楼主 #1 2018-03-23 21:14:59
已发帖子: 9,407
用全志官方软件PhoenixSuit.exe烧录 V3s步骤
用全志官方软件 PhoenixSuit 烧录 V3s步骤
1. 安裝驱动
2. 打开PhoenixSuit, 选择需要下载的 img 文件.
3. 按下S2按键, 准备USB micro 线,一头插入电脑, 一头插入USB J511插座。
楼主 #2 2018-03-23 21:30:01
已发帖子: 9,407
Re: 用全志官方软件PhoenixSuit.exe烧录 V3s步骤
楼主 #3 2018-03-23 21:31:13
已发帖子: 9,407
占位
楼主 #4 2018-03-23 21:31:18
已发帖子: 9,407
占位
楼主 #5 2018-03-23 21:31:21
已发帖子: 9,407
get_ifm reg_val=7
===i2c gpio === 22777722
axp read fail, maybe no pmu
set pmu vol failed,maybe no pmu
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 408 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
Succeed in reading Boot1 file head.
Jump to secend Boot.
[      0.088]
U-Boot 2011.09-rc1-00000-g79832e3-dirty (Mar 23 2018 - 20:45:30) Allwinner Technology
[      0.098]version: 1.1.0
[      0.103]pmbus:
ready
axp read error
probe axp20x failed
axp_probe fail,run clock=912
set power on vol to default
axp_set_power_supply_output dcdc2_vol = 1250
axp set dcdc2_vol to 1250 failed
axp_set_power_supply_output dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
axp_set_power_supply_output aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
axp_set_power_supply_output aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
axp_set_power_supply_output ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
axp_set_power_supply_output ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
axp_set_power_supply_output ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
fel key new mode
run key detect
no key found
[      0.184]DRAM:  64 MiB
[debug_jaosn]:use the clock in sys_config
OK
[      0.206]sunxi flash init ok
hello @flash_speed=1
env_relocate_spec storage_type = 3
In:    serial
Out:   serial
Err:   serial
WORK_MODE_BOOT
read bootlogo partition successful,start_block=0x71a0,rblock=0x100 ,ret=256
Use decode 2x2 sampling
sunxi_read_bootlogo: jpg convert argb
[      0.329]Hit any key to stop autoboot:  0
read boot or recovery all
try to read all
[      0.617]sunxi flash read :offset 4000, 4194304 bytes OK
## Booting kernel from Legacy Image at 40007fc0 ...
   Image Name:   Linux-3.4.39
   Data Size:    2614776 Bytes = 2.5 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
OK
[      0.671]
[    0.000000] Linux version 3.4.39 (hexing@ubuntu) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #345 Fri Mar 23 20:52:32 CST 2018
[    0.000000] Machine: sun8i
[    0.000000] Initialized persistent memory from 41d00800-41d107ff
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat c0522b24, node_mem_map c05b1000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 16256 pages, LIFO batch:3
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 init=/linuxrc loglevel=8 partitions= mac_addr= uid=1234567890 kmemleak=on rootfstype=jffs2
[    0.000000] Memory: 29292k/29292k available, 36244k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc048f000   (4636 kB)
[    0.000000]       .init : 0xc048f000 - 0xc04b2000   ( 140 kB)
[    0.000000]       .data : 0xc04b2000 - 0xc0523260   ( 453 kB)
[    0.000000]        .bss : 0xc0523284 - 0xc05b0a64   ( 566 kB)
[    0.000000] NR_IRQS:544
[    0.000000] 524 ahb1 set parent pll_periph0d2
[    0.000156] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000179] pid_max: default: 32768 minimum: 301
[    0.000329] Mount-cache hash table entries: 512
[    0.000849] CPU: Testing write buffer coherency: ok
[    0.001113] Setting up static identity map for 0x40367798 - 0x403677f0
[    0.001769] devtmpfs: initialized
[    0.003674] pinctrl core: initialized pinctrl subsystem
[    0.004171] NET: Registered protocol family 16
[    0.004542] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.004594] script_sysfs_init success
[    0.004630] sunxi_dump_init success
[    0.005386] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.006314] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.006668] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[    0.007348] tsc2003 device registered
[    0.007631] persistent_ram: uncorrectable error in header
[    0.007645] persistent_ram: no valid data in buffer (sig = 0x00000003)
[    0.014120] console [ram-1] enabled
[    0.014538] [sunxi-module]: [sunxi-module.0] probe success
[    0.014767] ++axp20_board_init!
[    0.014959] axp driver uning configuration failed(801)
[    0.015071] axp driver uning configuration failed(808)
[    0.015550] script config pll_isp to 360 Mhz
[    0.015688] Not Found clk pll_video in script
[    0.015893] script config pll_ve to 360 Mhz
[    0.016015] Not Found clk pll_periph0 in script
[    0.016123] Not Found clk pll_de in script
[    0.016320] sunxi_default_clk_init
[    0.016428] try to set pll6ahb1 to 200000000
[    0.016539] Error not get clk pll6ahb1
[    0.016741] Error not get clk pll6ahb1try to set ahb1 to 200000000
[    0.016961] try to set apb1 to 100000000
[    0.017452] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.021302] bio: create slab <bio-0> at 0
[    0.021668] pwm module init!
[    0.023481] ion_mem.size = 30408704
[    0.024168] SCSI subsystem initialized
[    0.024505] usbcore: registered new interface driver usbfs
[    0.024776] usbcore: registered new interface driver hub
[    0.025029] usbcore: registered new device driver usb
[    0.025363] twi_chan_cfg()342 - [twi0] has no twi_speed!
[    0.025479] twi_chan_cfg()353 - [twi0] has no twi_regulator.
[    0.025682] twi_chan_cfg()342 - [twi1] has no twi_speed!
[    0.025792] twi_chan_cfg()353 - [twi1] has no twi_regulator.
[    0.025993] sunxi_i2c_adap_init()1563 - Sunxi I2C init channel 0
[    0.026219] sunxi_i2c_adap_init()1563 - Sunxi I2C init channel 1
[    0.026526] ++sunxi_i2c_probe
[    0.026681] twi_request_gpio()406 - Pinctrl init 0 ... [twi0]
[    0.026987] twi_clk_write_reg()241 - twi_clk_write_reg: clk_n = 0, clk_m = 5
[    0.027320] ++axp_i2c_probe!
[    0.027617] sunxi_i2c_do_xfer()998 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x34)
[    0.027829] axp20_board 0-0034: failed reading at 0x03
[    0.028027] [AXP20-MFD] try to read chip id failed = -70!
[    0.028137] axp mfd register failed
[    0.028257] axp20_board: probe of 0-0034 failed with error -70
[    0.028468] sunxi_i2c_probe()1250 - I2C: i2c-0: sunxi I2C adapter
[    0.028582] sunxi_i2c_probe()1251 - TWI_CTL  0xf1c2ac0c: 0x00000040
[    0.028785] sunxi_i2c_probe()1252 - TWI_STAT 0xf1c2ac10: 0x000000f8
[    0.028987] sunxi_i2c_probe()1253 - TWI_CLK  0xf1c2ac14: 0x00000028
[    0.029099] sunxi_i2c_probe()1254 - TWI_SRST 0xf1c2ac18: 0x00000000
[    0.029301] sunxi_i2c_probe()1255 - TWI_EFR  0xf1c2ac1c: 0x00000000
[    0.029429] ++sunxi_i2c_probe
[    0.029575] twi_request_gpio()406 - Pinctrl init 1 ... [twi1]
[    0.029776] twi_clk_write_reg()241 - twi_clk_write_reg: clk_n = 0, clk_m = 11
[    0.030209] sunxi_i2c_probe()1250 - I2C: i2c-1: sunxi I2C adapter
[    0.030329] sunxi_i2c_probe()1251 - TWI_CTL  0xf1c2b00c: 0x00000040
[    0.030532] sunxi_i2c_probe()1252 - TWI_STAT 0xf1c2b010: 0x000000f8
[    0.030645] sunxi_i2c_probe()1253 - TWI_CLK  0xf1c2b014: 0x00000058
[    0.030848] sunxi_i2c_probe()1254 - TWI_SRST 0xf1c2b018: 0x00000000
[    0.030960] sunxi_i2c_probe()1255 - TWI_EFR  0xf1c2b01c: 0x00000000
[    0.031196] Linux video capture interface: v2.00
[    0.031409] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[    0.031611] axp pinctrl used,skip
[    0.032026] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.033160] cfg80211: Calling CRDA to update world regulatory domain
[    0.034245] Switching to clocksource arch_sys_counter
[    0.039940] NET: Registered protocol family 2
[    0.039940] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.040560] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.040717] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.040937] TCP: Hash tables configured (established 2048 bind 2048)
[    0.041139] TCP: reno registered
[    0.041252] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.041375] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.041841] NET: Registered protocol family 1
[    0.042345] [pm]aw_pm_init!
[    0.042555] standby_mode = 1.
[    0.042665] wakeup src cnt is : 3.
[    0.042779] pmu name: pmu1_para .
[    0.042892] pmu1_enable = 0x1.
[    0.043090] pmux_id = 0x1.
[    0.043200] pmu name: pmu2_para .
[    0.043309] config_pmux_para: script_parser_fetch err.
[    0.043507] pmu2_enable = 0x0.
[    0.043618] add_sys_pwr_dm: get ldo name failed
[    0.043726] add_sys_pwr_dm: get ldo name failed
[    0.043924] add_sys_pwr_dm: get ldo name failed
[    0.044033] add_sys_pwr_dm: get ldo name failed
[    0.044231] add_sys_pwr_dm: get ldo name failed
[    0.044341] add_sys_pwr_dm: get ldo name failed
[    0.044450] add_sys_pwr_dm: get ldo name failed
[    0.044649] add_sys_pwr_dm: get ldo name failed
[    0.044760] add_sys_pwr_dm: get ldo name failed
[    0.044960] add_sys_pwr_dm: get ldo name failed
[    0.045068] after inited: sys_mask config = 0x0.
[    0.045178] dynamic_standby enalbe = 0x0.
[    0.045422] sunxi_reg_init enter
[    0.047254] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.047512] jffs2: version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
[    0.047819] msgmni has been set to 57
[    0.048835] io scheduler noop registered
[    0.049046] io scheduler deadline registered
[    0.049222] io scheduler cfq registered (default)
[    0.049834] [DISP]disp_module_init
[    0.050418] cmdline,disp=
[    0.051059] rotation_sw module is config as no used
[    0.051282] [DISP] disp_get_rotation_sw,line:68:disp 0 out of range? g_rot_sw=0
[    0.051498] [DISP] disp_init_connections,line:289:NULL pointer: 0, 0
[    0.051875] disp_fb_to_var:format = 0
[    0.051992] fb_para.width = 480,fb_para.height = 272,fb_para.buffer_num = 2
[    0.052200] gen_pool_alloc:nbits = 255,size = 1044480,order = 12
[    0.052312] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 30408704
[    0.052615] end_bit = 7424
[    0.056445] [DISP] disp_sys_power_enable,line:387:some error happen, fail to get regulator
[    0.056770] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.057734] [DISP]disp_module_init finish
[    0.058159] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.058714] uart2: ttyS0 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.058835] sw_uart_pm()890 - uart2 clk is already enable
[    0.059048] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.155036] console [ttyS0] enabled
[    1.077551] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.085399] spi spi0: master is unqueued, this is deprecated
[    1.092050] m25p_probe()966 - Use the Dual Mode Read.
[    1.097861] NorFlash ID: 0xef4019 - 0x0
[    1.102351] m25p80 spi0.0: unrecognized JEDEC id ef4019
[    1.108534] priv->phy_ext = INT_PHY
[    1.113738] Failed to alloc md5
[    1.117377] eth0: Use random mac address
[    1.121939] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.149495] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.158558] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.167297] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.174103] [DISP] disp_lcd_pwm_enable,line:1022:pwm device hdl is NULL
[    1.200039] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.207548] hub 1-0:1.0: USB hub found
[    1.211950] hub 1-0:1.0: 1 port detected
[    1.216858] sunxi-ehci sunxi-ehci.1: remove, state 1
[    1.222612] usb usb1: USB disconnect, device number 1
[    1.512667] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[    1.529153] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.556214] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.564968] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[    1.573627] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.644644] hub 1-0:1.0: USB hub found
[    1.649020] hub 1-0:1.0: 1 port detected
[    1.653981] sunxi-ohci sunxi-ohci.1: remove, state 1
[    1.659607] usb usb1: USB disconnect, device number 1
[    1.666021] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[    1.682449] Initializing USB Mass Storage driver...
[    1.688144] usbcore: registered new interface driver usb-storage
[    1.694933] USB Mass Storage support registered.
[    1.700597] file system registered
[    1.706060] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.713860] android_usb gadget: Number of LUNs=1
[    1.719087]  lun0: LUN: removable file: (no medium)
[    1.725109] android_usb gadget: android_usb ready
[    1.730685] sunxikbd_script_init: key para not found, used default para.
[    1.738906] tsc2003_ts_init
[    1.742248] =====ctp_fetch_sysconfig_para=====.
[    1.747480] ctp_fetch_sysconfig_para: ctp_power_ldo script_get_item err.
[    1.755218] ctp_fetch_sysconfig_para: ctp_power_ldo_vol script_get_item err.
[    1.763260] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[    1.770896] script_get_item ctp_wakeup err
[    1.775549] ctp_irq gpio number is 36
[    1.779831] wakeup gpio_request is failed
[    1.784449] =============GT82x Probe==================
[    1.791012] sunxi_i2c_do_xfer()998 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x48)
[    1.800414] i2c_write_bytes error -70
[    1.804591] tsc2003: probe of 1-0048 failed with error -70
[    1.811460] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.819081] sunxi cedar version 0.1
[    1.823325] [cedar]: install start!!!
[    1.827768] [cedar]: install end!!!
[    1.832253] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    1.841231] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    1.850175] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    1.858812] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    1.867560] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    1.876296] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    1.884953] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    1.893960] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.901311] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.912734] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.920405] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.926794] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.936535] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Mar 23 2018 at 20:51:16
[    1.948113] [mmc]: get mmc0's sdc_power failed
[    1.953267] [mmc]: get mmc1's sdc_power failed
[    1.958306] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    1.966531] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.979850] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.992763] sunxi_leds_fetch_sysconfig_para leds is not used in config
[    2.000252] =========script_get_err============
[    2.005578] usbcore: registered new interface driver usbhid
[    2.011991] usbhid: USB HID core driver
[    2.016980] ashmem: initialized
[    2.020758] logger: created 256K log 'log_main'
[    2.026088] logger: created 32K log 'log_events'
[    2.031491] logger: created 32K log 'log_radio'
[    2.036746] logger: created 32K log 'log_system'
[    2.043514] script_get_item return audio_pa_ctrl type err
[    2.050493] asoc: sndcodec <-> sunxi-codec mapping ok
[    2.058343] TCP: cubic registered
[    2.062209] NET: Registered protocol family 17
[    2.067459] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    2.076193] ThumbEE CPU extension supported.
[    2.081156] Registering SWP/SWPB emulation handler
[    2.087636] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    2.096796] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    2.105368] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    2.114021] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    2.122666] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    2.131222] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    2.140055] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    2.148955] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:07:24 UTC (444)
[    2.159193] [wifi module_pm]: select module num is 6
[    2.164993] [wifi module_pm]: step [0] failed to fetch module_power0
[    2.172162] [wifi module_pm]: mod has no chip_en gpio
[    2.177956] [wifi module_pm]: failed to fetch lpo_use_apclk
[    2.184600] [wifi_pm]: wifi gpio init is OK !!
[    2.189831] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[    2.198639]
[    2.198642] *****Mar 23 2018 20:51:22 EAGLE DRIVER VER:75be56bfbaf7*****
[    2.198649]
[    2.209842] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[    2.218773] =======================================================
[    2.225943] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    2.233015] =======================================================
[    2.240168] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.25(01/22/2016),Drv: 2.26) init.
[    2.250997] [wifi_pm]: set wl_reg_on 1 !
[    2.355623] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.365611] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[    2.374165] [mmc]: sdc1 power_supply is null
[    2.380350] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[    2.388905] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[    2.397664] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[    2.406332] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[    2.415252] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.442358] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.451597] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.459940] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.472709] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.484978] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    2.493310] *******************Try sdio*******************
[    2.500301] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.509429] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.518578] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.527623] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.535945] *******************Try sd *******************
[    2.542856] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.552078] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.561303] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.570431] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.578852] *******************Try mmc*******************
[    2.584953] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.596223] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1,  RTO !!
[    2.604553] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.614670] [mmc]: sdc1 power_supply is null
[    2.622107] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.633482] [mmc]: sdc1 power_supply is null
[    2.650035] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.682603] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.692101] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.700434] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.713403] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.725962] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    2.734196] *******************Try sdio*******************
[    2.741555] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.750945] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.760248] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.769638] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    2.777976] *******************Try sd *******************
[    2.785148] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.794642] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.804038] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.813532] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    2.821949] *******************Try mmc*******************
[    2.823503] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.839592] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1,  RTO !!
[    2.847926] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.857942] [mmc]: sdc1 power_supply is null
[    2.865478] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.876754] [mmc]: sdc1 power_supply is null
[    2.900022] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.933135] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.943074] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.951506] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.969751] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.982860] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    2.991095] *******************Try sdio*******************
[    2.998980] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.008825] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.018755] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.028680] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.036917] *******************Try sd *******************
[    3.044717] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.054686] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.064710] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.074736] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.083070] *******************Try mmc*******************
[    3.084693] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.101372] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1,  RTO !!
[    3.109610] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.119726] [mmc]: sdc1 power_supply is null
[    3.127170] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.138544] [mmc]: sdc1 power_supply is null
[    3.160029] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.192603] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    3.202100] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    3.210522] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.223401] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.235965] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    3.244287] *******************Try sdio*******************
[    3.251555] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.265023] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.274425] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.283724] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 5,  RTO !!
[    3.292052] *******************Try sd *******************
[    3.299211] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.308701] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.318188] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.327588] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 55,  RTO !!
[    3.336024] *******************Try mmc*******************
[    3.342219] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.353672] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 1,  RTO !!
[    3.362003] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.372114] [mmc]: sdc1 power_supply is null
串口2输出正常了!
#6 2019-02-21 16:45:25
leozlee
晕哥,固件烧录只烧录了4s就显示成功了,是啥情况啊
楼主 #7 2019-02-21 17:14:01
已发帖子: 9,407
leozlee 说:
可以接调试串口, 通过调试串口可以看到错误信息。
官方的烧录软件是先把 u-boot 下载到dram, 把u-boot跑起来再和烧录软件通讯。
#8 2019-02-21 18:09:42
leozlee
leozlee 说:
U-Boot 2011.09-rc1-dirty (Jun 16 2015 - 13:24:29) Allwinner Technology
[      2.233]version: 1.1.0
[      2.238]pmbus:
===i2c gpio === 22777777
ready
axp read error
probe axp20x failed
axp_probe fail,run clock=1008
axp_set_power_supply_output dcdc2_vol = 1200
axp set dcdc2_vol to 1200 failed
[      2.299]DRAM:  64 MiB
save config for small mem_size
workmode = 16
OK
spinor id is 0
try nor successed
sunxi sprite has installed spi function
read flash error
In:    serial
Out:   serial
Err:   serial
mbr not exist
[      2.374]Hit any key to stop autoboot:  0
work mode=0x10
run usb efex
delay time 2500
usb init ok
set address 0x3e
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x0
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
sunxi spinor is already inited
flash size =16 M
algin 512 byte  fullimg_size 13697024
before sunxi_sprite_setdata_finish
spinor_datafinish
spinor id = 0x0
_spinor_wrsr status is 0
begin to erase all ..
status = 0
count = 1134783053
spinor has erasered
total write bytes = 13697024
start = 0x0, cnt=0x6880
nor_page_cnt=53504
nor_page_cnt=511
nor_page_cnt=1023
nor_page_cnt=1535
nor_page_cnt=2047
nor_page_cnt=2559
nor_page_cnt=3071
nor_page_cnt=3583
nor_page_cnt=4095
nor_page_cnt=4607
nor_page_cnt=5119
nor_page_cnt=5631
nor_page_cnt=6143
nor_page_cnt=6655
nor_page_cnt=7167
nor_page_cnt=7679
nor_page_cnt=8191
nor_page_cnt=8703
nor_page_cnt=9215
nor_page_cnt=9727
nor_page_cnt=10239
nor_page_cnt=10751
nor_page_cnt=11263
nor_page_cnt=11775
nor_page_cnt=12287
nor_page_cnt=12799
nor_page_cnt=13311
nor_page_cnt=13823
nor_page_cnt=14335
nor_page_cnt=14847
nor_page_cnt=15359
nor_page_cnt=15871
nor_page_cnt=16383
nor_page_cnt=16895
nor_page_cnt=17407
nor_page_cnt=17919
nor_page_cnt=18431
nor_page_cnt=18943
nor_page_cnt=19455
nor_page_cnt=19967
nor_page_cnt=20479
nor_page_cnt=20991
nor_page_cnt=21503
nor_page_cnt=22015
nor_page_cnt=22527
nor_page_cnt=23039
nor_page_cnt=23551
nor_page_cnt=24063
nor_page_cnt=24575
nor_page_cnt=25087
nor_page_cnt=25599
nor_page_cnt=26111
nor_page_cnt=26623
nor_page_cnt=27135
nor_page_cnt=27647
nor_page_cnt=28159
nor_page_cnt=28671
nor_page_cnt=29183
nor_page_cnt=29695
nor_page_cnt=30207
nor_page_cnt=30719
nor_page_cnt=31231
nor_page_cnt=31743
nor_page_cnt=32255
nor_page_cnt=32767
nor_page_cnt=33279
nor_page_cnt=33791
nor_page_cnt=34303
nor_page_cnt=34815
nor_page_cnt=35327
nor_page_cnt=35839
nor_page_cnt=36351
nor_page_cnt=36863
nor_page_cnt=37375
nor_page_cnt=37887
nor_page_cnt=38399
nor_page_cnt=38911
nor_page_cnt=39423
nor_page_cnt=39935
nor_page_cnt=40447
nor_page_cnt=40959
nor_page_cnt=41471
nor_page_cnt=41983
nor_page_cnt=42495
nor_page_cnt=43007
nor_page_cnt=43519
nor_page_cnt=44031
nor_page_cnt=44543
nor_page_cnt=45055
nor_page_cnt=45567
nor_page_cnt=46079
nor_page_cnt=46591
nor_page_cnt=47103
nor_page_cnt=47615
nor_page_cnt=48127
nor_page_cnt=48639
nor_page_cnt=49151
nor_page_cnt=49663
nor_page_cnt=50175
nor_page_cnt=50687
nor_page_cnt=51199
nor_page_cnt=51711
nor_page_cnt=52223
nor_page_cnt=52735
nor_page_cnt=53247
spinor download data ok
sunxi_efex_next_action=2
exit usb
next work 2
SUNXI_UPDATE_NEXT_ACTION_REBOOT
set next mode 14
drv_disp_exit
[      9.306][mmc]: MMC Device 2 not found
[      9.310][mmc]:  mmc Wot find,so not exit
sunxi spinor has not inited
beign to init dram
DRAM CLK = 360 MHz
DRAM size = 64 MB
init dram ok
fes1 reg_val=7
[      2.238]
查看串口发现一直在这个过程
楼主 #9 2019-02-21 18:11:14
已发帖子: 9,407
你的是 V3s 还是 S3 ?
#10 2019-02-21 18:12:21
leozlee
后来我用另外一个软件(PhoenixCard_V310),制作了一张启动卡,可以看到和你贴出的log一样的信息,不过好像没有出现那几个 摄像头模式的按钮?
#11 2019-02-21 18:17:00
leozlee
你的是 V3s 还是 S3 ?
V3s
楼主 #12 2019-02-21 18:35:56
已发帖子: 9,407
leozlee 说:
哪个按钮?
#13 2019-02-22 09:36:58
leozlee
leozlee 说:
哪个按钮?
就是显示屏上的那三个button
楼主 #14 2019-02-22 09:41:12
已发帖子: 9,407
leozlee 说:
leozlee 说:
哪个按钮?
就是显示屏上的那三个button
https://whycan.cn/t_1780.html#p10747
这上面的按钮?
#15 2019-02-22 09:48:53
leozlee
leozlee 说:
哪个按钮?
就是显示屏上的那三个button
这上面的按钮?
是的
你的那个固件是只能用flash启动的吗?
楼主 #16 2019-02-22 09:53:05
已发帖子: 9,407
对, 应该只支持 flash
#17 2019-02-22 10:01:12
leozlee
对, 应该只支持 flash
我直接用PhoenixCard.exe这个软件做了一个启动卡,然后查到核心板的tf卡卡槽,
最后启动到下面就卡住了。
[   57.278196] init: processing action 0x1e481c8 (boot)
[   57.284247] init: command 'ifup' r=0
[   57.288574] init: command 'hostname' r=0
[   57.293137] init: command 'domainname' r=0
[   57.297806] init: command 'setrlimit' r=0
[   57.302563] init: command 'chown' r=0
[   57.306763] init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
[   57.315902] init: cannot find '/system/bin/vold', disabling 'vold'
[   57.322911] init: cannot find '/system/bin/mediaserver', disabling 'media'
[   57.330803] init: cannot find '/system/bin/startup_music', disabling 'startupSound'
[   57.339509] init: command 'class_start' r=0
[   57.344297] init: cannot find '/system/bin/ccdr', disabling 'ccdr'
[   57.351281] init: command 'class_start' r=0
[   57.356029] init: processing action 0x1e48fd0 (boot)
[   57.361665] init: starting 'adbd'
[   57.365907] init: command 'start' r=0
[   57.370540] init: Created socket '/dev/socket/adbd' with mode '660', user '1000', group '1000'
[   57.380550] init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
[   57.388498] init: command 'start' r=0
[   57.394427] adb_open
[   57.397170] init: cannot find '/system/bin/standbyservice', disabling 'standby'
[   57.406115] init: command 'start' r=0
[   57.410464] init: processing action 0x1e4a4f8 (queue_property_triggers)
[   57.417973] init: command 'queue_property_triggers' r=0
[   57.424003] init: processing action 0x1e484a8 (property:ro.debuggable=1)
[   57.431614] init: cannot find '/system/bin/sh', disabling 'console'
[   57.438762] init: command 'start' r=0
#18 2019-02-22 10:03:14
山无棱
已发帖子: 116
看起来好像是缺文件,是不是烧录不完整
#19 2019-02-22 10:19:27
leozlee
山无棱 说:
看起来好像是缺文件,是不是烧录不完整
我是直接烧录在一个tf卡上的,不知道有没有关系
楼主 #20 2019-02-22 10:23:55
已发帖子: 9,407
leozlee 说:
山无棱 说:
看起来好像是缺文件,是不是烧录不完整
那可能不行了,起码你的根文件系统跑不起来
#21 2019-12-11 11:25:19
小白
您好,我想给v3s烧固件,选择文件后提示固件文件打开失败,这个是什么原因造成的?
#22 2019-12-11 11:28:38
呵哈呵哈
已发帖子: 22
小白 说:
可能是固件不完整, 打包有问题。
#23 2019-12-12 09:30:09
小白
呵哈呵哈 说:
可能是固件不完整, 打包有问题。
固件是我用fel从v3s的flash中读出来的,文件名为XXX.img,请问这样有什么问题吗?
楼主 #24 2019-12-12 09:48:26
已发帖子: 9,407
小白 说:
从flash读出来应该用sunxi-fel烧录: https://whycan.cn/t_444.html
不能用官方烧录软件了。
#25 2019-12-12 10:47:03
小白
不能用官方烧录软件了。
好的,如果要用PhoneixSuit烧固件的话,固件应该怎么打包呢?
楼主 #26 2019-12-12 10:51:09
已发帖子: 9,407
小白 说:
https://whycan.cn/t_1902.html
https://whycan.cn/t_1739.html
https://whycan.cn/t_1014.html
https://whycan.cn/t_1522.html
#27 2019-12-12 11:22:14
小白
#28 2021-12-23 18:28:43
哥白尼
晕哥,固件烧录只烧录了4s就显示成功了,是啥情况啊  遇到相同问题不知怎么解决  V3S
#29 2021-12-23 18:34:43
已发帖子: 3,391
哥白尼 说:
看串口提示信息。
#30 2023-01-02 17:46:06
vigour1000
已发帖子: 101
S2键在哪里呀
#31 2023-09-13 23:07:36
varzhou
已发帖子: 109
有点旧了的版本
#32 2024-08-05 08:20:56
袜裤够穿吗
晕哥,按下S2按键,S2接在哪里啊?我的不是标准的板子
#33 2025-04-23 23:34:42
kendmaster
请教一下 给eMMC flash烧录的时候一直卡在0%进度,然后过一会就提示烧录失败,请问怎么看错误信息和原因啊,eMMC只接了 cmd clk data0三根线
#35 2025-09-19 22:59:47
ivan923
kendmaster 说:
使用PhoenixCard4.1.1或4.1.2进行录制
