楼主 #1 2019-02-25 15:43:26
vkaoke
荔枝派Nano Pi PWM背光设置问题
设备树配置:
   pio:pinctrl@1c20800 {
			compatible = "allwinner,suniv-pinctrl";
			reg = <0x1c20800 0x400>;
			interrupts = <0x26 0x27 0x28>;
			clocks = <0x3 0x24 0x5 0xb>;
			gpio-controller;
			interrupt-controller;
			#interrupt-cells = <0x3>;
			#gpio-cells = <0x3>;
			phandle = <0xd>;
			pwm1_pins: pwm1 {
					pins = "PE6";
					function = "pwm1";
       pwm:pwm@1C21000 {
		    compatible = "allwinner,sun7i-a20-pwm";
			reg = <0x1C21000 0x400>;
			clocks = <0x5>;
			#pwm-cells = <3>;
			pinctrl-names = "default";
			pinctrl-0 = <&pwm1_pins>;
内核配置:
         --- Pulse-Width Modulation (PWM) Support                                                       │ │
  │ │                        < >   Freescale FlexTimer Module (FTM) PWM support                                             │ │
  │ │                        < >   NXP PCA9685 PWM driver        │ │
  │ │                        <*>   Allwinner PWM support        │ │
  Symbol: PWM [=y]        │
  │ Type  : boolean        │
  │ Prompt: Pulse-Width Modulation (PWM) Support        │
  │   Location:        │
  │ (1) -> Device Drivers        │
  │   Defined at drivers/pwm/Kconfig:1        │
  │   Selected by: S3C24XX_PWM [=n] && PLAT_SAMSUNG [=n] && SAMSUNG_ATAGS [=n] || FB_SSD1307 [=y] && HAS_IOMEM [=y] && FB [=y │
  │ Symbol: BACKLIGHT_PWM [=y]        │
  │ Type  : tristate        │
  │ Prompt: Generic PWM based Backlight Driver        │
  │   Location:        │
  │     -> Device Drivers        │
  │       -> Graphics support        │
  │         -> Backlight & LCD device support (BACKLIGHT_LCD_SUPPORT [=y])                                                    │
  │ (2)       -> Lowlevel Backlight controls (BACKLIGHT_CLASS_DEVICE [=y])                                                    │
  │   Defined at drivers/video/backlight/Kconfig:261        │
  │   Depends on: HAS_IOMEM [=y] && BACKLIGHT_LCD_SUPPORT [=y] && BACKLIGHT_CLASS_DEVICE [=y] && PWM [=y]
 Symbol: COMMON_CLK_PWM [=n]        │
  │ Type  : tristate        │
  │ Prompt: Clock driver for PWMs used as clock outputs        │
  │   Location:        │
  │ (4)   -> Common Clock Framework        │
  │   Defined at drivers/clk/Kconfig:197        │
  │   Depends on: COMMON_CLK [=y] && PWM [=y]
驱动中已经打开了;
echo 1 > /sys/class/pwm/pwmchip0/export
echo 1000000 > /sys/class/pwm/pwmchip0/pwm1/period
echo 200000 > /sys/class/pwm/pwmchip0/pwm1/duty_cycle
echo 1 > /sys/class/pwm/pwmchip0/pwm1/enable
由于默认设备树开启了led,我将下面的代码从设备树中移除了,并且去掉了默认的led驱动
 leds {
             compatible = "gpio-leds";
             blue_led {
                     label = "licheepi:blue:usr";
                     gpios = <&pio 4 4 GPIO_ACTIVE_LOW>; /* PE4 */
             green_led {
                     label = "licheepi:green:usr";
                     gpios = <&pio 4 5 GPIO_ACTIVE_LOW>; /* PE5 */
                     default-state = "on";
             red_led {
                     label = "licheepi:red:usr";
                     gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PE6 */
上面的命令都可以执行成功,但是PE6脚输出一直是高电平,没有PWM波形的输出,这个哪个问题导致的呀
最近编辑记录 vkaoke (2019-02-25 15:44:25)
#2 2019-02-25 17:07:22
jimmy
已发帖子: 316
#3 2019-02-25 17:14:40
已发帖子: 9,415
Re: 荔枝派Nano Pi PWM背光设置问题
https://licheezero.readthedocs.io/zh/latest/%E9%A9%B1%E5%8A%A8/PWM.html
仔细核对了一下 荔枝派 V3s 的文档, 基本操作没有太大问题。
PWM_CTRL_REG  0x00  PWM Control Register
PWM_CH1_PERIOD  0x08  PWM Channel 1 Period Register
用 busybox 里面的 devmem 把这两个寄存器读出来看看:
devmem 0x01C21000
devmem 0x01C21008
楼主 #4 2019-02-26 09:13:52
vkaoke
devmem 0x01C21000
devmem 0x01C21008
# devmem 0x01C21000
0x002F8000
# devmem 0x01C21008
0x5DBF12C0
pwm控制寄存器:
0000 0000 0010 1111 1000 0000 0000 0000
PWM_CH1_PRESCAL=1  PWM_CH1_EN=1   PWM_CH1_CLK_GATING=1(Gating the Special Clock for PWM1 (0: mask, 1: pass).)
设置的参数:
0101 1101 1011 1111 0001 0010 1100 0000
PWM_CH1_ACT_CYS=4800
PWM_CH1_ENTIRE_CYS=23999
我不知道,是不是pwm控制器里面有哪些位是不是还得设置一下。
楼主 #5 2019-02-26 09:14:53
vkaoke
clk-24M {
            #clock-cells = <0x0>;
            compatible = "fixed-clock";
            clock-frequency = <0x16e3600>;
            phandle = <0x5>;
引用的应该是24M的时钟
#6 2019-02-26 09:20:18
jimmy
已发帖子: 316
#7 2019-02-26 12:46:39
jiangming1399
已发帖子: 113
#8 2019-02-26 12:59:49
duckduckgo
已发帖子: 58
试试这个帖子里面的驱动, https://whycan.cn/t_1457.html
是好的,我已经用过了。
楼主 #9 2019-02-27 15:58:53
vkaoke
jiangming1399 说:
设备树中,去掉gpios的配置就正常啦,十分感谢大家
compatible = "qiaodian,qd43003c0-40", "simple-panel";
 		#address-cells = <1>;
 		#size-cells = <0>;
-		enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
楼主 #10 2019-02-27 15:59:53
vkaoke
/dts-v1/;
#include <dt-bindings/interrupt-controller/irq.h>
	#address-cells = <0x1>;
	#size-cells = <0x1>;
	interrupt-parent = <0x1>;
	model = "Lichee Pi Nano";
	compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s", "allwinner,suniv";
	clocks {
		ranges;
		clk-24M {
			phandle = <0x5>;
		clk-32k {
			clock-frequency = <0x8000>;
			phandle = <0xb>;
		clk-100M {
			clock-frequency = <0x5f5e100>;
			clock-output-names = "fake-100M";
	cpus {
		#address-cells = <0x0>;
		#size-cells = <0x0>;
		cpu {
			device_type = "cpu";
	display-engine {
		compatible = "allwinner,suniv-display-engine";
		allwinner,pipelines = <0x2>;
	soc {
		compatible = "simple-bus";
		ranges;
		sram-controller@1c00000 {
			compatible = "allwinner,sun4i-a10-sram-controller";
			reg = <0x1c00000 0x30>;
			ranges;
			sram@10000 {
				compatible = "mmio-sram";
				reg = <0x10000 0x1000>;
				ranges = <0x0 0x10000 0x1000>;
				sram-section@0 {
					reg = <0x0 0x1000>;
					phandle = <0x11>;
		spi@1c05000 {
			compatible = "allwinner,suniv-spi", "allwinner,sun8i-h3-spi";
			reg = <0x1c05000 0x1000>;
			interrupts = <0xa>;
			clocks = <0x3 0x11 0x3 0x11>;
			clock-names = "ahb", "mod";
			resets = <0x3 0x4>;
			pinctrl-0 = <0x4>;
			flash@0 {
				reg = <0x0>;
				spi-max-frequency = <0x2625a00>;
		spi@1c06000 {
			reg = <0x1c06000 0x1000>;
			interrupts = <0xb>;
			clocks = <0x3 0x12 0x3 0x12>;
			resets = <0x3 0x5>;
			status = "disabled";
		lcd-controller@1c0c000 {
			compatible = "allwinner,suniv-tcon";
			reg = <0x1c0c000 0x1000>;
			interrupts = <0x1d>;
			clocks = <0x3 0x15 0x3 0x39 0x5>;
			clock-names = "ahb", "tcon-ch0", "tcon-ch1";
			clock-output-names = "tcon-pixel-clock";
			resets = <0x3 0x8>;
			reset-names = "lcd";
			pinctrl-0 = <0x6>;
			ports {
				port@0 {
					reg = <0x0>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x7>;
						phandle = <0x14>;
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x8>;
						phandle = <0x15>;
		mmc@1c0f000 {
			compatible = "allwinner,suniv-mmc", "allwinner,sun7i-a20-mmc";
			reg = <0x1c0f000 0x1000>;
			clocks = <0x3 0xe 0x3 0x28 0x3 0x2a 0x3 0x29>;
			clock-names = "ahb", "mmc", "output", "sample";
			resets = <0x3 0x1>;
			reset-names = "ahb";
			interrupts = <0x17>;
			pinctrl-0 = <0x9>;
			vmmc-supply = <0xa>;
			bus-width = <0x4>;
			broken-cd;
		mmc@1c10000 {
			reg = <0x1c10000 0x1000>;
			clocks = <0x3 0xf 0x3 0x2b 0x3 0x2d 0x3 0x2c>;
			resets = <0x3 0x2>;
			interrupts = <0x18>;
		clock@1c20000 {
			compatible = "allwinner,suniv-ccu";
			reg = <0x1c20000 0x400>;
			clocks = <0x5 0xb>;
			clock-names = "hosc", "losc";
			#clock-cells = <0x1>;
			#reset-cells = <0x1>;
			phandle = <0x3>;
		interrupt-controller@1c20400 {
			compatible = "allwinner,suniv-ic";
			reg = <0x1c20400 0x400>;
			#interrupt-cells = <0x1>;
			phandle = <0x1>;
			gpio-controller;
			phandle = <0xd>;
			spi0-pins-pc {
				function = "spi0";
				phandle = <0x4>;
			i2c0 {
				pins = "PE11", "PE12";
				function = "i2c0";
				phandle = <0xc>;
			lcd-rgb666-pins {
				pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21";
				function = "lcd";
				phandle = <0x6>;
			uart-pins-pe {
				pins = "PE0", "PE1";
				function = "uart0";
				phandle = <0xf>;
			uart-pins-pina{
				pins = "PA2", "PA3";
				function = "uart1";
				phandle = <0x1a>;
            uart-pins-pinb{
				pins = "PE7", "PE8";
				function = "uart2";
				phandle = <0xe>;
			mmc0-pins {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
				phandle = <0x9>;
			pwm1_pins: pwm1 {
					pins = "PE6";
					function = "pwm1";
		timer@1c20c00 {
			compatible = "allwinner,suniv-timer";
			reg = <0x1c20c00 0x90>;
			interrupts = <0xd>;
			clocks = <0x5>;
		watchdog@1c20ca0 {
			reg = <0x1c20ca0 0x20>;
		pwm:pwm@1C21000 {
			reg = <0x1C21000 0xC>;
			clocks = <0x5>;
			#pwm-cells = <3>;
		i2c@1C27000 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x1c27000 0x400>;
			interrupts = <0x7>;
			clocks = <0x3 0x21>;
			resets = <0x3 0x14>;
			pinctrl-0 = <0xc>;
			lcos@0x48 {
				compatible = "lcos,lcos_hx7097";
				reg = <0x48>;
			axp209:pmic@0x34 {
		    compatible = "x-powers,axp209";
			reg = <0x34>;
			interrupt-parent = <&pio>;
            interrupts = <4 2 IRQ_TYPE_LEVEL_LOW>; /* (PE2) */
			/* interrupts = <0 IRQ_TYPE_LEVEL_LOW>;*/
			#interrupt-cells = <1>;
				battery_power_supply: battery-power-supply{
						compatible = "x-powers,axp209-battery-power-supply";
				ac_power_supply:ac-power-supply{
						compatible = "x-powers,axp202-ac-power-supply";
				axp_gpio:gpio{
						compatible = "x-powers,axp209-gpio";
						gpio-controller;
						#gpio-cells = <2>;
		serial@1c25000 {
			reg = <0x1c25000 0x400>;
			interrupts = <0x1>;
			reg-shift = <0x2>;
			reg-io-width = <0x4>;
			clocks = <0x3 0x25>;
			resets = <0x3 0x17>;
			pinctrl-0 = <0xf>;
		serial@1c25400 {
			reg = <0x1c25400 0x400>;
			interrupts = <0x2>;
			reg-shift = <0x2>;
			clocks = <0x3 0x26>;
			resets = <0x3 0x18>;
			pinctrl-0 = <0x1a>;
		serial@1c25800 {
			reg = <0x1c25800 0x400>;
			interrupts = <0x3>;
			reg-shift = <0x2>;
			clocks = <0x3 0x27>;
			resets = <0x3 0x19>;
			pinctrl-0 = <0xe>;
		usb@1c13000 {
			reg = <0x1c13000 0x400>;
			clocks = <0x3 0x13>;
			resets = <0x3 0x6>;
			interrupts = <0x1a>;
			interrupt-names = "mc";
			phys = <0x10 0x0>;
			phy-names = "usb";
			extcon = <0x10 0x0>;
			allwinner,sram = <0x11 0x1>;
			dr_mode = "otg";
		phy@1c13400 {
			reg = <0x1c13400 0x10>;
			reg-names = "phy_ctrl";
			clocks = <0x3 0x30>;
			clock-names = "usb0_phy";
			resets = <0x3 0x0>;
			reset-names = "usb0_reset";
			#phy-cells = <0x1>;
			usb0_id_det-gpio = <0xd 0x4 0x2 0x0>;
			phandle = <0x10>;
		display-frontend@1e00000 {
			compatible = "allwinner,suniv-display-frontend";
			reg = <0x1e00000 0x20000>;
			interrupts = <0x1e>;
			clocks = <0x3 0x1b 0x3 0x38 0x3 0x35>;
			clock-names = "ahb", "mod", "ram";
			resets = <0x3 0xe>;
			phandle = <0x2>;
			ports {
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x12>;
						phandle = <0x13>;
		display-backend@1e60000 {
			compatible = "allwinner,suniv-display-backend";
			reg = <0x1e60000 0x10000>;
			reg-names = "be";
			interrupts = <0x1f>;
			clocks = <0x3 0x1a 0x3 0x37 0x3 0x36>;
			resets = <0x3 0xd>;
			reset-names = "be";
			assigned-clocks = <0x3 0x37>;
			assigned-clock-rates = <0x11e1a300>;
			ports {
				port@0 {
					reg = <0x0>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x13>;
						phandle = <0x12>;
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x14>;
						phandle = <0x7>;
	aliases {
		serial0 = "/soc/serial@1c25000";
		spi0 = "/soc/spi@1c05000";
		i2c0 = "/soc/i2c@1C27000";
	chosen {
	panel {
		compatible = "lg,lb070wv8", "simple-panel";
		port@0 {
			reg = <0x0>;
			endpoint@0 {
				reg = <0x0>;
				remote-endpoint = <0x15>;
				phandle = <0x8>;
	vcc3v3 {
		regulator-name = "vcc3v3";
		regulator-min-microvolt = <0x325aa0>;
		regulator-max-microvolt = <0x325aa0>;
		phandle = <0xa>;
	backlight
		compatible = "pwm-backlight";
		pwms = <&pwm 1 500000 0>;
		brightness-levels = <0 4 8 16 32 64 128 255>;
		default-brightness-level = <6>;
#11 2019-02-27 16:20:54
已发帖子: 9,415
vkaoke 说:
jiangming1399 说:
        #size-cells = <0>;
感谢分享经验,应该是这里把IO的复用状态切换到GPIO了,而不是PWM。
#12 2019-07-22 07:18:53
路漫漫
已发帖子: 65
先 mark, 晚点我也要调试 c100 linux 4.15 的背光调节.
#13 2019-07-27 17:42:04
路漫漫
已发帖子: 65
vkaoke 说:
jiangming1399 说:
 		#size-cells = <0>;
进了同一个坑, 开始怎么调都出不来,总是保持高电平,后来输出 PE6 复用寄存器状态才恍然大悟。
#15 2019-12-02 16:50:36
aaayao
已发帖子: 85
楼主,你好:
               正好要做leds驱动,请教一个问题,没有看到有leds目录,是少了那个配置文件呢?
板子log:
# ls /sys/bus/platform/devices
10000.sram               1c20ca0.watchdog         regulatory.0
1c00000.sram-controller  1c25000.serial           serial8250
1c05000.spi              1e60000.display-backend  snd-soc-dummy
1c0c000.lcd-controller   alarmtimer               snd_aloop.0
1c0f000.mmc              display-engine           soc
1c13000.usb              musb-hdrc.1.auto         usb_phy_generic.0.auto
1c13400.phy              my-leds2                 vcc3v3
1c20800.pinctrl          panel
1c20c00.timer            reg-dummy
# ls /sys/bus/platform/devices/my-leds2
driver_override  of_node          subsystem
modalias         power            uevent
设备树:
    my-leds2 {
        compatible = "gpio-leds";        /* 才能被识别为Led */
        pinctrl-0 = <&leds_pins>;
             blue_led {
             green_led {
             red_led {
		pio: pinctrl@1c20800 {
			reg = <0x01c20800 0x400>;
			gpio-controller;
			#interrupt-cells = <3>;
			#gpio-cells = <3>;
			leds_pins: leds-pins {
				pins = "PE4","PE5","PE6";
				function = "gpio_out";
#16 2019-12-13 11:05:59
异乡是故乡
已发帖子: 74
vkaoke 说:
 		#size-cells = <0>;
原来如此, 调了大半天死活不起作用,正在准备放弃治疗了。
#17 2019-12-13 11:06:37
异乡是故乡
已发帖子: 74
