# ffmpeg -s 640x480 -pix_fmt yuv420p -i rawvideoA.yuv -vcodec mjpeg outputA.mov
ffmpeg version 3.4.5 Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 7.4.0 (Buildroot 2019.02.2)
configuration: --enable-cross-compile --cross-prefix=/opt/f1c100s/buildroot-2019.02.2/output/host/bin/arm-buildroot-linux-gnueabi- --sysroot=/opt/f1c100s/buildroot-2019.02.2/output/host/arm-buildroot-linux-gnueabi/sysroot --host-cc=/usr/bin/gcc --arch=arm --target-os=linux --disable-stripping --pkg-config=/opt/f1c100s/buildroot-2019.02.2/output/host/bin/pkg-config --disable-static --enable-shared --prefix=/usr --enable-avfilter --disable-version3 --enable-logging --enable-optimizations --disable-extra-warnings --enable-avdevice --enable-avcodec --enable-avformat --enable-network --disable-gray --enable-swscale-alpha --disable-small --enable-dct --enable-fft --enable-mdct --enable-rdft --disable-crystalhd --disable-dxva2 --enable-runtime-cpudetect --disable-hardcoded-tables --disable-mipsdsp --disable-mipsdspr2 --disable-msa --enable-hwaccels --disable-cuda --disable-cuvid --disable-nvenc --disable-avisynth --disable-frei0r --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libdc1394 --disable-libgsm --disable-libilbc --disable-libvo-amrwbenc --disable-symver --disable-doc --enable-gpl --enable-nonfree --enable-ffmpeg --enable-ffplay --enable-ffserver --enable-avresample --enable-ffprobe --enable-postproc --enable-swscale --enable-indevs --disable-alsa --enable-outdevs --enable-pthreads --enable-zlib --disable-bzlib --disable-libfdk-aac --disable-libcdio --disable-gnutls --enable-openssl --disable-libdrm --disable-libopenh264 --disable-vaapi --disable-vdpau --disable-mmal --disable-omx --disable-omx-rpi --disable-libopencv --disable-libopus --disable-libvpx --disable-libass --disable-libbluray --disable-librtmp --disable-libmp3lame --disable-libmodplug --disable-libspeex --disable-libtheora --disable-libwavpack --disable-iconv --enable-libfreetype --disable-fontconfig --disable-libopenjpeg --disable-libx264 --disable-libx265 --disable-x86asm --disable-mmx --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-avx --disable-avx2 --disable-armv6 --disable-armv6t2 --disable-vfp --disable-neon --disable-altivec --extra-libs=-latomic --enable-pic --cpu=arm926ej-s
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[rawvideo @ 0x6e370] Estimating duration from bitrate, this may be inaccurate
Input #0, rawvideo, from 'rawvideoA.yuv':
Duration: 00:00:02.44, start: 0.000000, bitrate: 92160 kb/s
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 640x480, 92160 kb/s, 25 tbr, 25 tbn, 25 tbc
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> mjpeg (native))
Press [q] to stop, [?] for help
[swscaler @ 0x7fcf0] deprecated pixel format used, make sure you did set range correctly
Output #0, mov, to 'outputA.mov':
Metadata:
encoder : Lavf57.83.100
Stream #0:0: Video: mjpeg (jpeg / 0x6765706A), yuvj420p(pc), 640x480, q=2-31, 200 kb/s, 25 fps, 12800 tbn, 25 tbc
Metadata:
encoder : Lavc57.107.100 mjpeg
Side data:
cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
frame= 61 fps=6.2 q=24.8 Lsize= 504kB time=00:00:02.40 bitrate=1718.8kbits/s speed=0.243x
video:503kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.188468%
ffplay@ubuntu:/mnt/hgfs/D/newfiles$ ffmpeg -s 640x480 -pix_fmt yuv420p -i /tmp/rawvideoA.yuv -vcodec mjpeg /tmp/outputA.mov
ffmpeg version 0.8.6-6:0.8.6-1ubuntu2, Copyright (c) 2000-2013 the Libav developers
built on Mar 30 2013 22:20:06 with gcc 4.7.2
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
[rawvideo @ 0x2244360] Estimating duration from bitrate, this may be inaccurate
Input #0, rawvideo, from '/tmp/rawvideoA.yuv':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 640x480, 25 tbr, 25 tbn, 25 tbc
File '/tmp/outputA.mov' already exists. Overwrite ? [y/N] y
Incompatible pixel format 'yuv420p' for codec 'mjpeg', auto-selecting format 'yuvj420p'
[buffer @ 0x224cec0] w:640 h:480 pixfmt:yuv420p
[avsink @ 0x2243d00] auto-inserting filter 'auto-inserted scaler 0' between the filter 'src' and the filter 'out'
[scale @ 0x2245600] w:640 h:480 fmt:yuv420p -> w:640 h:480 fmt:yuvj420p flags:0x4
Output #0, mov, to '/tmp/outputA.mov':
Metadata:
encoder : Lavf53.21.1
Stream #0.0: Video: mjpeg, yuvj420p, 640x480, q=2-31, 200 kb/s, 25 tbn, 25 tbc
Stream mapping:
Stream #0.0 -> #0.0
Press ctrl-c to stop encoding
frame= 275 fps=210 q=24.8 Lsize= 2538kB time=11.00 bitrate=1890.5kbits/s
video:2536kB audio:0kB global headers:0kB muxing overhead 0.110687%
用 辣鸡电脑Ubuntu 试了一下, 同样的品质, 电脑可以达到 200fps 以上。
# ffmpeg -s 640x480 -pix_fmt yuv420p -i rawvideoA.yuv -vcodec mjpeg -qscale 3 outputA.mov
[rawvideo @ 0x6e380] Estimating duration from bitrate, this may be inaccurate
Please use -q:a or -q:v, -qscale is ambiguous
File 'outputA.mov' already exists. Overwrite ? [y/N] y
Stream mapping:
[swscaler @ 0x809d0] deprecated pixel format used, make sure you did set range correctly
Metadata:
Metadata:
Side data:
frame= 61 fps=5.9 q=3.0 Lsize= 1257kB time=00:00:02.40 bitrate=4289.1kbits/s speed=0.232x
video:1256kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.076685%
品质各种调整 3 (2 - 31) 帧率也没什么变化。
# ffmpeg -s 320x240 -pix_fmt yuv420p -i rawvideoA.yuv -vcodec mjpeg -qscale 31 -vb 100k outputA.mov
[rawvideo @ 0x6e400] Estimating duration from bitrate, this may be inaccurate
Duration: 00:00:09.76, start: 0.000000, bitrate: 23040 kb/s
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 320x240, 23040 kb/s, 25 tbr, 25 tbn, 25 tbc
Stream mapping:
[swscaler @ 0x9cf80] deprecated pixel format used, make sure you did set range correctly
Metadata:
Stream #0:0: Video: mjpeg (jpeg / 0x6765706A), yuvj420p(pc), 320x240, q=2-31, 100 kb/s, 25 fps, 12800 tbn, 25 tbc
Metadata:
Side data:
cpb: bitrate max/min/avg: 0/0/100000 buffer size: 0 vbv_delay: -1
frame= 244 fps= 27 q=31.0 Lsize= 673kB time=00:00:09.72 bitrate= 567.2kbits/s speed=1.09x
video:671kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.247602%
320x240 分辨率可以接近 30fps
ffmpeg 用的好溜,上面的
是在录一个视频么?
不是的, 就是把一个 YUV420P 格式的纯像素文件 rawvideoA.yuv 编码成 jpeg格式的文件,
用于测试 f1c100s 的编码能力。
那不就是软件编码么?
那不就是软件编码么?
对, 就是测试软编码, 哎,太耗CPU了。
1、效果就是看转换的帧数?
2、为什么不用硬件的编码?
1、效果就是看转换的帧数?
2、为什么不用硬件的编码?
1. 一楼红色圈圈那一行可以看帧率,总帧数等
2. 因为还不会,只能先软件搞搞
了然了然。 非常感谢。
https://whycan.cn 还真挺好,传道受业解惑,真的学到不不少。
影响编码效率的参数有很多,主频可能是其中一个不很重要的因素,考虑到编码图像基本上都在进行重复性很高的工作,因此编码器的处理能力和体系结构对部分函数运行效率的关系很大,这也就是硬件编码器可以在低于CPU的频率下实现更高编码效率的主要原因。
类似于这样的编码应用,瓶颈往往在于一些经常被调用的、计算量比较大的函数,比如说预测时计算cost、变换和量化之类,这些函数通常有大量的低精度乘法、乘加运算等操作,在这些情况下一般要使用SIMD来优化执行的效率。我记得ARMv5好像没有SIMD指令?楼主可以试着比较一下ffmpeg中的ff_simple_idct_arm(ARM9使用)和ff_simple_idct_neon(Cortex-A9等使用),就可以发现代码之间的差异了。我猜把ffmpeg搬到同主频的Cortex-A9上应该会快不少。
另外可能需要考虑的因素在于存储设备的读写能力,毕竟一帧VGA大小的yuv420p已经有640*480*1.5=450KB了,而SD卡在嵌入式设备的性能可能有限(特别是在电压是3.3V时),所以也不能指望编码速度能达到什么程度。如果要测试软件的编码能力,建议还是采用摄像头等输入源,这样就不会受到存储设备的瓶颈限制。
最近编辑记录 metro (2019-08-31 17:32:35)
感谢楼上朋友耐心指教,请问默认情况下 ff_simple_idct_arm 这个函数是汇编优化的吗?我还有优化的空间吗?目前就是因为摄像头驱动没有搞定,我猜想着先用文件测试,确定编码器速率没有问题才去弄摄像头驱动程序。
看来是不是应该用 f1c200s, 用内存做文件存储,先排除问题。
不好意思哈,只是对视频编码有所了解,对ffmpeg不是很清楚,上面的例子也是临时找的,不过应该比较有代表性。
不过像ffmpeg这样久经考验的项目,汇编部分的优化基本到极致了,指望在编译器或者程序库之外的地方优化执行速度不大现实,最好还是考虑在其它地方改善性能吧。
多谢楼上朋友指教!
arm9没有neon,软件编码肯定巨慢啊,再怎么汇编优化也一样。
期待有大神把硬件编解码搞定...
感觉瓶颈在IO上面吧。
有弄硬编么?
有弄硬编么?
公司正在申请 tina 的 sdk, 要过些时间才会开始.
luo 说:有弄硬编么?
linux的硬编 可以搞到相关资料? 分享一下嘛
关注,学习
这些芯片真累,资料也不公开
楼主cache没开吧,没开就是这样的
Linux默认开了cache,软解吗速度就是酱紫的
请问如何提升频率?
请问一下如何提升F1C100S的运行主频?原厂那边都说不行的。
唯一的解决办法就是搞硬编
现在全志的硬解码资料是保密的,一般个人是没办法拿到的,网上见多的都软解码的,性能差很多。
我现在是用软件解码,显示logo,性能的确勉强。。。
