楼主 #1 2019-10-25 16:01:56
wupaul2001
已发帖子: 259
刚刚弄好Linux 4.19的USB驱动,但发现一个问题,只要我打开fb, Otg就会失效,有大神能解决这个问题吗?
刚刚弄好Linux 4.19的USB驱动,但发现一个问题,只要我打开fb, Otg就会失效,有大神能解决这个问题吗?必须dr_mode="host",才能使用host模式
#2 2019-10-25 16:06:38
所在地: 微信 whycan_cn
已发帖子: 9,245
Re: 刚刚弄好Linux 4.19的USB驱动,但发现一个问题,只要我打开fb, Otg就会失效,有大神能解决这个问题吗?
没有遇到过,我的4.14正常
楼主 #3 2019-10-25 16:12:30
wupaul2001
已发帖子: 259
@晕哥,能发个zImage和dtb测试吓吗?
#4 2019-10-25 16:16:46
所在地: 微信 whycan_cn
已发帖子: 9,245
楼主 #5 2019-10-25 16:32:26
wupaul2001
已发帖子: 259
@晕哥 有TF的版本吗?
#6 2019-10-25 16:38:33
shaoxi2010
已发帖子: 367
没遇到,4.20也是正常的
楼主 #7 2019-10-25 16:47:45
wupaul2001
已发帖子: 259
@shaoxi2010 你的是TF镜像吗?能共享测试一吓吗?
#8 2019-10-25 16:56:47
所在地: 微信 whycan_cn
已发帖子: 9,245
4.19 LCD 是怎么搞定的?
楼主 #9 2019-10-25 17:20:49
wupaul2001
已发帖子: 259
修改suniv-tcon.c
楼主 #10 2019-10-25 17:21:20
wupaul2001
已发帖子: 259
打了patch后,LCD还不行的
#11 2019-10-25 17:28:02
所在地: 微信 whycan_cn
已发帖子: 9,245
wupaul2001 说:
修改suniv-tcon.c
怎么改的?
楼主 #12 2019-10-25 17:38:01
wupaul2001
已发帖子: 259
static const struct sun4i_tcon_quirks suniv_quirks = {
    .has_channel_0        = true,
const struct of_device_id sun4i_tcon_of_table[] = {
    { .compatible = "allwinner,suniv-tcon", .data = &suniv_quirks },
    { .compatible = "allwinner,sun4i-a10-tcon", .data = &sun4i_a10_quirks },
    { .compatible = "allwinner,sun5i-a13-tcon", .data = &sun5i_a13_quirks },
    { .compatible = "allwinner,sun6i-a31-tcon", .data = &sun6i_a31_quirks },
    { .compatible = "allwinner,sun6i-a31s-tcon", .data = &sun6i_a31s_quirks },
    { .compatible = "allwinner,sun7i-a20-tcon", .data = &sun7i_a20_quirks },
    { .compatible = "allwinner,sun8i-a33-tcon", .data = &sun8i_a33_quirks },
    { .compatible = "allwinner,sun8i-a83t-tcon-lcd", .data = &sun8i_a83t_lcd_quirks },
    { .compatible = "allwinner,sun8i-a83t-tcon-tv", .data = &sun8i_a83t_tv_quirks },
    { .compatible = "allwinner,sun8i-v3s-tcon", .data = &sun8i_v3s_quirks },
    { .compatible = "allwinner,sun9i-a80-tcon-lcd", .data = &sun9i_a80_tcon_lcd_quirks },
    { .compatible = "allwinner,sun9i-a80-tcon-tv", .data = &sun9i_a80_tcon_tv_quirks },
#13 2019-10-25 17:39:50
所在地: 微信 whycan_cn
已发帖子: 9,245
感谢分享,我明白了,就是参考另外一个帖子的。
楼主 #14 2019-10-25 17:55:26
wupaul2001
已发帖子: 259
另外一个贴字小改了{ .compatible = "allwinner,suniv-tcon", .data = &suniv_quirks }, 这个是我自己加上去的
楼主 #15 2019-10-25 17:56:18
wupaul2001
已发帖子: 259
但OTG不知道是什么问题
#16 2019-10-25 18:24:16
shaoxi2010
已发帖子: 367
wupaul2001 说:
没有,我没nano了,自己画的
