地址: svn://oslife.top/f1c100s/release/bootloader/u-boot
地址: svn://release.lenrek.cn/f1c100s/release/bootloader/u-boot
账号: user
密码: userpasswd
svn命令下载:
svn checkout svn://oslife.top/f1c100s/release/bootloader/u-boot --username user
svn checkout svn://release.lenrek.cn/f1c100s/release/bootloader/u-boot --username user然后输入密码: userpasswd 即可!
2019-06-08 修改:
域名改为: release.lenrek.cn
2019-06-13 更新:
源码本站打包下载: u-boot-lenrek.tgz
这个u-boot 支持 spi nand
这个目录下面 svn://oslife.top/f1c100s/release 有一个sunxi-fel 二进制可执行文件支持spi nand
linux4.19 直接支持 spi nand: https://whycan.cn/t_1672.html#p10579
晕哥,尝试编译完的,烧录到tf卡进去未果......
首先将百度网盘Nano_pub_V4/image里的Nano_tf_800480.dd烧进tf卡,测试可以启动。
然后将我编译好的u-boot-sunxi-with-spl.bin
sudo dd if=/dev/zero of=/dev/sdb bs=1024 seek=8 count=512
sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdb bs=1024 seek=8
sync
插上TF卡,启动效果如下:只有三行..就停住了
U-Boot SPL 2018.01-svn89 (Nov 06 2018 - 21:25:01)
DRAM: 32 MiB
Trying to boot from sunxi SPI
不会上传图片....用文字吧
还有使用sunxi-fel直接ram中运行uboot。
sudo sunxi-fel uboot u-boot-sunxi-with-spl.bin
串口信息如下
DRAM: 32 MiB
Trying to boot from FEL
U-Boot 2018.01-svn89 (Nov 06 2018 - 21:25:01 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SPI-NAND type mfr_id: ef, dev_id: aa is not in id table.
SPI-NAND: W25N01GV is found.
*** Warning - spi_flash_read() failed, using default environment
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
SPI-NAND: 2490368 bytes @ 0x80000 Read: ERROR
Unknown command 'sf' - try 'help'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
上面这个 id 没有在 flash id 数组里面, 你添加一下,重新编译看下效果.
发图片的方法: https://whycan.cn/t_588.html
打开 u-boot/drivers/mtd/spi-nand/spi-nand-base.c
static struct spi_nand_flash spi_nand_table[] = {
SPI_NAND_INFO("GD5F1GQ4UAYIG", 0xC8, 0xF1, 2048, 64, 64, 1024,
1, 1, 0 | SPINAND_USED_GIGADEVICE),
SPI_NAND_INFO("GD5F1GQ4UBYIG", 0xC8, 0xD1, 2048, 64, 64, 1024,
SPI_NAND_INFO("MT29F2G01AAAED", 0x2C, 0x22, 2048, 64, 64, 2048,
1, 1, SPINAND_NEED_PLANE_SELECT),
SPI_NAND_INFO("MT29F4G01AAADD", 0x2C, 0x32, 2048, 64, 64, 4096,
SPI_NAND_INFO("MT29F4G01ABAGD", 0x2C, 0x36, 2048, 128, 64, 2048,
2, 8, SPINAND_NEED_PLANE_SELECT | SPINAND_NEED_DIE_SELECT),
SPI_NAND_INFO("MT29F2G01ABAGD", 0x2C, 0x24, 2048, 128, 64, 2048,
1, 8, SPINAND_NEED_PLANE_SELECT),
{.name = NULL},
在这里修改.
填写完毕:效果如下:
https://whycan.cn/files/members/1228/1.png
重新将编译好的uboot使用sunxi-fel在ram中运行
效果如下,可以识别到了,但CRC错误...
https://whycan.cn/files/members/1228/2.png
将uboot烧到spi nand里或tf卡里,和上面是一样的
迪卡 说:填写完毕:效果如下:
https://whycan.cn/files/members/1228/2.png将uboot烧到spi nand里或tf卡里,和上面是一样的
是的, 你还没有去写环境变量(u-boot执行saveenv命令),
所以u-boot读不到数据和CRC校验值,
所以显示一个警告而已。
就当没看到好了。
把生成的u-boot-sunxi-with-spl.bin烧写进tf卡
sync
上电效果如上图,还有用sunxi-fel烧进spi nand也是如此,可以说明...brom刚开始的校验没过.....
这.....
https://whycan.cn/files/members/1228/3.png
sync上电效果如上图,还有用sunxi-fel烧进spi nand也是如此,可以说明...brom刚开始的校验没过.....
这.....
对比一下 W25N 和 GD 的区别改下源码,
建议先买 GD 的spi nand flash先测试.
Hello,
How can I download frc100s uboot and linux bsp. svn link gives error for me. Is there any alternatif download link ?
Thanks,
Regards..
这个svn似乎连不上啊,好像域名过期了 @晕哥
我试了,可以用
release.lenrek.cn
把域名替换一下,其他操作一样, @assert 断言哥的回复,我还没来得及测试
release.lenrek.cn
晕哥,这个uboot可以启动官方bsp linux是吧?
使用SPI Flash Boot是否还需要改写?
是否将编译出来的u-boot-sunxi-with-spl.bin文件直接替换掉BSP Linux这个路径下面的C600_Linux\tools\pack\chips\sunivw1p1\bin\u-boot-spinor-sunivw1p1.bin?
谢谢!
我试了编译出来的u-boot-sunxi-with-spl.bin替换掉BSP Linux这个路径下面的C600_Linux\tools\pack\chips\sunivw1p1\bin\u-boot-spinor-sunivw1p1.bin后u-boot没有起来。
thanks.
晕哥 你修改过的sunxi-tool支持GD spi nand flash的源码能否提供参考一下,谢谢.
这个uboot和主线uboot有什么区别?
就是从主线u-boot改的, 支持spi nand启动.
感觉各位大佬的分享,虽然还无法通过sunxi-fel直接写入spi nand但可以通过内存写入,目前W25N01G 128MB spi nandflash uboot启动成功
源码及记录分享链接: https://github.com/hcly/f1c100s
这个更吊,围观
@晕哥,请问这个uboot能引导主线linux吗?我试了会卡在"Starting kernel...",不知道是要改uboot还是改kernel,能指点一下吗?谢谢!
晕哥,在spi-flash上用主线uboot+主线linux是没问题的,我现在用的是spi-nand,所以只能用这个改版的uboot,内核就起不来了。
那你参考这个V3s openwrt @spi nand帖子: https://whycan.cn/t_3123.html
代码在这里: https://github.com/bhorn/openwrt/tree/dolphinpi-spinand
谢谢晕哥,总算启动成功了,对比了spi-flash的uboot,发现uboot在把设备树传给kernel之前会添加memory的节点(我自己生成的dtb里面没有memory节点),而spi-nand的uboot不会给设备树添加这个节点,于是我在dtb里面添加上去就好了。虽然不知道为什么会有这个区别,折腾了好久,一直以为是kernel的问题。
我是在28楼的基础上进行调试的,也没修改太多东西:
1.设备树、内核、rootfs根据spi-nand的块大小对齐存放,也就是128K对齐;
2.设备树里面根据芯片容量和存放地址修改flash分区,并添加memory节点;
3.我用的是W25N01GV,发现uboot驱动中的“spi_nand_read_pages_fast”,接口读数据会出错,改用“spi_nand_read_pages”;
大概就这些,最重要的是想办法把数据写到spi nand里面,毕竟sunxi-fel是开源的,可以把uboot中的spi nand驱动及坏块管理移植上去。
收藏本帖,目前正在新增使用spi nand flash,启动引导主线Linux 4.19,各种学习中。。。
这个帖子更有参考价值: https://whycan.cn/t_3123.html
请问Trying to boot from sunxi SPI,这个问题解决了吗?
使用 https://github.com/hcly/f1c100s
这个可以了,注释GZYS_USBBURN的时候不用//,改用/**/
貌似是这个原因
