu frequency: -19
[ 2.229797] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.236984] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.237342] ATF no support L3 cache partition, please check or update
[ 2.244114] cpu cpu0: _set_opp_voltage: failed to set voltage (1100000 1100000 1100000 mV): -19
[ 2.252018] NET: Registered protocol family 10
[ 2.261146] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.267252] Segment Routing with IPv6
[ 2.273244] sunxi:pwmcs-20a0000.pwmcs0:[ERR]: can't parse pwm device
[ 2.277411] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.284454] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
[ 2.291633] NET: Registered protocol family 17
[ 2.300560] cpufreq: __target_index: Failed to change cpu frequency: -19
[ 2.313123] NET: Registered protocol family 15
[ 2.318125] can: controller area network core
[ 2.323113] NET: Registered protocol family 29
[ 2.328116] can: raw protocol
[ 2.331443] can: broadcast manager protocol
[ 2.336171] can: netlink gateway - max_hops=1
[ 2.341229] Registering SWP/SWPB emulation handler
[ 2.370932] sunxi:sound-common:[WARN]: 326 pacfg_level_trig_init(): pa-pin-msleep1-0 get failed, default 0
[ 2.382107] sunxi:sound-aa:[WARN]: 110 sunxi_aaudio_parse_dma_param(): capture-cma missing, using default value
[ 2.393447] sunxi:sound-aa:[WARN]: 132 sunxi_aaudio_parse_dma_param(): rx-fifo-size miss,using default value
[ 2.404476] sunxi:sound-aa:[WARN]: 166 sunxi_aaudio_parse_dma_param(): adc-txdata miss, no aaudio platform
[ 2.416259] sunxi:sound-mach:[WARN]: 372 asoc_simple_parse_ucfmt(): set data late to default
[ 2.426166] debugfs: Directory 'soc@3000000:codec_plat' with parent 'audiocodec' already present!
[ 2.438044] sunxi-ehci 4300000.ehci1-controller: supply hci not found, using dummy regulator
[ 2.447762] sunxi-ehci 4300000.ehci1-controller: EHCI Host Controller
[ 2.455020] sunxi-ehci 4300000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.464954] sunxi-ehci 4300000.ehci1-controller: irq 55, io mem 0x04300000
[ 2.494913] sunxi-ehci 4300000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.502895] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.512185] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.520292] usb usb1: Product: EHCI Host Controller
[ 2.525771] usb usb1: Manufacturer: Linux 5.10.198 ehci_hcd
[ 2.532016] usb usb1: SerialNumber: sunxi-ehci
[ 2.537512] hub 1-0:1.0: USB hub found
[ 2.541745] hub 1-0:1.0: 1 port detected
[ 2.548059] sunxi-ohci 4300400.ohci1-controller: supply hci not found, using dummy regulator
[ 2.557731] sunxi-ohci 4300400.ohci1-controller: OHCI Host Controller
[ 2.564988] sunxi-ohci 4300400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.574858] sunxi-ohci 4300400.ohci1-controller: irq 56, io mem 0x04300400
[ 2.649062] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.658346] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.666456] usb usb2: Product: OHCI Host Controller
[ 2.671922] usb usb2: Manufacturer: Linux 5.10.198 ohci_hcd
[ 2.678176] usb usb2: SerialNumber: sunxi-ohci
[ 2.683617] hub 2-0:1.0: USB hub found
[ 2.687866] hub 2-0:1.0: 1 port detected
[ 2.693894] sunxi_usb_udc 4200000.udc-controller: sunxi:sunxi_usb_udc UDC Inner DMA Feature - wordaddr: 1, extend: enabled
[ 2.706888] clk: Not disabling unused clocks
[ 2.711682] ALSA device list:
[ 2.715024] #0: audiocodec
[ 2.720971] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[ 2.730289] Freeing unused kernel memory: 1024K
[ 2.775088] Run /init as init process
[ 2.779192] with arguments:
[ 2.782513] /init
[ 2.785073] with environment:
[ 2.788589] HOME=/
[ 2.791228] TERM=linux
[ 2.794257] partitions=boot-resource@mtdblock1:env@mtdblock2:boot@mtdblock3:rootfs@mtdblock4:private@mtdblock5:rootfs_data@mtdblock6:UDISK@mtdblock7
[ 2.809566] snum=
[ 2.812108] ion_carveout_list=
[ 2.815928] boot_type=3
[ 2.819055] uboot_message=2023.04-rc4
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [ 4.002683] udevd[96]: starting version 3.2.11
[ 4.035760] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.043239] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.050629] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.102917] udevd[96]: specified group 'input' unknown
[ 4.109743] udevd[96]: specified group 'kvm' unknown
[ 4.145298] udevd[97]: starting eudev-3.2.11
done
/etc/init.d/S20mdev: line 6: /proc/sys/kernel/hotplug: No such file or directory
create /dev/sda
mkdir: can't create directory '/mnt/usb/': Read-only file system
mount: mounting /dev/sda on /mnt/usb/sda failed: No such file or directory
/etc/mdev/do_mount: line 4: mount.ntfs-3g: command not found
mkdir /mnt/usb/sda
mkdir: can't create directory '/mnt/usb/sda': No such file or directory
/etc/mdev/do_mount: line 11: mount.exfat: command not found
Saving random seed: SKIP (read-only file system detected)
usb0 current mode:
Starting adb: mkdir: can't create directory '/system/': Read-only file system
ln: /system/bin/sh: No such file or directory
[ 5.902097] file system registered
OK
init adb main
[ 5.945276] read descriptors
Handling main()
[ 5.949199] read strings
/etc/init.d/S50powerkey_display: line 12: powerkey_display: command not found
/etc/init.d/S50powerkey_suspend: line 12: powerkey_suspend: command not found
Starting telnetd: OK
[ 6.064532] blk_update_request: I/O error, dev mtdblock7, sector 0 op 0x0:(READ) flags 0x800 phys_seg 1 prio class 0
[ 6.076416] SQUASHFS error: Failed to read block 0x0: -5
[ 6.082378] unable to read squashfs_super_block
formating /dev/by-name/UDISK to jffs2...
/etc/partition_op.sh: line 34: mkfs.jffs2: command not found
dd: can't open '/tmp/jffs2.img': No such file or directory
[ 6.176455] Too few erase blocks (0)
mount: mounting /dev/by-name/UDISK on /mnt/UDISK failed: Invalid argument
[ 6.285040] sunxi_usb_udc 4200000.udc-controller: supply udc not found, using dummy regulator
Welcome to Allwinner Tina5.0 Platform
Tina5.0 login: root
#异常烧录日志:
[736]fes begin commit:{0a84c8b0}
[740][pmu]: bus read error
[743]set pll start
[744]set pll end
[746]dram para13 invalid use default para
[750]vaild para:1 select dram para0
[753]ic board init ok
[755]beign to init dram
[757]DRAM BOOT DRIVE INFO: V0.21
[760]DRAM use external ZQ
[930][AUTO DEBUG] 16bit, 1 rank training success
[991][AUTO DEBUG] row = 14, col = 10, bank = 3, bg = 0
[996][AUTO DEBUG] para1 = 0x30ea, para2 = 0x1, tpr13 = 0x8207071
[1002][SOFT TRAINING] Version: T2.5
[1005]Soft Training Version: T2.5
[1008][SOFT TRAINING] Dram Soft Training Loop1
[1247][SOFT TRAINING] Stable test, dram_clk=480,dram_tpr12=0x13131313,memtest pass
[1281][SOFT TRAINING] Start rdq vref training
[3373][SOFT TRAINING] Highest r vref: 0x4-0x78, high=0x76(766mV), delay=31
[3380][SOFT TRAINING] Max Vref=0x3e, Widest vref is 0x24~0x5c, center=0x40
[3387][SOFT TRAINING] After rdq00 vref training, dram_add[16] = 0x40404040
[3393][SOFT TRAINING] Start rdq vref training
[4289][SOFT TRAINING] Highest r vref: 0x4-0x7a, high=0x78(779mV), delay=29
[4295][SOFT TRAINING] Max Vref=0x38, Widest vref is 0x24~0x58, center=0x3e
[4302][SOFT TRAINING] After rdq01 vref training, dram_add[16] = 0x40403e40
[4309][SOFT TRAINING] Start rdq 1st training
[4328][SOFT TRAINING] Dbyte0 rdq 1st dqs_move:0,range: 0x10~0x23,width=20,center=0x19
[4385][SOFT TRAINING] Dbyte1 rdq 1st dqs_move:0,range: 0xc~0x23,width=24,center=0x17
[4393][SOFT TRAINING] After rdq 1st training, dram_tpr12 = 0x00001719
[4399][SOFT TRAINING] Start wdq vref training
[5872][SOFT TRAINING] Highest w vref: 0x4-0x7c, high=0x7c(1469mV), delay=148
[5879][SOFT TRAINING] Max vref=0x10, Widest vref is 0x4~0x20, center=0x12
[5886][SOFT TRAINING] After wdq vref training, para->dram_add[17] = 0x92
[5907][SOFT TRAINING] Start wdq 1st training
[5933][SOFT TRAINING] Dbyte0 wdq dqs_move:0,range: 0x88~0xa1,width=26,center=0x94
[5968][SOFT TRAINING] Dbyte1 wdq dqs_move:0,range: 0x8c~0xa1,width=22,center=0x96
[5976][SOFT TRAINING] After wdq 1st training, dram_tpr11 = 0x00009694
[5982][SOFT TRAINING] Start rdq 2nd training
[6535][SOFT TRAINING] After rdq 2nd training, dram_tpr12 = 0x00001719
[6541][SOFT TRAINING] After rdq 3th training, dram_tpr12 = 0x00001719
[6548][SOFT TRAINING] Start wdq 2nd training
[7145][SOFT TRAINING] After wdq 2nd training, dram_tpr11 = 0x00009694
[7151][SOFT TRAINING] After wdq 3th training, dram_tpr11 = 0x00009694
[7157][SOFT TRAINING] dram_add[16]=0x40403e40,tpr11=0x00009694,tpr12=0x00001719
[7190][SOFT TRAINING] CLK=933M Stable memtest pass
[7195]DRAM CLK = 933 MHz
[7197]DRAM Type = 3 (3:DDR3,4:DDR4)
[7227]DRAM SIZE = 256 MBytes, para1 = 30ea, para2 = 1000001, dram_tpr13 = 8207071
[7236]DRAM simple test OK.
[7238]rtc[7] value = 0x6
[7241]init dram ok
[11.118]ns16550_serial serial@2600000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2023.04-rc4 (Aug 06 2026 - 15:20:32 +0800) Allwinner Technology
U-Boot bsp (Aug 06 2026 - 15:20:32 +0800) Allwinner Technology
Model: sun8iw22
DRAM: 256 MiB
[11.149]Relocation Offset is: 0c928000
Working FDT set to 4de20310
[11.230]secure enable bit: 0
[11.233]CPU=1008MHz, PLL6=600Mhz, AHB=200Mhz, APB1=100Mhz, MBus=480Mhz
[11.239]workmode = 16,storage type = nand
[11.243][mmc]: mmc driver ver uboot2023:2025-04-02 14:45:00
[11.250][mmc]: get sdc_type fail and use default host:tm4.
[11.256][mmc]: Is not Boot mode!
[11.258][mmc]: SUNXI SDMMC Controller Version:0x50530
[11.266][mmc]: 200 MHz...
[11.268][mmc]: sample: 17 - 147(ps)
[11.272][mmc]: ds: 17 - 147(ps)
[11.274]set_sunxi_flash_curdev...45:cur_sunxi_flash :mmc@04022000.sunxi_flash
[11.287][mmc]: mmc 2 cmd timeout 100 status 100
[11.292][mmc]: smc 2 err, cmd 8, RTO
[11.295][mmc]: mmc 2 close bus gating and reset
[11.300][mmc]: mmc 2 cmd timeout 100 status 100
[11.304][mmc]: smc 2 err, cmd 55, RTO
[11.308][mmc]: mmc 2 close bus gating and reset
[11.316][mmc]: mmc 2 cmd timeout 100 status 100
[11.320][mmc]: smc 2 err, cmd 1, RTO
[11.323][mmc]: mmc 2 close bus gating and reset
[11.328]Card did not respond to voltage select! : -110
[11.333]try emmc fail
[11.334]Invalid bus 0 (err=-19)
[11.337]spinand flash probe error
[11.340]try ubi nand fail
[11.344]sunxi-spif spif@2800000: frequency no in range, use default value 150000000
[11.352]sunxi-spif spif@2800000: sample_mode:aaaaffff sample_delay:aaaaffff
[11.368]sunxi-spif spif@2800000: probe succeed (Version 1.0.0)
[11.374]sunxi-spif spif@2800000: sspi->mode:0x2400 mode:0x0
[11.397]sunxi-spif spif@2800000: spif sspi->speed_hz:50000000
[11.794]sunxi-spif spif@2800000: spif update delay param error
[11.799]sunxi-spif spif@2800000: Sample mode:0 start:0 end:0 sample_delay:0xaaaaffff
[11.826]sunxi-spif spif@2800000: sunxi_spif_release_bus()
[11.831]set_sunxi_flash_curdev...45:cur_sunxi_flash :spif-nor.sunxi_flash
Core: 164 devices, 26 uclasses, devicetree: separate
MMC: SUNXI SD/MMC: 0
[11.854]Loading Environment from SUNXI_FLASH... [11.858]OK
In: serial
Out: serial
Err: serial
Net: [11.864]No ethernet found.
sunxi work mode=0x10
[11.872]request gpio for led failed (-2)
run usb efex
buf queue page size = 65536
usb init ok
set address 0xd
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x12
origin_erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
*************MBR DUMP***************
total mbr part 7
part[0] name :boot-resource
part[0] classname :DISK
part[0] addrlo :0x20
part[0] lenlo :0x100
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] classname :DISK
part[1] addrlo :0x120
part[1] lenlo :0x100
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] name :boot
part[2] classname :DISK
part[2] addrlo :0x220
part[2] lenlo :0x2d00
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :rootfs
part[3] classname :DISK
part[3] addrlo :0x2f20
part[3] lenlo :0x4480
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] name :private
part[4] classname :DISK
part[4] addrlo :0x73a0
part[4] lenlo :0x80
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :rootfs_data
part[5] classname :DISK
part[5] addrlo :0x7420
part[5] lenlo :0x400
part[5] user_type :32768
part[5] keydata :0
part[5] ro :0
part[6] name :UDISK
part[6] classname :DISK
part[6] addrlo :0x7820
part[6] lenlo :0x0
part[6] user_type :0
part[6] keydata :0
part[6] ro :0
need erase flash: 18
[14.843]Item0 (Map) magic is bad
[14.847]erase secure storage: 0 ok
SUNXI_EFEX_MBR_TAG
mbr size = 0x4000
[14.853]logic size : 0x7820 sector(512 byte)
[14.857]flash size : 0x8000 sector(512 byte)
SF: write offset not multiple of erase size
[14.879]write primary GPT success
[14.882]spinor: skip backup GPT
[14.885]update partition map
FEX_CMD_fes_verify_value, start 0x120, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0x6ec2fd82这个是正常板子的烧录日志:
[837]fes begin commit:{0a84c8b0}
[841][pmu]: bus read error
[844]set pll start
[846]set pll end
[847]dram para13 invalid use default para
[851]vaild para:1 select dram para0
[854]ic board init ok
[857]beign to init dram
[859]DRAM BOOT DRIVE INFO: V0.21
[862]DRAM use external ZQ
[1031][AUTO DEBUG] 16bit, 1 rank training success
[1093][AUTO DEBUG] row = 14, col = 10, bank = 3, bg = 0
[1098][AUTO DEBUG] para1 = 0x30ea, para2 = 0x1, tpr13 = 0x8207071
[1104][SOFT TRAINING] Version: T2.5
[1107]Soft Training Version: T2.5
[1110][SOFT TRAINING] Dram Soft Training Loop1
[1349][SOFT TRAINING] Stable test, dram_clk=480,dram_tpr12=0x13131313,memtest pass
[1383][SOFT TRAINING] Start rdq vref training
[3459][SOFT TRAINING] Highest r vref: 0x6-0x78, high=0x74(753mV), delay=31
[3466][SOFT TRAINING] Max Vref=0x40, Widest vref is 0x24~0x62, center=0x43
[3473][SOFT TRAINING] After rdq00 vref training, dram_add[16] = 0x40404043
[3480][SOFT TRAINING] Start rdq vref training
[4331][SOFT TRAINING] Highest r vref: 0x6-0x78, high=0x74(753mV), delay=29
[4338][SOFT TRAINING] Max Vref=0x36, Widest vref is 0x2a~0x50, center=0x3d
[4345][SOFT TRAINING] After rdq01 vref training, dram_add[16] = 0x40403d43
[4352][SOFT TRAINING] Start rdq 1st training
[4373][SOFT TRAINING] Dbyte0 rdq 1st dqs_move:0,range: 0x10~0x25,width=22,center=0x1a
[4427][SOFT TRAINING] Dbyte1 rdq 1st dqs_move:0,range: 0xe~0x23,width=22,center=0x18
[4434][SOFT TRAINING] After rdq 1st training, dram_tpr12 = 0x0000181a
[4441][SOFT TRAINING] Start wdq vref training
[5876][SOFT TRAINING] Highest w vref: 0x4-0x7c, high=0x7c(1469mV), delay=148
[5883][SOFT TRAINING] Max vref=0x8, Widest vref is 0x4~0x24, center=0x14
[5890][SOFT TRAINING] After wdq vref training, para->dram_add[17] = 0x94
[5912][SOFT TRAINING] Start wdq 1st training
[5938][SOFT TRAINING] Dbyte0 wdq dqs_move:0,range: 0x88~0xa1,width=26,center=0x94
[5968][SOFT TRAINING] Dbyte1 wdq dqs_move:0,range: 0x8a~0xa1,width=24,center=0x95
[5975][SOFT TRAINING] After wdq 1st training, dram_tpr11 = 0x00009594
[6535][SOFT TRAINING] After rdq 2nd training, dram_tpr12 = 0x0000181a
[6542][SOFT TRAINING] After rdq 3th training, dram_tpr12 = 0x0000181a
[7136][SOFT TRAINING] After wdq 2nd training, dram_tpr11 = 0x00009594
[7142][SOFT TRAINING] After wdq 3th training, dram_tpr11 = 0x00009594
[7148][SOFT TRAINING] dram_add[16]=0x40403d43,tpr11=0x00009594,tpr12=0x0000181a
[7182][SOFT TRAINING] CLK=933M Stable memtest pass
[7186]DRAM CLK = 933 MHz
[7189]DRAM Type = 3 (3:DDR3,4:DDR4)
[7219]DRAM SIZE = 256 MBytes, para1 = 30ea, para2 = 1000001, dram_tpr13 = 8207071
[7228]DRAM simple test OK.
[7230]rtc[7] value = 0x1
[7232]init dram ok
[11.095]ns16550_serial serial@2600000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
Model: sun8iw22
DRAM: 256 MiB
[11.126]Relocation Offset is: 0c928000
[11.207]secure enable bit: 0
[11.209]CPU=1008MHz, PLL6=600Mhz, AHB=200Mhz, APB1=100Mhz, MBus=480Mhz
[11.216]workmode = 16,storage type = nand
[11.220][mmc]: mmc driver ver uboot2023:2025-04-02 14:45:00
[11.227][mmc]: get sdc_type fail and use default host:tm4.
[11.232][mmc]: Is not Boot mode!
[11.235][mmc]: SUNXI SDMMC Controller Version:0x50530
[11.243][mmc]: 200 MHz...
[11.245][mmc]: sample: 17 - 147(ps)
[11.248][mmc]: ds: 17 - 147(ps)
[11.251]set_sunxi_flash_curdev...45:cur_sunxi_flash :mmc@04022000.sunxi_flash
[11.264][mmc]: mmc 2 cmd timeout 100 status 100
[11.268][mmc]: smc 2 err, cmd 8, RTO
[11.272][mmc]: mmc 2 close bus gating and reset
[11.277][mmc]: mmc 2 cmd timeout 100 status 100
[11.281][mmc]: smc 2 err, cmd 55, RTO
[11.284][mmc]: mmc 2 close bus gating and reset
[11.293][mmc]: mmc 2 cmd timeout 100 status 100
[11.297][mmc]: smc 2 err, cmd 1, RTO
[11.300][mmc]: mmc 2 close bus gating and reset
[11.305]Card did not respond to voltage select! : -110
[11.309]try emmc fail
[11.311]Invalid bus 0 (err=-19)
[11.314]spinand flash probe error
[11.317]try ubi nand fail
[11.321]sunxi-spif spif@2800000: frequency no in range, use default value 150000000
[11.328]sunxi-spif spif@2800000: sample_mode:aaaaffff sample_delay:aaaaffff
[11.345]sunxi-spif spif@2800000: probe succeed (Version 1.0.0)
[11.350]sunxi-spif spif@2800000: sspi->mode:0x2400 mode:0x0
[11.880]sunxi-spif spif@2800000: spif sspi->speed_hz:50000000
[12.319]sunxi-spif spif@2800000: Sample mode:0 start:0 end:63 sample_delay:0x1f
[12.991]sunxi-spif spif@2800000: sunxi_spif_release_bus()
[12.996]set_sunxi_flash_curdev...45:cur_sunxi_flash :spif-nor.sunxi_flash
Core: 171 devices, 27 uclasses, devicetree: separate
[13.020]Loading Environment from SUNXI_FLASH... [13.024]OK
In: serial
Out: serial
Err: serial
Net: [13.030]No ethernet found.
[13.038]request gpio for led failed (-2)
run usb efex
usb init ok
set address 0x14
erase_flag = 0x12
total mbr part 7
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] keydata :0
part[1] ro :0
part[2] name :boot
part[2] keydata :0
part[2] ro :0
part[3] keydata :0
part[3] ro :0
part[4] lenlo :0x80
part[4] keydata :0
part[4] ro :0
part[5] keydata :0
part[5] ro :0
part[6] name :UDISK
part[6] lenlo :0x0
part[6] keydata :0
part[6] ro :0
[16.012]Item0 (Map) magic is bad
[16.015]erase secure storage: 0 ok
SUNXI_EFEX_MBR_TAG
mbr size = 0x4000
[16.021]logic size : 0x7820 sector(512 byte)
[16.025]flash size : 0x8000 sector(512 byte)
[16.302]write primary GPT success
[16.305]spinor: skip backup GPT
[16.308]update partition map
FEX_CMD_fes_verify_value 0xf29ba354
FEX_CMD_fes_verify_value, start 0x220, size high 0x0:low 0x54d000
FEX_CMD_fes_verify_value 0x8b6d1230
FEX_CMD_fes_verify_value, start 0x2f20, size high 0x0:low 0x503000
FEX_CMD_fes_verify_value 0x1e18c8cc
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0x1ac000, max size = 0x400000
[17.474]uboot size = 0x1ac000
[17.477]storage type = 3
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0x10000
[17.918]storage type = 3
boot_info->frequency:2faf080
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
......离线
@晕哥
实在不行就直接换个nand试试
