楼主 #1 2019-02-02 00:06:35
Freeboy
求助,编译S3 SDK烧录后不知道为什么内核挂了,提示Attempted to kill init! exitcode=0x0000000b
log1是修改了sys_config.fex中的flash型号编译的(w25q128),log2是烧录的s3 demo,看样子都是内核挂了。编程器读出flash实际只占用14MB左右,应该不会是没烧录完整,求助各位大神帮忙看看。
log1
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : c8e0a19bbff4496d5c9810791b445e7061801bb1
fel flag  = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x80000000
rtc[7] value = 0x00000118
i2c gpio config 22777722
axp209 read error
axp152 read error
DRAM DRIVE INFO: V0.9
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 696 MHz
DRAM zq value: 000039bb
DRAM size = 128 MB
dram size =128
Succeed in reading Boot1 file head.
The size of uboot is 00038000.
Ready to disable icache.
Jump to secend Boot.
[      0.773]
U-Boot 2011.09-rc1-00000-gc8e0a19-dirty (Dec 01 2017 - 15:08:10) Allwinner Techn        ology
[      0.782]version: 1.1.0
[      0.785]uboot commit : c8e0a19bbff4496d5c9810791b445e7061801bb1
[      0.795]pmbus:   ready
not set main pmu id
axp read error
probe axp20x failed
axp152 read error
probe axp15 failed
axp_probe error
[      1.409]PMU: pll1 408 Mhz,PLL6=600 Mhz
AXI=204 Mhz,AHB=204 Mhz, APB1=102 Mhz
set power on vol to default
dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
ldo4_vol = 1800
axp set ldo4_vol to 1800 failed
find power_sply to end
vbus exist
no battery, limit to dc
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      1.482]DRAM:  128 MiB
relocation Offset is: 076c1000
try gpio_flashing
workmode = 0
sunxi spinor is initing...[debug_jaosn]:use the clock in sys_config
OK
nor id is 0x1840ef
[      1.882]sunxi flash init ok
hello @flash_speed=1
In:    serial
Out:   serial
Err:   serial
-total partitions:7-
boot        : 4000          280000
system      : 284000        c83000
cfg         : f07000        40000
boot_logo   : f47000        20000
shutdown_logo: f67000        20000
env         : f87000        10000
UDISK       : f97000        0
WORK_MODE_BOOT
read bootlogo partition successful,start_block=0x7a38,rblock=0x100 ,ret=256
Use decode 1x1 sampling
sunxi_read_bootlogo: jpg convert argb
[      2.614]Hit any key to stop autoboot:  0
read boot or recovery all
[      2.796]sunxi flash read :offset 4000, 2621951 bytes OK
[      2.808]ready to boot
force sunxi spinor exit
[      2.810]
[    0.027846] axp20_board 0-0034: failed reading at 0x03
[    0.028684] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[    0.043880] Initramfs unpacking failed: compression method lzma not configure        d
[    0.180438] m25p_probe()966 - Use the Dual Mode Read.
[    0.200100] Failed to alloc md5
[    0.806720] sunxikbd_script_init: key para not found, used default para.
[    0.818214] [MIR3DA] fetch_sysconfig_para failed!
[    0.818225]
[    0.831106] Unhandled fault: imprecise external abort (0x1c06) at 0xc8bbc016
[    0.839134] Internal error: : 1c06 [#1] ARM
[    0.841024] Modules linked in:
[    0.841024] CPU: 0    Not tainted  (3.4.39 #1)
[    0.841024] PC is at radix_tree_lookup_element+0x48/0xac
[    0.841024] LR is at 0x2
[    0.841024] pc : [<c010aaf4>]    lr : [<00000002>]    psr: 20000013
[    0.841024] sp : c2827d8c  ip : 00000001  fp : c2827d9c
[    0.841024] r10: c04e5ac0  r9 : c04e5ac0  r8 : c04e56d0
[    0.841024] r7 : 05555555  r6 : 000000c0  r5 : c2851ec0  r4 : c04cc644
[    0.841024] r3 : c2405d08  r2 : 00000000  r1 : 000000c0  r0 : 00000fff
[    0.841024] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kern        el
[    0.841024] Control: 10c5387d  Table: 40004059  DAC: 00000015
[    0.841024]
[    0.841024] PC: 0xc010aa74:
[    0.841024] aa74  e2800008 e5932008 e0850000 e2422001 e1a04214 ebffff0e e5913        000 e5893000
[    0.841024] aa94  e2443001 e7952206 e0022003 e0822004 e5872000 e89dabf0 e1a0c        00d e92dd810
[    0.841024] aab4  e24cb004 e1a03000 e5900008 e3500000 089da810 e210c001 1a000        004 e3510000
[    0.841024] aad4  1a000018 e3520000 12830008 e89da810 e3c03001 e59f0064 e593e        000 e790010e
[    0.841024] aaf4  e1510000 8a000011 e3a0c006 e00c0e9c e24cc006 e1a04c31 e2833        010 e204403f
[    0.841024] ab14  e0830104 e7933104 e3530000 0a000009 e25ee001 e24cc006 1afff        ff5 e3520000
[    0.841024] ab34  03c30001 e89da810 e1a0000c e89da810 e3a00000 e89da810 e1a00        003 e89da810
[    0.841024] ab54  c04b433c e1a0c00d e92dd800 e24cb004 e3a02001 ebffffcf e89da        800 e1a0c00d
[    0.841024]
[    0.841024] SP: 0xc2827d0c:
[    0.841024] 7d0c  c2827df4 c2a05883 c2a05885 c2a05880 c044d0e6 c010aaf4 20000        013 ffffffff
[    0.841024] 7d2c  c2827d74 c2827d9c c2827d40 c000d558 c0008330 00000fff 00000        0c0 00000000
[    0.841024] 7d4c  c2405d08 c04cc644 c2851ec0 000000c0 05555555 c04e56d0 c04e5        ac0 c04e5ac0
[    0.841024] 7d6c  c2827d9c 00000001 c2827d8c 00000002 c010aaf4 20000013 fffff        fff c0412ada
[    0.841024] 7d8c  c04cc644 c2827dac c2827da0 c010ab84 c010aab8 c2827dcc c2827        db0 c01214ec
[    0.841024] 7dac  c010ab7c c04cc644 000000c0 c284bb50 05555555 c2827df4 c2827        dd0 c01242e0
[    0.841024] 7dcc  c01214dc c2827e40 000000c0 000000c0 c2851ec0 000000c0 00010        003 c2827e14
[    0.841024] 7dec  c2827df8 c012243c c0124110 c2a08800 c04e56d0 c2a089c0 00000        001 c2827e74
[    0.841024]
[    0.841024] FP: 0xc2827d1c:
[    0.841024] 7d1c  c044d0e6 c010aaf4 20000013 ffffffff c2827d74 c2827d9c c2827        d40 c000d558
[    0.841024] 7d3c  c0008330 00000fff 000000c0 00000000 c2405d08 c04cc644 c2851        ec0 000000c0
[    0.841024] 7d5c  05555555 c04e56d0 c04e5ac0 c04e5ac0 c2827d9c 00000001 c2827        d8c 00000002
[    0.841024] 7d7c  c010aaf4 20000013 ffffffff c0412ada c04cc644 c2827dac c2827        da0 c010ab84
[    0.841024] 7d9c  c010aab8 c2827dcc c2827db0 c01214ec c010ab7c c04cc644 00000        0c0 c284bb50
[    0.841024] 7dbc  05555555 c2827df4 c2827dd0 c01242e0 c01214dc c2827e40 00000        0c0 000000c0
[    0.841024] 7ddc  c2851ec0 000000c0 00010003 c2827e14 c2827df8 c012243c c0124        110 c2a08800
[    0.841024] 7dfc  c04e56d0 c2a089c0 00000001 c2827e74 c2827e18 c024c1fc c0122        3c8 c044d220
[    0.841024]
[    0.841024] R3: 0xc2405c88:
[    0.841024] 5c88  c284d3c0 c284d380 c284d340 c284d300 c284d2c0 c284d280 c284d        240 c284d200
[    0.841024] 5ca8  c284d1c0 c284d180 c284d140 c2852fc0 c2852f80 c2852f40 c2852        f00 c2852ec0
[    0.841024] 5cc8  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5ce8  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5d08  00000002 00000004 00000000 00000000 c2405e30 c2405be0 c2405        ab8 c2405990
[    0.841024] 5d28  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5d48  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5d68  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024]
[    0.841024] R4: 0xc04cc5c4:
[    0.841024] c5c4  00000000 00000120 c041083e 00000000 c284bb50 f1c20800 00000        060 00000016
[    0.841024] c5e4  00000000 00000000 00000120 c0425cbc 00000000 c284bb50 f1c20        800 00000080
[    0.841024] c604  00000019 00000000 00000000 00000120 c0425cbf 00000000 c284b        b50 f1c20800
[    0.841024] c624  000000a0 00000007 00000000 00000000 00000120 c0425cc2 00000        000 c284bb50
[    0.841024] c644  f1c20800 000000c0 0000000e 00000001 00000000 00000031 c044e        0e5 c285bf00
[    0.841024] c664  c284bb50 00000020 c0425cc5 c04cdc14 00000021 c0425cc9 c04cd        bdc 00000022
[    0.841024] c684  c0425ccd c04cdbac 00000023 c0425cd1 c04cdb7c 00000024 c0425        cd5 c04cdb4c
[    0.841024] c6a4  00000025 c0425cd9 c04cdb1c 00000026 c0425cdd c04cdaec 00000        027 c0425ce1
[    0.841024]
[    0.841024] R5: 0xc2851e40:
[    0.841024] 1e40  c2851e00 c2851e80 c2851ec0 c2851e0c c2851e8c c284dfc0 00000        021 00000021
[    0.841024] 1e60  00000021 00000001 c284bb50 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 1e80  c2851e40 c284bb90 c2851ec0 c2851e4c c2851ed8 c284dfc0 00000        020 00000020
[    0.841024] 1ea0  00000020 00000001 c284bb50 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 1ec0  c285bdc0 c04cc2e0 c04cc504 00000002 000000d0 c2405d09 c2851        e8c c285364c
[    0.841024] 1ee0  c04cc390 00000000 c284bb50 c2852300 00000000 00000000 c2401        e18 00000000
[    0.841024] 1f00  c284dbc0 c2851f40 c018df20 00000000 c0425e21 c0425e25 c0425        e29 c0425e2d
[    0.841024] 1f20  c0425e31 c0425e35 04388083 07101b93 dc060084 062ef0b0 0c244        208 c8ada421
[    0.841024]
[    0.841024] R8: 0xc04e5650:
[    0.841024] 5650  000000a6 00000000 00000001 00000002 ffffffff 00000000 00000        000 00000000
[    0.841024] 5670  00000000 00000000 00000000 00000000 00000000 00000000 00000        001 00000000
[    0.841024] 5690  00000005 00000002 00000003 00000004 00000003 00000002 00000        004 00000004
[    0.841024] 56b0  00000002 00000004 00000005 00000001 00000004 00000006 00000        001 00000004
[    0.841024] 56d0  003f0000 0000000f 00000000 00000000 000249f0 02faf080 00000        000 20070008
[    0.841024] 56f0  00000000 00000000 00000000 00000000 10040401 000000c0 00000        002 00000001
[    0.841024] 5710  00000001 ffffffff 000000c1 00000002 00000001 00000001 fffff        fff 000000c2
[    0.841024] 5730  00000002 00000001 00000001 ffffffff 000000c3 00000002 00000        001 00000001
[    0.841024]
[    0.841024] R9: 0xc04e5a40:
[    0.841024] 5a40  c04e5540 00000000 00000002 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5a60  00000000 00000000 00000000 c04e5a6c c04e5a6c 00000000 00000        000 00000000
[    0.841024] 5a80  00000000 00000000 c04e5a88 c04e5a88 00000000 00000000 00000        000 00000000
[    0.841024] 5aa0  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 00000000
[    0.841024] 5ac0  c044d220 00000001 c04d7190 c29fe1c0 c2a05e00 c2a08c14 c04e5        a04 c04d7198
[    0.841024] 5ae0  c28108c0 c04d7058 c2a01208 00000003 00000007 00000000 00000        000 00000000
[    0.841024] 5b00  c04e5b00 c04e5b00 c04d7248 c04e5504 c04e56d0 00000000 00000        002 00000000
[    0.841024] 5b20  00000000 00000000 00000000 00000000 00000000 00000000 00000        000 c04e5b3c
[    0.841024]
[    0.841024] R10: 0xc04e5a40:
[    0.841024] Process swapper (pid: 1, stack limit = 0xc28262f0)
[    0.841024] Stack: (0xc2827d8c to 0xc2828000)
[    0.841024] 7d80:                            c04cc644 c2827dac c2827da0 c010a        b84 c010aab8
[    0.841024] 7da0: c2827dcc c2827db0 c01214ec c010ab7c c04cc644 000000c0 c284b        b50 05555555
[    0.841024] 7dc0: c2827df4 c2827dd0 c01242e0 c01214dc c2827e40 000000c0 00000        0c0 c2851ec0
[    0.841024] 7de0: 000000c0 00010003 c2827e14 c2827df8 c012243c c0124110 c2a08        800 c04e56d0
[    0.841024] 7e00: c2a089c0 00000001 c2827e74 c2827e18 c024c1fc c01223c8 c044d        220 c2a08dc0
[    0.841024] 7e20: c2a06f88 00000000 c2a01208 00000001 c04e5ac8 00000000 00000        000 00000000
[    0.841024] 7e40: 00304750 00000000 c2827e64 c04e5ac8 c04e5afc c051ccb4 c04e5        504 c04e54f0
[    0.841024] 7e60: c04e59f0 000000d0 c2827e84 c2827e78 c018cf9c c024c01c c2827        ea4 c2827e88
[    0.841024] 7e80: c018bf34 c018cf8c c04e5ac8 c04e5afc c04e5504 c04d7248 c2827        ec4 c2827ea8
[    0.841024] 7ea0: c018c11c c018be9c 00000000 c04e5504 c018c0ac c04d7248 c2827        eec c2827ec8
[    0.841024] 7ec0: c018a6c0 c018c0b8 c281c48c c29fe1f0 c0109128 c04e5504 c29fe        140 00000000
[    0.841024] 7ee0: c2827efc c2827ef0 c018babc c018a658 c2827f2c c2827f00 c018b        698 c018baa8
[    0.841024] 7f00: c044d220 00000003 c2827f2c c04e5504 00000000 c04e55c0 00000        003 c04e54f0
[    0.841024] 7f20: c2827f4c c2827f30 c018c494 c018b5bc 00000003 00000000 c04e5        5c0 00000003
[    0.841024] 7f40: c2827f5c c2827f50 c018d3b8 c018c3f8 c2827f8c c2827f60 c049c        15c c018d378
[    0.841024] 7f60: 00000000 00000007 c04f20c0 c2826000 c049c01c 00000000 c04f2        0c0 00000000
[    0.841024] 7f80: c2827fcc c2827f90 c00085d4 c049c028 00000006 00000006 00000        095 c0485ac8
[    0.841024] 7fa0: c0037664 00000007 00000095 00000007 00000095 c04f20c0 c04ab        6d4 c04a7750
[    0.841024] 7fc0: c2827ff4 c2827fd0 c048790c c0008540 00000006 00000006 c0487        228 00000000
[    0.841024] 7fe0: 00000000 00000013 00000000 c2827ff8 c001f350 c0487820 ee3d8        e24 a44276ec
[    0.841024] Backtrace:
[    0.841024] [<c010aaac>] (radix_tree_lookup_element+0x0/0xac) from [<c010ab84        >] (radix_tree_lookup+0x14/0x18)
[    0.841024]  r4:c04cc644
[    0.841024] [<c010ab70>] (radix_tree_lookup+0x0/0x18) from [<c01214ec>] (pin_        get_name+0x1c/0x48)
[    0.841024] [<c01214d0>] (pin_get_name+0x0/0x48) from [<c01242e0>] (sunxi_pin        conf_set+0x1dc/0x1e8)
[    0.841024]  r7:05555555 r6:c284bb50 r5:000000c0 r4:c04cc644
[    0.841024] [<c0124104>] (sunxi_pinconf_set+0x0/0x1e8) from [<c012243c>] (pin        _config_set+0x80/0xbc)
[    0.841024]  r7:00010003 r6:000000c0 r5:c2851ec0 r4:000000c0
[    0.841024] [<c01223bc>] (pin_config_set+0x0/0xbc) from [<c024c1fc>] (sunxi_m        ci_probe+0x1ec/0xea4)
[    0.841024]  r7:00000001 r6:c2a089c0 r5:c04e56d0 r4:c2a08800
[    0.841024] [<c024c010>] (sunxi_mci_probe+0x0/0xea4) from [<c018cf9c>] (platf        orm_drv_probe+0x1c/0x20)
[    0.841024] [<c018cf80>] (platform_drv_probe+0x0/0x20) from [<c018bf34>] (dri        ver_probe_device+0xa4/0x1d0)
[    0.841024] [<c018be90>] (driver_probe_device+0x0/0x1d0) from [<c018c11c>] (_        _driver_attach+0x70/0x94)
[    0.841024]  r7:c04d7248 r6:c04e5504 r5:c04e5afc r4:c04e5ac8
[    0.841024] [<c018c0ac>] (__driver_attach+0x0/0x94) from [<c018a6c0>] (bus_fo        r_each_dev+0x74/0x98)
[    0.841024]  r7:c04d7248 r6:c018c0ac r5:c04e5504 r4:00000000
[    0.841024] [<c018a64c>] (bus_for_each_dev+0x0/0x98) from [<c018babc>] (drive        r_attach+0x20/0x28)
[    0.841024]  r6:00000000 r5:c29fe140 r4:c04e5504
[    0.841024] [<c018ba9c>] (driver_attach+0x0/0x28) from [<c018b698>] (bus_add_        driver+0xe8/0x224)
[    0.841024] [<c018b5b0>] (bus_add_driver+0x0/0x224) from [<c018c494>] (driver        _register+0xa8/0x120)
[    0.841024]  r8:c04e54f0 r7:00000003 r6:c04e55c0 r5:00000000 r4:c04e5504
[    0.841024] [<c018c3ec>] (driver_register+0x0/0x120) from [<c018d3b8>] (platf        orm_driver_register+0x4c/0x60)
[    0.841024]  r7:00000003 r6:c04e55c0 r5:00000000 r4:00000003
[    0.841024] [<c018d36c>] (platform_driver_register+0x0/0x60) from [<c049c15c>        ] (sunxi_mci_init+0x140/0x15c)
[    0.841024] [<c049c01c>] (sunxi_mci_init+0x0/0x15c) from [<c00085d4>] (do_one        _initcall+0xa0/0x15c)
[    0.841024] [<c0008534>] (do_one_initcall+0x0/0x15c) from [<c048790c>] (kerne        l_init+0xf8/0x1a4)
[    0.841024]  r8:c04a7750 r7:c04ab6d4 r6:c04f20c0 r5:00000095 r4:00000007
[    0.841024] [<c0487814>] (kernel_init+0x0/0x1a4) from [<c001f350>] (do_exit+0        x0/0x644)
[    0.841024]  r7:00000013
[    0.841024] Code: e3c03001 e59f0064 e593e000 e790010e (e1510000)
[    2.126245] ---[ end trace 43667db9e44d542f ]---
[    2.131501] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00        00000b
[    2.131508]
log2
boot0 commit : 8
rtc[6] value = 0x00000000
rtc[7] value = 0x00000000
axp209 read error
axp152 read error
DRAM DRIVE INFO: V0.7
DRAM CLK = 800 MHz
DRAM size = 128 MB
dram size =128
[      0.725]
U-Boot 2011.09-rc1 (Apr 08 2017 - 19:50:24) Allwinner Technology
[      0.733]version: 1.1.0
[      0.735]uboot commit : 8
[      0.742]pmbus:   ready
not set main pmu id
axp read error
probe axp20x failed
axp152 read error
probe axp15 failed
axp_probe error
[      1.356]PMU: pll1 408 Mhz,PLL6=600 Mhz
dcdc2_vol = 1100
axp set dcdc2_vol to 1100 failed
dcdc3_vol = 3300
aldo2_vol = 2500
aldo3_vol = 3000
ldo1_vol = 3300
ldo2_vol = 3000
ldo3_vol = 3000
ldo4_vol = 1800
vbus exist
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
[      1.429]DRAM:  128 MiB
try gpio_flashing
workmode = 0
OK
nor id is 0x1940ef
[      1.828]sunxi flash init ok
In:    serial
Out:   serial
Err:   serial
boot        : 4000          280000
cfg         : f07000        40000
env         : f87000        10000
UDISK       : f97000        0
WORK_MODE_BOOT
[      2.560]Hit any key to stop autoboot:  0
[      2.742]sunxi flash read :offset 4000, 2621951 bytes OK
[      2.753]ready to boot
[      2.755]
[    0.000000] Linux version 3.4.39 (huangzhihua@srv3) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 Thu Nov 9 18:15:42 CST 2017
[    0.000000] Machine: sun8i
[    0.000000] Ignoring unrecognised tag 0x00000000
[    0.000000] Initialized persistent memory from 41d20800-41d307ff
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat c04f17c4, node_mem_map c058d000
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 32512 pages, LIFO batch:7
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 init=/init loglevel=8 partitions=boot@spinorp0:system@spinorp1:cfg@spinorp2:boot_logo@spinorp3:shutdown_logo@spinorp4:env@spinorp5:UDISK@spinorp6 mac_addr= uid=8882f574-3e53-45 kmemleak=on boot_type=3 fb_base=0x41b00000 config_size=49152
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 128MB = 128MB total
[    0.000000] Memory: 39788k/39788k available, 91284k reserved, 0K highmem
[    0.000000]     vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0487000   (4604 kB)
[    0.000000]       .init : 0xc0487000 - 0xc04ac000   ( 148 kB)
[    0.000000]       .data : 0xc04ac000 - 0xc04f2080   ( 281 kB)
[    0.000000]        .bss : 0xc04f20a4 - 0xc058c460   ( 617 kB)
[    0.000000] NR_IRQS:544
[    0.000000] 524 ahb1 set parent pll_periph0d2
[    0.000230] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000276] pid_max: default: 32768 minimum: 301
[    0.000530] Mount-cache hash table entries: 512
[    0.001308] CPU: Testing write buffer coherency: ok
[    0.001588] Setting up static identity map for 0x403623c8 - 0x403623fc
[    0.002556] devtmpfs: initialized
[    0.005723] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.005931] pinctrl core: initialized pinctrl subsystem
[    0.006612] NET: Registered protocol family 16
[    0.007262] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.007336] script_sysfs_init success
[    0.007395] sunxi_dump_init success
[    0.008800] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.010871] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.011345] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.012816] persistent_ram: uncorrectable error in header
[    0.012843] persistent_ram: no valid data in buffer (sig = 0xdc01892f)
[    0.030018] console [ram-1] enabled
[    0.031007] [sunxi-module]: [sunxi-module.0] probe success
[    0.031464] axp driver uning configuration failed(838)
[    0.031928] axp driver uning configuration failed(844)
[    0.032178] axp driver uning configuration failed(850)
[    0.032632] axp driver uning configuration failed(857)
[    0.033087] script config pll_isp to 360 Mhz
[    0.033361] Not Found clk pll_video in script
[    0.033827] script config pll_ve to 360 Mhz
[    0.034087] Not Found clk pll_periph0 in script
[    0.034540] Not Found clk pll_de in script
[    0.034785] sunxi_default_clk_init
[    0.035030] try to set pll6ahb1 to 200000000
[    0.035486] Error not get clk pll6ahb1
[    0.035743] Error not get clk pll6ahb1try to set ahb1 to 200000000
[    0.036244] try to set apb1 to 100000000
[    0.037208] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.044387] bio: create slab <bio-0> at 0
[    0.045213] pwm module init!
[    0.048211] SCSI subsystem initialized
[    0.048856] usbcore: registered new interface driver usbfs
[    0.049442] usbcore: registered new interface driver hub
[    0.049866] usbcore: registered new device driver usb
[    0.050236] twi_chan_cfg()341 - [twi0] has no twi_speed!
[    0.050495] twi_chan_cfg()352 - [twi0] has no twi_regulator.
[    0.050957] twi_chan_cfg()341 - [twi1] has no twi_speed!
[    0.051205] twi_chan_cfg()352 - [twi1] has no twi_regulator.
[    0.052447] twi_start()446 - [i2c0] START can't sendout!
[    0.052971] twi_start()446 - [i2c0] START can't sendout!
[    0.053489] twi_start()446 - [i2c0] START can't sendout!
[    0.054054] axp20_board 0-0034: failed reading at 0x03
[    0.054300] [AXP20-MFD] try to read chip id failed!
[    0.054750] axp mfd register failed
[    0.055013] axp20_board: probe of 0-0034 failed with error -121
[    0.055795] Linux video capture interface: v2.00
[    0.056195] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[    0.056651] axp pinctrl used,skip
[    0.057346] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.058825] cfg80211: Calling CRDA to update world regulatory domain
[    0.059886] Switching to clocksource arch_sys_counter
[    0.071107] NET: Registered protocol family 2
[    0.071953] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.073031] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.073653] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.074198] TCP: Hash tables configured (established 4096 bind 4096)
[    0.074449] TCP: reno registered
[    0.074909] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.075179] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.076192] NET: Registered protocol family 1
[    0.076749] Unpacking initramfs...
[    0.077012] Initramfs unpacking failed: compression method lzma not configured
[    0.082794] Freeing initrd memory: 2336K
[    0.083462] sunxi_reg_init enter
[    0.086164] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.086507] jffs2: version 2.2. (NAND) (SUMMARY)  ? 2001-2006 Red Hat, Inc.
[    0.087324] msgmni has been set to 82
[    0.088841] io scheduler noop registered
[    0.089098] io scheduler deadline registered
[    0.089636] io scheduler cfq registered (default)
[    0.090413] [DISP]disp_module_init
[    0.091119] cmdline,disp=
[    0.092572] disp_init_rotation_sw
[    0.092860] @@@rot-degree=1, scn_size[854,480]
[    0.093190] disp_rot_sw_set_manager,1246
[    0.130515] rot_degree =1, w=854, h=480
[    0.217676] [DISP]disp_module_init finish
[    0.218234] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.219090] uart2: ttyS0 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.219347] sw_uart_pm()890 - uart2 clk is already enable
[    0.219814] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.413088] ####rm68172 LCD_panel_init,vcom is 4023
[    1.016043] console [ttyS0] enabled
[    1.021654] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.029941] spi spi0: master is unqueued, this is deprecated
[    1.036693] m25p_probe()966 - Use the Dual Mode Read.
[    1.042882] NorFlash ID: 0xef4019 - 0x0
[    1.047414] m25p80 spi0.0: unrecognized JEDEC id ef4019
[    1.055525] Failed to alloc md5
[    1.059522] eth0: Use random mac address
[    1.064333] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.092227] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.101450] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.110504] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.130084] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.137917] hub 1-0:1.0: USB hub found
[    1.142406] hub 1-0:1.0: 1 port detected
[    1.147763] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.175041] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.685668] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2
[    1.694626] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.764986] hub 2-0:1.0: USB hub found
[    1.769637] hub 2-0:1.0: 1 port detected
[    1.774789] Initializing USB Mass Storage driver...
[    1.780726] usbcore: registered new interface driver usb-storage
[    1.787866] USB Mass Storage support registered.
[    1.793664] file system registered
[    1.799656] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.807625] android_usb gadget: Number of LUNs=1
[    1.813244]  lun0: LUN: removable file: (no medium)
[    1.819412] android_usb gadget: android_usb ready
[    1.825085] sunxikbd_script_init: key para not found, used default para.
[    1.834185] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.842236] sunxi cedar version 0.1
[    1.846520] [cedar]: install start!!!
[    1.851128] [cedar]: install end!!!
[    1.856201] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.865268] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.874513] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.883557] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.892387] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.901439] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.910487] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.919553] step1 : gsensor_fetch_sysconfig_para
[    1.925166] step2 : gsensor_fetch_sysconfig_para
[    1.930556] [MIR3DA] fetch_sysconfig_para failed!
[    1.930567]
[    1.938116] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.945594] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.957302] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.965483] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.971952] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.981725] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    1.992813] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Nov  9 2017 at 18:15:22
[    2.004334] [mmc]: get mmc0's sdc_power failed
[    2.009373] [mmc]: get mmc1's sdc_power failed
[    2.014440] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    2.022344] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.035453] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.048195] no led_0, ignore it!
[    2.051996] no led_1, ignore it!
[    2.055685] no led_2, ignore it!
[    2.059375] no led_3, ignore it!
[    2.063155] no led_4, ignore it!
[    2.066844] no led_5, ignore it!
[    2.070538] no led_6, ignore it!
[    2.074224] no led_7, ignore it!
[    2.078001] ####init finish
[    2.081385] usbcore: registered new interface driver usbhid
[    2.087697] usbhid: USB HID core driver
[    2.092554] ashmem: initialized
[    2.096203] logger: created 256K log 'log_main'
[    2.101447] logger: created 32K log 'log_events'
[    2.106819] logger: created 32K log 'log_radio'
[    2.112018] logger: created 32K log 'log_system'
[    2.118866] asoc: sndcodec <-> sunxi-codec mapping ok
[    2.125708] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    2.136518] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    2.146529] [DAUDIO0] driver not init,just return.
[    2.152243] IPv4 over IPv4 tunneling driver
[    2.157542] TCP: cubic registered
[    2.161433] Initializing XFRM netlink socket
[    2.166389] NET: Registered protocol family 10
[    2.172374] IPv6 over IPv4 tunneling driver
[    2.177657] NET: Registered protocol family 17
[    2.183052] ThumbEE CPU extension supported.
[    2.188007] Registering SWP/SWPB emulation handler
[    2.193849] [HDMI]ep952_module_init begin
[    2.198427] [ep952] hdmi_power: axp20_ldo3
[    2.203250] [DISP_I2C] hdmi_i2c_detect, get right i2c adapter, id=0
[    2.210427] [DISP_I2C] hdmi_i2c_probe
[    2.214737] hdmi_parse_config(): --- 117 ---- io_name:gpio_0, i:0
[    2.221644] hdmi_parse_config(): --- 117 ---- io_name:gpio_1, i:1
[    2.228686] hdmi_parse_config(): --- 117 ---- io_name:gpio_2, i:2
[    2.235593] hdmi_parse_config(): --- 117 ---- io_name:gpio_3, i:3
[    2.242584] hdmi_gpio_config(): --- 137 ---- gpio_id:2, bon:1
[    2.249237] ep952_thread:237
[    2.252943] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    2.261980] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    2.270672] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    2.279336] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    2.287920] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    2.296600] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    2.305459] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    2.314275] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
[    2.324151] [rf_pm]: Did not config module_power0 in sys_config
[    2.331000] [rf_pm]: Did not config module_power1 in sys_config
[    2.337701] [rf_pm]: Did not config module_power2 in sys_config
[    2.344499] [rf_pm]: Did not config module_power3 in sys_config
[    2.351203] [rf_pm]: mod has no chip_en gpio
[    2.356139] [rf_pm]: regulator on.
[    2.360053] [rf_pm]: Get ap 32k clk out failed!
[    2.365207] [wifi_pm]: failed to fetch wifi configuration!
[    2.371515] ALSA device list:
[    2.374913]   #0: audiocodec
[    2.378632] VFS: Cannot open root device "mtdblock2" or unknown-block(0,0): error -6
[    2.387490] Please append a correct "root=" boot option; here are the available partitions:
[    2.397012] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    2.406335] Backtrace:
[    2.409350] [<c00114c0>] (dump_backtrace+0x0/0x108) from [<c035a6d8>] (dump_stack+0x18/0x1c)
[    2.418877]  r7:c04a7778 r6:c040ffbc r5:c2837000 r4:c04f2670
[    2.425734] [<c035a6c0>] (dump_stack+0x0/0x1c) from [<c035a8d4>] (panic+0x78/0x1c0)
[    2.434477] [<c035a85c>] (panic+0x0/0x1c0) from [<c0487d60>] (mount_block_root+0x250/0x288)
[    2.443898]  r3:00000000 r2:00000000 r1:c2827f48 r0:c040ff54
[    2.450767]  r7:c04a7778
[    2.453768] [<c0487b10>] (mount_block_root+0x0/0x288) from [<c0487df0>] (mount_root+0x58/0x6c)
[    2.463573] [<c0487d98>] (mount_root+0x0/0x6c) from [<c0487f34>] (prepare_namespace+0x130/0x190)
[    2.473564]  r5:c04a778d r4:c04f2124
[    2.477823] [<c0487e04>] (prepare_namespace+0x0/0x190) from [<c0487978>] (kernel_init+0x164/0x1a4)
[    2.488012]  r5:00000095 r4:00000008
[    2.492273] [<c0487814>] (kernel_init+0x0/0x1a4) from [<c001f350>] (do_exit+0x0/0x644)
[    2.501296]  r7:00000013
#2 2019-02-02 12:27:05
已发帖子: 9,342
Re: 求助,编译S3 SDK烧录后不知道为什么内核挂了,提示Attempted to kill init! exitcode=0x0000000b
从 log2 看, 貌似驱动识别到了 w25q128, 但是这个 id 没有加到驱动列表, 所以他没有执行生成 mtd 分区, 导致了后面的错误.
#3 2019-02-02 12:30:15
已发帖子: 9,342
我刚刚看了 S3 官方开发板原理图
用的是 MX25L12835F,
看能否找到这个芯片焊上?
先排除问题
参考链接: https://whycan.cn/t_1739.html
#4 2019-02-02 13:07:46
已发帖子: 9,342
这个帖子是我把索智S3的SDK移植到V3s: https://whycan.cn/t_1739.html#p10340
改了一点点配置.
要不你按上面的套路试一试把 V3s 的 SDK 弄到 S3:  https://github.com/qq516333132/camdroid
楼主 #5 2019-02-02 16:31:23
Freeboy
改了一点点配置.
正在尝试,谢晕哥
楼主 #6 2019-02-03 03:02:29
Freeboy
我觉得有希望了,mtd分区生成了,明天参照playflash把CONFIG_CPU_FREQ=y关了再试试看 yikes
log3
boot0 commit : 8
rtc[7] value = 0x0000011e
axp209 read error
axp152 read error
DRAM CLK = 672 MHz
DRAM size = 128 MB
dram size =128
[      0.726]
[      0.736]uboot commit : 8
not set main pmu id
axp read error
probe axp20x failed
axp152 read error
probe axp15 failed
axp_probe error
dcdc2_vol = 1100
dcdc3_vol = 3300
aldo2_vol = 2500
aldo3_vol = 3000
ldo1_vol = 3300
ldo2_vol = 3000
ldo3_vol = 3000
ldo4_vol = 1800
vbus exist
fel key old mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
try gpio_flashing
workmode = 0
OK
nor id is 0x1840ef
[      1.829]sunxi flash init ok
In:    serial
Out:   serial
Err:   serial
boot        : 4000          280000
cfg         : f07000        40000
env         : f87000        10000
UDISK       : f97000        0
WORK_MODE_BOOT
[      2.561]Hit any key to stop autoboot:  0
[      2.743]sunxi flash read :offset 4000, 2621951 bytes OK
[      2.755]ready to boot
[      2.758]
[    0.000000] Linux version 3.4.39  (gcc version 5.3.1 20160412 (             Linaro GCC 5.3-2016.05) ) #1 Sun Feb 3 02:24:29 CST 2019
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio             n cache
[    0.000000] free_area_init_node: node 0, pgdat c04f17c4, node_mem_map c058d00             0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag             es: 32512
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 ini             t=/init loglevel=8 partitions=boot@spinorp0:system@spinorp1:cfg@spinorp2:boot_lo             go@spinorp3:shutdown_logo@spinorp4:env@spinorp5:UDISK@spinorp6 mac_addr= uid=888             2f574-3e53-45 kmemleak=on boot_type=3 fb_base=0x41b00000 config_size=49152
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 17895             6ms
[    0.000237] Calibrating delay loop (skipped), value calculated using timer fr             equency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000282] pid_max: default: 32768 minimum: 301
[    0.001327] CPU: Testing write buffer coherency: ok
[    0.001616] Setting up static identity map for 0x403623c8 - 0x403623fc
[    0.002612] devtmpfs: initialized
[    0.005810] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7              rev 5
[    0.006029] pinctrl core: initialized pinctrl subsystem
[    0.006734] NET: Registered protocol family 16
[    0.007392] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.007468] script_sysfs_init success
[    0.007527] sunxi_dump_init success
[    0.008934] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.011025] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.011510] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctr             l
[    0.013003] persistent_ram: uncorrectable error in header
[    0.013030] persistent_ram: no valid data in buffer (sig = 0x54010805)
[    0.030017] console [ram-1] enabled
[    0.031010] [sunxi-module]: [sunxi-module.0] probe success
[    0.031469] axp driver uning configuration failed(838)
[    0.031931] axp driver uning configuration failed(844)
[    0.032182] axp driver uning configuration failed(850)
[    0.032639] axp driver uning configuration failed(857)
[    0.033102] script config pll_isp to 360 Mhz
[    0.033377] Not Found clk pll_video in script
[    0.033843] script config pll_ve to 360 Mhz
[    0.034104] Not Found clk pll_periph0 in script
[    0.034561] Not Found clk pll_de in script
[    0.034806] sunxi_default_clk_init
[    0.035049] try to set pll6ahb1 to 200000000
[    0.035505] Error not get clk pll6ahb1
[    0.035759] Error not get clk pll6ahb1try to set ahb1 to 200000000
[    0.036251] try to set apb1 to 100000000
[    0.037245] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.044432] bio: create slab <bio-0> at 0
[    0.045264] pwm module init!
[    0.048296] SCSI subsystem initialized
[    0.048946] usbcore: registered new interface driver usbfs
[    0.049536] usbcore: registered new interface driver hub
[    0.049964] usbcore: registered new device driver usb
[    0.050239] twi_chan_cfg()341 - [twi0] has no twi_speed!
[    0.050956] twi_chan_cfg()341 - [twi1] has no twi_speed!
[    0.051206] twi_chan_cfg()352 - [twi1] has no twi_regulator.
[    0.052263] twi_start()446 - [i2c0] START can't sendout!
[    0.053000] twi_start()446 - [i2c0] START can't sendout!
[    0.053517] twi_start()446 - [i2c0] START can't sendout!
[    0.054082] axp20_board 0-0034: failed reading at 0x03
[    0.054326] [AXP20-MFD] try to read chip id failed!
[    0.054779] axp mfd register failed
[    0.055044] axp20_board: probe of 0-0034 failed with error -121
[    0.055834] Linux video capture interface: v2.00
[    0.056239] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[    0.056701] axp pinctrl used,skip
[    0.057408] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.058918] cfg80211: Calling CRDA to update world regulatory domain
[    0.059993] Switching to clocksource arch_sys_counter
[    0.071261] NET: Registered protocol family 2
[    0.072117] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.073209] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.073828] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.074375] TCP: Hash tables configured (established 4096 bind 4096)
[    0.074625] TCP: reno registered
[    0.074878] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.075354] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.076355] NET: Registered protocol family 1
[    0.076915] Unpacking initramfs...
[    0.077176] Initramfs unpacking failed: compression method lzma not configure             d
[    0.082965] Freeing initrd memory: 2336K
[    0.083634] sunxi_reg_init enter
[    0.086390] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.086727] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.087545] msgmni has been set to 82
[    0.089099] io scheduler noop registered
[    0.089357] io scheduler deadline registered
[    0.089900] io scheduler cfq registered (default)
[    0.090696] [DISP]disp_module_init
[    0.091410] cmdline,disp=
[    0.092876] disp_init_rotation_sw
[    0.093169] @@@rot-degree=1, scn_size[854,480]
[    0.093499] disp_rot_sw_set_manager,1246
[    0.133798] rot_degree =1, w=854, h=480
[    0.227334] [DISP]disp_module_init finish
[    0.227902] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.228771] uart2: ttyS0 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.229031] sw_uart_pm()890 - uart2 clk is already enable
[    0.229502] sw_console_setup()1233 - console setup baud 115200 parity n bits              8, flow n
[    0.325978] ####rm68172 LCD_panel_init,vcom is 4023
[    1.029925] console [ttyS0] enabled
[    1.035565] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.043749] spi spi0: master is unqueued, this is deprecated
[    1.050714] m25p_probe()966 - Use the Dual Mode Read.
[    1.056678] NorFlash ID: 0xef4018 - 0x0
[    1.061451] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    1.071127] @@@[debug_jaosn]: Invalid partitions count: 4 8
[    1.078362] Creating 7 MTD partitions on "spi0.0":
[    1.084022] 0x000000000000-0x000000040000 : "uboot"
[    1.091165] 0x000000040000-0x0000002c0000 : "boot"
[    1.098219] 0x0000002c0000-0x000000f43000 : "system"
[    1.104051] mtd: partition "system" doesn't end on an erase block -- force re             ad-only
[    1.114467] 0x000000f43000-0x000000f83000 : "cfg"
[    1.119958] mtd: partition "cfg" doesn't start on an erase block boundary --              force read-only
[    1.632459] 0x000000f83000-0x000000fa3000 : "boot_logo"
[    1.638738] mtd: partition "boot_logo" doesn't start on an erase block bounda             ry -- force read-only
[    1.650243] 0x000000fa3000-0x000000fc3000 : "shutdown_logo"
[    1.656917] mtd: partition "shutdown_logo" doesn't start on an erase block bo             undary -- force read-only
[    1.668975] 0x000000fc3000-0x000000fd3000 : "env"
[    1.674512] mtd: partition "env" doesn't start on an erase block boundary --              force read-only
[    1.687623] Failed to alloc md5
[    1.691474] eth0: Use random mac address
[    1.696175] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.723836] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EH             CI) Driver
[    1.733263] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus num             ber 1
[    1.742093] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.760047] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.768003] hub 1-0:1.0: USB hub found
[    1.772483] ####init finish
[    1.775886] hub 1-0:1.0: 1 port detected
[    1.781037] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.808487] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI)              Driver
[    1.817525] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus num             ber 2
[    1.826295] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.894971] hub 2-0:1.0: USB hub found
[    1.899449] hub 2-0:1.0: 1 port detected
[    1.904815] Initializing USB Mass Storage driver...
[    1.910762] usbcore: registered new interface driver usb-storage
[    1.917716] USB Mass Storage support registered.
[    1.923699] file system registered
[    1.929485] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.937680] android_usb gadget: Number of LUNs=1
[    1.943085]  lun0: LUN: removable file: (no medium)
[    1.949493] android_usb gadget: android_usb ready
[    1.955180] sunxikbd_script_init: key para not found, used default para.
[    1.964427] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.972315] sunxi cedar version 0.1
[    1.976807] [cedar]: install start!!!
[    1.981442] [cedar]: install end!!!
[    1.986405] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe d             eferral
[    1.995685] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe d             eferral
[    2.005073] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe def             erral
[    2.013931] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe def             erral
[    2.022999] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe def             erral
[    2.032063] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe def             erral
[    2.040928] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe              deferral
[    2.050229] step1 : gsensor_fetch_sysconfig_para
[    2.055625] step2 : gsensor_fetch_sysconfig_para
[    2.061226] [MIR3DA] fetch_sysconfig_para failed!
[    2.061238]
[    2.068633] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.076369] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->sta             rt 0x01c20ca0, res->end 0x01c20cbf
[    2.088118] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    2.096089] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    2.102762] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual ti             meout 16 sec
[    2.112556] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed,              use max_freq
[    2.123499] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21)              Compiled in Feb  3 2019 at 02:23:26
[    2.135082] [mmc]: get mmc0's sdc_power failed
[    2.140253] [mmc]: get mmc1's sdc_power failed
[    2.145311] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    2.153251] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing              LEGACY(SDR12) dt B
[    2.166288] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing              LEGACY(SDR12) dt B
[    2.179143] no led_0, ignore it!
[    2.182839] no led_1, ignore it!
[    2.186610] no led_2, ignore it!
[    2.190317] no led_3, ignore it!
[    2.194005] no led_4, ignore it!
[    2.197691] no led_5, ignore it!
[    2.201471] no led_6, ignore it!
[    2.205161] no led_7, ignore it!
[    2.209040] usbcore: registered new interface driver usbhid
[    2.215421] usbhid: USB HID core driver
[    2.220247] ashmem: initialized
[    2.223935] logger: created 256K log 'log_main'
[    2.229236] logger: created 32K log 'log_events'
[    2.234547] logger: created 32K log 'log_radio'
[    2.239816] logger: created 32K log 'log_system'
[    2.246706] asoc: sndcodec <-> sunxi-codec mapping ok
[    2.253627] [DAUDIO]sunxi-daudio cannot find any using configuration for cont             rollers, return directly!
[    2.264397] [I2S]snddaudio cannot find any using configuration for controller             s, return directly!
[    2.274409] [DAUDIO0] driver not init,just return.
[    2.280244] IPv4 over IPv4 tunneling driver
[    2.285538] TCP: cubic registered
[    2.289315] Initializing XFRM netlink socket
[    2.294456] NET: Registered protocol family 10
[    2.300351] IPv6 over IPv4 tunneling driver
[    2.305618] NET: Registered protocol family 17
[    2.311060] ThumbEE CPU extension supported.
[    2.315936] Registering SWP/SWPB emulation handler
[    2.321747] [HDMI]ep952_module_init begin
[    2.326325] [ep952] hdmi_power: axp20_ldo3
[    2.331076] [DISP_I2C] hdmi_i2c_detect, get right i2c adapter, id=0
[    2.338312] [DISP_I2C] hdmi_i2c_probe
[    2.342553] hdmi_parse_config(): --- 117 ---- io_name:gpio_0, i:0
[    2.349537] hdmi_parse_config(): --- 117 ---- io_name:gpio_1, i:1
[    2.356504] hdmi_parse_config(): --- 117 ---- io_name:gpio_2, i:2
[    2.363505] hdmi_parse_config(): --- 117 ---- io_name:gpio_3, i:3
[    2.370408] hdmi_gpio_config(): --- 137 ---- gpio_id:2, bon:1
[    2.377158] ep952_thread:237
[    2.380821] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe              deferral
[    2.389884] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe def             erral
[    2.398525] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe def             erral
[    2.407208] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe def             erral
[    2.415880] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe def             erral
[    2.424469] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe d             eferral
[    2.433334] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe d             eferral
[    2.442235] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:02:03              UTC (123)
[    2.452291] [rf_pm]: Did not config module_power0 in sys_config
[    2.459057] [rf_pm]: Did not config module_power1 in sys_config
[    2.465885] [rf_pm]: Did not config module_power2 in sys_config
[    2.472613] [rf_pm]: Did not config module_power3 in sys_config
[    2.479396] [rf_pm]: mod has no chip_en gpio
[    2.484262] [rf_pm]: regulator on.
[    2.488174] [rf_pm]: Get ap 32k clk out failed!
[    2.493416] [wifi_pm]: failed to fetch wifi configuration!
[    2.499627] ALSA device list:
[    2.503043]   #0: audiocodec
[    2.514455] SQUASHFS error: unable to read fragment index table
[    2.521935] List of all partitions:
[    2.525940] 1f00             256 mtdblock0  (driver?)
[    2.531879] 1f01            2560 mtdblock1  (driver?)
[    2.537720] 1f02           12812 mtdblock2  (driver?)
[    2.543640] 1f03             256 mtdblock3  (driver?)
[    2.549464] 1f04             128 mtdblock4  (driver?)
[    2.555390] 1f05             128 mtdblock5  (driver?)
[    2.561223] 1f06              64 mtdblock6  (driver?)
[    2.567128] No filesystem could mount root, tried:  cramfs squashfs vfat
[    2.575095] Kernel panic - not syncing: VFS: Unable to mount root fs on unkno             wn-block(31,2)
[    2.584597] Backtrace:
[    2.587559] [<c00114c0>] (dump_backtrace+0x0/0x108) from [<c035a6d8>] (dump_s             tack+0x18/0x1c)
[    2.597168]  r7:c04a7778 r6:c040ffbc r5:c0417e8e r4:c04f2670
[    2.603938] [<c035a6c0>] (dump_stack+0x0/0x1c) from [<c035a8d4>] (panic+0x78/             0x1c0)
[    2.612685] [<c035a85c>] (panic+0x0/0x1c0) from [<c0487d60>] (mount_block_roo             t+0x250/0x288)
[    2.622201]  r3:00000000 r2:80000000 r1:c2827f48 r0:c040ff54
[    2.628952]  r7:c04a7778
[    2.631962] [<c0487b10>] (mount_block_root+0x0/0x288) from [<c0487df0>] (moun             t_root+0x58/0x6c)
[    2.641687] [<c0487d98>] (mount_root+0x0/0x6c) from [<c0487f34>] (prepare_nam             espace+0x130/0x190)
[    2.651676]  r5:c04a778d r4:c04f2124
[    2.655930] [<c0487e04>] (prepare_namespace+0x0/0x190) from [<c0487978>] (ker             nel_init+0x164/0x1a4)
[    2.666116]  r5:00000095 r4:00000008
[    2.670379] [<c0487814>] (kernel_init+0x0/0x1a4) from [<c001f350>] (do_exit+0             x0/0x644)
[    2.679392]  r7:00000013
#7 2019-02-03 07:40:24
已发帖子: 9,342
厉害厉害
这是用 索智zeta sdk,还是camdroid?
楼主 #8 2019-02-03 11:36:39
Freeboy
厉害厉害
ZETA SDK
