楼主 #1 2019-10-19 09:00:21
Linux主线已经支持 VPU H.264 硬解码多时了,有没有哪位测试过?
驱动代码: https://github.com/torvalds/linux/tree/master/drivers/staging/media/sunxi/cedrus
make menuconfig 必须选择以下内核配置参数:
CONFIG_MEDIA_SUPPORT
CONFIG_MEDIA_CONTROLLER_REQUEST_API
CONFIG_V4L_MEM2MEM_DRIVERS
CONFIG_VIDEO_SUNXI_CEDRUS
Device Drivers  ---> Generic Driver Options  --->
        (256) Size in Mega Bytes
Device Drivers  ---> Multimedia support
        [*]   Cameras/video grabbers support
        [*]   Media Controller API
        [*]     Enable Media controller Request API (EXPERIMENTAL)
        [*]   V4L2 sub-device userspace API
        [*]   Enable advanced debug functionality on V4L2 drivers
        [*]   V4L platform devices  --->
                <M>   Allwinner V3s Camera Sensor Interface driver
        [*]   Memory-to-memory multimedia devices  --->
                <M>   Deinterlace support
                <M>   SuperH VEU mem2mem video processing driver
         [*]   Media test drivers  --->
                <M>   Virtual Media Controller Driver (VIMC)
                <M>   Virtual Video Test Driver
                 [ ]     Enable CEC emulation support (NEW)
                (64)    Maximum number of devices (NEW)
                <M>   Virtual Memory-to-Memory Driver
                <M>   Virtual Codec Driver
Device Drivers  ---> Staging drivers   ---> Media staging drivers  --->
        [*]   Allwinner sunXi family Video Devices
        <M>     Allwinner Cedrus VPU driver
解码测试:
ffmpeg -hwaccel drm -hwaccel_device /dev/dri/card0 -i h264.mp4 -pix_fmt bgra -f fbdev /dev/fb0
参考链接1: 已删除
参考链接2: https://lkml.org/lkml/2019/8/22/1425
#2 2019-10-19 10:22:49
sy373466062
已发帖子: 135
Re: Linux主线已经支持 VPU H.264 硬解码多时了,有没有哪位测试过?
这个意思是全志那一票的芯片在Linux下的H264硬解应该是可以了?
楼主 #3 2019-10-19 10:50:40
应该是的 https://github.com/torvalds/linux/blob/master/drivers/staging/media/sunxi/cedrus/cedrus.c
目前直接支持 A10/A13/A20/A33/H3/A64/H5/H6
但是 V3s/S3 使用需要可能还需要修改一点点
static const struct of_device_id cedrus_dt_match[] = {
		.compatible = "allwinner,sun4i-a10-video-engine",
		.data = &sun4i_a10_cedrus_variant,
		.compatible = "allwinner,sun5i-a13-video-engine",
		.data = &sun5i_a13_cedrus_variant,
		.compatible = "allwinner,sun7i-a20-video-engine",
		.data = &sun7i_a20_cedrus_variant,
		.compatible = "allwinner,sun8i-a33-video-engine",
		.data = &sun8i_a33_cedrus_variant,
		.compatible = "allwinner,sun8i-h3-video-engine",
		.data = &sun8i_h3_cedrus_variant,
		.compatible = "allwinner,sun50i-a64-video-engine",
		.data = &sun50i_a64_cedrus_variant,
		.compatible = "allwinner,sun50i-h5-video-engine",
		.data = &sun50i_h5_cedrus_variant,
		.compatible = "allwinner,sun50i-h6-video-engine",
		.data = &sun50i_h6_cedrus_variant,
	{ /* sentinel */ }
#4 2019-10-20 10:44:16
牛逼啊,看来F1C200S也可以了
#5 2019-10-20 17:58:00
晕哥你觉得,F1C200S这个片子,
做核心板销量好,
还是MP4手持机开发板销量好。
楼主 #6 2019-10-20 19:18:27
做成锂电,TF插座/USB插座,旋转编码器,带按键,电容触摸屏,有外壳(或者亚克力)的准成品应该比较好卖。
#7 2019-10-20 19:37:07
checkout
已发帖子: 173
牛逼,赶紧试试
#8 2019-10-20 19:47:04
MP4是锂电的,为了通用用诺基亚电池。
TF卡槽有,和sd nand共存,sd nand 存app。
大口USB座有1个,
旋转编码器是啥东西??求教。
按键这东西,就是lradc了,做个音量+-,还有电源啥的。
是电容屏,3寸480*800,视网膜电容屏。
有外壳,3D打印+亮面喷漆。
相当于成品。
楼主 #9 2019-10-20 19:47:50
楼主 #10 2019-10-20 20:02:07
旋转编码器挺多地方使用,车上的收音机, HIFI播放器用得比较多,可以顺时针/逆时针旋转,有些可以按下。
https://detail.tmall.com/item.htm?id=577549877220
#11 2019-10-20 20:41:22
旋转编码器需要3个io。编码器处理还比较复杂。
楼主 #12 2019-10-20 20:44:38
软件没问题, Linux自带了驱动: https://whycan.cn/t_2393.html#p18277
只是看有没有多余的能中断的GPIO
#13 2019-10-21 09:45:15
shaoxi2010
已发帖子: 400
照着H3改过v3s的,但是sram的初始化不对,工作不起来
楼主 #14 2019-10-21 10:01:13
SRAM? 为什么要改SRAM?SRAM不是 boot0才用的吗?
#15 2019-10-21 10:16:56
nothing
测试过官方的库在V3S的BSP内核,初始化成功,但是编码出错,由于官方只提供库,测试的现象是一读取编码结果就死机,追踪到的结果是编码获取地址没有映射成功,但是又没有源码排查,只能乖乖用camdroid
#16 2019-10-21 11:49:38
shaoxi2010
已发帖子: 400
主线的代码在初始化的时候要将SRAM特殊初始化给VE使用,H3的SRAM布局和V3S的不一样,然后就卡死在上面了。没记错的话USB和eMAC都在用SRAM
#17 2019-10-21 11:54:36
shaoxi2010
已发帖子: 400
找到了,在这里有提到的。有一段C1的SRAM用于VE,但是V3S在手册没得提到这东西,看看那位大佬可以搞定这个不。
https://linux-sunxi.org/SRAM_Controller_Register_Guide
楼主 #18 2019-10-21 12:13:01
还有这种操作啊
#19 2019-10-21 13:09:28
dgtg
已发帖子: 276
好期待啊
#20 2019-10-21 14:04:19
nothing
你说的是这个mmap吧,手册59页里面有提到,就给了映射地址,具体详细介绍没有,我之间弄过,初始化成功,编码会死掉,核心库全志没有开放代码,追踪不到死掉的原因
#21 2019-10-21 16:28:37
shaoxi2010
已发帖子: 400
/files/members/1974/_20191021140119.png
还不是那个地方吧,因为全志复用ip核的可能性极大,看社区说的是在H3上改过来的,我按着H3修改后驱动报错的位置是在,SRAM contorl里面,然后加了几个打印发现SRAM功能配置失败了,我也就没管了。
#22 2020-04-05 02:40:22
aodzip
已发帖子: 130
在S3上跑起来Cedrus了,只可惜好像出BUG了
某些帧还是能看出来有那么几块是处理正确的
#23 2020-04-05 08:20:54
楼上威武!
#24 2020-04-27 15:25:15
aodzip
已发帖子: 130
我就挖一铲子,这样通过搜索引擎过来的人也知道传统的CedarX框架也支持主线了
https://whycan.cn/t_4219.html
#25 2020-04-29 09:52:23
qdk0901
我们去年7月份就用上这个了,用在a10/a20/h3的片子上,出了大概600k的货,虽然有一些问题(比如B帧P帧的解码马赛克,绿屏等等),但是解决后还是不错的
#26 2020-04-29 09:56:39
有梦的地方
已发帖子: 284
牛,方便分享一些使用方法吗?
#27 2020-04-29 10:21:47
qdk0901
有梦的地方 wrote:
牛,方便分享一些使用方法吗?
用户空间用sunxi-cedrus开源项目配套的libva-v4l2-request+ffmpeg,ffmpeg的avcodec_decode_video2里使用vaapi context做硬件加速,解码完之后,用drm接口提交buffer去显示
#28 2020-05-22 15:12:02
twig
好消息~~~
#29 2020-05-22 15:17:50
ljw22676739
好消息!硬件很重要!全志的系列芯片,驱动是硬伤啊!
#30 2020-05-22 16:57:54
秦皇岛岛主
已发帖子: 59
晕哥要不要出些成品的板子,已经比较有规模了,应该很多人为此做贡献吧
#31 2020-06-18 22:07:54
tianjjff
已发帖子: 129
这个设备树该如何写呢?
#32 2021-12-24 10:56:56
xucwei@hotmail.com
我参考:https://patchwork.kernel.org/project/linux-arm-kernel/cover/20200912143052.30952-1-m.cerveny@computer.org/
在v3s上开启cedrus,然而kernel运行时,也是报了sram的错误:
[ 1.347934] cedrus 1c0e000.video-codec: Failed to claim SRAM
[ 1.353612] cedrus 1c0e000.video-codec: Failed to probe hardware
有没有大佬能指点一下。
#33 2022-11-28 14:22:33
edisondeng
已发帖子: 19
@晕哥
我的ffmpeg提示 No device available for decoder: device type drm needed for codec h264.
请问要怎么处理呢?
谢谢!
#34 2022-12-04 12:41:47
edisondeng
已发帖子: 19
qdk0901 wrote:
有梦的地方 wrote:
牛,方便分享一些使用方法吗?
请问是在v3s吗?主线linux版本是多少?libva-v4l2-request好像不支持 linux 6.0.
